1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Program to convert between RADIANCE and TIFF files. |
9 |
* Added experimental LogLuv encodings 7/97 (GWL). |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tiffio.h" |
15 |
#include "color.h" |
16 |
#include "resolu.h" |
17 |
18 |
#define GAMCOR 2.2 /* default gamma */ |
19 |
20 |
#ifndef malloc |
21 |
extern char *malloc(); |
22 |
#endif |
23 |
/* conversion flags */ |
24 |
#define C_CXFM 0x1 /* needs color transformation */ |
25 |
#define C_GAMUT 0x2 /* needs gamut mapping */ |
26 |
#define C_GAMMA 0x4 /* needs gamma correction */ |
27 |
#define C_GRY 0x8 /* TIFF is greyscale */ |
28 |
#define C_XYZE 0x10 /* Radiance is XYZE */ |
29 |
#define C_RFLT 0x20 /* Radiance data is float */ |
30 |
#define C_TFLT 0x40 /* TIFF data is float */ |
31 |
#define C_PRIM 0x80 /* has assigned primaries */ |
32 |
33 |
struct { |
34 |
uint16 flags; /* conversion flags (defined above) */ |
35 |
uint16 comp; /* TIFF compression type */ |
36 |
uint16 phot; /* TIFF photometric type */ |
37 |
uint16 pconf; /* TIFF planar configuration */ |
38 |
float gamcor; /* gamma correction value */ |
39 |
short bradj; /* Radiance exposure adjustment (stops) */ |
40 |
uint16 orient; /* visual orientation (TIFF spec.) */ |
41 |
double stonits; /* input conversion to nits */ |
42 |
float pixrat; /* pixel aspect ratio */ |
43 |
FILE *rfp; /* Radiance stream pointer */ |
44 |
TIFF *tif; /* TIFF pointer */ |
45 |
uint32 xmax, ymax; /* image dimensions */ |
46 |
COLORMAT cmat; /* color transformation matrix */ |
47 |
RGBPRIMS prims; /* RGB primaries */ |
48 |
union { |
49 |
COLR *colrs; /* 4-byte ???E pointer */ |
50 |
COLOR *colors; /* float array pointer */ |
51 |
char *p; /* generic pointer */ |
52 |
} r; /* Radiance scanline */ |
53 |
union { |
54 |
uint8 *bp; /* byte pointer */ |
55 |
float *fp; /* float pointer */ |
56 |
57 |
} t; /* TIFF scanline */ |
58 |
int (*tf)(); /* translation procedure */ |
59 |
} cvts = { /* conversion structure */ |
60 |
0, COMPRESSION_NONE, PHOTOMETRIC_RGB, |
61 |
PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., |
62 |
63 |
64 |
#define CHK(f) (cvts.flags & (f)) |
65 |
#define SET(f) (cvts.flags |= (f)) |
66 |
#define CLR(f) (cvts.flags &= ~(f)) |
67 |
#define TGL(f) (cvts.flags ^= (f)) |
68 |
69 |
int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); |
70 |
int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); |
71 |
72 |
short ortab[8] = { /* orientation conversion table */ |
73 |
YMAJOR|YDECR, |
74 |
YMAJOR|YDECR|XDECR, |
75 |
YMAJOR|XDECR, |
76 |
YMAJOR, |
77 |
YDECR, |
78 |
XDECR|YDECR, |
79 |
XDECR, |
80 |
0 |
81 |
82 |
83 |
#define pixorder() ortab[cvts.orient-1] |
84 |
85 |
char *progname; |
86 |
87 |
88 |
main(argc, argv) |
89 |
int argc; |
90 |
char *argv[]; |
91 |
92 |
int reverse = 0; |
93 |
int i; |
94 |
95 |
progname = argv[0]; |
96 |
97 |
for (i = 1; i < argc; i++) |
98 |
if (argv[i][0] == '-') |
99 |
switch (argv[i][1]) { |
100 |
case 'g': /* gamma correction */ |
101 |
cvts.gamcor = atof(argv[++i]); |
102 |
break; |
103 |
case 'x': /* XYZE Radiance output */ |
104 |
TGL(C_XYZE); |
105 |
break; |
106 |
case 'z': /* LZW compressed output */ |
107 |
cvts.comp = COMPRESSION_LZW; |
108 |
break; |
109 |
case 'L': /* LogLuv 32-bit output */ |
110 |
cvts.comp = COMPRESSION_SGILOG; |
111 |
cvts.phot = PHOTOMETRIC_LOGLUV; |
112 |
break; |
113 |
case 'l': /* LogLuv 24-bit output */ |
114 |
cvts.comp = COMPRESSION_SGILOG24; |
115 |
116 |
break; |
117 |
case 'b': /* greyscale output? */ |
118 |
TGL(C_GRY); |
119 |
break; |
120 |
case 'e': /* exposure adjustment */ |
121 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
122 |
goto userr; |
123 |
cvts.bradj = atoi(argv[++i]); |
124 |
break; |
125 |
case 'r': /* reverse conversion? */ |
126 |
reverse = !reverse; |
127 |
break; |
128 |
case '\0': |
129 |
goto doneopts; |
130 |
default: |
131 |
goto userr; |
132 |
133 |
else |
134 |
break; |
135 |
doneopts: |
136 |
if (reverse) { |
137 |
138 |
if (i != argc-2 && i != argc-1) |
139 |
goto userr; |
140 |
141 |
tiff2ra(i, argv); |
142 |
143 |
} else { |
144 |
145 |
if (i != argc-2) |
146 |
goto userr; |
147 |
148 |
if (CHK(C_GRY)) /* consistency corrections */ |
149 |
if (cvts.phot == PHOTOMETRIC_RGB) |
150 |
cvts.phot = PHOTOMETRIC_MINISBLACK; |
151 |
else { |
152 |
cvts.phot = PHOTOMETRIC_LOGL; |
153 |
154 |
155 |
156 |
ra2tiff(i, argv); |
157 |
158 |
159 |
exit(0); |
160 |
userr: |
161 |
fprintf(stderr, |
162 |
"Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", |
163 |
progname); |
164 |
fprintf(stderr, |
165 |
" Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", |
166 |
progname); |
167 |
exit(1); |
168 |
169 |
170 |
171 |
quiterr(err) /* print message and exit */ |
172 |
char *err; |
173 |
174 |
if (err != NULL) { |
175 |
fprintf(stderr, "%s: %s\n", progname, err); |
176 |
exit(1); |
177 |
178 |
exit(0); |
179 |
180 |
181 |
182 |
allocbufs() /* allocate scanline buffers */ |
183 |
184 |
int rsiz, tsiz; |
185 |
186 |
rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); |
187 |
tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) * |
188 |
(CHK(C_GRY) ? 1 : 3); |
189 |
cvts.r.p = (char *)malloc(rsiz*cvts.xmax); |
190 |
cvts.t.p = (char *)malloc(tsiz*cvts.xmax); |
191 |
if (cvts.r.p == NULL | cvts.t.p == NULL) |
192 |
quiterr("no memory to allocate scanline buffers"); |
193 |
194 |
195 |
196 |
initfromtif() /* initialize conversion from TIFF input */ |
197 |
198 |
uint16 hi; |
199 |
float *fa, f1, f2; |
200 |
201 |
CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM); |
202 |
203 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); |
204 |
205 |
if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
206 |
cvts.prims[RED][CIEX] = fa[0]; |
207 |
cvts.prims[RED][CIEY] = fa[1]; |
208 |
cvts.prims[GRN][CIEX] = fa[2]; |
209 |
cvts.prims[GRN][CIEY] = fa[3]; |
210 |
cvts.prims[BLU][CIEX] = fa[4]; |
211 |
cvts.prims[BLU][CIEY] = fa[5]; |
212 |
cvts.prims[WHT][CIEX] = 1./3.; |
213 |
cvts.prims[WHT][CIEY] = 1./3.; |
214 |
if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) { |
215 |
cvts.prims[WHT][CIEX] = fa[0]; |
216 |
cvts.prims[WHT][CIEY] = fa[1]; |
217 |
218 |
SET(C_PRIM); |
219 |
220 |
221 |
if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp)) |
222 |
cvts.comp = COMPRESSION_NONE; |
223 |
224 |
if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && |
225 |
TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) |
226 |
cvts.pixrat = f1/f2; |
227 |
228 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient); |
229 |
230 |
if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot)) |
231 |
quiterr("TIFF has unspecified photometric type"); |
232 |
233 |
switch (cvts.phot) { |
234 |
case PHOTOMETRIC_LOGLUV: |
235 |
SET(C_RFLT|C_TFLT); |
236 |
if (!CHK(C_XYZE)) { |
237 |
cpcolormat(cvts.cmat, xyz2rgbmat); |
238 |
SET(C_CXFM|C_GAMUT); |
239 |
} else if (cvts.comp == COMPRESSION_SGILOG) |
240 |
SET(C_GAMUT); |
241 |
if (cvts.pconf != PLANARCONFIG_CONTIG) |
242 |
quiterr("cannot handle separate Luv planes"); |
243 |
TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, |
244 |
SGILOGDATAFMT_FLOAT); |
245 |
cvts.tf = Luv2Color; |
246 |
break; |
247 |
case PHOTOMETRIC_LOGL: |
248 |
SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); |
249 |
cvts.pconf = PLANARCONFIG_CONTIG; |
250 |
251 |
252 |
cvts.tf = L2Color; |
253 |
break; |
254 |
case PHOTOMETRIC_YCBCR: |
255 |
if (cvts.comp == COMPRESSION_JPEG && |
256 |
cvts.pconf == PLANARCONFIG_CONTIG) { |
257 |
TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE, |
258 |
JPEGCOLORMODE_RGB); |
259 |
cvts.phot = PHOTOMETRIC_RGB; |
260 |
} else |
261 |
quiterr("unsupported photometric type"); |
262 |
/* fall through */ |
263 |
case PHOTOMETRIC_RGB: |
264 |
SET(C_GAMMA|C_GAMUT); |
265 |
setcolrgam(cvts.gamcor); |
266 |
if (CHK(C_XYZE)) { |
267 |
comprgb2xyzmat(cvts.cmat, |
268 |
CHK(C_PRIM) ? cvts.prims : stdprims); |
269 |
SET(C_CXFM); |
270 |
271 |
if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || |
272 |
hi != 3) |
273 |
quiterr("unsupported samples per pixel for RGB"); |
274 |
if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) || |
275 |
hi != 8) |
276 |
quiterr("unsupported bits per sample for RGB"); |
277 |
cvts.tf = RGB2Colr; |
278 |
break; |
279 |
case PHOTOMETRIC_MINISBLACK: |
280 |
SET(C_GRY|C_GAMMA|C_GAMUT); |
281 |
282 |
283 |
284 |
hi != 1) |
285 |
quiterr("unsupported samples per pixel for greyscale"); |
286 |
287 |
hi != 8) |
288 |
quiterr("unsupported bits per sample for greyscale"); |
289 |
cvts.tf = Gry2Colr; |
290 |
break; |
291 |
default: |
292 |
293 |
break; |
294 |
295 |
296 |
if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || |
297 |
!TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) |
298 |
quiterr("unknown input image resolution"); |
299 |
300 |
if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) |
301 |
cvts.stonits = 1.; |
302 |
/* add to Radiance header */ |
303 |
if (cvts.pixrat < .99 || cvts.pixrat > 1.01) |
304 |
fputaspect(cvts.pixrat, cvts.rfp); |
305 |
306 |
fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); |
307 |
fputformat(CIEFMT, cvts.rfp); |
308 |
} else { |
309 |
if (CHK(C_PRIM)) |
310 |
fputprims(cvts.prims, cvts.rfp); |
311 |
fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, |
312 |
cvts.rfp); |
313 |
fputformat(COLRFMT, cvts.rfp); |
314 |
315 |
316 |
allocbufs(); /* allocate scanline buffers */ |
317 |
318 |
319 |
320 |
tiff2ra(ac, av) /* convert TIFF image to Radiance picture */ |
321 |
int ac; |
322 |
char *av[]; |
323 |
324 |
int32 y; |
325 |
/* open TIFF input */ |
326 |
if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL) |
327 |
quiterr("cannot open TIFF input"); |
328 |
/* open Radiance output */ |
329 |
if (av[ac+1] == NULL || !strcmp(av[ac+1], "-")) |
330 |
cvts.rfp = stdout; |
331 |
else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) |
332 |
quiterr("cannot open Radiance output picture"); |
333 |
/* start output header */ |
334 |
newheader("RADIANCE", cvts.rfp); |
335 |
printargs(ac, av, cvts.rfp); |
336 |
337 |
initfromtif(); /* initialize conversion */ |
338 |
339 |
fputc('\n', cvts.rfp); /* finish Radiance header */ |
340 |
fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp); |
341 |
342 |
for (y = 0; y < cvts.ymax; y++) /* convert image */ |
343 |
(*cvts.tf)(y); |
344 |
/* clean up */ |
345 |
fclose(cvts.rfp); |
346 |
TIFFClose(cvts.tif); |
347 |
348 |
349 |
350 |
int |
351 |
headline(s) /* process Radiance input header line */ |
352 |
char *s; |
353 |
354 |
char fmt[32]; |
355 |
356 |
if (formatval(fmt, s)) { |
357 |
if (!strcmp(fmt, COLRFMT)) |
358 |
CLR(C_XYZE); |
359 |
else if (!strcmp(fmt, CIEFMT)) |
360 |
SET(C_XYZE); |
361 |
else |
362 |
quiterr("unrecognized input picture format"); |
363 |
return(1); |
364 |
365 |
if (isexpos(s)) { |
366 |
cvts.stonits /= exposval(s); |
367 |
return(1); |
368 |
369 |
if (isaspect(s)) { |
370 |
cvts.pixrat *= aspectval(s); |
371 |
return(1); |
372 |
373 |
if (isprims(s)) { |
374 |
primsval(cvts.prims, s); |
375 |
SET(C_PRIM); |
376 |
return(1); |
377 |
378 |
return(0); |
379 |
380 |
381 |
382 |
initfromrad() /* initialize input from a Radiance picture */ |
383 |
384 |
int i1, i2, po; |
385 |
/* read Radiance header */ |
386 |
CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); |
387 |
388 |
cvts.pixrat = 1.; |
389 |
390 |
getheader(cvts.rfp, headline, NULL); |
391 |
if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) |
392 |
quiterr("bad Radiance picture"); |
393 |
cvts.xmax = i1; cvts.ymax = i2; |
394 |
for (i1 = 0; i1 < 8; i1++) /* interpret orientation */ |
395 |
if (ortab[i1] == po) { |
396 |
cvts.orient = i1 + 1; |
397 |
break; |
398 |
399 |
if (i1 >= 8) |
400 |
quiterr("internal error 1 in initfromrad"); |
401 |
if (!(po & YMAJOR)) |
402 |
cvts.pixrat = 1./cvts.pixrat; |
403 |
if (!CHK(C_XYZE)) |
404 |
cvts.stonits *= WHTEFFICACY; |
405 |
/* set up conversion */ |
406 |
TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); |
407 |
TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot); |
408 |
409 |
410 |
411 |
412 |
CLR(C_GRY); |
413 |
414 |
cpcolormat(cvts.cmat, rgb2xyzmat); |
415 |
SET(C_CXFM); |
416 |
417 |
if (cvts.comp != COMPRESSION_SGILOG && |
418 |
cvts.comp != COMPRESSION_SGILOG24) |
419 |
quiterr("internal error 2 in initfromrad"); |
420 |
421 |
422 |
cvts.tf = Color2Luv; |
423 |
break; |
424 |
425 |
SET(C_GRY|C_RFLT|C_TFLT); |
426 |
if (cvts.comp != COMPRESSION_SGILOG) |
427 |
quiterr("internal error 3 in initfromrad"); |
428 |
429 |
430 |
cvts.tf = Color2L; |
431 |
break; |
432 |
433 |
434 |
CLR(C_GRY); |
435 |
436 |
437 |
compxyz2rgbmat(cvts.cmat, |
438 |
439 |
SET(C_CXFM); |
440 |
441 |
if (CHK(C_PRIM)) { |
442 |
TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, |
443 |
(float *)cvts.prims); |
444 |
TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, |
445 |
(float *)cvts.prims[WHT]); |
446 |
447 |
cvts.tf = Colr2RGB; |
448 |
break; |
449 |
450 |
451 |
452 |
cvts.tf = Colr2Gry; |
453 |
break; |
454 |
default: |
455 |
quiterr("internal error 4 in initfromrad"); |
456 |
break; |
457 |
458 |
/* set other TIFF fields */ |
459 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); |
460 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); |
461 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); |
462 |
TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8); |
463 |
TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); |
464 |
TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); |
465 |
TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); |
466 |
TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2); |
467 |
TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); |
468 |
TIFFSetField(cvts.tif, TIFFTAG_STONITS, |
469 |
cvts.stonits/pow(2.,(double)cvts.bradj)); |
470 |
if (cvts.comp == COMPRESSION_NONE) |
471 |
i1 = TIFFScanlineSize(cvts.tif); |
472 |
else |
473 |
i1 = 3*cvts.xmax; /* conservative guess */ |
474 |
i2 = 8192/i1; /* compute good strip size */ |
475 |
if (i2 < 1) i2 = 1; |
476 |
TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); |
477 |
478 |
479 |
480 |
481 |
482 |
ra2tiff(ac, av) /* convert Radiance picture to TIFF image */ |
483 |
int ac; |
484 |
char *av[]; |
485 |
486 |
uint32 y; |
487 |
/* open Radiance file */ |
488 |
if (!strcmp(av[ac], "-")) |
489 |
cvts.rfp = stdin; |
490 |
else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) |
491 |
quiterr("cannot open Radiance input picture"); |
492 |
/* open TIFF file */ |
493 |
if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) |
494 |
quiterr("cannot open TIFF output"); |
495 |
496 |
initfromrad(); /* initialize conversion */ |
497 |
498 |
499 |
(*cvts.tf)(y); |
500 |
/* clean up */ |
501 |
502 |
fclose(cvts.rfp); |
503 |
504 |
505 |
506 |
int |
507 |
Luv2Color(y) /* read/convert/write Luv->COLOR scanline */ |
508 |
uint32 y; |
509 |
510 |
register int x; |
511 |
512 |
if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY)) |
513 |
quiterr("internal error 1 in Luv2Color"); |
514 |
515 |
if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
516 |
quiterr("error reading TIFF input"); |
517 |
518 |
for (x = cvts.xmax; x--; ) { |
519 |
colval(cvts.r.colors[x],CIEX) = cvts.t.fp[3*x]; |
520 |
colval(cvts.r.colors[x],CIEY) = cvts.t.fp[3*x + 1]; |
521 |
colval(cvts.r.colors[x],CIEZ) = cvts.t.fp[3*x + 2]; |
522 |
if (CHK(C_CXFM)) |
523 |
colortrans(cvts.r.colors[x], cvts.cmat, |
524 |
cvts.r.colors[x]); |
525 |
if (CHK(C_GAMUT)) |
526 |
clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], |
527 |
CGAMUT_LOWER, cblack, cwhite); |
528 |
529 |
if (cvts.bradj) { |
530 |
double m = pow(2.,(double)cvts.bradj); |
531 |
for (x = cvts.xmax; x--; ) |
532 |
scalecolor(cvts.r.colors[x], m); |
533 |
534 |
535 |
if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
536 |
quiterr("error writing Radiance picture"); |
537 |
538 |
539 |
540 |
int |
541 |
L2Color(y) /* read/convert/write L16->COLOR scanline */ |
542 |
uint32 y; |
543 |
544 |
register int x; |
545 |
546 |
if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
547 |
quiterr("internal error 1 in L2Color"); |
548 |
549 |
550 |
551 |
552 |
553 |
colval(cvts.r.colors[x],RED) = |
554 |
colval(cvts.r.colors[x],GRN) = |
555 |
colval(cvts.r.colors[x],BLU) = |
556 |
cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.; |
557 |
558 |
559 |
560 |
561 |
562 |
563 |
int |
564 |
RGB2Colr(y) /* read/convert/write RGB->COLR scanline */ |
565 |
uint32 y; |
566 |
567 |
COLOR ctmp; |
568 |
register int x; |
569 |
570 |
if (CHK(C_RFLT|C_TFLT|C_GRY)) |
571 |
quiterr("internal error 1 in RGB2Colr"); |
572 |
573 |
if (cvts.pconf == PLANARCONFIG_CONTIG) { |
574 |
575 |
goto readerr; |
576 |
577 |
cvts.r.colrs[x][RED] = cvts.t.bp[3*x]; |
578 |
cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1]; |
579 |
cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2]; |
580 |
581 |
} else { |
582 |
583 |
goto readerr; |
584 |
if (TIFFReadScanline(cvts.tif, |
585 |
(tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) |
586 |
goto readerr; |
587 |
588 |
(tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) |
589 |
goto readerr; |
590 |
591 |
cvts.r.colrs[x][RED] = cvts.t.bp[x]; |
592 |
cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x]; |
593 |
cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x]; |
594 |
595 |
596 |
597 |
gambs_colrs(cvts.r.colrs, cvts.xmax); |
598 |
if (CHK(C_CXFM)) |
599 |
600 |
colr_color(ctmp, cvts.r.colrs[x]); |
601 |
colortrans(ctmp, cvts.cmat, ctmp); |
602 |
if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */ |
603 |
clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER, |
604 |
cblack, cwhite); |
605 |
setcolr(cvts.r.colrs[x], colval(ctmp,RED), |
606 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
607 |
608 |
if (cvts.bradj) |
609 |
shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj); |
610 |
611 |
if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
612 |
613 |
return; |
614 |
readerr: |
615 |
616 |
617 |
618 |
619 |
int |
620 |
Gry2Colr(y) /* read/convert/write G8->COLR scanline */ |
621 |
uint32 y; |
622 |
623 |
register int x; |
624 |
625 |
if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY)) |
626 |
quiterr("internal error 1 in Gry2Colr"); |
627 |
628 |
629 |
630 |
631 |
632 |
cvts.r.colrs[x][RED] = |
633 |
cvts.r.colrs[x][GRN] = |
634 |
cvts.r.colrs[x][BLU] = cvts.t.bp[x]; |
635 |
636 |
637 |
if (cvts.bradj) |
638 |
639 |
640 |
641 |
642 |
643 |
644 |
645 |
int |
646 |
Color2L(y) /* read/convert/write COLOR->L16 scanline */ |
647 |
uint32 y; |
648 |
649 |
650 |
register int x; |
651 |
652 |
653 |
quiterr("internal error 1 in Color2L"); |
654 |
655 |
if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
656 |
quiterr("error reading Radiance picture"); |
657 |
658 |
659 |
cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) |
660 |
: bright(cvts.r.colors[x]) ); |
661 |
662 |
if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
663 |
quiterr("error writing TIFF output"); |
664 |
665 |
666 |
667 |
int |
668 |
Color2Luv(y) /* read/convert/write COLOR->Luv scanline */ |
669 |
uint32 y; |
670 |
671 |
register int x; |
672 |
673 |
674 |
quiterr("internal error 1 in Color2Luv"); |
675 |
676 |
677 |
678 |
679 |
if (CHK(C_CXFM)) |
680 |
681 |
682 |
683 |
if (cvts.bradj) { |
684 |
685 |
686 |
687 |
688 |
689 |
690 |
cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX); |
691 |
cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY); |
692 |
cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ); |
693 |
694 |
695 |
696 |
697 |
698 |
699 |
700 |
int |
701 |
Colr2Gry(y) /* read/convert/write COLR->RGB scanline */ |
702 |
uint32 y; |
703 |
704 |
register int x; |
705 |
706 |
707 |
quiterr("internal error 1 in Colr2Gry"); |
708 |
709 |
if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
710 |
711 |
712 |
if (cvts.bradj) |
713 |
714 |
715 |
colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]); |
716 |
colrs_gambs(cvts.r.colrs, cvts.xmax); |
717 |
718 |
719 |
cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY); |
720 |
721 |
722 |
723 |
724 |
725 |
726 |
int |
727 |
Colr2RGB(y) /* read/convert/write COLR->RGB scanline */ |
728 |
uint32 y; |
729 |
730 |
COLOR ctmp; |
731 |
register int x; |
732 |
733 |
734 |
quiterr("internal error 1 in Colr2RGB"); |
735 |
736 |
737 |
738 |
739 |
if (cvts.bradj) |
740 |
741 |
if (CHK(C_CXFM)) |
742 |
743 |
744 |
745 |
if (CHK(C_GAMUT)) |
746 |
clipgamut(ctmp, bright(ctmp), CGAMUT, |
747 |
cblack, cwhite); |
748 |
749 |
750 |
751 |
752 |
753 |
754 |
cvts.t.bp[3*x] = cvts.r.colrs[x][RED]; |
755 |
cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN]; |
756 |
cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU]; |
757 |
758 |
759 |
760 |
761 |
