root/radiance/ray/src/px/ra_xyze.c
Revision: 2.6
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.5: +9 -11 lines
5 * Program to convert between RADIANCE RGBE and XYZE formats
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include <stdio.h>
10 #include <string.h>
11 #include <math.h>
12 #include <time.h>
13 #include "color.h"
14 #include "resolu.h"
15
16 #ifdef MSDOS
17 #include <fcntl.h>
18 #endif
19
20 int rgbinp = -1; /* input is RGBE? */
21
22 int rgbout = 0; /* output should be RGBE? */
23
24 RGBPRIMS inprims = STDPRIMS; /* input primaries */
25
26 RGBPRIMS outprims = STDPRIMS; /* output primaries */
27
28 double expcomp = 1.0; /* exposure compensation */
29
30 int doflat = -1; /* produce flat file? */
31
32 char *progname;
33
34
35 int
36 headline(s) /* process header line */
37 char *s;
38 {
39 char fmt[32];
40
41 if (formatval(fmt, s)) { /* check if format string */
42 if (!strcmp(fmt,COLRFMT))
43 rgbinp = 1;
44 else if (!strcmp(fmt,CIEFMT))
45 rgbinp = 0;
46 else
47 rgbinp = -2;
48 return(0); /* don't echo */
49 }
50 if (isprims(s)) { /* get input primaries */
51 primsval(inprims, s);
52 return(0); /* don't echo */
53 }
54 /* should I grok colcorr also? */
55 return(fputs(s, stdout));
56 }
57
58
59 main(argc, argv)
60 int argc;
61 char *argv[];
62 {
63 int i;
64 #ifdef MSDOS
65 extern int _fmode;
66 _fmode = O_BINARY;
67 setmode(fileno(stdin), O_BINARY);
68 setmode(fileno(stdout), O_BINARY);
69 #endif
70 progname = argv[0];
71
72 for (i = 1; i < argc; i++)
73 if (argv[i][0] == '-')
74 switch (argv[i][1]) {
75 case 'c': /* rle-compressed output */
76 doflat = 0;
77 break;
78 case 'u': /* flat output */
79 doflat = 1;
80 break;
81 case 'r': /* RGBE output */
82 rgbout = 1;
83 break;
84 case 'p': /* RGB primaries */
85 if (i+8 >= argc)
86 goto userr;
87 outprims[RED][CIEX] = atof(argv[++i]);
88 outprims[RED][CIEY] = atof(argv[++i]);
89 outprims[GRN][CIEX] = atof(argv[++i]);
90 outprims[GRN][CIEY] = atof(argv[++i]);
91 outprims[BLU][CIEX] = atof(argv[++i]);
92 outprims[BLU][CIEY] = atof(argv[++i]);
93 outprims[WHT][CIEX] = atof(argv[++i]);
94 outprims[WHT][CIEY] = atof(argv[++i]);
95 break;
96 case 'e': /* exposure compensation */
97 expcomp = atof(argv[++i]);
98 if (argv[i][0] == '+' || argv[i][0] == '-')
99 expcomp = pow(2., expcomp);
100 break;
101 default:
102 goto userr;
103 }
104 else
105 break;
106
107 if (doflat < 0)
108 doflat = !rgbout;
109 if (i < argc-2)
110 goto userr;
111 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
112 fprintf(stderr, "%s: can't open input \"%s\"\n",
113 progname, argv[i]);
114 exit(1);
115 }
116 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
117 fprintf(stderr, "%s: can't open output \"%s\"\n",
118 progname, argv[i+1]);
119 exit(1);
120 }
121 getheader(stdin, headline, NULL);
122 if (rgbinp == -2)
123 quiterr("unrecognized input file format");
124 if (rgbinp == -1)
125 rgbinp = !rgbout;
126 printargs(argc, argv, stdout); /* add to header */
127 convert(); /* convert picture */
128 exit(0);
129 userr:
130 fprintf(stderr, "Usage: %s [-r][-e exp][-c|-u]", progname);
131 fprintf(stderr, "[-p rx ry gx gy bx by wx wy] [input [output]]\n");
132 exit(1);
133 }
134
135
136 quiterr(err) /* print message and exit */
137 char *err;
138 {
139 if (err != NULL) {
140 fprintf(stderr, "%s: %s\n", progname, err);
141 exit(1);
142 }
143 exit(0);
144 }
145
146
147 convert() /* convert to XYZE or RGBE picture */
148 {
149 int order;
150 int xmax, ymax;
151 COLORMAT xfm;
152 register COLOR *scanin;
153 register COLR *scanout;
154 double ourexp = expcomp;
155 int y;
156 register int x;
157 /* compute transform */
158 if (rgbout) {
159 if (rgbinp) { /* RGBE -> RGBE */
160 comprgb2rgbWBmat(xfm, inprims, outprims);
161 } else { /* XYZE -> RGBE */
162 compxyz2rgbWBmat(xfm, outprims);
163 ourexp *= WHTEFFICACY;
164 }
165 } else {
166 if (rgbinp) { /* RGBE -> XYZE */
167 comprgb2xyzWBmat(xfm, inprims);
168 ourexp /= WHTEFFICACY;
169 } else { /* XYZE -> XYZE */
170 for (y = 0; y < 3; y++)
171 for (x = 0; x < 3; x++)
172 xfm[y][x] = x==y ? 1. : 0.;
173 }
174 }
175 for (y = 0; y < 3; y++)
176 for (x = 0; x < 3; x++)
177 xfm[y][x] *= expcomp;
178 /* get input resolution */
179 if ((order = fgetresolu(&xmax, &ymax, stdin)) < 0)
180 quiterr("bad picture format");
181 /* complete output header */
182 if (ourexp < 0.99 || ourexp > 1.01)
183 fputexpos(ourexp, stdout);
184 if (rgbout) {
185 fputprims(outprims, stdout);
186 fputformat(COLRFMT, stdout);
187 } else
188 fputformat(CIEFMT, stdout);
189 putc('\n', stdout);
190 fputresolu(order, xmax, ymax, stdout);
191 /* allocate scanline */
192 scanin = (COLOR *)malloc(xmax*sizeof(COLOR));
193 if (scanin == NULL)
194 quiterr("out of memory in convert");
195 scanout = doflat ? (COLR *)malloc(xmax*sizeof(COLR)) : NULL;
196 /* convert image */
197 for (y = 0; y < ymax; y++) {
198 if (freadscan(scanin, xmax, stdin) < 0)
199 quiterr("error reading input picture");
200 for (x = 0; x < xmax; x++) {
201 colortrans(scanin[x], xfm, scanin[x]);
202 if (rgbout)
203 clipgamut(scanin[x], bright(scanin[x]),
204 CGAMUT_LOWER, cblack, cwhite);
205 }
206 if (scanout != NULL) {
207 for (x = 0; x < xmax; x++)
208 setcolr(scanout[x], colval(scanin[x],RED),
209 colval(scanin[x],GRN),
210 colval(scanin[x],BLU));
211 fwrite((char *)scanout, sizeof(COLR), xmax, stdout);
212 } else
213 fwritescan(scanin, xmax, stdout);
214 if (ferror(stdout))
215 quiterr("error writing output picture");
216 }
217 /* free scanline */
218 free((void *)scanin);
219 if (scanout != NULL)
220 free((void *)scanout);
221 }
