1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Program to convert between RADIANCE and TIFF files. |
9 |
* Added experimental LogLuv encodings 7/97 (GWL). |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tiffio.h" |
15 |
#include "color.h" |
16 |
#include "resolu.h" |
17 |
18 |
#define GAMCOR 2.2 /* default gamma */ |
19 |
20 |
#ifndef malloc |
21 |
extern char *malloc(); |
22 |
#endif |
23 |
/* conversion flags */ |
24 |
#define C_CXFM 0x1 /* needs color transformation */ |
25 |
#define C_GAMUT 0x2 /* needs gamut mapping */ |
26 |
#define C_GAMMA 0x4 /* needs gamma correction */ |
27 |
#define C_GRY 0x8 /* TIFF is greyscale */ |
28 |
#define C_XYZE 0x10 /* Radiance is XYZE */ |
29 |
#define C_RFLT 0x20 /* Radiance data is float */ |
30 |
#define C_TFLT 0x40 /* TIFF data is float */ |
31 |
#define C_PRIM 0x80 /* has assigned primaries */ |
32 |
33 |
struct { |
34 |
uint16 flags; /* conversion flags (defined above) */ |
35 |
uint16 comp; /* TIFF compression type */ |
36 |
uint16 pconf; /* TIFF planar configuration */ |
37 |
float gamcor; /* gamma correction value */ |
38 |
short bradj; /* Radiance exposure adjustment (stops) */ |
39 |
uint16 orient; /* visual orientation (TIFF spec.) */ |
40 |
float stonits; /* input conversion to nits */ |
41 |
float pixrat; /* pixel aspect ratio */ |
42 |
FILE *rfp; /* Radiance stream pointer */ |
43 |
TIFF *tif; /* TIFF pointer */ |
44 |
uint32 xmax, ymax; /* image dimensions */ |
45 |
COLORMAT cmat; /* color transformation matrix */ |
46 |
RGBPRIMS prims; /* RGB primaries */ |
47 |
union { |
48 |
COLR *colrs; /* 4-byte ???E pointer */ |
49 |
COLOR *colors; /* float array pointer */ |
50 |
char *p; /* generic pointer */ |
51 |
} r; /* Radiance scanline */ |
52 |
union { |
53 |
uint8 *bp; /* byte pointer */ |
54 |
float *fp; /* float pointer */ |
55 |
56 |
} t; /* TIFF scanline */ |
57 |
int (*tf)(); /* translation procedure */ |
58 |
} cvts = { /* conversion structure */ |
59 |
0, COMPRESSION_NONE, PLANARCONFIG_CONTIG, GAMCOR, 0, |
60 |
61 |
62 |
#define CHK(f) (cvts.flags & (f)) |
63 |
#define SET(f) (cvts.flags |= (f)) |
64 |
#define CLR(f) (cvts.flags &= ~(f)) |
65 |
#define TGL(f) (cvts.flags ^= (f)) |
66 |
67 |
int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); |
68 |
int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); |
69 |
70 |
short ortab[8] = { /* orientation conversion table */ |
71 |
YMAJOR|YDECR, |
72 |
YMAJOR|YDECR|XDECR, |
73 |
YMAJOR|XDECR, |
74 |
YMAJOR, |
75 |
YDECR, |
76 |
XDECR|YDECR, |
77 |
XDECR, |
78 |
0 |
79 |
80 |
81 |
#define pixorder() ortab[cvts.orient-1] |
82 |
83 |
char *progname; |
84 |
85 |
86 |
main(argc, argv) |
87 |
int argc; |
88 |
char *argv[]; |
89 |
90 |
int reverse = 0; |
91 |
int i; |
92 |
93 |
progname = argv[0]; |
94 |
95 |
for (i = 1; i < argc; i++) |
96 |
if (argv[i][0] == '-') |
97 |
switch (argv[i][1]) { |
98 |
case 'g': /* gamma correction */ |
99 |
cvts.gamcor = atof(argv[++i]); |
100 |
break; |
101 |
case 'x': /* XYZE Radiance output */ |
102 |
TGL(C_XYZE); |
103 |
break; |
104 |
case 'z': /* LZW compressed output */ |
105 |
cvts.comp = COMPRESSION_LZW; |
106 |
break; |
107 |
case 'L': /* LogLuv 32-bit output */ |
108 |
cvts.comp = COMPRESSION_LOGLUV32; |
109 |
break; |
110 |
case 'l': /* LogLuv 24-bit output */ |
111 |
cvts.comp = COMPRESSION_LOGLUV24; |
112 |
break; |
113 |
case 'b': /* greyscale output? */ |
114 |
TGL(C_GRY); |
115 |
break; |
116 |
case 'e': /* exposure adjustment */ |
117 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
118 |
goto userr; |
119 |
cvts.bradj = atoi(argv[++i]); |
120 |
break; |
121 |
case 'r': /* reverse conversion? */ |
122 |
reverse = !reverse; |
123 |
break; |
124 |
case '\0': |
125 |
goto doneopts; |
126 |
default: |
127 |
goto userr; |
128 |
129 |
else |
130 |
break; |
131 |
doneopts: |
132 |
if (reverse) { |
133 |
134 |
if (i != argc-2 && i != argc-1) |
135 |
goto userr; |
136 |
137 |
tiff2ra(i, argv); |
138 |
139 |
} else { |
140 |
141 |
if (i != argc-2) |
142 |
goto userr; |
143 |
144 |
if (CHK(C_GRY) && (cvts.comp == COMPRESSION_LOGLUV24 || |
145 |
cvts.comp == COMPRESSION_LOGLUV32)) |
146 |
cvts.comp = COMPRESSION_LOGL16; |
147 |
148 |
ra2tiff(i, argv); |
149 |
150 |
151 |
exit(0); |
152 |
userr: |
153 |
fprintf(stderr, |
154 |
"Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", |
155 |
progname); |
156 |
fprintf(stderr, |
157 |
" Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", |
158 |
progname); |
159 |
exit(1); |
160 |
161 |
162 |
163 |
quiterr(err) /* print message and exit */ |
164 |
char *err; |
165 |
166 |
if (err != NULL) { |
167 |
fprintf(stderr, "%s: %s\n", progname, err); |
168 |
exit(1); |
169 |
170 |
exit(0); |
171 |
172 |
173 |
174 |
allocbufs() /* allocate scanline buffers */ |
175 |
176 |
int rsiz, tsiz; |
177 |
178 |
rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); |
179 |
tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) * |
180 |
(CHK(C_GRY) ? 1 : 3); |
181 |
cvts.r.p = (char *)malloc(rsiz*cvts.xmax); |
182 |
cvts.t.p = (char *)malloc(tsiz*cvts.xmax); |
183 |
if (cvts.r.p == NULL | cvts.t.p == NULL) |
184 |
quiterr("no memory to allocate scanline buffers"); |
185 |
186 |
187 |
188 |
initfromtif() /* initialize conversion from TIFF input */ |
189 |
190 |
uint16 hi; |
191 |
float *fa, f1, f2; |
192 |
193 |
CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM); |
194 |
195 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); |
196 |
197 |
if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
198 |
cvts.prims[RED][CIEX] = fa[0]; |
199 |
cvts.prims[RED][CIEY] = fa[1]; |
200 |
cvts.prims[GRN][CIEX] = fa[2]; |
201 |
cvts.prims[GRN][CIEY] = fa[3]; |
202 |
cvts.prims[BLU][CIEX] = fa[4]; |
203 |
cvts.prims[BLU][CIEY] = fa[5]; |
204 |
cvts.prims[WHT][CIEX] = 1./3.; |
205 |
cvts.prims[WHT][CIEY] = 1./3.; |
206 |
if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) { |
207 |
cvts.prims[WHT][CIEX] = fa[0]; |
208 |
cvts.prims[WHT][CIEY] = fa[1]; |
209 |
210 |
SET(C_PRIM); |
211 |
212 |
213 |
if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp)) |
214 |
cvts.comp = COMPRESSION_NONE; |
215 |
216 |
if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && |
217 |
TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) |
218 |
cvts.pixrat = f1/f2; |
219 |
else |
220 |
cvts.pixrat = 1.; |
221 |
222 |
if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient)) |
223 |
cvts.orient = 1; |
224 |
225 |
switch (cvts.comp) { |
226 |
case COMPRESSION_LOGL16: |
227 |
SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); |
228 |
cvts.pconf = PLANARCONFIG_CONTIG; |
229 |
TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT, |
230 |
LOGLUVDATAFMT_FLTY); |
231 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, |
232 |
SAMPLEFORMAT_IEEEFP); |
233 |
cvts.tf = L2Color; |
234 |
break; |
235 |
case COMPRESSION_LOGLUV24: |
236 |
case COMPRESSION_LOGLUV32: |
237 |
SET(C_RFLT|C_TFLT); |
238 |
if (!CHK(C_XYZE)) { |
239 |
cpcolormat(cvts.cmat, xyz2rgbmat); |
240 |
SET(C_CXFM|C_GAMUT); |
241 |
} else if (cvts.comp == COMPRESSION_LOGLUV32) |
242 |
SET(C_GAMUT); |
243 |
if (cvts.pconf != PLANARCONFIG_CONTIG) |
244 |
quiterr("cannot handle separate Luv planes"); |
245 |
246 |
LOGLUVDATAFMT_FLTXYZ); |
247 |
248 |
249 |
cvts.tf = Luv2Color; |
250 |
break; |
251 |
default: |
252 |
SET(C_GAMMA|C_GAMUT); |
253 |
setcolrgam(cvts.gamcor); |
254 |
if (CHK(C_XYZE)) { |
255 |
comprgb2xyzmat(cvts.cmat, |
256 |
CHK(C_PRIM) ? cvts.prims : stdprims); |
257 |
SET(C_CXFM); |
258 |
259 |
if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || |
260 |
(hi != 1 && hi != 3)) |
261 |
quiterr("unsupported samples per pixel"); |
262 |
if (hi == 1) { |
263 |
SET(C_GRY); |
264 |
265 |
cvts.tf = Gry2Colr; |
266 |
} else |
267 |
cvts.tf = RGB2Colr; |
268 |
if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) || |
269 |
hi != 8) |
270 |
quiterr("unsupported bits per sample"); |
271 |
break; |
272 |
273 |
274 |
if (TIFFGetField(cvts.tif, TIFFTAG_PHOTOMETRIC, &hi) && |
275 |
hi != (CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB)) |
276 |
quiterr("unsupported photometric interpretation"); |
277 |
278 |
if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || |
279 |
!TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) |
280 |
quiterr("unknown input image resolution"); |
281 |
282 |
if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) |
283 |
cvts.stonits = 1.; |
284 |
/* add to Radiance header */ |
285 |
if (cvts.pixrat < .99 || cvts.pixrat > 1.01) |
286 |
fputaspect(cvts.pixrat, cvts.rfp); |
287 |
288 |
fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); |
289 |
fputformat(CIEFMT, cvts.rfp); |
290 |
} else { |
291 |
if (CHK(C_PRIM)) |
292 |
fputprims(cvts.prims, cvts.rfp); |
293 |
fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, |
294 |
cvts.rfp); |
295 |
fputformat(COLRFMT, cvts.rfp); |
296 |
297 |
298 |
allocbufs(); /* allocate scanline buffers */ |
299 |
300 |
301 |
302 |
tiff2ra(ac, av) /* convert TIFF image to Radiance picture */ |
303 |
int ac; |
304 |
char *av[]; |
305 |
306 |
int32 y; |
307 |
/* open TIFF input */ |
308 |
if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL) |
309 |
quiterr("cannot open TIFF input"); |
310 |
/* open Radiance output */ |
311 |
if (av[ac+1] == NULL || !strcmp(av[ac+1], "-")) |
312 |
cvts.rfp = stdout; |
313 |
else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) |
314 |
quiterr("cannot open Radiance output picture"); |
315 |
/* start output header */ |
316 |
newheader("RADIANCE", cvts.rfp); |
317 |
printargs(ac, av, cvts.rfp); |
318 |
319 |
initfromtif(); /* initialize conversion */ |
320 |
321 |
fputc('\n', cvts.rfp); /* finish Radiance header */ |
322 |
fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp); |
323 |
324 |
for (y = 0; y < cvts.ymax; y++) /* convert image */ |
325 |
(*cvts.tf)(y); |
326 |
/* clean up */ |
327 |
fclose(cvts.rfp); |
328 |
TIFFClose(cvts.tif); |
329 |
330 |
331 |
332 |
int |
333 |
headline(s) /* process Radiance input header line */ |
334 |
char *s; |
335 |
336 |
char fmt[32]; |
337 |
338 |
if (formatval(fmt, s)) { |
339 |
if (!strcmp(fmt, COLRFMT)) |
340 |
CLR(C_XYZE); |
341 |
else if (!strcmp(fmt, CIEFMT)) |
342 |
SET(C_XYZE); |
343 |
else |
344 |
quiterr("unrecognized input picture format"); |
345 |
return; |
346 |
347 |
if (isexpos(s)) { |
348 |
cvts.stonits /= exposval(s); |
349 |
return; |
350 |
351 |
if (isaspect(s)) { |
352 |
cvts.pixrat *= aspectval(s); |
353 |
return; |
354 |
355 |
if (isprims(s)) { |
356 |
primsval(cvts.prims, s); |
357 |
SET(C_PRIM); |
358 |
return; |
359 |
360 |
361 |
362 |
363 |
initfromrad() /* initialize input from a Radiance picture */ |
364 |
365 |
int i1, i2, po; |
366 |
/* read Radiance header */ |
367 |
CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); |
368 |
369 |
cvts.pixrat = 1.; |
370 |
371 |
getheader(cvts.rfp, headline, NULL); |
372 |
if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) |
373 |
quiterr("bad Radiance picture"); |
374 |
cvts.xmax = i1; cvts.ymax = i2; |
375 |
for (i1 = 0; i1 < 8; i1++) /* interpret orientation */ |
376 |
if (ortab[i1] == po) { |
377 |
cvts.orient = i1 + 1; |
378 |
break; |
379 |
380 |
if (i1 >= 8) |
381 |
quiterr("internal error 1 in initfromrad"); |
382 |
if (!(po & YMAJOR)) |
383 |
cvts.pixrat = 1./cvts.pixrat; |
384 |
if (!CHK(C_XYZE)) |
385 |
cvts.stonits *= WHTEFFICACY; |
386 |
/* set up conversion */ |
387 |
TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); |
388 |
389 |
390 |
391 |
SET(C_GRY|C_RFLT|C_TFLT); |
392 |
393 |
394 |
395 |
396 |
cvts.tf = Color2L; |
397 |
break; |
398 |
399 |
400 |
401 |
CLR(C_GRY); |
402 |
403 |
cpcolormat(cvts.cmat, rgb2xyzmat); |
404 |
SET(C_CXFM); |
405 |
406 |
407 |
408 |
409 |
410 |
cvts.tf = Color2Luv; |
411 |
break; |
412 |
default: |
413 |
414 |
415 |
416 |
compxyz2rgbmat(cvts.cmat, |
417 |
418 |
SET(C_CXFM); |
419 |
420 |
if (CHK(C_GRY)) |
421 |
cvts.tf = Colr2Gry; |
422 |
else |
423 |
cvts.tf = Colr2RGB; |
424 |
if (CHK(C_PRIM)) { |
425 |
TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, |
426 |
(float *)cvts.prims); |
427 |
TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, |
428 |
(float *)cvts.prims[WHT]); |
429 |
430 |
break; |
431 |
432 |
/* set other TIFF fields */ |
433 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); |
434 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); |
435 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); |
436 |
TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8); |
437 |
TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, |
438 |
CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB); |
439 |
TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); |
440 |
TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); |
441 |
TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); |
442 |
TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2); |
443 |
TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); |
444 |
TIFFSetField(cvts.tif, TIFFTAG_STONITS, |
445 |
cvts.stonits/pow(2.,(double)cvts.bradj)); |
446 |
i1 = TIFFScanlineSize(cvts.tif); |
447 |
i2 = 8192/i1; /* compute good strip size */ |
448 |
if (i2 < 1) i2 = 1; |
449 |
TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); |
450 |
451 |
452 |
453 |
454 |
455 |
ra2tiff(ac, av) /* convert Radiance picture to TIFF image */ |
456 |
int ac; |
457 |
char *av[]; |
458 |
459 |
uint32 y; |
460 |
/* open Radiance file */ |
461 |
if (!strcmp(av[ac], "-")) |
462 |
cvts.rfp = stdin; |
463 |
else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) |
464 |
quiterr("cannot open Radiance input picture"); |
465 |
/* open TIFF file */ |
466 |
if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) |
467 |
quiterr("cannot open TIFF output"); |
468 |
469 |
initfromrad(); /* initialize conversion */ |
470 |
471 |
472 |
(*cvts.tf)(y); |
473 |
/* clean up */ |
474 |
475 |
fclose(cvts.rfp); |
476 |
477 |
478 |
479 |
int |
480 |
Luv2Color(y) /* read/convert/write Luv->COLOR scanline */ |
481 |
uint32 y; |
482 |
483 |
register int x; |
484 |
485 |
if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY)) |
486 |
quiterr("internal error 1 in Luv2Color"); |
487 |
488 |
if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
489 |
quiterr("error reading TIFF input"); |
490 |
491 |
for (x = cvts.xmax; x--; ) { |
492 |
cvts.r.colors[x][RED] = cvts.t.fp[3*x]; |
493 |
cvts.r.colors[x][GRN] = cvts.t.fp[3*x + 1]; |
494 |
cvts.r.colors[x][BLU] = cvts.t.fp[3*x + 2]; |
495 |
if (CHK(C_CXFM)) |
496 |
colortrans(cvts.r.colors[x], cvts.cmat, |
497 |
cvts.r.colors[x]); |
498 |
if (CHK(C_GAMUT)) |
499 |
clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], |
500 |
CGAMUT_LOWER, cblack, cwhite); |
501 |
502 |
if (cvts.bradj) { |
503 |
double m = pow(2.,(double)cvts.bradj); |
504 |
for (x = cvts.xmax; x--; ) |
505 |
scalecolor(cvts.r.colors[x], m); |
506 |
507 |
508 |
if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
509 |
quiterr("error writing Radiance picture"); |
510 |
511 |
512 |
513 |
int |
514 |
L2Color(y) /* read/convert/write L16->COLOR scanline */ |
515 |
uint32 y; |
516 |
517 |
register int x; |
518 |
519 |
if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
520 |
quiterr("internal error 1 in L2Color"); |
521 |
522 |
523 |
524 |
525 |
526 |
cvts.r.colors[x][RED] = |
527 |
cvts.r.colors[x][GRN] = |
528 |
cvts.r.colors[x][BLU] = cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.; |
529 |
530 |
531 |
532 |
533 |
534 |
535 |
int |
536 |
RGB2Colr(y) /* read/convert/write RGB->COLR scanline */ |
537 |
uint32 y; |
538 |
539 |
COLOR ctmp; |
540 |
register int x; |
541 |
542 |
if (CHK(C_RFLT|C_TFLT|C_GRY)) |
543 |
quiterr("internal error 1 in RGB2Colr"); |
544 |
545 |
if (cvts.pconf == PLANARCONFIG_CONTIG) { |
546 |
547 |
goto readerr; |
548 |
549 |
cvts.r.colrs[x][RED] = cvts.t.bp[3*x]; |
550 |
cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1]; |
551 |
cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2]; |
552 |
553 |
} else { |
554 |
555 |
goto readerr; |
556 |
if (TIFFReadScanline(cvts.tif, |
557 |
(tidata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) |
558 |
goto readerr; |
559 |
560 |
(tidata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) |
561 |
goto readerr; |
562 |
563 |
cvts.r.colrs[x][RED] = cvts.t.bp[x]; |
564 |
cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x]; |
565 |
cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x]; |
566 |
567 |
568 |
569 |
gambs_colrs(cvts.r.colrs, cvts.xmax); |
570 |
if (CHK(C_CXFM)) |
571 |
572 |
colr_color(ctmp, cvts.r.colrs[x]); |
573 |
colortrans(ctmp, cvts.cmat, ctmp); |
574 |
if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */ |
575 |
clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER, |
576 |
cblack, cwhite); |
577 |
setcolr(cvts.r.colrs[x], colval(ctmp,RED), |
578 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
579 |
580 |
if (cvts.bradj) |
581 |
shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj); |
582 |
583 |
if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
584 |
585 |
return; |
586 |
readerr: |
587 |
588 |
589 |
590 |
591 |
int |
592 |
Gry2Colr(y) /* read/convert/write G8->COLR scanline */ |
593 |
uint32 y; |
594 |
595 |
register int x; |
596 |
597 |
if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY)) |
598 |
quiterr("internal error 1 in Gry2Colr"); |
599 |
600 |
601 |
602 |
603 |
604 |
cvts.r.colrs[x][RED] = |
605 |
cvts.r.colrs[x][GRN] = |
606 |
cvts.r.colrs[x][BLU] = cvts.t.bp[x]; |
607 |
608 |
609 |
if (cvts.bradj) |
610 |
611 |
612 |
613 |
614 |
615 |
616 |
617 |
int |
618 |
Color2L(y) /* read/convert/write COLOR->L16 scanline */ |
619 |
uint32 y; |
620 |
621 |
622 |
register int x; |
623 |
624 |
if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | !CHK(C_GRY)) |
625 |
quiterr("internal error 1 in Color2L"); |
626 |
627 |
if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
628 |
quiterr("error reading Radiance picture"); |
629 |
630 |
631 |
cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) |
632 |
: bright(cvts.r.colors[x]) ); |
633 |
634 |
if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
635 |
quiterr("error writing TIFF output"); |
636 |
637 |
638 |
639 |
int |
640 |
Color2Luv(y) /* read/convert/write COLOR->Luv scanline */ |
641 |
uint32 y; |
642 |
643 |
register int x; |
644 |
645 |
646 |
quiterr("internal error 1 in Color2Luv"); |
647 |
648 |
649 |
650 |
651 |
if (CHK(C_CXFM)) |
652 |
653 |
654 |
655 |
if (cvts.bradj) { |
656 |
657 |
658 |
659 |
660 |
661 |
662 |
cvts.t.fp[3*x] = colval(cvts.r.colors[x],RED); |
663 |
cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],GRN); |
664 |
cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],BLU); |
665 |
666 |
667 |
668 |
669 |
670 |
671 |
672 |
int |
673 |
Colr2Gry(y) /* read/convert/write COLR->RGB scanline */ |
674 |
uint32 y; |
675 |
676 |
register int x; |
677 |
678 |
679 |
quiterr("internal error 1 in Colr2Gry"); |
680 |
681 |
if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
682 |
683 |
684 |
if (cvts.bradj) |
685 |
686 |
687 |
colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]); |
688 |
colrs_gambs(cvts.r.colrs, cvts.xmax); |
689 |
690 |
691 |
cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY); |
692 |
693 |
694 |
695 |
696 |
697 |
698 |
int |
699 |
Colr2RGB(y) /* read/convert/write COLR->RGB scanline */ |
700 |
uint32 y; |
701 |
702 |
COLOR ctmp; |
703 |
register int x; |
704 |
705 |
706 |
quiterr("internal error 1 in Colr2RGB"); |
707 |
708 |
709 |
710 |
711 |
if (cvts.bradj) |
712 |
713 |
if (CHK(C_CXFM)) |
714 |
715 |
716 |
717 |
if (CHK(C_GAMUT)) |
718 |
clipgamut(ctmp, bright(ctmp), CGAMUT, |
719 |
cblack, cwhite); |
720 |
721 |
722 |
723 |
724 |
725 |
726 |
cvts.t.bp[3*x] = cvts.r.colrs[x][RED]; |
727 |
cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN]; |
728 |
cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU]; |
729 |
730 |
731 |
732 |
733 |
