root/radiance/ray/src/px/ra_xyze.c
Revision 2.17 - (view) (download) (annotate) - [selected]
Sat Jun 7 05:09:46 2025 UTC (3 weeks, 2 days ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16
Fri Jun 6 19:11:21 2025 UTC (3 weeks, 3 days ago) by greg
Diff to previous 2.15 , to selected 2.17
refactor: Making use of printargs() more consistent with fixargv0()
Tue Oct 1 20:04:44 2024 UTC (8 months, 4 weeks ago) by greg
Changes since 2.14: +25 -4 lines
Diff to previous 2.14 , to selected 2.17
perf(ra_xyze): sped up conversion from hyperspectral by a factor of 4 or so
Tue Oct 1 01:16:26 2024 UTC (8 months, 4 weeks ago) by greg
Changes since 2.13: +60 -26 lines
Diff to previous 2.13 , to selected 2.17
feat(ra_xyze): added accurate conversion of hyperspectral pictures on input
Sat Dec 28 18:05:14 2019 UTC (5 years, 6 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.12: +1 -4 lines
Diff to previous 2.12 , to selected 2.17
Thu Aug 2 18:33:48 2018 UTC (6 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.17
Thu Aug 18 00:52:48 2016 UTC (8 years, 10 months ago) by greg
Changes since 2.10: +3 -2 lines
Diff to previous 2.10 , to selected 2.17
Tue Aug 22 21:38:22 2006 UTC (18 years, 10 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 2.9: +26 -8 lines
Diff to previous 2.9 , to selected 2.17
Added -o option to ra_xyze for original pixel values.
Sun Mar 28 20:33:14 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.8: +12 -13 lines
Diff to previous 2.8 , to selected 2.17
Fri Jan 2 12:47:01 2004 UTC (21 years, 6 months ago) by schorsch
Diff to previous 2.7 , to selected 2.17
Thu Jun 5 19:29:34 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.6: +6 -11 lines
Diff to previous 2.6 , to selected 2.17
Sat Feb 22 02:07:28 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.5: +9 -11 lines
Diff to previous 2.5 , to selected 2.17
Tue Oct 27 09:08:27 1998 UTC (26 years, 8 months ago) by gwlarson
Diff to previous 2.4 , to selected 2.17
Tue Jul 22 10:17:53 1997 UTC (27 years, 11 months ago) by gregl
Changes since 2.3: +11 -14 lines
Diff to previous 2.3 , to selected 2.17
made it so EXPOSURE is changed rather than actual pixel values
Fri Jan 31 12:51:22 1997 UTC (28 years, 5 months ago) by greg
Changes since 2.2: +6 -2 lines
Diff to previous 2.2 , to selected 2.17
created new clipgamut() function
Wed Oct 25 15:13:38 1995 UTC (29 years, 8 months ago) by greg
Diff to previous 2.1 , to selected 2.17
fixed bad argument counting in -p processing
Sun Oct 15 14:07:12 1995 UTC (29 years, 8 months ago) by greg
Diff to selected 2.17
