1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ra_tiff.c,v 2.23 2003/07/14 04:56:54 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Program to convert between RADIANCE and TIFF files. |
6 |
* Added LogLuv encodings 7/97 (GWL). |
7 |
* Added white-balance adjustment 10/01 (GW). |
8 |
9 |
10 |
#include <stdio.h> |
11 |
#include <math.h> |
12 |
#include <ctype.h> |
13 |
#include <time.h> |
14 |
#include "tiffio.h" |
15 |
#include "color.h" |
16 |
#include "resolu.h" |
17 |
18 |
#define GAMCOR 2.2 /* default gamma */ |
19 |
20 |
/* conversion flags */ |
21 |
#define C_CXFM 0x1 /* needs color transformation */ |
22 |
#define C_GAMUT 0x2 /* needs gamut mapping */ |
23 |
#define C_GAMMA 0x4 /* needs gamma correction */ |
24 |
#define C_GRY 0x8 /* TIFF is greyscale */ |
25 |
#define C_XYZE 0x10 /* Radiance is XYZE */ |
26 |
#define C_RFLT 0x20 /* Radiance data is float */ |
27 |
#define C_TFLT 0x40 /* TIFF data is float */ |
28 |
#define C_TWRD 0x80 /* TIFF data is 16-bit */ |
29 |
#define C_PRIM 0x100 /* has assigned primaries */ |
30 |
31 |
struct { |
32 |
uint16 flags; /* conversion flags (defined above) */ |
33 |
char capdate[20]; /* capture date/time */ |
34 |
char owner[256]; /* content owner */ |
35 |
uint16 comp; /* TIFF compression type */ |
36 |
uint16 phot; /* TIFF photometric type */ |
37 |
uint16 pconf; /* TIFF planar configuration */ |
38 |
float gamcor; /* gamma correction value */ |
39 |
short bradj; /* Radiance exposure adjustment (stops) */ |
40 |
uint16 orient; /* visual orientation (TIFF spec.) */ |
41 |
double stonits; /* input conversion to nits */ |
42 |
float pixrat; /* pixel aspect ratio */ |
43 |
FILE *rfp; /* Radiance stream pointer */ |
44 |
TIFF *tif; /* TIFF pointer */ |
45 |
uint32 xmax, ymax; /* image dimensions */ |
46 |
COLORMAT cmat; /* color transformation matrix */ |
47 |
RGBPRIMS prims; /* RGB primaries */ |
48 |
union { |
49 |
COLR *colrs; /* 4-byte ???E pointer */ |
50 |
COLOR *colors; /* float array pointer */ |
51 |
char *p; /* generic pointer */ |
52 |
} r; /* Radiance scanline */ |
53 |
union { |
54 |
uint8 *bp; /* byte pointer */ |
55 |
uint16 *wp; /* word pointer */ |
56 |
float *fp; /* float pointer */ |
57 |
58 |
} t; /* TIFF scanline */ |
59 |
void (*tf)(); /* translation procedure */ |
60 |
} cvts = { /* conversion structure */ |
61 |
0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB, |
62 |
PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., |
63 |
64 |
65 |
#define CHK(f) (cvts.flags & (f)) |
66 |
#define SET(f) (cvts.flags |= (f)) |
67 |
#define CLR(f) (cvts.flags &= ~(f)) |
68 |
#define TGL(f) (cvts.flags ^= (f)) |
69 |
70 |
void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); |
71 |
void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); |
72 |
void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry(); |
73 |
74 |
#define RfGfBf2Color Luv2Color |
75 |
#define Gryf2Color L2Color |
76 |
#define Color2Gryf Color2L |
77 |
#define Color2RfGfBf Color2Luv |
78 |
79 |
short ortab[8] = { /* orientation conversion table */ |
80 |
YMAJOR|YDECR, |
81 |
YMAJOR|YDECR|XDECR, |
82 |
YMAJOR|XDECR, |
83 |
YMAJOR, |
84 |
YDECR, |
85 |
XDECR|YDECR, |
86 |
XDECR, |
87 |
0 |
88 |
89 |
90 |
#define pixorder() ortab[cvts.orient-1] |
91 |
92 |
extern char TMSTR[]; /* "CAPDATE=" from header.c */ |
93 |
char OWNSTR[] = "OWNER="; |
94 |
95 |
char *progname; |
96 |
97 |
98 |
main(argc, argv) |
99 |
int argc; |
100 |
char *argv[]; |
101 |
102 |
int reverse = 0; |
103 |
int i; |
104 |
105 |
progname = argv[0]; |
106 |
107 |
for (i = 1; i < argc; i++) |
108 |
if (argv[i][0] == '-') |
109 |
switch (argv[i][1]) { |
110 |
case 'g': /* gamma correction */ |
111 |
cvts.gamcor = atof(argv[++i]); |
112 |
break; |
113 |
case 'x': /* XYZE Radiance output */ |
114 |
TGL(C_XYZE); |
115 |
break; |
116 |
case 'z': /* LZW compressed output */ |
117 |
cvts.comp = COMPRESSION_LZW; |
118 |
break; |
119 |
case 'L': /* LogLuv 32-bit output */ |
120 |
cvts.comp = COMPRESSION_SGILOG; |
121 |
cvts.phot = PHOTOMETRIC_LOGLUV; |
122 |
break; |
123 |
case 'l': /* LogLuv 24-bit output */ |
124 |
cvts.comp = COMPRESSION_SGILOG24; |
125 |
126 |
break; |
127 |
case 'w': /* 16-bit/primary output? */ |
128 |
TGL(C_TWRD); |
129 |
break; |
130 |
case 'f': /* IEEE float output? */ |
131 |
TGL(C_TFLT); |
132 |
break; |
133 |
case 'b': /* greyscale output? */ |
134 |
TGL(C_GRY); |
135 |
break; |
136 |
case 'e': /* exposure adjustment */ |
137 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
138 |
goto userr; |
139 |
cvts.bradj = atoi(argv[++i]); |
140 |
break; |
141 |
case 'r': /* reverse conversion? */ |
142 |
reverse = !reverse; |
143 |
break; |
144 |
case '\0': |
145 |
goto doneopts; |
146 |
default: |
147 |
goto userr; |
148 |
149 |
else |
150 |
break; |
151 |
doneopts: |
152 |
if (reverse) { |
153 |
154 |
if (i != argc-2 && i != argc-1) |
155 |
goto userr; |
156 |
157 |
tiff2ra(i, argv); |
158 |
159 |
} else { |
160 |
161 |
if (i != argc-2) |
162 |
goto userr; |
163 |
/* consistency checks */ |
164 |
if (CHK(C_GRY)) |
165 |
if (cvts.phot == PHOTOMETRIC_RGB) |
166 |
cvts.phot = PHOTOMETRIC_MINISBLACK; |
167 |
else { |
168 |
cvts.phot = PHOTOMETRIC_LOGL; |
169 |
170 |
171 |
if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT)) |
172 |
goto userr; |
173 |
174 |
ra2tiff(i, argv); |
175 |
176 |
177 |
exit(0); |
178 |
userr: |
179 |
fprintf(stderr, |
180 |
"Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", |
181 |
progname); |
182 |
fprintf(stderr, |
183 |
" Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", |
184 |
progname); |
185 |
exit(1); |
186 |
187 |
188 |
189 |
quiterr(err) /* print message and exit */ |
190 |
char *err; |
191 |
192 |
if (err != NULL) { |
193 |
fprintf(stderr, "%s: %s\n", progname, err); |
194 |
exit(1); |
195 |
196 |
exit(0); |
197 |
198 |
199 |
200 |
allocbufs() /* allocate scanline buffers */ |
201 |
202 |
int rsiz, tsiz; |
203 |
204 |
rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); |
205 |
tsiz = (CHK(C_TFLT) ? sizeof(float) : |
206 |
CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) * |
207 |
(CHK(C_GRY) ? 1 : 3); |
208 |
cvts.r.p = (char *)malloc(rsiz*cvts.xmax); |
209 |
cvts.t.p = (char *)malloc(tsiz*cvts.xmax); |
210 |
if (cvts.r.p == NULL | cvts.t.p == NULL) |
211 |
quiterr("no memory to allocate scanline buffers"); |
212 |
213 |
214 |
215 |
initfromtif() /* initialize conversion from TIFF input */ |
216 |
217 |
uint16 hi; |
218 |
char *cp; |
219 |
float *fa, f1, f2; |
220 |
221 |
CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM); |
222 |
223 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); |
224 |
225 |
if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
226 |
cvts.prims[RED][CIEX] = fa[0]; |
227 |
cvts.prims[RED][CIEY] = fa[1]; |
228 |
cvts.prims[GRN][CIEX] = fa[2]; |
229 |
cvts.prims[GRN][CIEY] = fa[3]; |
230 |
cvts.prims[BLU][CIEX] = fa[4]; |
231 |
cvts.prims[BLU][CIEY] = fa[5]; |
232 |
cvts.prims[WHT][CIEX] = 1./3.; |
233 |
cvts.prims[WHT][CIEY] = 1./3.; |
234 |
if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) { |
235 |
cvts.prims[WHT][CIEX] = fa[0]; |
236 |
cvts.prims[WHT][CIEY] = fa[1]; |
237 |
238 |
SET(C_PRIM); |
239 |
240 |
241 |
if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp)) |
242 |
cvts.comp = COMPRESSION_NONE; |
243 |
244 |
if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && |
245 |
TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) |
246 |
cvts.pixrat = f1/f2; |
247 |
248 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient); |
249 |
250 |
if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot)) |
251 |
quiterr("TIFF has unspecified photometric type"); |
252 |
253 |
switch (cvts.phot) { |
254 |
case PHOTOMETRIC_LOGLUV: |
255 |
SET(C_RFLT|C_TFLT); |
256 |
if (!CHK(C_XYZE)) { |
257 |
cpcolormat(cvts.cmat, xyz2rgbmat); |
258 |
SET(C_CXFM|C_GAMUT); |
259 |
} else if (cvts.comp == COMPRESSION_SGILOG) |
260 |
SET(C_GAMUT); |
261 |
if (cvts.pconf != PLANARCONFIG_CONTIG) |
262 |
quiterr("cannot handle separate Luv planes"); |
263 |
TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, |
264 |
SGILOGDATAFMT_FLOAT); |
265 |
cvts.tf = Luv2Color; |
266 |
break; |
267 |
case PHOTOMETRIC_LOGL: |
268 |
SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); |
269 |
cvts.pconf = PLANARCONFIG_CONTIG; |
270 |
271 |
272 |
cvts.tf = L2Color; |
273 |
break; |
274 |
case PHOTOMETRIC_YCBCR: |
275 |
if (cvts.comp == COMPRESSION_JPEG && |
276 |
cvts.pconf == PLANARCONFIG_CONTIG) { |
277 |
TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE, |
278 |
JPEGCOLORMODE_RGB); |
279 |
cvts.phot = PHOTOMETRIC_RGB; |
280 |
} else |
281 |
quiterr("unsupported photometric type"); |
282 |
/* fall through */ |
283 |
case PHOTOMETRIC_RGB: |
284 |
SET(C_GAMMA); |
285 |
setcolrgam(cvts.gamcor); |
286 |
if (CHK(C_XYZE)) { |
287 |
comprgb2xyzWBmat(cvts.cmat, |
288 |
CHK(C_PRIM) ? cvts.prims : stdprims); |
289 |
SET(C_CXFM); |
290 |
291 |
if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || |
292 |
hi != 3) |
293 |
quiterr("unsupported samples per pixel for RGB"); |
294 |
if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi)) |
295 |
hi = -1; |
296 |
switch (hi) { |
297 |
case 8: |
298 |
cvts.tf = RGB2Colr; |
299 |
break; |
300 |
case 16: |
301 |
cvts.tf = RRGGBB2Color; |
302 |
SET(C_RFLT|C_TWRD); |
303 |
break; |
304 |
case 32: |
305 |
cvts.tf = RfGfBf2Color; |
306 |
307 |
break; |
308 |
default: |
309 |
quiterr("unsupported bits per sample for RGB"); |
310 |
311 |
break; |
312 |
case PHOTOMETRIC_MINISBLACK: |
313 |
SET(C_GRY|C_GAMMA); |
314 |
315 |
316 |
317 |
hi != 1) |
318 |
quiterr("unsupported samples per pixel for greyscale"); |
319 |
320 |
hi = -1; |
321 |
switch (hi) { |
322 |
case 8: |
323 |
cvts.tf = Gry2Colr; |
324 |
break; |
325 |
case 16: |
326 |
cvts.tf = GGry2Color; |
327 |
328 |
break; |
329 |
case 32: |
330 |
cvts.tf = Gryf2Color; |
331 |
332 |
break; |
333 |
default: |
334 |
quiterr("unsupported bits per sample for Gray"); |
335 |
336 |
break; |
337 |
default: |
338 |
339 |
break; |
340 |
341 |
342 |
if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || |
343 |
!TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) |
344 |
quiterr("unknown input image resolution"); |
345 |
346 |
if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) |
347 |
cvts.stonits = 1.; |
348 |
349 |
if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp)) |
350 |
cvts.capdate[0] = '\0'; |
351 |
else { |
352 |
strncpy(cvts.capdate, cp, 19); |
353 |
cvts.capdate[19] = '\0'; |
354 |
355 |
if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp)) |
356 |
cvts.owner[0] = '\0'; |
357 |
else { |
358 |
strncpy(cvts.owner, cp, sizeof(cvts.owner)); |
359 |
cvts.owner[sizeof(cvts.owner)-1] = '\0'; |
360 |
361 |
/* add to Radiance header */ |
362 |
if (cvts.pixrat < .99 || cvts.pixrat > 1.01) |
363 |
fputaspect(cvts.pixrat, cvts.rfp); |
364 |
365 |
fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); |
366 |
fputformat(CIEFMT, cvts.rfp); |
367 |
} else { |
368 |
if (CHK(C_PRIM)) |
369 |
fputprims(cvts.prims, cvts.rfp); |
370 |
fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, |
371 |
cvts.rfp); |
372 |
fputformat(COLRFMT, cvts.rfp); |
373 |
374 |
if (cvts.capdate[0]) |
375 |
fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate); |
376 |
if (cvts.owner[0]) |
377 |
fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner); |
378 |
379 |
allocbufs(); /* allocate scanline buffers */ |
380 |
381 |
382 |
383 |
tiff2ra(ac, av) /* convert TIFF image to Radiance picture */ |
384 |
int ac; |
385 |
char *av[]; |
386 |
387 |
int32 y; |
388 |
/* open TIFF input */ |
389 |
if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL) |
390 |
quiterr("cannot open TIFF input"); |
391 |
/* open Radiance output */ |
392 |
if (av[ac+1] == NULL || !strcmp(av[ac+1], "-")) |
393 |
cvts.rfp = stdout; |
394 |
else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) |
395 |
quiterr("cannot open Radiance output picture"); |
396 |
/* start output header */ |
397 |
newheader("RADIANCE", cvts.rfp); |
398 |
printargs(ac, av, cvts.rfp); |
399 |
400 |
initfromtif(); /* initialize conversion */ |
401 |
402 |
fputc('\n', cvts.rfp); /* finish Radiance header */ |
403 |
fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp); |
404 |
405 |
for (y = 0; y < cvts.ymax; y++) /* convert image */ |
406 |
(*cvts.tf)(y); |
407 |
/* clean up */ |
408 |
fclose(cvts.rfp); |
409 |
TIFFClose(cvts.tif); |
410 |
411 |
412 |
413 |
int |
414 |
headline(s) /* process Radiance input header line */ |
415 |
char *s; |
416 |
417 |
static int tmstrlen = 0; |
418 |
static int ownstrlen = 0; |
419 |
char fmt[32]; |
420 |
421 |
if (!tmstrlen) |
422 |
tmstrlen = strlen(TMSTR); |
423 |
if (!ownstrlen) |
424 |
ownstrlen = strlen(OWNSTR); |
425 |
if (formatval(fmt, s)) { |
426 |
if (!strcmp(fmt, COLRFMT)) |
427 |
CLR(C_XYZE); |
428 |
else if (!strcmp(fmt, CIEFMT)) |
429 |
SET(C_XYZE); |
430 |
else |
431 |
quiterr("unrecognized input picture format"); |
432 |
return(1); |
433 |
434 |
if (isexpos(s)) { |
435 |
cvts.stonits /= exposval(s); |
436 |
return(1); |
437 |
438 |
if (isaspect(s)) { |
439 |
cvts.pixrat *= aspectval(s); |
440 |
return(1); |
441 |
442 |
if (isprims(s)) { |
443 |
primsval(cvts.prims, s); |
444 |
SET(C_PRIM); |
445 |
return(1); |
446 |
447 |
if (isdate(s)) { |
448 |
if (s[tmstrlen] == ' ') |
449 |
strncpy(cvts.capdate, s+tmstrlen+1, 19); |
450 |
else |
451 |
strncpy(cvts.capdate, s+tmstrlen, 19); |
452 |
453 |
return(1); |
454 |
455 |
if (!strncmp(s, OWNSTR, ownstrlen)) { |
456 |
register char *cp = s + ownstrlen; |
457 |
458 |
while (isspace(*cp)) |
459 |
++cp; |
460 |
461 |
462 |
for (cp = cvts.owner; *cp; cp++) |
463 |
464 |
while (cp > cvts.owner && isspace(cp[-1])) |
465 |
*--cp = '\0'; |
466 |
return(1); |
467 |
468 |
return(0); |
469 |
470 |
471 |
472 |
initfromrad() /* initialize input from a Radiance picture */ |
473 |
474 |
int i1, i2, po; |
475 |
/* read Radiance header */ |
476 |
CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); |
477 |
478 |
479 |
480 |
cvts.pixrat = 1.; |
481 |
482 |
getheader(cvts.rfp, headline, NULL); |
483 |
if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) |
484 |
quiterr("bad Radiance picture"); |
485 |
cvts.xmax = i1; cvts.ymax = i2; |
486 |
for (i1 = 0; i1 < 8; i1++) /* interpret orientation */ |
487 |
if (ortab[i1] == po) { |
488 |
cvts.orient = i1 + 1; |
489 |
break; |
490 |
491 |
if (i1 >= 8) |
492 |
quiterr("internal error 1 in initfromrad"); |
493 |
if (!(po & YMAJOR)) |
494 |
cvts.pixrat = 1./cvts.pixrat; |
495 |
if (!CHK(C_XYZE)) |
496 |
cvts.stonits *= WHTEFFICACY; |
497 |
/* set up conversion */ |
498 |
TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); |
499 |
TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot); |
500 |
501 |
502 |
503 |
504 |
CLR(C_GRY|C_TWRD); |
505 |
506 |
507 |
508 |
SET(C_CXFM); |
509 |
510 |
if (cvts.comp != COMPRESSION_SGILOG && |
511 |
cvts.comp != COMPRESSION_SGILOG24) |
512 |
quiterr("internal error 2 in initfromrad"); |
513 |
514 |
515 |
cvts.tf = Color2Luv; |
516 |
break; |
517 |
518 |
SET(C_GRY|C_RFLT|C_TFLT); |
519 |
CLR(C_TWRD); |
520 |
if (cvts.comp != COMPRESSION_SGILOG) |
521 |
quiterr("internal error 3 in initfromrad"); |
522 |
523 |
524 |
cvts.tf = Color2L; |
525 |
break; |
526 |
527 |
SET(C_GAMMA|C_GAMUT); |
528 |
CLR(C_GRY); |
529 |
530 |
531 |
compxyz2rgbWBmat(cvts.cmat, |
532 |
533 |
SET(C_CXFM); |
534 |
535 |
if (CHK(C_PRIM)) { |
536 |
TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, |
537 |
(float *)cvts.prims); |
538 |
TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, |
539 |
(float *)cvts.prims[WHT]); |
540 |
541 |
if (CHK(C_TWRD)) { |
542 |
cvts.tf = Color2RRGGBB; |
543 |
SET(C_RFLT); |
544 |
} else if (CHK(C_TFLT)) { |
545 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, |
546 |
SAMPLEFORMAT_IEEEFP); |
547 |
cvts.tf = Color2RfGfBf; |
548 |
SET(C_RFLT); |
549 |
} else |
550 |
cvts.tf = Colr2RGB; |
551 |
break; |
552 |
553 |
SET(C_GRY|C_GAMMA|C_GAMUT); |
554 |
555 |
556 |
cvts.tf = Color2GGry; |
557 |
SET(C_RFLT); |
558 |
559 |
560 |
561 |
cvts.tf = Color2Gryf; |
562 |
SET(C_RFLT); |
563 |
} else |
564 |
cvts.tf = Colr2Gry; |
565 |
break; |
566 |
default: |
567 |
quiterr("internal error 4 in initfromrad"); |
568 |
break; |
569 |
570 |
/* set other TIFF fields */ |
571 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); |
572 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); |
573 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); |
574 |
TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, |
575 |
CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8); |
576 |
TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); |
577 |
TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); |
578 |
TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); |
579 |
TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2); |
580 |
TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); |
581 |
TIFFSetField(cvts.tif, TIFFTAG_STONITS, |
582 |
cvts.stonits/pow(2.,(double)cvts.bradj)); |
583 |
584 |
TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate); |
585 |
586 |
TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner); |
587 |
if (cvts.comp == COMPRESSION_NONE) |
588 |
i1 = TIFFScanlineSize(cvts.tif); |
589 |
else |
590 |
i1 = 3*cvts.xmax; /* conservative guess */ |
591 |
i2 = 8192/i1; /* compute good strip size */ |
592 |
if (i2 < 1) i2 = 1; |
593 |
TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); |
594 |
595 |
596 |
597 |
598 |
599 |
ra2tiff(ac, av) /* convert Radiance picture to TIFF image */ |
600 |
int ac; |
601 |
char *av[]; |
602 |
603 |
uint32 y; |
604 |
/* open Radiance file */ |
605 |
if (!strcmp(av[ac], "-")) |
606 |
cvts.rfp = stdin; |
607 |
else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) |
608 |
quiterr("cannot open Radiance input picture"); |
609 |
/* open TIFF file */ |
610 |
if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) |
611 |
quiterr("cannot open TIFF output"); |
612 |
613 |
initfromrad(); /* initialize conversion */ |
614 |
615 |
616 |
(*cvts.tf)(y); |
617 |
/* clean up */ |
618 |
619 |
fclose(cvts.rfp); |
620 |
621 |
622 |
623 |
void |
624 |
Luv2Color(y) /* read/convert/write Luv->COLOR scanline */ |
625 |
uint32 y; |
626 |
627 |
register int x; |
628 |
629 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) |
630 |
quiterr("internal error 1 in Luv2Color"); |
631 |
632 |
if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
633 |
quiterr("error reading TIFF input"); |
634 |
/* also works for float RGB */ |
635 |
for (x = cvts.xmax; x--; ) { |
636 |
setcolor(cvts.r.colors[x], |
637 |
cvts.t.fp[3*x], |
638 |
cvts.t.fp[3*x + 1], |
639 |
cvts.t.fp[3*x + 2]); |
640 |
if (CHK(C_CXFM)) |
641 |
colortrans(cvts.r.colors[x], cvts.cmat, |
642 |
cvts.r.colors[x]); |
643 |
if (CHK(C_GAMUT)) |
644 |
clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], |
645 |
CGAMUT_LOWER, cblack, cwhite); |
646 |
647 |
if (cvts.bradj) { |
648 |
double m = pow(2.,(double)cvts.bradj); |
649 |
for (x = cvts.xmax; x--; ) |
650 |
scalecolor(cvts.r.colors[x], m); |
651 |
652 |
653 |
if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
654 |
quiterr("error writing Radiance picture"); |
655 |
656 |
657 |
658 |
void |
659 |
RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */ |
660 |
uint32 y; |
661 |
662 |
int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; |
663 |
register double d; |
664 |
register int x; |
665 |
666 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT)) |
667 |
quiterr("internal error 1 in RRGGBB2Color"); |
668 |
669 |
670 |
671 |
672 |
673 |
d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16)); |
674 |
if (dogamma) d = pow(d, cvts.gamcor); |
675 |
colval(cvts.r.colors[x],RED) = d; |
676 |
d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16)); |
677 |
678 |
colval(cvts.r.colors[x],GRN) = d; |
679 |
d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16)); |
680 |
681 |
colval(cvts.r.colors[x],BLU) = d; |
682 |
if (CHK(C_CXFM)) |
683 |
684 |
685 |
if (CHK(C_GAMUT)) |
686 |
687 |
688 |
689 |
if (cvts.bradj) { |
690 |
d = pow(2.,(double)cvts.bradj); |
691 |
692 |
scalecolor(cvts.r.colors[x], d); |
693 |
694 |
695 |
696 |
697 |
698 |
699 |
700 |
void |
701 |
L2Color(y) /* read/convert/write Lfloat->COLOR scanline */ |
702 |
uint32 y; |
703 |
704 |
float m = pow(2., (double)cvts.bradj); |
705 |
register int x; |
706 |
707 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
708 |
quiterr("internal error 1 in L2Color"); |
709 |
710 |
711 |
712 |
/* also works for float greyscale */ |
713 |
714 |
register float f = cvts.t.fp[x]; |
715 |
if (cvts.bradj) f *= m; |
716 |
setcolor(cvts.r.colors[x], f, f, f); |
717 |
718 |
719 |
720 |
721 |
722 |
723 |
void |
724 |
RGB2Colr(y) /* read/convert/write RGB->COLR scanline */ |
725 |
uint32 y; |
726 |
727 |
COLOR ctmp; |
728 |
register int x; |
729 |
730 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY)) |
731 |
quiterr("internal error 1 in RGB2Colr"); |
732 |
733 |
if (cvts.pconf == PLANARCONFIG_CONTIG) { |
734 |
735 |
goto readerr; |
736 |
737 |
cvts.r.colrs[x][RED] = cvts.t.bp[3*x]; |
738 |
cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1]; |
739 |
cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2]; |
740 |
741 |
} else { |
742 |
743 |
goto readerr; |
744 |
if (TIFFReadScanline(cvts.tif, |
745 |
(tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) |
746 |
goto readerr; |
747 |
748 |
(tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) |
749 |
goto readerr; |
750 |
751 |
cvts.r.colrs[x][RED] = cvts.t.bp[x]; |
752 |
cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x]; |
753 |
cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x]; |
754 |
755 |
756 |
757 |
gambs_colrs(cvts.r.colrs, cvts.xmax); |
758 |
if (CHK(C_CXFM)) |
759 |
760 |
colr_color(ctmp, cvts.r.colrs[x]); |
761 |
colortrans(ctmp, cvts.cmat, ctmp); |
762 |
if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */ |
763 |
clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER, |
764 |
cblack, cwhite); |
765 |
setcolr(cvts.r.colrs[x], colval(ctmp,RED), |
766 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
767 |
768 |
if (cvts.bradj) |
769 |
shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj); |
770 |
771 |
if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
772 |
773 |
return; |
774 |
readerr: |
775 |
776 |
777 |
778 |
779 |
void |
780 |
Gry2Colr(y) /* read/convert/write G8->COLR scanline */ |
781 |
uint32 y; |
782 |
783 |
register int x; |
784 |
785 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) |
786 |
quiterr("internal error 1 in Gry2Colr"); |
787 |
788 |
789 |
790 |
791 |
792 |
cvts.r.colrs[x][RED] = |
793 |
cvts.r.colrs[x][GRN] = |
794 |
cvts.r.colrs[x][BLU] = cvts.t.bp[x]; |
795 |
796 |
797 |
if (cvts.bradj) |
798 |
799 |
800 |
801 |
802 |
803 |
804 |
805 |
void |
806 |
GGry2Color(y) /* read/convert/write G16->COLOR scanline */ |
807 |
uint32 y; |
808 |
809 |
810 |
double m; |
811 |
812 |
register int x; |
813 |
814 |
if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD)) |
815 |
quiterr("internal error 1 in GGry2Color"); |
816 |
817 |
818 |
819 |
820 |
if (cvts.bradj) |
821 |
822 |
823 |
d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16)); |
824 |
825 |
if (cvts.bradj) d *= m; |
826 |
colval(cvts.r.colors[x],RED) = |
827 |
colval(cvts.r.colors[x],GRN) = |
828 |
829 |
830 |
831 |
832 |
833 |
834 |
835 |
void |
836 |
Color2GGry(y) /* read/convert/write COLOR->G16 scanline */ |
837 |
uint32 y; |
838 |
839 |
840 |
float m = pow(2.,(double)cvts.bradj); |
841 |
register int x; |
842 |
843 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY)) |
844 |
quiterr("internal error 1 in Color2GGry"); |
845 |
846 |
if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
847 |
quiterr("error reading Radiance picture"); |
848 |
849 |
850 |
register float f = m*( CHK(C_XYZE) ? |
851 |
colval(cvts.r.colors[x],CIEY) |
852 |
: bright(cvts.r.colors[x]) ); |
853 |
if (f <= 0) |
854 |
cvts.t.wp[x] = 0; |
855 |
else if (f >= 1) |
856 |
cvts.t.wp[x] = 0xffff; |
857 |
else if (dogamma) |
858 |
cvts.t.wp[x] = (int)((float)(1L<<16) * |
859 |
pow(f, 1./cvts.gamcor)); |
860 |
else |
861 |
cvts.t.wp[x] = (int)((float)(1L<<16) * f); |
862 |
863 |
864 |
if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
865 |
quiterr("error writing TIFF output"); |
866 |
867 |
868 |
869 |
void |
870 |
Color2L(y) /* read/convert/write COLOR->Lfloat scanline */ |
871 |
uint32 y; |
872 |
873 |
874 |
register int x; |
875 |
876 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
877 |
quiterr("internal error 1 in Color2L"); |
878 |
879 |
880 |
881 |
882 |
883 |
cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) |
884 |
885 |
886 |
887 |
888 |
889 |
890 |
891 |
void |
892 |
Color2Luv(y) /* read/convert/write COLOR->Luv scanline */ |
893 |
uint32 y; |
894 |
895 |
register int x; |
896 |
897 |
898 |
quiterr("internal error 1 in Color2Luv"); |
899 |
900 |
901 |
902 |
903 |
if (CHK(C_CXFM)) |
904 |
905 |
906 |
907 |
if (cvts.bradj) { |
908 |
909 |
910 |
911 |
912 |
913 |
914 |
cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX); |
915 |
cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY); |
916 |
cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ); |
917 |
918 |
919 |
920 |
921 |
922 |
923 |
924 |
void |
925 |
Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */ |
926 |
uint32 y; |
927 |
928 |
929 |
930 |
register int x, i; |
931 |
932 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD)) |
933 |
quiterr("internal error 1 in Color2RRGGBB"); |
934 |
935 |
936 |
937 |
938 |
939 |
for (i = 3; i--; ) { |
940 |
register float f = m*colval(cvts.r.colors[x],i); |
941 |
if (f <= 0) |
942 |
cvts.t.wp[3*x + i] = 0; |
943 |
else if (f >= 1) |
944 |
cvts.t.wp[3*x + i] = 0xffff; |
945 |
else if (dogamma) |
946 |
cvts.t.wp[3*x + i] = (int)((float)(1L<<16) * |
947 |
948 |
else |
949 |
cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f); |
950 |
951 |
952 |
953 |
954 |
955 |
956 |
957 |
void |
958 |
Colr2Gry(y) /* read/convert/write COLR->RGB scanline */ |
959 |
uint32 y; |
960 |
961 |
register int x; |
962 |
963 |
964 |
quiterr("internal error 1 in Colr2Gry"); |
965 |
966 |
if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
967 |
968 |
969 |
if (cvts.bradj) |
970 |
971 |
972 |
colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]); |
973 |
colrs_gambs(cvts.r.colrs, cvts.xmax); |
974 |
975 |
976 |
cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY); |
977 |
978 |
979 |
980 |
981 |
982 |
983 |
void |
984 |
Colr2RGB(y) /* read/convert/write COLR->RGB scanline */ |
985 |
uint32 y; |
986 |
987 |
COLOR ctmp; |
988 |
register int x; |
989 |
990 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY)) |
991 |
quiterr("internal error 1 in Colr2RGB"); |
992 |
993 |
994 |
995 |
996 |
if (cvts.bradj) |
997 |
998 |
if (CHK(C_CXFM)) |
999 |
1000 |
1001 |
1002 |
if (CHK(C_GAMUT)) |
1003 |
clipgamut(ctmp, bright(ctmp), CGAMUT, |
1004 |
cblack, cwhite); |
1005 |
1006 |
1007 |
1008 |
1009 |
1010 |
1011 |
cvts.t.bp[3*x] = cvts.r.colrs[x][RED]; |
1012 |
cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN]; |
1013 |
cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU]; |
1014 |
1015 |
1016 |
1017 |
1018 |
