| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ra_xyze.c,v 2.9 2004/03/28 20:33:14 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Program to convert between RADIANCE RGBE and XYZE formats
| 6 |
* Added white-balance adjustment 10/01 (GW).
| 7 |
| 8 |
| 9 |
#include <stdio.h>
| 10 |
#include <string.h>
| 11 |
#include <math.h>
| 12 |
#include <time.h>
| 13 |
| 14 |
#include "platform.h"
| 15 |
#include "color.h"
| 16 |
#include "resolu.h"
| 17 |
| 18 |
int rgbinp = -1; /* input is RGBE? */
| 19 |
int rgbout = 0; /* output should be RGBE? */
| 20 |
RGBPRIMS inprims = STDPRIMS; /* input primaries */
| 21 |
RGBPRIMS outprims = STDPRIMS; /* output primaries */
| 22 |
double expcomp = 1.0; /* exposure compensation */
| 23 |
int doflat = -1; /* produce flat file? */
| 24 |
double origexp = -1.0; /* original exposure */
| 25 |
char *progname;
| 26 |
| 27 |
static gethfunc headline;
| 28 |
static void quiterr(char *err);
| 29 |
static void convert(void);
| 30 |
| 31 |
| 32 |
| 33 |
static int
| 34 |
headline( /* process header line */
| 35 |
char *s,
| 36 |
void *p
| 37 |
| 38 |
| 39 |
char fmt[32];
| 40 |
| 41 |
if (formatval(fmt, s)) { /* check if format string */
| 42 |
if (!strcmp(fmt,COLRFMT))
| 43 |
rgbinp = 1;
| 44 |
else if (!strcmp(fmt,CIEFMT))
| 45 |
rgbinp = 0;
| 46 |
else
| 47 |
rgbinp = -2;
| 48 |
return(0); /* don't echo */
| 49 |
| 50 |
if (origexp > 0.0 && isexpos(s)) {
| 51 |
origexp *= exposval(s);
| 52 |
| 53 |
| 54 |
if (isprims(s)) { /* get input primaries */
| 55 |
primsval(inprims, s);
| 56 |
| 57 |
| 58 |
/* should I grok colcorr also? */
| 59 |
return(fputs(s, stdout));
| 60 |
| 61 |
| 62 |
| 63 |
int
| 64 |
main(int argc, char *argv[])
| 65 |
| 66 |
int i;
| 67 |
SET_DEFAULT_BINARY();
| 68 |
SET_FILE_BINARY(stdin);
| 69 |
SET_FILE_BINARY(stdout);
| 70 |
progname = argv[0];
| 71 |
| 72 |
for (i = 1; i < argc; i++)
| 73 |
if (argv[i][0] == '-')
| 74 |
switch (argv[i][1]) {
| 75 |
case 'c': /* rle-compressed output */
| 76 |
doflat = 0;
| 77 |
break;
| 78 |
case 'u': /* flat output */
| 79 |
doflat = 1;
| 80 |
break;
| 81 |
case 'r': /* RGBE output */
| 82 |
rgbout = 1;
| 83 |
break;
| 84 |
case 'p': /* RGB primaries */
| 85 |
if (i+8 >= argc)
| 86 |
goto userr;
| 87 |
outprims[RED][CIEX] = atof(argv[++i]);
| 88 |
outprims[RED][CIEY] = atof(argv[++i]);
| 89 |
outprims[GRN][CIEX] = atof(argv[++i]);
| 90 |
outprims[GRN][CIEY] = atof(argv[++i]);
| 91 |
outprims[BLU][CIEX] = atof(argv[++i]);
| 92 |
outprims[BLU][CIEY] = atof(argv[++i]);
| 93 |
outprims[WHT][CIEX] = atof(argv[++i]);
| 94 |
outprims[WHT][CIEY] = atof(argv[++i]);
| 95 |
break;
| 96 |
case 'o': /* original exposure */
| 97 |
origexp = 1.0;
| 98 |
break;
| 99 |
case 'e': /* exposure compensation */
| 100 |
expcomp = atof(argv[++i]);
| 101 |
if (argv[i][0] == '+' || argv[i][0] == '-')
| 102 |
expcomp = pow(2., expcomp);
| 103 |
break;
| 104 |
default:
| 105 |
goto userr;
| 106 |
| 107 |
else
| 108 |
break;
| 109 |
| 110 |
if (doflat < 0)
| 111 |
doflat = !rgbout;
| 112 |
if (i < argc-2)
| 113 |
goto userr;
| 114 |
if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
| 115 |
fprintf(stderr, "%s: can't open input \"%s\"\n",
| 116 |
progname, argv[i]);
| 117 |
exit(1);
| 118 |
| 119 |
if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
| 120 |
fprintf(stderr, "%s: can't open output \"%s\"\n",
| 121 |
progname, argv[i+1]);
| 122 |
exit(1);
| 123 |
| 124 |
getheader(stdin, headline, NULL);
| 125 |
if (rgbinp == -2)
| 126 |
quiterr("unrecognized input file format");
| 127 |
if (rgbinp == -1)
| 128 |
rgbinp = !rgbout;
| 129 |
printargs(argc, argv, stdout); /* add to header */
| 130 |
convert(); /* convert picture */
| 131 |
exit(0);
| 132 |
userr:
| 133 |
fprintf(stderr, "Usage: %s [-r][-o][-e exp][-c|-u]", progname);
| 134 |
fprintf(stderr, "[-p rx ry gx gy bx by wx wy] [input [output]]\n");
| 135 |
exit(1);
| 136 |
| 137 |
| 138 |
| 139 |
static void
| 140 |
quiterr( /* print message and exit */
| 141 |
char *err
| 142 |
| 143 |
| 144 |
if (err != NULL) {
| 145 |
fprintf(stderr, "%s: %s\n", progname, err);
| 146 |
exit(1);
| 147 |
| 148 |
exit(0);
| 149 |
| 150 |
| 151 |
| 152 |
static void
| 153 |
convert(void) /* convert to XYZE or RGBE picture */
| 154 |
| 155 |
int order;
| 156 |
int xmax, ymax;
| 157 |
COLORMAT xfm;
| 158 |
register COLOR *scanin;
| 159 |
register COLR *scanout;
| 160 |
double exp2do = expcomp;
| 161 |
double exp2report = expcomp;
| 162 |
int y;
| 163 |
register int x;
| 164 |
/* recover original? */
| 165 |
if (origexp > 0.0)
| 166 |
exp2do /= origexp;
| 167 |
/* compute transform */
| 168 |
if (rgbout) {
| 169 |
if (rgbinp) { /* RGBE -> RGBE */
| 170 |
comprgb2rgbWBmat(xfm, inprims, outprims);
| 171 |
} else { /* XYZE -> RGBE */
| 172 |
compxyz2rgbWBmat(xfm, outprims);
| 173 |
if (origexp > 0.0)
| 174 |
exp2do /= WHTEFFICACY;
| 175 |
else
| 176 |
exp2report *= WHTEFFICACY;
| 177 |
| 178 |
} else {
| 179 |
if (rgbinp) { /* RGBE -> XYZE */
| 180 |
comprgb2xyzWBmat(xfm, inprims);
| 181 |
if (origexp > 0.0)
| 182 |
exp2do *= WHTEFFICACY;
| 183 |
else
| 184 |
exp2report /= WHTEFFICACY;
| 185 |
} else { /* XYZE -> XYZE */
| 186 |
for (y = 0; y < 3; y++)
| 187 |
for (x = 0; x < 3; x++)
| 188 |
xfm[y][x] = x==y ? 1. : 0.;
| 189 |
| 190 |
| 191 |
| 192 |
| 193 |
xfm[y][x] *= exp2do;
| 194 |
/* get input resolution */
| 195 |
if ((order = fgetresolu(&xmax, &ymax, stdin)) < 0)
| 196 |
quiterr("bad picture format");
| 197 |
/* complete output header */
| 198 |
if ((exp2report < 0.99) | (exp2report > 1.01))
| 199 |
fputexpos(exp2report, stdout);
| 200 |
if (rgbout) {
| 201 |
fputprims(outprims, stdout);
| 202 |
fputformat(COLRFMT, stdout);
| 203 |
} else
| 204 |
fputformat(CIEFMT, stdout);
| 205 |
putc('\n', stdout);
| 206 |
fputresolu(order, xmax, ymax, stdout);
| 207 |
/* allocate scanline */
| 208 |
scanin = (COLOR *)malloc(xmax*sizeof(COLOR));
| 209 |
if (scanin == NULL)
| 210 |
quiterr("out of memory in convert");
| 211 |
scanout = doflat ? (COLR *)malloc(xmax*sizeof(COLR)) : NULL;
| 212 |
/* convert image */
| 213 |
for (y = 0; y < ymax; y++) {
| 214 |
if (freadscan(scanin, xmax, stdin) < 0)
| 215 |
quiterr("error reading input picture");
| 216 |
for (x = 0; x < xmax; x++) {
| 217 |
colortrans(scanin[x], xfm, scanin[x]);
| 218 |
if (rgbout)
| 219 |
clipgamut(scanin[x], bright(scanin[x]),
| 220 |
CGAMUT_LOWER, cblack, cwhite);
| 221 |
| 222 |
if (scanout != NULL) {
| 223 |
| 224 |
setcolr(scanout[x], colval(scanin[x],RED),
| 225 |
colval(scanin[x],GRN),
| 226 |
colval(scanin[x],BLU));
| 227 |
fwrite((char *)scanout, sizeof(COLR), xmax, stdout);
| 228 |
} else
| 229 |
fwritescan(scanin, xmax, stdout);
| 230 |
if (ferror(stdout))
| 231 |
quiterr("error writing output picture");
| 232 |
| 233 |
/* free scanline */
| 234 |
free((void *)scanin);
| 235 |
| 236 |
free((void *)scanout);
| 237 |
