root/radiance/ray/src/px/ra_xyze.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.12: +1 -4 lines
Diff to previous 2.12
Thu Aug 2 18:33:48 2018 UTC (5 years, 9 months ago) by greg
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 2.10: +3 -2 lines
Tue Aug 22 21:38:22 2006 UTC (17 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 2.9: +26 -8 lines
Added -o option to ra_xyze for original pixel values.
Changes since 2.8: +12 -13 lines
Fri Jan 2 12:47:01 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.6: +6 -11 lines
Changes since 2.5: +9 -11 lines
Tue Oct 27 09:08:27 1998 UTC (25 years, 7 months ago) by gwlarson
Tue Jul 22 10:17:53 1997 UTC (26 years, 10 months ago) by gregl
Changes since 2.3: +11 -14 lines
made it so EXPOSURE is changed rather than actual pixel values
Fri Jan 31 12:51:22 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.2: +6 -2 lines
created new clipgamut() function
Wed Oct 25 15:13:38 1995 UTC (28 years, 7 months ago) by greg
fixed bad argument counting in -p processing
Sun Oct 15 14:07:12 1995 UTC (28 years, 7 months ago) by greg
