root/radiance/ray/src/px/ra_xyze.c
Revision: 2.11
Committed: Thu Aug 18 00:52:48 2016 UTC (7 years, 10 months ago) by greg
Changes since 2.10: +3 -2 lines
2 static const char RCSid[] = "$Id: ra_xyze.c,v 2.10 2006/08/22 21:38:22 greg Exp $";
5 * Program to convert between RADIANCE RGBE and XYZE formats
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include <stdio.h>
10 #include <string.h>
11 #include <math.h>
12 #include <time.h>
13
14 #include "platform.h"
15 #include "color.h"
16 #include "resolu.h"
17 #include "rtio.h"
18
19 int rgbinp = -1; /* input is RGBE? */
20 int rgbout = 0; /* output should be RGBE? */
21 RGBPRIMS inprims = STDPRIMS; /* input primaries */
22 RGBPRIMS outprims = STDPRIMS; /* output primaries */
23 double expcomp = 1.0; /* exposure compensation */
24 int doflat = -1; /* produce flat file? */
25 double origexp = -1.0; /* original exposure */
26 char *progname;
27
28 static gethfunc headline;
29 static void quiterr(char *err);
30 static void convert(void);
31
32
33
34 static int
35 headline( /* process header line */
36 char *s,
37 void *p
38 )
39 {
40 char fmt[32];
41
42 if (formatval(fmt, s)) { /* check if format string */
43 if (!strcmp(fmt,COLRFMT))
44 rgbinp = 1;
45 else if (!strcmp(fmt,CIEFMT))
46 rgbinp = 0;
47 else
48 rgbinp = -2;
49 return(0); /* don't echo */
50 }
51 if (origexp > 0.0 && isexpos(s)) {
52 origexp *= exposval(s);
53 return(0); /* don't echo */
54 }
55 if (isprims(s)) { /* get input primaries */
56 primsval(inprims, s);
57 return(0); /* don't echo */
58 }
59 /* should I grok colcorr also? */
60 return(fputs(s, stdout));
61 }
62
63
64 int
65 main(int argc, char *argv[])
66 {
67 int i;
68 SET_DEFAULT_BINARY();
69 SET_FILE_BINARY(stdin);
70 SET_FILE_BINARY(stdout);
71 progname = argv[0];
72
73 for (i = 1; i < argc; i++)
74 if (argv[i][0] == '-')
75 switch (argv[i][1]) {
76 case 'c': /* rle-compressed output */
77 doflat = 0;
78 break;
79 case 'u': /* flat output */
80 doflat = 1;
81 break;
82 case 'r': /* RGBE output */
83 rgbout = 1;
84 break;
85 case 'p': /* RGB primaries */
86 if (i+8 >= argc)
87 goto userr;
88 outprims[RED][CIEX] = atof(argv[++i]);
89 outprims[RED][CIEY] = atof(argv[++i]);
90 outprims[GRN][CIEX] = atof(argv[++i]);
91 outprims[GRN][CIEY] = atof(argv[++i]);
92 outprims[BLU][CIEX] = atof(argv[++i]);
93 outprims[BLU][CIEY] = atof(argv[++i]);
94 outprims[WHT][CIEX] = atof(argv[++i]);
95 outprims[WHT][CIEY] = atof(argv[++i]);
96 break;
97 case 'o': /* original exposure */
98 origexp = 1.0;
99 break;
100 case 'e': /* exposure compensation */
101 expcomp = atof(argv[++i]);
102 if (argv[i][0] == '+' || argv[i][0] == '-')
103 expcomp = pow(2., expcomp);
104 break;
105 default:
106 goto userr;
107 }
108 else
109 break;
110
111 if (doflat < 0)
112 doflat = !rgbout;
113 if (i < argc-2)
114 goto userr;
115 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
116 fprintf(stderr, "%s: can't open input \"%s\"\n",
117 progname, argv[i]);
118 exit(1);
119 }
120 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
121 fprintf(stderr, "%s: can't open output \"%s\"\n",
122 progname, argv[i+1]);
123 exit(1);
124 }
125 getheader(stdin, headline, NULL);
126 if (rgbinp == -2)
127 quiterr("unrecognized input file format");
128 if (rgbinp == -1)
129 rgbinp = !rgbout;
130 printargs(argc, argv, stdout); /* add to header */
131 convert(); /* convert picture */
132 exit(0);
133 userr:
134 fprintf(stderr, "Usage: %s [-r][-o][-e exp][-c|-u]", progname);
135 fprintf(stderr, "[-p rx ry gx gy bx by wx wy] [input [output]]\n");
136 exit(1);
137 }
138
139
140 static void
141 quiterr( /* print message and exit */
142 char *err
143 )
144 {
145 if (err != NULL) {
146 fprintf(stderr, "%s: %s\n", progname, err);
147 exit(1);
148 }
149 exit(0);
150 }
151
152
153 static void
154 convert(void) /* convert to XYZE or RGBE picture */
155 {
156 int order;
157 int xmax, ymax;
158 COLORMAT xfm;
159 register COLOR *scanin;
160 register COLR *scanout;
161 double exp2do = expcomp;
162 double exp2report = expcomp;
163 int y;
164 register int x;
165 /* recover original? */
166 if (origexp > 0.0)
167 exp2do /= origexp;
168 /* compute transform */
169 if (rgbout) {
170 if (rgbinp) { /* RGBE -> RGBE */
171 comprgb2rgbWBmat(xfm, inprims, outprims);
172 } else { /* XYZE -> RGBE */
173 compxyz2rgbWBmat(xfm, outprims);
174 if (origexp > 0.0)
175 exp2do /= WHTEFFICACY;
176 else
177 exp2report *= WHTEFFICACY;
178 }
179 } else {
180 if (rgbinp) { /* RGBE -> XYZE */
181 comprgb2xyzWBmat(xfm, inprims);
182 if (origexp > 0.0)
183 exp2do *= WHTEFFICACY;
184 else
185 exp2report /= WHTEFFICACY;
186 } else { /* XYZE -> XYZE */
187 for (y = 0; y < 3; y++)
188 for (x = 0; x < 3; x++)
189 xfm[y][x] = x==y ? 1. : 0.;
190 }
191 }
192 for (y = 0; y < 3; y++)
193 for (x = 0; x < 3; x++)
194 xfm[y][x] *= exp2do;
195 /* get input resolution */
196 if ((order = fgetresolu(&xmax, &ymax, stdin)) < 0)
197 quiterr("bad picture format");
198 /* complete output header */
199 if ((exp2report < 0.99) | (exp2report > 1.01))
200 fputexpos(exp2report, stdout);
201 if (rgbout) {
202 fputprims(outprims, stdout);
203 fputformat(COLRFMT, stdout);
204 } else
205 fputformat(CIEFMT, stdout);
206 putc('\n', stdout);
207 fputresolu(order, xmax, ymax, stdout);
208 /* allocate scanline */
209 scanin = (COLOR *)malloc(xmax*sizeof(COLOR));
210 if (scanin == NULL)
211 quiterr("out of memory in convert");
212 scanout = doflat ? (COLR *)malloc(xmax*sizeof(COLR)) : NULL;
213 /* convert image */
214 for (y = 0; y < ymax; y++) {
215 if (freadscan(scanin, xmax, stdin) < 0)
216 quiterr("error reading input picture");
217 for (x = 0; x < xmax; x++) {
218 colortrans(scanin[x], xfm, scanin[x]);
219 if (rgbout)
220 clipgamut(scanin[x], bright(scanin[x]),
221 CGAMUT_LOWER, cblack, cwhite);
222 }
223 if (scanout != NULL) {
224 for (x = 0; x < xmax; x++)
225 setcolr(scanout[x], colval(scanin[x],RED),
226 colval(scanin[x],GRN),
227 colval(scanin[x],BLU));
228 putbinary((char *)scanout, sizeof(COLR), xmax, stdout);
229 } else
230 fwritescan(scanin, xmax, stdout);
231 if (ferror(stdout))
232 quiterr("error writing output picture");
233 }
234 /* free scanline */
235 free((void *)scanin);
236 if (scanout != NULL)
237 free((void *)scanout);
238 }
