root/radiance/ray/src/px/ra_tiff.c
Revision: 2.36
Committed: Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.36 static const char RCSid[] = "$Id: ra_tiff.c,v 2.35 2018/08/02 18:33:47 greg Exp $";
3 greg 1.1 #endif
4     /*
5 gregl 2.9 * Program to convert between RADIANCE and TIFF files.
6 greg 2.20 * Added LogLuv encodings 7/97 (GWL).
7     * Added white-balance adjustment 10/01 (GW).
8 greg 1.1 */
9
10 greg 2.3 #include <math.h>
11 greg 2.22 #include <ctype.h>
12 schorsch 2.27
13 greg 2.36 #include "rtio.h"
14 greg 2.34 #include "platform.h"
15 greg 1.1 #include "tiffio.h"
16     #include "color.h"
17 greg 1.6 #include "resolu.h"
18
19 greg 2.8 #define GAMCOR 2.2 /* default gamma */
20
21 gregl 2.9 /* conversion flags */
22     #define C_CXFM 0x1 /* needs color transformation */
23     #define C_GAMUT 0x2 /* needs gamut mapping */
24     #define C_GAMMA 0x4 /* needs gamma correction */
25     #define C_GRY 0x8 /* TIFF is greyscale */
26     #define C_XYZE 0x10 /* Radiance is XYZE */
27     #define C_RFLT 0x20 /* Radiance data is float */
28     #define C_TFLT 0x40 /* TIFF data is float */
29 gwlarson 2.19 #define C_TWRD 0x80 /* TIFF data is 16-bit */
30     #define C_PRIM 0x100 /* has assigned primaries */
31 greg 1.1
32 schorsch 2.28 typedef void colcvf_t(uint32 y);
33
34 gregl 2.9 struct {
35     uint16 flags; /* conversion flags (defined above) */
36 greg 2.22 char capdate[20]; /* capture date/time */
37     char owner[256]; /* content owner */
38 gregl 2.9 uint16 comp; /* TIFF compression type */
39 gregl 2.10 uint16 phot; /* TIFF photometric type */
40 gregl 2.9 uint16 pconf; /* TIFF planar configuration */
41     float gamcor; /* gamma correction value */
42     short bradj; /* Radiance exposure adjustment (stops) */
43     uint16 orient; /* visual orientation (TIFF spec.) */
44 gregl 2.11 double stonits; /* input conversion to nits */
45 gregl 2.9 float pixrat; /* pixel aspect ratio */
46     FILE *rfp; /* Radiance stream pointer */
47     TIFF *tif; /* TIFF pointer */
48     uint32 xmax, ymax; /* image dimensions */
49     COLORMAT cmat; /* color transformation matrix */
50     RGBPRIMS prims; /* RGB primaries */
51     union {
52     COLR *colrs; /* 4-byte ???E pointer */
53     COLOR *colors; /* float array pointer */
54     char *p; /* generic pointer */
55     } r; /* Radiance scanline */
56     union {
57     uint8 *bp; /* byte pointer */
58 gwlarson 2.18 uint16 *wp; /* word pointer */
59 gregl 2.9 float *fp; /* float pointer */
60     char *p; /* generic pointer */
61     } t; /* TIFF scanline */
62 schorsch 2.28 colcvf_t *tf; /* translation procedure */
63 gregl 2.9 } cvts = { /* conversion structure */
64 greg 2.22 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
65 gregl 2.10 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
66 gregl 2.9 };
67 greg 1.4
68 gregl 2.9 #define CHK(f) (cvts.flags & (f))
69     #define SET(f) (cvts.flags |= (f))
70     #define CLR(f) (cvts.flags &= ~(f))
71     #define TGL(f) (cvts.flags ^= (f))
72 greg 1.5
73 schorsch 2.28 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
74     static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
75     static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
76
77     static gethfunc headline;
78     static void quiterr(char *err);
79     static void allocbufs(void);
80     static void initfromtif(void);
81     static void tiff2ra(int ac, char *av[]);
82     static void initfromrad(void);
83     static void ra2tiff(int ac, char *av[]);
84
85
86 greg 2.21
87     #define RfGfBf2Color Luv2Color
88     #define Gryf2Color L2Color
89     #define Color2Gryf Color2L
90     #define Color2RfGfBf Color2Luv
91 greg 1.1
92 gregl 2.9 short ortab[8] = { /* orientation conversion table */
93     YMAJOR|YDECR,
94     YMAJOR|YDECR|XDECR,
95     YMAJOR|XDECR,
96     YMAJOR,
97     YDECR,
98     XDECR|YDECR,
99     XDECR,
100     0
101     };
102 greg 1.1
103 gregl 2.9 #define pixorder() ortab[cvts.orient-1]
104
105 greg 2.22 extern char TMSTR[]; /* "CAPDATE=" from header.c */
106     char OWNSTR[] = "OWNER=";
107
108 greg 1.1 char *progname;
109
110 schorsch 2.27
111 schorsch 2.28 int
112     main(int argc, char *argv[])
113 greg 1.1 {
114     int reverse = 0;
115     int i;
116
117     progname = argv[0];
118
119     for (i = 1; i < argc; i++)
120     if (argv[i][0] == '-')
121     switch (argv[i][1]) {
122 gregl 2.9 case 'g': /* gamma correction */
123     cvts.gamcor = atof(argv[++i]);
124 greg 1.1 break;
125 gregl 2.9 case 'x': /* XYZE Radiance output */
126     TGL(C_XYZE);
127 greg 1.4 break;
128 gregl 2.9 case 'z': /* LZW compressed output */
129     cvts.comp = COMPRESSION_LZW;
130 greg 1.5 break;
131 gregl 2.9 case 'L': /* LogLuv 32-bit output */
132 gregl 2.10 cvts.comp = COMPRESSION_SGILOG;
133     cvts.phot = PHOTOMETRIC_LOGLUV;
134 gregl 2.9 break;
135     case 'l': /* LogLuv 24-bit output */
136 gregl 2.10 cvts.comp = COMPRESSION_SGILOG24;
137     cvts.phot = PHOTOMETRIC_LOGLUV;
138 gregl 2.9 break;
139 greg 2.21 case 'w': /* 16-bit/primary output? */
140     TGL(C_TWRD);
141     break;
142     case 'f': /* IEEE float output? */
143     TGL(C_TFLT);
144     break;
145 gregl 2.9 case 'b': /* greyscale output? */
146     TGL(C_GRY);
147     break;
148     case 'e': /* exposure adjustment */
149 greg 1.1 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
150     goto userr;
151 gregl 2.9 cvts.bradj = atoi(argv[++i]);
152 greg 1.1 break;
153 gregl 2.9 case 'r': /* reverse conversion? */
154 greg 1.1 reverse = !reverse;
155     break;
156     case '\0':
157     goto doneopts;
158     default:
159     goto userr;
160     }
161     else
162     break;
163     doneopts:
164 gregl 2.9 if (reverse) {
165 greg 1.1
166     if (i != argc-2 && i != argc-1)
167     goto userr;
168 gregl 2.9
169     tiff2ra(i, argv);
170
171     } else {
172
173 greg 1.1 if (i != argc-2)
174     goto userr;
175 greg 2.21 /* consistency checks */
176 schorsch 2.25 if (CHK(C_GRY)) {
177 gregl 2.10 if (cvts.phot == PHOTOMETRIC_RGB)
178     cvts.phot = PHOTOMETRIC_MINISBLACK;
179     else {
180     cvts.phot = PHOTOMETRIC_LOGL;
181     cvts.comp = COMPRESSION_SGILOG;
182     }
183 schorsch 2.25 }
184 greg 2.21 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
185     goto userr;
186 gregl 2.9
187     ra2tiff(i, argv);
188     }
189
190 greg 1.1 exit(0);
191     userr:
192 greg 1.4 fprintf(stderr,
193 greg 2.33 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n",
194 greg 1.1 progname);
195 gregl 2.9 fprintf(stderr,
196 greg 2.33 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n",
197 gregl 2.9 progname);
198 greg 1.1 exit(1);
199     }
200
201
202 schorsch 2.28 static void
203     quiterr( /* print message and exit */
204     char *err
205     )
206 greg 1.1 {
207     if (err != NULL) {
208     fprintf(stderr, "%s: %s\n", progname, err);
209     exit(1);
210     }
211     exit(0);
212     }
213
214
215 schorsch 2.28 static void
216     allocbufs(void) /* allocate scanline buffers */
217 greg 1.1 {
218 gregl 2.9 int rsiz, tsiz;
219
220     rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
221 gwlarson 2.19 tsiz = (CHK(C_TFLT) ? sizeof(float) :
222     CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
223 gregl 2.9 (CHK(C_GRY) ? 1 : 3);
224     cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
225     cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
226 schorsch 2.26 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
227 gregl 2.9 quiterr("no memory to allocate scanline buffers");
228     }
229
230
231 schorsch 2.28 static void
232     initfromtif(void) /* initialize conversion from TIFF input */
233 gregl 2.9 {
234     uint16 hi;
235 greg 2.22 char *cp;
236 gregl 2.9 float *fa, f1, f2;
237
238 greg 2.21 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
239 gregl 2.9
240     TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
241
242     if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
243     cvts.prims[RED][CIEX] = fa[0];
244     cvts.prims[RED][CIEY] = fa[1];
245     cvts.prims[GRN][CIEX] = fa[2];
246     cvts.prims[GRN][CIEY] = fa[3];
247     cvts.prims[BLU][CIEX] = fa[4];
248     cvts.prims[BLU][CIEY] = fa[5];
249     cvts.prims[WHT][CIEX] = 1./3.;
250     cvts.prims[WHT][CIEY] = 1./3.;
251     if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
252     cvts.prims[WHT][CIEX] = fa[0];
253     cvts.prims[WHT][CIEY] = fa[1];
254     }
255     SET(C_PRIM);
256     }
257
258     if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
259     cvts.comp = COMPRESSION_NONE;
260
261     if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
262     TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
263     cvts.pixrat = f1/f2;
264
265 gregl 2.10 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
266 gregl 2.9
267 gregl 2.10 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
268     quiterr("TIFF has unspecified photometric type");
269
270     switch (cvts.phot) {
271     case PHOTOMETRIC_LOGLUV:
272 gregl 2.9 SET(C_RFLT|C_TFLT);
273     if (!CHK(C_XYZE)) {
274     cpcolormat(cvts.cmat, xyz2rgbmat);
275     SET(C_CXFM|C_GAMUT);
276 gregl 2.10 } else if (cvts.comp == COMPRESSION_SGILOG)
277 greg 2.29 SET(C_GAMUT); /* may be outside XYZ gamut */
278 gregl 2.9 if (cvts.pconf != PLANARCONFIG_CONTIG)
279     quiterr("cannot handle separate Luv planes");
280 gregl 2.10 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
281 gregl 2.12 SGILOGDATAFMT_FLOAT);
282 gregl 2.9 cvts.tf = Luv2Color;
283     break;
284 gregl 2.10 case PHOTOMETRIC_LOGL:
285     SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
286     cvts.pconf = PLANARCONFIG_CONTIG;
287     TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
288 gregl 2.12 SGILOGDATAFMT_FLOAT);
289 gregl 2.10 cvts.tf = L2Color;
290     break;
291 gregl 2.11 case PHOTOMETRIC_YCBCR:
292     if (cvts.comp == COMPRESSION_JPEG &&
293     cvts.pconf == PLANARCONFIG_CONTIG) {
294     TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
295     JPEGCOLORMODE_RGB);
296     cvts.phot = PHOTOMETRIC_RGB;
297     } else
298     quiterr("unsupported photometric type");
299     /* fall through */
300 gregl 2.10 case PHOTOMETRIC_RGB:
301 gwlarson 2.18 SET(C_GAMMA);
302 gregl 2.9 setcolrgam(cvts.gamcor);
303     if (CHK(C_XYZE)) {
304 greg 2.20 comprgb2xyzWBmat(cvts.cmat,
305 gregl 2.9 CHK(C_PRIM) ? cvts.prims : stdprims);
306     SET(C_CXFM);
307     }
308     if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
309 gregl 2.10 hi != 3)
310     quiterr("unsupported samples per pixel for RGB");
311 greg 2.21 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
312     hi = -1;
313     switch (hi) {
314     case 8:
315 gwlarson 2.18 cvts.tf = RGB2Colr;
316 greg 2.21 break;
317     case 16:
318 gwlarson 2.18 cvts.tf = RRGGBB2Color;
319 gwlarson 2.19 SET(C_RFLT|C_TWRD);
320 greg 2.21 break;
321     case 32:
322     cvts.tf = RfGfBf2Color;
323     SET(C_RFLT|C_TFLT);
324     break;
325     default:
326     quiterr("unsupported bits per sample for RGB");
327 gwlarson 2.18 }
328 gregl 2.9 break;
329 gregl 2.10 case PHOTOMETRIC_MINISBLACK:
330 gwlarson 2.18 SET(C_GRY|C_GAMMA);
331 gregl 2.15 setcolrgam(cvts.gamcor);
332 gregl 2.10 cvts.pconf = PLANARCONFIG_CONTIG;
333     if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
334     hi != 1)
335     quiterr("unsupported samples per pixel for greyscale");
336 greg 2.21 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
337     hi = -1;
338     switch (hi) {
339     case 8:
340 gwlarson 2.18 cvts.tf = Gry2Colr;
341 greg 2.21 break;
342     case 16:
343 gwlarson 2.18 cvts.tf = GGry2Color;
344 gwlarson 2.19 SET(C_RFLT|C_TWRD);
345 greg 2.21 break;
346     case 32:
347     cvts.tf = Gryf2Color;
348     SET(C_RFLT|C_TFLT);
349     break;
350     default:
351     quiterr("unsupported bits per sample for Gray");
352 gwlarson 2.18 }
353 gregl 2.10 break;
354     default:
355     quiterr("unsupported photometric type");
356     break;
357 gregl 2.9 }
358
359     if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
360     !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
361 greg 1.1 quiterr("unknown input image resolution");
362 gregl 2.9
363     if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
364 greg 2.32 cvts.stonits = -1.;
365 greg 2.22
366     if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
367     cvts.capdate[0] = '\0';
368     else {
369     strncpy(cvts.capdate, cp, 19);
370     cvts.capdate[19] = '\0';
371     }
372     if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
373     cvts.owner[0] = '\0';
374     else {
375     strncpy(cvts.owner, cp, sizeof(cvts.owner));
376     cvts.owner[sizeof(cvts.owner)-1] = '\0';
377     }
378 gregl 2.9 /* add to Radiance header */
379     if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
380     fputaspect(cvts.pixrat, cvts.rfp);
381     if (CHK(C_XYZE)) {
382 greg 2.32 if (cvts.stonits > .0)
383     fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
384 gregl 2.9 fputformat(CIEFMT, cvts.rfp);
385     } else {
386     if (CHK(C_PRIM))
387     fputprims(cvts.prims, cvts.rfp);
388 greg 2.32 if (cvts.stonits > .0)
389     fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
390     cvts.rfp);
391 gregl 2.9 fputformat(COLRFMT, cvts.rfp);
392     }
393 greg 2.22 if (cvts.capdate[0])
394     fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
395     if (cvts.owner[0])
396     fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
397 gregl 2.9
398     allocbufs(); /* allocate scanline buffers */
399     }
400
401
402 schorsch 2.28 static void
403     tiff2ra( /* convert TIFF image to Radiance picture */
404     int ac,
405     char *av[]
406     )
407 gregl 2.9 {
408     int32 y;
409     /* open TIFF input */
410     if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
411     quiterr("cannot open TIFF input");
412     /* open Radiance output */
413     if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
414     cvts.rfp = stdout;
415     else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
416     quiterr("cannot open Radiance output picture");
417 greg 2.34 SET_FILE_BINARY(cvts.rfp);
418 gregl 2.9 /* start output header */
419     newheader("RADIANCE", cvts.rfp);
420     printargs(ac, av, cvts.rfp);
421
422     initfromtif(); /* initialize conversion */
423
424     fputc('\n', cvts.rfp); /* finish Radiance header */
425     fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
426
427     for (y = 0; y < cvts.ymax; y++) /* convert image */
428     (*cvts.tf)(y);
429     /* clean up */
430     fclose(cvts.rfp);
431     TIFFClose(cvts.tif);
432     }
433
434
435 schorsch 2.27 static int
436     headline( /* process Radiance input header line */
437     char *s,
438     void *p
439     )
440 gregl 2.9 {
441 greg 2.22 static int tmstrlen = 0;
442     static int ownstrlen = 0;
443 greg 2.35 char fmt[MAXFMTLEN];
444 gregl 2.9
445 greg 2.22 if (!tmstrlen)
446     tmstrlen = strlen(TMSTR);
447     if (!ownstrlen)
448     ownstrlen = strlen(OWNSTR);
449 gregl 2.9 if (formatval(fmt, s)) {
450     if (!strcmp(fmt, COLRFMT))
451     CLR(C_XYZE);
452     else if (!strcmp(fmt, CIEFMT))
453     SET(C_XYZE);
454     else
455     quiterr("unrecognized input picture format");
456 gwlarson 2.17 return(1);
457 gregl 2.9 }
458     if (isexpos(s)) {
459     cvts.stonits /= exposval(s);
460 gwlarson 2.17 return(1);
461 gregl 2.9 }
462     if (isaspect(s)) {
463     cvts.pixrat *= aspectval(s);
464 gwlarson 2.17 return(1);
465 gregl 2.9 }
466     if (isprims(s)) {
467     primsval(cvts.prims, s);
468     SET(C_PRIM);
469 gwlarson 2.17 return(1);
470 gregl 2.9 }
471 greg 2.22 if (isdate(s)) {
472     if (s[tmstrlen] == ' ')
473     strncpy(cvts.capdate, s+tmstrlen+1, 19);
474     else
475     strncpy(cvts.capdate, s+tmstrlen, 19);
476     cvts.capdate[19] = '\0';
477     return(1);
478     }
479     if (!strncmp(s, OWNSTR, ownstrlen)) {
480     register char *cp = s + ownstrlen;
481
482     while (isspace(*cp))
483     ++cp;
484     strncpy(cvts.owner, cp, sizeof(cvts.owner));
485     cvts.owner[sizeof(cvts.owner)-1] = '\0';
486     for (cp = cvts.owner; *cp; cp++)
487     ;
488     while (cp > cvts.owner && isspace(cp[-1]))
489     *--cp = '\0';
490     return(1);
491     }
492 gwlarson 2.17 return(0);
493 gregl 2.9 }
494
495
496 schorsch 2.28 static void
497     initfromrad(void) /* initialize input from a Radiance picture */
498 gregl 2.9 {
499     int i1, i2, po;
500     /* read Radiance header */
501 greg 2.21 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
502 greg 2.22 cvts.capdate[0] = '\0';
503     cvts.owner[0] = '\0';
504 gregl 2.9 cvts.stonits = 1.;
505     cvts.pixrat = 1.;
506     cvts.pconf = PLANARCONFIG_CONTIG;
507     getheader(cvts.rfp, headline, NULL);
508     if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
509     quiterr("bad Radiance picture");
510     cvts.xmax = i1; cvts.ymax = i2;
511     for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
512     if (ortab[i1] == po) {
513     cvts.orient = i1 + 1;
514     break;
515 greg 1.1 }
516 gregl 2.9 if (i1 >= 8)
517     quiterr("internal error 1 in initfromrad");
518     if (!(po & YMAJOR))
519     cvts.pixrat = 1./cvts.pixrat;
520     if (!CHK(C_XYZE))
521     cvts.stonits *= WHTEFFICACY;
522     /* set up conversion */
523     TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
524 gregl 2.10 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
525 gregl 2.9
526 gregl 2.10 switch (cvts.phot) {
527     case PHOTOMETRIC_LOGLUV:
528 gregl 2.9 SET(C_RFLT|C_TFLT);
529 greg 2.21 CLR(C_GRY|C_TWRD);
530 gregl 2.9 if (!CHK(C_XYZE)) {
531 greg 2.20 comprgb2xyzWBmat(cvts.cmat,
532     CHK(C_PRIM) ? cvts.prims : stdprims);
533 gregl 2.9 SET(C_CXFM);
534     }
535 gregl 2.10 if (cvts.comp != COMPRESSION_SGILOG &&
536     cvts.comp != COMPRESSION_SGILOG24)
537     quiterr("internal error 2 in initfromrad");
538     TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
539 gregl 2.12 SGILOGDATAFMT_FLOAT);
540 gregl 2.9 cvts.tf = Color2Luv;
541     break;
542 gregl 2.10 case PHOTOMETRIC_LOGL:
543     SET(C_GRY|C_RFLT|C_TFLT);
544 greg 2.21 CLR(C_TWRD);
545 gregl 2.10 if (cvts.comp != COMPRESSION_SGILOG)
546     quiterr("internal error 3 in initfromrad");
547     TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
548 gregl 2.12 SGILOGDATAFMT_FLOAT);
549 gregl 2.10 cvts.tf = Color2L;
550     break;
551     case PHOTOMETRIC_RGB:
552 gregl 2.9 SET(C_GAMMA|C_GAMUT);
553 gregl 2.10 CLR(C_GRY);
554 gregl 2.9 setcolrgam(cvts.gamcor);
555     if (CHK(C_XYZE)) {
556 greg 2.20 compxyz2rgbWBmat(cvts.cmat,
557 gregl 2.9 CHK(C_PRIM) ? cvts.prims : stdprims);
558     SET(C_CXFM);
559     }
560     if (CHK(C_PRIM)) {
561     TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
562     (float *)cvts.prims);
563     TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
564     (float *)cvts.prims[WHT]);
565     }
566 greg 2.21 if (CHK(C_TWRD)) {
567     cvts.tf = Color2RRGGBB;
568     SET(C_RFLT);
569     } else if (CHK(C_TFLT)) {
570 greg 2.23 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
571     SAMPLEFORMAT_IEEEFP);
572 greg 2.21 cvts.tf = Color2RfGfBf;
573     SET(C_RFLT);
574 greg 2.29 CLR(C_GAMUT);
575 greg 2.21 } else
576     cvts.tf = Colr2RGB;
577 gregl 2.9 break;
578 gregl 2.10 case PHOTOMETRIC_MINISBLACK:
579     SET(C_GRY|C_GAMMA|C_GAMUT);
580     setcolrgam(cvts.gamcor);
581 greg 2.21 if (CHK(C_TWRD)) {
582     cvts.tf = Color2GGry;
583     SET(C_RFLT);
584     } else if (CHK(C_TFLT)) {
585 greg 2.23 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
586     SAMPLEFORMAT_IEEEFP);
587 greg 2.21 cvts.tf = Color2Gryf;
588     SET(C_RFLT);
589     } else
590     cvts.tf = Colr2Gry;
591 gregl 2.10 break;
592     default:
593     quiterr("internal error 4 in initfromrad");
594     break;
595 greg 1.1 }
596 gregl 2.9 /* set other TIFF fields */
597     TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
598     TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
599     TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
600 greg 2.21 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
601     CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
602 gregl 2.9 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
603     TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
604     TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
605     TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
606     TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
607     TIFFSetField(cvts.tif, TIFFTAG_STONITS,
608     cvts.stonits/pow(2.,(double)cvts.bradj));
609 greg 2.22 if (cvts.capdate[0])
610     TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
611     if (cvts.owner[0])
612     TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
613 gregl 2.10 if (cvts.comp == COMPRESSION_NONE)
614     i1 = TIFFScanlineSize(cvts.tif);
615     else
616     i1 = 3*cvts.xmax; /* conservative guess */
617 gregl 2.9 i2 = 8192/i1; /* compute good strip size */
618     if (i2 < 1) i2 = 1;
619     TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
620
621     allocbufs(); /* allocate scanline buffers */
622     }
623
624
625 schorsch 2.28 static void
626     ra2tiff( /* convert Radiance picture to TIFF image */
627     int ac,
628     char *av[]
629     )
630 gregl 2.9 {
631     uint32 y;
632     /* open Radiance file */
633     if (!strcmp(av[ac], "-"))
634     cvts.rfp = stdin;
635     else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
636     quiterr("cannot open Radiance input picture");
637 greg 2.34 SET_FILE_BINARY(cvts.rfp);
638 gregl 2.9 /* open TIFF file */
639     if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
640     quiterr("cannot open TIFF output");
641
642     initfromrad(); /* initialize conversion */
643
644     for (y = 0; y < cvts.ymax; y++) /* convert image */
645     (*cvts.tf)(y);
646 greg 1.1 /* clean up */
647 gregl 2.9 TIFFClose(cvts.tif);
648     fclose(cvts.rfp);
649     }
650
651
652 schorsch 2.28 static void
653     Luv2Color( /* read/convert/write Luv->COLOR scanline */
654     uint32 y
655     )
656 gregl 2.9 {
657     register int x;
658
659 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
660 gregl 2.9 quiterr("internal error 1 in Luv2Color");
661
662 greg 2.31 if (cvts.pconf != PLANARCONFIG_CONTIG)
663     quiterr("cannot handle separate 32-bit color planes");
664
665 gregl 2.9 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
666     quiterr("error reading TIFF input");
667 greg 2.21 /* also works for float RGB */
668 gregl 2.9 for (x = cvts.xmax; x--; ) {
669 greg 2.21 setcolor(cvts.r.colors[x],
670     cvts.t.fp[3*x],
671     cvts.t.fp[3*x + 1],
672     cvts.t.fp[3*x + 2]);
673 gregl 2.9 if (CHK(C_CXFM))
674     colortrans(cvts.r.colors[x], cvts.cmat,
675     cvts.r.colors[x]);
676     if (CHK(C_GAMUT))
677     clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
678     CGAMUT_LOWER, cblack, cwhite);
679     }
680     if (cvts.bradj) {
681     double m = pow(2.,(double)cvts.bradj);
682     for (x = cvts.xmax; x--; )
683     scalecolor(cvts.r.colors[x], m);
684     }
685
686     if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
687     quiterr("error writing Radiance picture");
688     }
689
690
691 schorsch 2.28 static void
692     RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
693     uint32 y
694     )
695 gwlarson 2.18 {
696 schorsch 2.26 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
697 gwlarson 2.18 register double d;
698     register int x;
699
700 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
701 gwlarson 2.18 quiterr("internal error 1 in RRGGBB2Color");
702
703 greg 2.31 if (cvts.pconf != PLANARCONFIG_CONTIG)
704     quiterr("cannot handle separate 16-bit color planes");
705
706 gwlarson 2.18 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
707     quiterr("error reading TIFF input");
708
709     for (x = cvts.xmax; x--; ) {
710     d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
711     if (dogamma) d = pow(d, cvts.gamcor);
712     colval(cvts.r.colors[x],RED) = d;
713     d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
714     if (dogamma) d = pow(d, cvts.gamcor);
715     colval(cvts.r.colors[x],GRN) = d;
716     d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
717     if (dogamma) d = pow(d, cvts.gamcor);
718     colval(cvts.r.colors[x],BLU) = d;
719     if (CHK(C_CXFM))
720     colortrans(cvts.r.colors[x], cvts.cmat,
721     cvts.r.colors[x]);
722     }
723     if (cvts.bradj) {
724     d = pow(2.,(double)cvts.bradj);
725     for (x = cvts.xmax; x--; )
726     scalecolor(cvts.r.colors[x], d);
727     }
728
729     if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
730     quiterr("error writing Radiance picture");
731     }
732
733
734 schorsch 2.28 static void
735     L2Color( /* read/convert/write Lfloat->COLOR scanline */
736     uint32 y
737     )
738 gregl 2.9 {
739 greg 2.21 float m = pow(2., (double)cvts.bradj);
740 gregl 2.9 register int x;
741
742 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
743 gregl 2.9 quiterr("internal error 1 in L2Color");
744
745     if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
746     quiterr("error reading TIFF input");
747 greg 2.21 /* also works for float greyscale */
748     for (x = cvts.xmax; x--; ) {
749     register float f = cvts.t.fp[x];
750     if (cvts.bradj) f *= m;
751     setcolor(cvts.r.colors[x], f, f, f);
752     }
753 gregl 2.9 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
754     quiterr("error writing Radiance picture");
755     }
756
757
758 schorsch 2.28 static void
759     RGB2Colr( /* read/convert/write RGB->COLR scanline */
760     uint32 y
761     )
762 gregl 2.9 {
763     COLOR ctmp;
764     register int x;
765
766 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
767 gregl 2.9 quiterr("internal error 1 in RGB2Colr");
768
769     if (cvts.pconf == PLANARCONFIG_CONTIG) {
770     if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
771     goto readerr;
772     for (x = cvts.xmax; x--; ) {
773     cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
774     cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
775     cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
776     }
777     } else {
778     if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
779     goto readerr;
780     if (TIFFReadScanline(cvts.tif,
781 gregl 2.14 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
782 gregl 2.9 goto readerr;
783     if (TIFFReadScanline(cvts.tif,
784 gregl 2.14 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
785 gregl 2.9 goto readerr;
786     for (x = cvts.xmax; x--; ) {
787     cvts.r.colrs[x][RED] = cvts.t.bp[x];
788     cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
789     cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
790     }
791     }
792
793     gambs_colrs(cvts.r.colrs, cvts.xmax);
794     if (CHK(C_CXFM))
795     for (x = cvts.xmax; x--; ) {
796     colr_color(ctmp, cvts.r.colrs[x]);
797     colortrans(ctmp, cvts.cmat, ctmp);
798     if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
799     clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
800     cblack, cwhite);
801     setcolr(cvts.r.colrs[x], colval(ctmp,RED),
802     colval(ctmp,GRN), colval(ctmp,BLU));
803     }
804     if (cvts.bradj)
805     shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
806
807     if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
808     quiterr("error writing Radiance picture");
809 greg 1.1 return;
810     readerr:
811     quiterr("error reading TIFF input");
812     }
813
814
815 schorsch 2.28 static void
816     Gry2Colr( /* read/convert/write G8->COLR scanline */
817     uint32 y
818     )
819 greg 1.1 {
820     register int x;
821 gregl 2.9
822 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
823 gregl 2.9 quiterr("internal error 1 in Gry2Colr");
824
825     if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
826     quiterr("error reading TIFF input");
827
828     for (x = cvts.xmax; x--; )
829     cvts.r.colrs[x][RED] =
830     cvts.r.colrs[x][GRN] =
831     cvts.r.colrs[x][BLU] = cvts.t.bp[x];
832
833     gambs_colrs(cvts.r.colrs, cvts.xmax);
834     if (cvts.bradj)
835     shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
836
837     if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
838     quiterr("error writing Radiance picture");
839     }
840
841
842 schorsch 2.28 static void
843     GGry2Color( /* read/convert/write G16->COLOR scanline */
844     uint32 y
845     )
846 gwlarson 2.18 {
847 schorsch 2.26 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
848 gwlarson 2.18 double m;
849     register double d;
850     register int x;
851
852 gwlarson 2.19 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
853 gwlarson 2.18 quiterr("internal error 1 in GGry2Color");
854
855     if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
856     quiterr("error reading TIFF input");
857
858     if (cvts.bradj)
859     m = pow(2., (double)cvts.bradj);
860     for (x = cvts.xmax; x--; ) {
861     d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
862     if (dogamma) d = pow(d, cvts.gamcor);
863     if (cvts.bradj) d *= m;
864     colval(cvts.r.colors[x],RED) =
865     colval(cvts.r.colors[x],GRN) =
866     colval(cvts.r.colors[x],BLU) = d;
867     }
868     if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
869     quiterr("error writing Radiance picture");
870     }
871
872
873 schorsch 2.28 static void
874     Color2GGry( /* read/convert/write COLOR->G16 scanline */
875     uint32 y
876     )
877 greg 2.21 {
878 schorsch 2.26 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
879 greg 2.21 float m = pow(2.,(double)cvts.bradj);
880     register int x;
881
882     if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
883     quiterr("internal error 1 in Color2GGry");
884
885     if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
886     quiterr("error reading Radiance picture");
887
888     for (x = cvts.xmax; x--; ) {
889     register float f = m*( CHK(C_XYZE) ?
890     colval(cvts.r.colors[x],CIEY)
891     : bright(cvts.r.colors[x]) );
892     if (f <= 0)
893     cvts.t.wp[x] = 0;
894     else if (f >= 1)
895     cvts.t.wp[x] = 0xffff;
896     else if (dogamma)
897     cvts.t.wp[x] = (int)((float)(1L<<16) *
898     pow(f, 1./cvts.gamcor));
899     else
900     cvts.t.wp[x] = (int)((float)(1L<<16) * f);
901     }
902
903     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
904     quiterr("error writing TIFF output");
905     }
906
907
908 schorsch 2.28 static void
909     Color2L( /* read/convert/write COLOR->Lfloat scanline */
910     uint32 y
911     )
912 gregl 2.9 {
913 greg 2.21 float m = pow(2.,(double)cvts.bradj);
914 gregl 2.9 register int x;
915
916 gwlarson 2.19 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
917 gregl 2.9 quiterr("internal error 1 in Color2L");
918
919     if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
920     quiterr("error reading Radiance picture");
921
922     for (x = cvts.xmax; x--; )
923     cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
924     : bright(cvts.r.colors[x]) );
925
926     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
927     quiterr("error writing TIFF output");
928     }
929
930
931 schorsch 2.28 static void
932     Color2Luv( /* read/convert/write COLOR->Luv scanline */
933     uint32 y
934     )
935 gregl 2.9 {
936     register int x;
937
938 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
939 gregl 2.9 quiterr("internal error 1 in Color2Luv");
940
941     if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
942     quiterr("error reading Radiance picture");
943
944     if (CHK(C_CXFM))
945     for (x = cvts.xmax; x--; )
946     colortrans(cvts.r.colors[x], cvts.cmat,
947     cvts.r.colors[x]);
948     if (cvts.bradj) {
949     double m = pow(2.,(double)cvts.bradj);
950     for (x = cvts.xmax; x--; )
951     scalecolor(cvts.r.colors[x], m);
952     }
953 greg 2.21 /* also works for float RGB */
954 gregl 2.9 for (x = cvts.xmax; x--; ) {
955 gwlarson 2.16 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
956     cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
957     cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
958 gregl 2.9 }
959
960     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
961     quiterr("error writing TIFF output");
962     }
963
964
965 schorsch 2.28 static void
966     Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
967     uint32 y
968     )
969 greg 2.21 {
970 schorsch 2.26 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
971 greg 2.21 float m = pow(2.,(double)cvts.bradj);
972     register int x, i;
973
974     if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
975     quiterr("internal error 1 in Color2RRGGBB");
976
977     if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
978     quiterr("error reading Radiance picture");
979
980 greg 2.29 for (x = cvts.xmax; x--; ) {
981     if (CHK(C_CXFM)) {
982     colortrans(cvts.r.colors[x], cvts.cmat,
983     cvts.r.colors[x]);
984     if (CHK(C_GAMUT))
985 greg 2.30 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
986 greg 2.29 CGAMUT_LOWER, cblack, cwhite);
987     }
988 greg 2.21 for (i = 3; i--; ) {
989     register float f = m*colval(cvts.r.colors[x],i);
990     if (f <= 0)
991     cvts.t.wp[3*x + i] = 0;
992     else if (f >= 1)
993     cvts.t.wp[3*x + i] = 0xffff;
994     else if (dogamma)
995     cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
996     pow(f, 1./cvts.gamcor));
997     else
998     cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
999     }
1000 greg 2.29 }
1001 greg 2.21
1002     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1003     quiterr("error writing TIFF output");
1004     }
1005
1006
1007 schorsch 2.28 static void
1008     Colr2Gry( /* read/convert/write COLR->RGB scanline */
1009     uint32 y
1010     )
1011 gregl 2.9 {
1012     register int x;
1013
1014 gwlarson 2.19 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1015 gregl 2.9 quiterr("internal error 1 in Colr2Gry");
1016
1017     if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1018     quiterr("error reading Radiance picture");
1019
1020     if (cvts.bradj)
1021     shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1022     for (x = cvts.xmax; x--; )
1023     colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1024     colrs_gambs(cvts.r.colrs, cvts.xmax);
1025
1026     for (x = cvts.xmax; x--; )
1027     cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1028
1029     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1030     quiterr("error writing TIFF output");
1031     }
1032
1033
1034 schorsch 2.28 static void
1035     Colr2RGB( /* read/convert/write COLR->RGB scanline */
1036     uint32 y
1037     )
1038 gregl 2.9 {
1039     COLOR ctmp;
1040     register int x;
1041
1042 gwlarson 2.19 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1043 gregl 2.9 quiterr("internal error 1 in Colr2RGB");
1044
1045     if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1046     quiterr("error reading Radiance picture");
1047
1048     if (cvts.bradj)
1049     shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1050     if (CHK(C_CXFM))
1051     for (x = cvts.xmax; x--; ) {
1052     colr_color(ctmp, cvts.r.colrs[x]);
1053     colortrans(ctmp, cvts.cmat, ctmp);
1054     if (CHK(C_GAMUT))
1055     clipgamut(ctmp, bright(ctmp), CGAMUT,
1056     cblack, cwhite);
1057     setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1058     colval(ctmp,GRN), colval(ctmp,BLU));
1059 greg 1.1 }
1060 gregl 2.9 colrs_gambs(cvts.r.colrs, cvts.xmax);
1061
1062     for (x = cvts.xmax; x--; ) {
1063     cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1064     cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1065     cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1066 greg 1.1 }
1067 gregl 2.9
1068     if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1069     quiterr("error writing TIFF output");
1070 greg 1.1 }
