root/radiance/ray/src/px/ra_tiff.c
Revision: 2.25
Committed: Mon Jul 21 22:30:19 2003 UTC (21 years, 11 months ago) by schorsch
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.24 2003/07/16 01:32:53 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include <time.h>
14 #include "tiffio.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define GAMCOR 2.2 /* default gamma */
19
20 /* conversion flags */
21 #define C_CXFM 0x1 /* needs color transformation */
22 #define C_GAMUT 0x2 /* needs gamut mapping */
23 #define C_GAMMA 0x4 /* needs gamma correction */
24 #define C_GRY 0x8 /* TIFF is greyscale */
25 #define C_XYZE 0x10 /* Radiance is XYZE */
26 #define C_RFLT 0x20 /* Radiance data is float */
27 #define C_TFLT 0x40 /* TIFF data is float */
28 #define C_TWRD 0x80 /* TIFF data is 16-bit */
29 #define C_PRIM 0x100 /* has assigned primaries */
30
31 struct {
32 uint16 flags; /* conversion flags (defined above) */
33 char capdate[20]; /* capture date/time */
34 char owner[256]; /* content owner */
35 uint16 comp; /* TIFF compression type */
36 uint16 phot; /* TIFF photometric type */
37 uint16 pconf; /* TIFF planar configuration */
38 float gamcor; /* gamma correction value */
39 short bradj; /* Radiance exposure adjustment (stops) */
40 uint16 orient; /* visual orientation (TIFF spec.) */
41 double stonits; /* input conversion to nits */
42 float pixrat; /* pixel aspect ratio */
43 FILE *rfp; /* Radiance stream pointer */
44 TIFF *tif; /* TIFF pointer */
45 uint32 xmax, ymax; /* image dimensions */
46 COLORMAT cmat; /* color transformation matrix */
47 RGBPRIMS prims; /* RGB primaries */
48 union {
49 COLR *colrs; /* 4-byte ???E pointer */
50 COLOR *colors; /* float array pointer */
51 char *p; /* generic pointer */
52 } r; /* Radiance scanline */
53 union {
54 uint8 *bp; /* byte pointer */
55 uint16 *wp; /* word pointer */
56 float *fp; /* float pointer */
57 char *p; /* generic pointer */
58 } t; /* TIFF scanline */
59 void (*tf)(); /* translation procedure */
60 } cvts = { /* conversion structure */
61 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
62 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
63 };
64
65 #define CHK(f) (cvts.flags & (f))
66 #define SET(f) (cvts.flags |= (f))
67 #define CLR(f) (cvts.flags &= ~(f))
68 #define TGL(f) (cvts.flags ^= (f))
69
70 void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
71 void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
72 void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry();
73
74 #define RfGfBf2Color Luv2Color
75 #define Gryf2Color L2Color
76 #define Color2Gryf Color2L
77 #define Color2RfGfBf Color2Luv
78
79 short ortab[8] = { /* orientation conversion table */
80 YMAJOR|YDECR,
81 YMAJOR|YDECR|XDECR,
82 YMAJOR|XDECR,
83 YMAJOR,
84 YDECR,
85 XDECR|YDECR,
86 XDECR,
87 0
88 };
89
90 #define pixorder() ortab[cvts.orient-1]
91
92 extern char TMSTR[]; /* "CAPDATE=" from header.c */
93 char OWNSTR[] = "OWNER=";
94
95 char *progname;
96
97
98 main(argc, argv)
99 int argc;
100 char *argv[];
101 {
102 int reverse = 0;
103 int i;
104
105 progname = argv[0];
106
107 for (i = 1; i < argc; i++)
108 if (argv[i][0] == '-')
109 switch (argv[i][1]) {
110 case 'g': /* gamma correction */
111 cvts.gamcor = atof(argv[++i]);
112 break;
113 case 'x': /* XYZE Radiance output */
114 TGL(C_XYZE);
115 break;
116 case 'z': /* LZW compressed output */
117 cvts.comp = COMPRESSION_LZW;
118 break;
119 case 'L': /* LogLuv 32-bit output */
120 cvts.comp = COMPRESSION_SGILOG;
121 cvts.phot = PHOTOMETRIC_LOGLUV;
122 break;
123 case 'l': /* LogLuv 24-bit output */
124 cvts.comp = COMPRESSION_SGILOG24;
125 cvts.phot = PHOTOMETRIC_LOGLUV;
126 break;
127 case 'w': /* 16-bit/primary output? */
128 TGL(C_TWRD);
129 break;
130 case 'f': /* IEEE float output? */
131 TGL(C_TFLT);
132 break;
133 case 'b': /* greyscale output? */
134 TGL(C_GRY);
135 break;
136 case 'e': /* exposure adjustment */
137 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
138 goto userr;
139 cvts.bradj = atoi(argv[++i]);
140 break;
141 case 'r': /* reverse conversion? */
142 reverse = !reverse;
143 break;
144 case '\0':
145 goto doneopts;
146 default:
147 goto userr;
148 }
149 else
150 break;
151 doneopts:
152 if (reverse) {
153
154 if (i != argc-2 && i != argc-1)
155 goto userr;
156
157 tiff2ra(i, argv);
158
159 } else {
160
161 if (i != argc-2)
162 goto userr;
163 /* consistency checks */
164 if (CHK(C_GRY)) {
165 if (cvts.phot == PHOTOMETRIC_RGB)
166 cvts.phot = PHOTOMETRIC_MINISBLACK;
167 else {
168 cvts.phot = PHOTOMETRIC_LOGL;
169 cvts.comp = COMPRESSION_SGILOG;
170 }
171 }
172 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
173 goto userr;
174
175 ra2tiff(i, argv);
176 }
177
178 exit(0);
179 userr:
180 fprintf(stderr,
181 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
182 progname);
183 fprintf(stderr,
184 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
185 progname);
186 exit(1);
187 }
188
189
190 quiterr(err) /* print message and exit */
191 char *err;
192 {
193 if (err != NULL) {
194 fprintf(stderr, "%s: %s\n", progname, err);
195 exit(1);
196 }
197 exit(0);
198 }
199
200
201 allocbufs() /* allocate scanline buffers */
202 {
203 int rsiz, tsiz;
204
205 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
206 tsiz = (CHK(C_TFLT) ? sizeof(float) :
207 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
208 (CHK(C_GRY) ? 1 : 3);
209 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
210 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
211 if (cvts.r.p == NULL | cvts.t.p == NULL)
212 quiterr("no memory to allocate scanline buffers");
213 }
214
215
216 initfromtif() /* initialize conversion from TIFF input */
217 {
218 uint16 hi;
219 char *cp;
220 float *fa, f1, f2;
221
222 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
223
224 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
225
226 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
227 cvts.prims[RED][CIEX] = fa[0];
228 cvts.prims[RED][CIEY] = fa[1];
229 cvts.prims[GRN][CIEX] = fa[2];
230 cvts.prims[GRN][CIEY] = fa[3];
231 cvts.prims[BLU][CIEX] = fa[4];
232 cvts.prims[BLU][CIEY] = fa[5];
233 cvts.prims[WHT][CIEX] = 1./3.;
234 cvts.prims[WHT][CIEY] = 1./3.;
235 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
236 cvts.prims[WHT][CIEX] = fa[0];
237 cvts.prims[WHT][CIEY] = fa[1];
238 }
239 SET(C_PRIM);
240 }
241
242 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
243 cvts.comp = COMPRESSION_NONE;
244
245 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
246 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
247 cvts.pixrat = f1/f2;
248
249 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
250
251 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
252 quiterr("TIFF has unspecified photometric type");
253
254 switch (cvts.phot) {
255 case PHOTOMETRIC_LOGLUV:
256 SET(C_RFLT|C_TFLT);
257 if (!CHK(C_XYZE)) {
258 cpcolormat(cvts.cmat, xyz2rgbmat);
259 SET(C_CXFM|C_GAMUT);
260 } else if (cvts.comp == COMPRESSION_SGILOG)
261 SET(C_GAMUT);
262 if (cvts.pconf != PLANARCONFIG_CONTIG)
263 quiterr("cannot handle separate Luv planes");
264 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
265 SGILOGDATAFMT_FLOAT);
266 cvts.tf = Luv2Color;
267 break;
268 case PHOTOMETRIC_LOGL:
269 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
270 cvts.pconf = PLANARCONFIG_CONTIG;
271 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
272 SGILOGDATAFMT_FLOAT);
273 cvts.tf = L2Color;
274 break;
275 case PHOTOMETRIC_YCBCR:
276 if (cvts.comp == COMPRESSION_JPEG &&
277 cvts.pconf == PLANARCONFIG_CONTIG) {
278 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
279 JPEGCOLORMODE_RGB);
280 cvts.phot = PHOTOMETRIC_RGB;
281 } else
282 quiterr("unsupported photometric type");
283 /* fall through */
284 case PHOTOMETRIC_RGB:
285 SET(C_GAMMA);
286 setcolrgam(cvts.gamcor);
287 if (CHK(C_XYZE)) {
288 comprgb2xyzWBmat(cvts.cmat,
289 CHK(C_PRIM) ? cvts.prims : stdprims);
290 SET(C_CXFM);
291 }
292 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
293 hi != 3)
294 quiterr("unsupported samples per pixel for RGB");
295 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
296 hi = -1;
297 switch (hi) {
298 case 8:
299 cvts.tf = RGB2Colr;
300 break;
301 case 16:
302 cvts.tf = RRGGBB2Color;
303 SET(C_RFLT|C_TWRD);
304 break;
305 case 32:
306 cvts.tf = RfGfBf2Color;
307 SET(C_RFLT|C_TFLT);
308 break;
309 default:
310 quiterr("unsupported bits per sample for RGB");
311 }
312 break;
313 case PHOTOMETRIC_MINISBLACK:
314 SET(C_GRY|C_GAMMA);
315 setcolrgam(cvts.gamcor);
316 cvts.pconf = PLANARCONFIG_CONTIG;
317 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
318 hi != 1)
319 quiterr("unsupported samples per pixel for greyscale");
320 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
321 hi = -1;
322 switch (hi) {
323 case 8:
324 cvts.tf = Gry2Colr;
325 break;
326 case 16:
327 cvts.tf = GGry2Color;
328 SET(C_RFLT|C_TWRD);
329 break;
330 case 32:
331 cvts.tf = Gryf2Color;
332 SET(C_RFLT|C_TFLT);
333 break;
334 default:
335 quiterr("unsupported bits per sample for Gray");
336 }
337 break;
338 default:
339 quiterr("unsupported photometric type");
340 break;
341 }
342
343 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
344 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
345 quiterr("unknown input image resolution");
346
347 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
348 cvts.stonits = 1.;
349
350 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
351 cvts.capdate[0] = '\0';
352 else {
353 strncpy(cvts.capdate, cp, 19);
354 cvts.capdate[19] = '\0';
355 }
356 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
357 cvts.owner[0] = '\0';
358 else {
359 strncpy(cvts.owner, cp, sizeof(cvts.owner));
360 cvts.owner[sizeof(cvts.owner)-1] = '\0';
361 }
362 /* add to Radiance header */
363 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
364 fputaspect(cvts.pixrat, cvts.rfp);
365 if (CHK(C_XYZE)) {
366 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
367 fputformat(CIEFMT, cvts.rfp);
368 } else {
369 if (CHK(C_PRIM))
370 fputprims(cvts.prims, cvts.rfp);
371 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
372 cvts.rfp);
373 fputformat(COLRFMT, cvts.rfp);
374 }
375 if (cvts.capdate[0])
376 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
377 if (cvts.owner[0])
378 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
379
380 allocbufs(); /* allocate scanline buffers */
381 }
382
383
384 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
385 int ac;
386 char *av[];
387 {
388 int32 y;
389 /* open TIFF input */
390 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
391 quiterr("cannot open TIFF input");
392 /* open Radiance output */
393 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
394 cvts.rfp = stdout;
395 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
396 quiterr("cannot open Radiance output picture");
397 /* start output header */
398 newheader("RADIANCE", cvts.rfp);
399 printargs(ac, av, cvts.rfp);
400
401 initfromtif(); /* initialize conversion */
402
403 fputc('\n', cvts.rfp); /* finish Radiance header */
404 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
405
406 for (y = 0; y < cvts.ymax; y++) /* convert image */
407 (*cvts.tf)(y);
408 /* clean up */
409 fclose(cvts.rfp);
410 TIFFClose(cvts.tif);
411 }
412
413
414 int
415 headline(s) /* process Radiance input header line */
416 char *s;
417 {
418 static int tmstrlen = 0;
419 static int ownstrlen = 0;
420 char fmt[32];
421
422 if (!tmstrlen)
423 tmstrlen = strlen(TMSTR);
424 if (!ownstrlen)
425 ownstrlen = strlen(OWNSTR);
426 if (formatval(fmt, s)) {
427 if (!strcmp(fmt, COLRFMT))
428 CLR(C_XYZE);
429 else if (!strcmp(fmt, CIEFMT))
430 SET(C_XYZE);
431 else
432 quiterr("unrecognized input picture format");
433 return(1);
434 }
435 if (isexpos(s)) {
436 cvts.stonits /= exposval(s);
437 return(1);
438 }
439 if (isaspect(s)) {
440 cvts.pixrat *= aspectval(s);
441 return(1);
442 }
443 if (isprims(s)) {
444 primsval(cvts.prims, s);
445 SET(C_PRIM);
446 return(1);
447 }
448 if (isdate(s)) {
449 if (s[tmstrlen] == ' ')
450 strncpy(cvts.capdate, s+tmstrlen+1, 19);
451 else
452 strncpy(cvts.capdate, s+tmstrlen, 19);
453 cvts.capdate[19] = '\0';
454 return(1);
455 }
456 if (!strncmp(s, OWNSTR, ownstrlen)) {
457 register char *cp = s + ownstrlen;
458
459 while (isspace(*cp))
460 ++cp;
461 strncpy(cvts.owner, cp, sizeof(cvts.owner));
462 cvts.owner[sizeof(cvts.owner)-1] = '\0';
463 for (cp = cvts.owner; *cp; cp++)
464 ;
465 while (cp > cvts.owner && isspace(cp[-1]))
466 *--cp = '\0';
467 return(1);
468 }
469 return(0);
470 }
471
472
473 initfromrad() /* initialize input from a Radiance picture */
474 {
475 int i1, i2, po;
476 /* read Radiance header */
477 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
478 cvts.capdate[0] = '\0';
479 cvts.owner[0] = '\0';
480 cvts.stonits = 1.;
481 cvts.pixrat = 1.;
482 cvts.pconf = PLANARCONFIG_CONTIG;
483 getheader(cvts.rfp, headline, NULL);
484 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
485 quiterr("bad Radiance picture");
486 cvts.xmax = i1; cvts.ymax = i2;
487 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
488 if (ortab[i1] == po) {
489 cvts.orient = i1 + 1;
490 break;
491 }
492 if (i1 >= 8)
493 quiterr("internal error 1 in initfromrad");
494 if (!(po & YMAJOR))
495 cvts.pixrat = 1./cvts.pixrat;
496 if (!CHK(C_XYZE))
497 cvts.stonits *= WHTEFFICACY;
498 /* set up conversion */
499 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
500 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
501
502 switch (cvts.phot) {
503 case PHOTOMETRIC_LOGLUV:
504 SET(C_RFLT|C_TFLT);
505 CLR(C_GRY|C_TWRD);
506 if (!CHK(C_XYZE)) {
507 comprgb2xyzWBmat(cvts.cmat,
508 CHK(C_PRIM) ? cvts.prims : stdprims);
509 SET(C_CXFM);
510 }
511 if (cvts.comp != COMPRESSION_SGILOG &&
512 cvts.comp != COMPRESSION_SGILOG24)
513 quiterr("internal error 2 in initfromrad");
514 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
515 SGILOGDATAFMT_FLOAT);
516 cvts.tf = Color2Luv;
517 break;
518 case PHOTOMETRIC_LOGL:
519 SET(C_GRY|C_RFLT|C_TFLT);
520 CLR(C_TWRD);
521 if (cvts.comp != COMPRESSION_SGILOG)
522 quiterr("internal error 3 in initfromrad");
523 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
524 SGILOGDATAFMT_FLOAT);
525 cvts.tf = Color2L;
526 break;
527 case PHOTOMETRIC_RGB:
528 SET(C_GAMMA|C_GAMUT);
529 CLR(C_GRY);
530 setcolrgam(cvts.gamcor);
531 if (CHK(C_XYZE)) {
532 compxyz2rgbWBmat(cvts.cmat,
533 CHK(C_PRIM) ? cvts.prims : stdprims);
534 SET(C_CXFM);
535 }
536 if (CHK(C_PRIM)) {
537 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
538 (float *)cvts.prims);
539 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
540 (float *)cvts.prims[WHT]);
541 }
542 if (CHK(C_TWRD)) {
543 cvts.tf = Color2RRGGBB;
544 SET(C_RFLT);
545 } else if (CHK(C_TFLT)) {
546 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
547 SAMPLEFORMAT_IEEEFP);
548 cvts.tf = Color2RfGfBf;
549 SET(C_RFLT);
550 } else
551 cvts.tf = Colr2RGB;
552 break;
553 case PHOTOMETRIC_MINISBLACK:
554 SET(C_GRY|C_GAMMA|C_GAMUT);
555 setcolrgam(cvts.gamcor);
556 if (CHK(C_TWRD)) {
557 cvts.tf = Color2GGry;
558 SET(C_RFLT);
559 } else if (CHK(C_TFLT)) {
560 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
561 SAMPLEFORMAT_IEEEFP);
562 cvts.tf = Color2Gryf;
563 SET(C_RFLT);
564 } else
565 cvts.tf = Colr2Gry;
566 break;
567 default:
568 quiterr("internal error 4 in initfromrad");
569 break;
570 }
571 /* set other TIFF fields */
572 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
573 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
574 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
575 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
576 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
577 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
578 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
579 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
580 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
581 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
582 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
583 cvts.stonits/pow(2.,(double)cvts.bradj));
584 if (cvts.capdate[0])
585 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
586 if (cvts.owner[0])
587 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
588 if (cvts.comp == COMPRESSION_NONE)
589 i1 = TIFFScanlineSize(cvts.tif);
590 else
591 i1 = 3*cvts.xmax; /* conservative guess */
592 i2 = 8192/i1; /* compute good strip size */
593 if (i2 < 1) i2 = 1;
594 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
595
596 allocbufs(); /* allocate scanline buffers */
597 }
598
599
600 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
601 int ac;
602 char *av[];
603 {
604 uint32 y;
605 /* open Radiance file */
606 if (!strcmp(av[ac], "-"))
607 cvts.rfp = stdin;
608 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
609 quiterr("cannot open Radiance input picture");
610 /* open TIFF file */
611 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
612 quiterr("cannot open TIFF output");
613
614 initfromrad(); /* initialize conversion */
615
616 for (y = 0; y < cvts.ymax; y++) /* convert image */
617 (*cvts.tf)(y);
618 /* clean up */
619 TIFFClose(cvts.tif);
620 fclose(cvts.rfp);
621 }
622
623
624 void
625 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
626 uint32 y;
627 {
628 register int x;
629
630 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
631 quiterr("internal error 1 in Luv2Color");
632
633 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
634 quiterr("error reading TIFF input");
635 /* also works for float RGB */
636 for (x = cvts.xmax; x--; ) {
637 setcolor(cvts.r.colors[x],
638 cvts.t.fp[3*x],
639 cvts.t.fp[3*x + 1],
640 cvts.t.fp[3*x + 2]);
641 if (CHK(C_CXFM))
642 colortrans(cvts.r.colors[x], cvts.cmat,
643 cvts.r.colors[x]);
644 if (CHK(C_GAMUT))
645 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
646 CGAMUT_LOWER, cblack, cwhite);
647 }
648 if (cvts.bradj) {
649 double m = pow(2.,(double)cvts.bradj);
650 for (x = cvts.xmax; x--; )
651 scalecolor(cvts.r.colors[x], m);
652 }
653
654 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
655 quiterr("error writing Radiance picture");
656 }
657
658
659 void
660 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
661 uint32 y;
662 {
663 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
664 register double d;
665 register int x;
666
667 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
668 quiterr("internal error 1 in RRGGBB2Color");
669
670 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
671 quiterr("error reading TIFF input");
672
673 for (x = cvts.xmax; x--; ) {
674 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
675 if (dogamma) d = pow(d, cvts.gamcor);
676 colval(cvts.r.colors[x],RED) = d;
677 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
678 if (dogamma) d = pow(d, cvts.gamcor);
679 colval(cvts.r.colors[x],GRN) = d;
680 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
681 if (dogamma) d = pow(d, cvts.gamcor);
682 colval(cvts.r.colors[x],BLU) = d;
683 if (CHK(C_CXFM))
684 colortrans(cvts.r.colors[x], cvts.cmat,
685 cvts.r.colors[x]);
686 if (CHK(C_GAMUT))
687 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
688 CGAMUT_LOWER, cblack, cwhite);
689 }
690 if (cvts.bradj) {
691 d = pow(2.,(double)cvts.bradj);
692 for (x = cvts.xmax; x--; )
693 scalecolor(cvts.r.colors[x], d);
694 }
695
696 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
697 quiterr("error writing Radiance picture");
698 }
699
700
701 void
702 L2Color(y) /* read/convert/write Lfloat->COLOR scanline */
703 uint32 y;
704 {
705 float m = pow(2., (double)cvts.bradj);
706 register int x;
707
708 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
709 quiterr("internal error 1 in L2Color");
710
711 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
712 quiterr("error reading TIFF input");
713 /* also works for float greyscale */
714 for (x = cvts.xmax; x--; ) {
715 register float f = cvts.t.fp[x];
716 if (cvts.bradj) f *= m;
717 setcolor(cvts.r.colors[x], f, f, f);
718 }
719 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
720 quiterr("error writing Radiance picture");
721 }
722
723
724 void
725 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
726 uint32 y;
727 {
728 COLOR ctmp;
729 register int x;
730
731 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
732 quiterr("internal error 1 in RGB2Colr");
733
734 if (cvts.pconf == PLANARCONFIG_CONTIG) {
735 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
736 goto readerr;
737 for (x = cvts.xmax; x--; ) {
738 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
739 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
740 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
741 }
742 } else {
743 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
744 goto readerr;
745 if (TIFFReadScanline(cvts.tif,
746 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
747 goto readerr;
748 if (TIFFReadScanline(cvts.tif,
749 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
750 goto readerr;
751 for (x = cvts.xmax; x--; ) {
752 cvts.r.colrs[x][RED] = cvts.t.bp[x];
753 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
754 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
755 }
756 }
757
758 gambs_colrs(cvts.r.colrs, cvts.xmax);
759 if (CHK(C_CXFM))
760 for (x = cvts.xmax; x--; ) {
761 colr_color(ctmp, cvts.r.colrs[x]);
762 colortrans(ctmp, cvts.cmat, ctmp);
763 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
764 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
765 cblack, cwhite);
766 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
767 colval(ctmp,GRN), colval(ctmp,BLU));
768 }
769 if (cvts.bradj)
770 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
771
772 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
773 quiterr("error writing Radiance picture");
774 return;
775 readerr:
776 quiterr("error reading TIFF input");
777 }
778
779
780 void
781 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
782 uint32 y;
783 {
784 register int x;
785
786 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
787 quiterr("internal error 1 in Gry2Colr");
788
789 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
790 quiterr("error reading TIFF input");
791
792 for (x = cvts.xmax; x--; )
793 cvts.r.colrs[x][RED] =
794 cvts.r.colrs[x][GRN] =
795 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
796
797 gambs_colrs(cvts.r.colrs, cvts.xmax);
798 if (cvts.bradj)
799 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
800
801 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
802 quiterr("error writing Radiance picture");
803 }
804
805
806 void
807 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
808 uint32 y;
809 {
810 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
811 double m;
812 register double d;
813 register int x;
814
815 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
816 quiterr("internal error 1 in GGry2Color");
817
818 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
819 quiterr("error reading TIFF input");
820
821 if (cvts.bradj)
822 m = pow(2., (double)cvts.bradj);
823 for (x = cvts.xmax; x--; ) {
824 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
825 if (dogamma) d = pow(d, cvts.gamcor);
826 if (cvts.bradj) d *= m;
827 colval(cvts.r.colors[x],RED) =
828 colval(cvts.r.colors[x],GRN) =
829 colval(cvts.r.colors[x],BLU) = d;
830 }
831 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
832 quiterr("error writing Radiance picture");
833 }
834
835
836 void
837 Color2GGry(y) /* read/convert/write COLOR->G16 scanline */
838 uint32 y;
839 {
840 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
841 float m = pow(2.,(double)cvts.bradj);
842 register int x;
843
844 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
845 quiterr("internal error 1 in Color2GGry");
846
847 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
848 quiterr("error reading Radiance picture");
849
850 for (x = cvts.xmax; x--; ) {
851 register float f = m*( CHK(C_XYZE) ?
852 colval(cvts.r.colors[x],CIEY)
853 : bright(cvts.r.colors[x]) );
854 if (f <= 0)
855 cvts.t.wp[x] = 0;
856 else if (f >= 1)
857 cvts.t.wp[x] = 0xffff;
858 else if (dogamma)
859 cvts.t.wp[x] = (int)((float)(1L<<16) *
860 pow(f, 1./cvts.gamcor));
861 else
862 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
863 }
864
865 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
866 quiterr("error writing TIFF output");
867 }
868
869
870 void
871 Color2L(y) /* read/convert/write COLOR->Lfloat scanline */
872 uint32 y;
873 {
874 float m = pow(2.,(double)cvts.bradj);
875 register int x;
876
877 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
878 quiterr("internal error 1 in Color2L");
879
880 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
881 quiterr("error reading Radiance picture");
882
883 for (x = cvts.xmax; x--; )
884 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
885 : bright(cvts.r.colors[x]) );
886
887 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
888 quiterr("error writing TIFF output");
889 }
890
891
892 void
893 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
894 uint32 y;
895 {
896 register int x;
897
898 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
899 quiterr("internal error 1 in Color2Luv");
900
901 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
902 quiterr("error reading Radiance picture");
903
904 if (CHK(C_CXFM))
905 for (x = cvts.xmax; x--; )
906 colortrans(cvts.r.colors[x], cvts.cmat,
907 cvts.r.colors[x]);
908 if (cvts.bradj) {
909 double m = pow(2.,(double)cvts.bradj);
910 for (x = cvts.xmax; x--; )
911 scalecolor(cvts.r.colors[x], m);
912 }
913 /* also works for float RGB */
914 for (x = cvts.xmax; x--; ) {
915 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
916 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
917 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
918 }
919
920 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
921 quiterr("error writing TIFF output");
922 }
923
924
925 void
926 Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */
927 uint32 y;
928 {
929 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
930 float m = pow(2.,(double)cvts.bradj);
931 register int x, i;
932
933 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
934 quiterr("internal error 1 in Color2RRGGBB");
935
936 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
937 quiterr("error reading Radiance picture");
938
939 for (x = cvts.xmax; x--; )
940 for (i = 3; i--; ) {
941 register float f = m*colval(cvts.r.colors[x],i);
942 if (f <= 0)
943 cvts.t.wp[3*x + i] = 0;
944 else if (f >= 1)
945 cvts.t.wp[3*x + i] = 0xffff;
946 else if (dogamma)
947 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
948 pow(f, 1./cvts.gamcor));
949 else
950 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
951 }
952
953 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
954 quiterr("error writing TIFF output");
955 }
956
957
958 void
959 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
960 uint32 y;
961 {
962 register int x;
963
964 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
965 quiterr("internal error 1 in Colr2Gry");
966
967 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
968 quiterr("error reading Radiance picture");
969
970 if (cvts.bradj)
971 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
972 for (x = cvts.xmax; x--; )
973 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
974 colrs_gambs(cvts.r.colrs, cvts.xmax);
975
976 for (x = cvts.xmax; x--; )
977 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
978
979 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
980 quiterr("error writing TIFF output");
981 }
982
983
984 void
985 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
986 uint32 y;
987 {
988 COLOR ctmp;
989 register int x;
990
991 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
992 quiterr("internal error 1 in Colr2RGB");
993
994 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
995 quiterr("error reading Radiance picture");
996
997 if (cvts.bradj)
998 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
999 if (CHK(C_CXFM))
1000 for (x = cvts.xmax; x--; ) {
1001 colr_color(ctmp, cvts.r.colrs[x]);
1002 colortrans(ctmp, cvts.cmat, ctmp);
1003 if (CHK(C_GAMUT))
1004 clipgamut(ctmp, bright(ctmp), CGAMUT,
1005 cblack, cwhite);
1006 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1007 colval(ctmp,GRN), colval(ctmp,BLU));
1008 }
1009 colrs_gambs(cvts.r.colrs, cvts.xmax);
1010
1011 for (x = cvts.xmax; x--; ) {
1012 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1013 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1014 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1015 }
1016
1017 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1018 quiterr("error writing TIFF output");
1019 }
