--- ray/src/px/ra_tiff.c 2005/06/07 16:54:23 2.31 +++ ray/src/px/ra_tiff.c 2024/10/04 19:15:19 2.38 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_tiff.c,v 2.31 2005/06/07 16:54:23 greg Exp $"; +static const char RCSid[] = "$Id: ra_tiff.c,v 2.38 2024/10/04 19:15:19 greg Exp $"; #endif /* * Program to convert between RADIANCE and TIFF files. @@ -7,12 +7,11 @@ static const char RCSid[] = "$Id: ra_tiff.c,v 2.31 200 * Added white-balance adjustment 10/01 (GW). */ -#include #include #include -#include -#include +#include "rtio.h" +#include "platform.h" #include "tiffio.h" #include "color.h" #include "resolu.h" @@ -25,14 +24,15 @@ static const char RCSid[] = "$Id: ra_tiff.c,v 2.31 200 #define C_GAMMA 0x4 /* needs gamma correction */ #define C_GRY 0x8 /* TIFF is greyscale */ #define C_XYZE 0x10 /* Radiance is XYZE */ -#define C_RFLT 0x20 /* Radiance data is float */ -#define C_TFLT 0x40 /* TIFF data is float */ -#define C_TWRD 0x80 /* TIFF data is 16-bit */ -#define C_PRIM 0x100 /* has assigned primaries */ +#define C_SPEC 0x20 /* Radiance is spectral */ +#define C_RFLT 0x40 /* Radiance data is float */ +#define C_TFLT 0x80 /* TIFF data is float */ +#define C_TWRD 0x100 /* TIFF data is 16-bit */ +#define C_PRIM 0x200 /* has assigned primaries */ typedef void colcvf_t(uint32 y); -struct { +struct CONVST { uint16 flags; /* conversion flags (defined above) */ char capdate[20]; /* capture date/time */ char owner[256]; /* content owner */ @@ -44,6 +44,8 @@ struct { uint16 orient; /* visual orientation (TIFF spec.) */ double stonits; /* input conversion to nits */ float pixrat; /* pixel aspect ratio */ + int ncc; /* # color components for spectral */ + float wpt[4]; /* wavelength partitions */ FILE *rfp; /* Radiance stream pointer */ TIFF *tif; /* TIFF pointer */ uint32 xmax, ymax; /* image dimensions */ @@ -52,18 +54,18 @@ struct { union { COLR *colrs; /* 4-byte ???E pointer */ COLOR *colors; /* float array pointer */ - char *p; /* generic pointer */ + void *p; /* generic pointer */ } r; /* Radiance scanline */ union { uint8 *bp; /* byte pointer */ uint16 *wp; /* word pointer */ float *fp; /* float pointer */ - char *p; /* generic pointer */ + void *p; /* generic pointer */ } t; /* TIFF scanline */ colcvf_t *tf; /* translation procedure */ } cvts = { /* conversion structure */ 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB, - PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., + PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., 3, }; #define CHK(f) (cvts.flags & (f)) @@ -82,9 +84,9 @@ static void initfromtif(void); static void tiff2ra(int ac, char *av[]); static void initfromrad(void); static void ra2tiff(int ac, char *av[]); +static void ReadRadScan(struct CONVST *cvp); - #define RfGfBf2Color Luv2Color #define Gryf2Color L2Color #define Color2Gryf Color2L @@ -191,10 +193,10 @@ doneopts: exit(0); userr: fprintf(stderr, - "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", + "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n", progname); fprintf(stderr, - " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", + " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n", progname); exit(1); } @@ -222,8 +224,8 @@ allocbufs(void) /* allocate scanline buffers */ tsiz = (CHK(C_TFLT) ? sizeof(float) : CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) * (CHK(C_GRY) ? 1 : 3); - cvts.r.p = (char *)malloc(rsiz*cvts.xmax); - cvts.t.p = (char *)malloc(tsiz*cvts.xmax); + cvts.r.p = malloc(rsiz*cvts.xmax); + cvts.t.p = malloc(tsiz*cvts.xmax); if ((cvts.r.p == NULL) | (cvts.t.p == NULL)) quiterr("no memory to allocate scanline buffers"); } @@ -236,8 +238,6 @@ initfromtif(void) /* initialize conversion from TIFF char *cp; float *fa, f1, f2; - CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM); - TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { @@ -362,7 +362,7 @@ initfromtif(void) /* initialize conversion from TIFF quiterr("unknown input image resolution"); if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) - cvts.stonits = 1.; + cvts.stonits = -1.; if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp)) cvts.capdate[0] = '\0'; @@ -380,13 +380,15 @@ initfromtif(void) /* initialize conversion from TIFF if (cvts.pixrat < .99 || cvts.pixrat > 1.01) fputaspect(cvts.pixrat, cvts.rfp); if (CHK(C_XYZE)) { - fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); + if (cvts.stonits > .0) + fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); fputformat(CIEFMT, cvts.rfp); } else { if (CHK(C_PRIM)) fputprims(cvts.prims, cvts.rfp); - fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, - cvts.rfp); + if (cvts.stonits > .0) + fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, + cvts.rfp); fputformat(COLRFMT, cvts.rfp); } if (cvts.capdate[0]) @@ -413,6 +415,7 @@ tiff2ra( /* convert TIFF image to Radiance picture */ cvts.rfp = stdout; else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) quiterr("cannot open Radiance output picture"); + SET_FILE_BINARY(cvts.rfp); /* start output header */ newheader("RADIANCE", cvts.rfp); printargs(ac, av, cvts.rfp); @@ -438,55 +441,63 @@ headline( /* process Radiance input header line */ { static int tmstrlen = 0; static int ownstrlen = 0; - char fmt[32]; + struct CONVST *cvp = (struct CONVST *)p; + char fmt[MAXFMTLEN]; - if (!tmstrlen) + if (!tmstrlen) { tmstrlen = strlen(TMSTR); - if (!ownstrlen) ownstrlen = strlen(OWNSTR); + } if (formatval(fmt, s)) { - if (!strcmp(fmt, COLRFMT)) - CLR(C_XYZE); - else if (!strcmp(fmt, CIEFMT)) + CLR(C_XYZE|C_SPEC); + if (!strcmp(fmt, CIEFMT)) SET(C_XYZE); - else - quiterr("unrecognized input picture format"); + else if (!strcmp(fmt, SPECFMT)) + SET(C_SPEC); + else if (strcmp(fmt, COLRFMT)) + return(-1); return(1); } if (isexpos(s)) { - cvts.stonits /= exposval(s); + cvp->stonits /= exposval(s); return(1); } if (isaspect(s)) { - cvts.pixrat *= aspectval(s); + cvp->pixrat *= aspectval(s); return(1); } if (isprims(s)) { - primsval(cvts.prims, s); + primsval(cvp->prims, s); SET(C_PRIM); return(1); } if (isdate(s)) { if (s[tmstrlen] == ' ') - strncpy(cvts.capdate, s+tmstrlen+1, 19); + strncpy(cvp->capdate, s+tmstrlen+1, 19); else - strncpy(cvts.capdate, s+tmstrlen, 19); - cvts.capdate[19] = '\0'; + strncpy(cvp->capdate, s+tmstrlen, 19); + cvp->capdate[19] = '\0'; return(1); } if (!strncmp(s, OWNSTR, ownstrlen)) { - register char *cp = s + ownstrlen; + char *cp = s + ownstrlen; while (isspace(*cp)) ++cp; - strncpy(cvts.owner, cp, sizeof(cvts.owner)); - cvts.owner[sizeof(cvts.owner)-1] = '\0'; - for (cp = cvts.owner; *cp; cp++) + strncpy(cvp->owner, cp, sizeof(cvp->owner)); + cvp->owner[sizeof(cvp->owner)-1] = '\0'; + for (cp = cvp->owner; *cp; cp++) ; - while (cp > cvts.owner && isspace(cp[-1])) + while (cp > cvp->owner && isspace(cp[-1])) *--cp = '\0'; return(1); } + if (isncomp(s)) { + cvp->ncc = ncompval(s); + return((3 <= cvp->ncc) & (cvp->ncc < MAXCSAMP) ? 1 : -1); + } + if (iswlsplit(s)) + return(wlsplitval(cvp->wpt, s) ? 1 : -1); return(0); } @@ -496,14 +507,9 @@ initfromrad(void) /* initialize input from a Radianc { int i1, i2, po; /* read Radiance header */ - CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); - cvts.capdate[0] = '\0'; - cvts.owner[0] = '\0'; - cvts.stonits = 1.; - cvts.pixrat = 1.; - cvts.pconf = PLANARCONFIG_CONTIG; - getheader(cvts.rfp, headline, NULL); - if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) + memcpy(cvts.wpt, WLPART, sizeof(cvts.wpt)); + if (getheader(cvts.rfp, headline, &cvts) < 0 || + (po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) quiterr("bad Radiance picture"); cvts.xmax = i1; cvts.ymax = i2; for (i1 = 0; i1 < 8; i1++) /* interpret orientation */ @@ -525,7 +531,7 @@ initfromrad(void) /* initialize input from a Radianc case PHOTOMETRIC_LOGLUV: SET(C_RFLT|C_TFLT); CLR(C_GRY|C_TWRD); - if (!CHK(C_XYZE)) { + if (!CHK(C_XYZE|C_SPEC)) { comprgb2xyzWBmat(cvts.cmat, CHK(C_PRIM) ? cvts.prims : stdprims); SET(C_CXFM); @@ -550,7 +556,7 @@ initfromrad(void) /* initialize input from a Radianc SET(C_GAMMA|C_GAMUT); CLR(C_GRY); setcolrgam(cvts.gamcor); - if (CHK(C_XYZE)) { + if (CHK(C_TWRD|C_TFLT) ? CHK(C_XYZE|C_SPEC) : CHK(C_XYZE)) { compxyz2rgbWBmat(cvts.cmat, CHK(C_PRIM) ? cvts.prims : stdprims); SET(C_CXFM); @@ -632,6 +638,7 @@ ra2tiff( /* convert Radiance picture to TIFF image */ cvts.rfp = stdin; else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) quiterr("cannot open Radiance input picture"); + SET_FILE_BINARY(cvts.rfp); /* open TIFF file */ if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) quiterr("cannot open TIFF output"); @@ -647,11 +654,49 @@ ra2tiff( /* convert Radiance picture to TIFF image */ static void +ReadRadScan(struct CONVST *cvp) +{ + static struct CONVST *lastcvp = NULL; + static COLOR scomp[MAXCSAMP]; + + if (cvp->ncc > 3) { /* convert spectral pixels */ + SCOLR sclr; + SCOLOR scol; + COLOR xyz; + int x, n; + if (lastcvp != cvp) { + for (n = cvp->ncc; n--; ) + spec_cie(scomp[n], + cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*(n+1)/cvp->ncc, + cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*n/cvp->ncc); + lastcvp = cvp; + } + for (x = 0; x < cvp->xmax; x++) { + if (getbinary(sclr, cvp->ncc+1, 1, cvp->rfp) != 1) + goto readerr; + scolr2scolor(scol, sclr, cvp->ncc); + setcolor(cvp->r.colors[x], 0, 0, 0); + for (n = cvp->ncc; n--; ) { + copycolor(xyz, scomp[n]); + scalecolor(xyz, scol[n]); + addcolor(cvp->r.colors[x], xyz); + } + } + return; + } + if (freadscan(cvp->r.colors, cvp->xmax, cvp->rfp) >= 0) + return; +readerr: + quiterr("error reading Radiance picture"); +} + + +static void Luv2Color( /* read/convert/write Luv->COLOR scanline */ uint32 y ) { - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) quiterr("internal error 1 in Luv2Color"); @@ -691,8 +736,8 @@ RRGGBB2Color( /* read/convert/write RGB16->COLOR sca ) { int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01); - register double d; - register int x; + double d; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT)) quiterr("internal error 1 in RRGGBB2Color"); @@ -734,7 +779,7 @@ L2Color( /* read/convert/write Lfloat->COLOR scanlin ) { float m = pow(2., (double)cvts.bradj); - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) quiterr("internal error 1 in L2Color"); @@ -743,7 +788,7 @@ L2Color( /* read/convert/write Lfloat->COLOR scanlin quiterr("error reading TIFF input"); /* also works for float greyscale */ for (x = cvts.xmax; x--; ) { - register float f = cvts.t.fp[x]; + float f = cvts.t.fp[x]; if (cvts.bradj) f *= m; setcolor(cvts.r.colors[x], f, f, f); } @@ -758,7 +803,7 @@ RGB2Colr( /* read/convert/write RGB->COLR scanline * ) { COLOR ctmp; - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY)) quiterr("internal error 1 in RGB2Colr"); @@ -814,7 +859,7 @@ Gry2Colr( /* read/convert/write G8->COLR scanline */ uint32 y ) { - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) quiterr("internal error 1 in Gry2Colr"); @@ -843,8 +888,8 @@ GGry2Color( /* read/convert/write G16->COLOR scanlin { int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01); double m; - register double d; - register int x; + double d; + int x; if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD)) quiterr("internal error 1 in GGry2Color"); @@ -874,16 +919,15 @@ Color2GGry( /* read/convert/write COLOR->G16 scanlin { int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01); float m = pow(2.,(double)cvts.bradj); - register int x; + int x; if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY)) quiterr("internal error 1 in Color2GGry"); - if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) - quiterr("error reading Radiance picture"); + ReadRadScan(&cvts); for (x = cvts.xmax; x--; ) { - register float f = m*( CHK(C_XYZE) ? + float f = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) : bright(cvts.r.colors[x]) ); if (f <= 0) @@ -908,13 +952,12 @@ Color2L( /* read/convert/write COLOR->Lfloat scanlin ) { float m = pow(2.,(double)cvts.bradj); - register int x; + int x; if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) quiterr("internal error 1 in Color2L"); - if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) - quiterr("error reading Radiance picture"); + ReadRadScan(&cvts); for (x = cvts.xmax; x--; ) cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) @@ -930,13 +973,12 @@ Color2Luv( /* read/convert/write COLOR->Luv scanline uint32 y ) { - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) quiterr("internal error 1 in Color2Luv"); - if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) - quiterr("error reading Radiance picture"); + ReadRadScan(&cvts); if (CHK(C_CXFM)) for (x = cvts.xmax; x--; ) @@ -966,13 +1008,12 @@ Color2RRGGBB( /* read/convert/write COLOR->RGB16 sca { int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01); float m = pow(2.,(double)cvts.bradj); - register int x, i; + int x, i; if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD)) quiterr("internal error 1 in Color2RRGGBB"); - if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) - quiterr("error reading Radiance picture"); + ReadRadScan(&cvts); for (x = cvts.xmax; x--; ) { if (CHK(C_CXFM)) { @@ -983,7 +1024,7 @@ Color2RRGGBB( /* read/convert/write COLOR->RGB16 sca CGAMUT_LOWER, cblack, cwhite); } for (i = 3; i--; ) { - register float f = m*colval(cvts.r.colors[x],i); + float f = m*colval(cvts.r.colors[x],i); if (f <= 0) cvts.t.wp[3*x + i] = 0; else if (f >= 1) @@ -1006,12 +1047,13 @@ Colr2Gry( /* read/convert/write COLR->RGB scanline * uint32 y ) { - register int x; + int x; if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) quiterr("internal error 1 in Colr2Gry"); - if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) + if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp, + cvts.ncc, cvts.wpt) < 0) quiterr("error reading Radiance picture"); if (cvts.bradj) @@ -1034,12 +1076,13 @@ Colr2RGB( /* read/convert/write COLR->RGB scanline * ) { COLOR ctmp; - register int x; + int x; if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY)) quiterr("internal error 1 in Colr2RGB"); - if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) + if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp, + cvts.ncc, cvts.wpt) < 0) quiterr("error reading Radiance picture"); if (cvts.bradj)
