root/radiance/ray/src/px/ra_tiff.c
Revision: 2.24
Committed: Wed Jul 16 01:32:53 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.23: +2 -1 lines
Minor compile fixes
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.23 2003/07/14 04:56:54 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include <time.h>
14 #include "tiffio.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define GAMCOR 2.2 /* default gamma */
19
20 /* conversion flags */
21 #define C_CXFM 0x1 /* needs color transformation */
22 #define C_GAMUT 0x2 /* needs gamut mapping */
23 #define C_GAMMA 0x4 /* needs gamma correction */
24 #define C_GRY 0x8 /* TIFF is greyscale */
25 #define C_XYZE 0x10 /* Radiance is XYZE */
26 #define C_RFLT 0x20 /* Radiance data is float */
27 #define C_TFLT 0x40 /* TIFF data is float */
28 #define C_TWRD 0x80 /* TIFF data is 16-bit */
29 #define C_PRIM 0x100 /* has assigned primaries */
30
31 struct {
32 uint16 flags; /* conversion flags (defined above) */
33 char capdate[20]; /* capture date/time */
34 char owner[256]; /* content owner */
35 uint16 comp; /* TIFF compression type */
36 uint16 phot; /* TIFF photometric type */
37 uint16 pconf; /* TIFF planar configuration */
38 float gamcor; /* gamma correction value */
39 short bradj; /* Radiance exposure adjustment (stops) */
40 uint16 orient; /* visual orientation (TIFF spec.) */
41 double stonits; /* input conversion to nits */
42 float pixrat; /* pixel aspect ratio */
43 FILE *rfp; /* Radiance stream pointer */
44 TIFF *tif; /* TIFF pointer */
45 uint32 xmax, ymax; /* image dimensions */
46 COLORMAT cmat; /* color transformation matrix */
47 RGBPRIMS prims; /* RGB primaries */
48 union {
49 COLR *colrs; /* 4-byte ???E pointer */
50 COLOR *colors; /* float array pointer */
51 char *p; /* generic pointer */
52 } r; /* Radiance scanline */
53 union {
54 uint8 *bp; /* byte pointer */
55 uint16 *wp; /* word pointer */
56 float *fp; /* float pointer */
57 char *p; /* generic pointer */
58 } t; /* TIFF scanline */
59 void (*tf)(); /* translation procedure */
60 } cvts = { /* conversion structure */
61 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
62 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
63 };
64
65 #define CHK(f) (cvts.flags & (f))
66 #define SET(f) (cvts.flags |= (f))
67 #define CLR(f) (cvts.flags &= ~(f))
68 #define TGL(f) (cvts.flags ^= (f))
69
70 void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
71 void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
72 void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry();
73
74 #define RfGfBf2Color Luv2Color
75 #define Gryf2Color L2Color
76 #define Color2Gryf Color2L
77 #define Color2RfGfBf Color2Luv
78
79 short ortab[8] = { /* orientation conversion table */
80 YMAJOR|YDECR,
81 YMAJOR|YDECR|XDECR,
82 YMAJOR|XDECR,
83 YMAJOR,
84 YDECR,
85 XDECR|YDECR,
86 XDECR,
87 0
88 };
89
90 #define pixorder() ortab[cvts.orient-1]
91
92 extern char TMSTR[]; /* "CAPDATE=" from header.c */
93 char OWNSTR[] = "OWNER=";
94
95 char *progname;
96
97
98 main(argc, argv)
99 int argc;
100 char *argv[];
101 {
102 int reverse = 0;
103 int i;
104
105 progname = argv[0];
106
107 for (i = 1; i < argc; i++)
108 if (argv[i][0] == '-')
109 switch (argv[i][1]) {
110 case 'g': /* gamma correction */
111 cvts.gamcor = atof(argv[++i]);
112 break;
113 case 'x': /* XYZE Radiance output */
114 TGL(C_XYZE);
115 break;
116 case 'z': /* LZW compressed output */
117 cvts.comp = COMPRESSION_LZW;
118 break;
119 case 'L': /* LogLuv 32-bit output */
120 cvts.comp = COMPRESSION_SGILOG;
121 cvts.phot = PHOTOMETRIC_LOGLUV;
122 break;
123 case 'l': /* LogLuv 24-bit output */
124 cvts.comp = COMPRESSION_SGILOG24;
125 cvts.phot = PHOTOMETRIC_LOGLUV;
126 break;
127 case 'w': /* 16-bit/primary output? */
128 TGL(C_TWRD);
129 break;
130 case 'f': /* IEEE float output? */
131 TGL(C_TFLT);
132 break;
133 case 'b': /* greyscale output? */
134 TGL(C_GRY);
135 break;
136 case 'e': /* exposure adjustment */
137 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
138 goto userr;
139 cvts.bradj = atoi(argv[++i]);
140 break;
141 case 'r': /* reverse conversion? */
142 reverse = !reverse;
143 break;
144 case '\0':
145 goto doneopts;
146 default:
147 goto userr;
148 }
149 else
150 break;
151 doneopts:
152 if (reverse) {
153
154 if (i != argc-2 && i != argc-1)
155 goto userr;
156
157 tiff2ra(i, argv);
158
159 } else {
160
161 if (i != argc-2)
162 goto userr;
163 /* consistency checks */
164 if (CHK(C_GRY))
165 if (cvts.phot == PHOTOMETRIC_RGB)
166 cvts.phot = PHOTOMETRIC_MINISBLACK;
167 else {
168 cvts.phot = PHOTOMETRIC_LOGL;
169 cvts.comp = COMPRESSION_SGILOG;
170 }
171 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
172 goto userr;
173
174 ra2tiff(i, argv);
175 }
176
177 exit(0);
178 userr:
179 fprintf(stderr,
180 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
181 progname);
182 fprintf(stderr,
183 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
184 progname);
185 exit(1);
186 }
187
188
189 quiterr(err) /* print message and exit */
190 char *err;
191 {
192 if (err != NULL) {
193 fprintf(stderr, "%s: %s\n", progname, err);
194 exit(1);
195 }
196 exit(0);
197 }
198
199
200 allocbufs() /* allocate scanline buffers */
201 {
202 int rsiz, tsiz;
203
204 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
205 tsiz = (CHK(C_TFLT) ? sizeof(float) :
206 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
207 (CHK(C_GRY) ? 1 : 3);
208 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
209 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
210 if (cvts.r.p == NULL | cvts.t.p == NULL)
211 quiterr("no memory to allocate scanline buffers");
212 }
213
214
215 initfromtif() /* initialize conversion from TIFF input */
216 {
217 uint16 hi;
218 char *cp;
219 float *fa, f1, f2;
220
221 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
222
223 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
224
225 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
226 cvts.prims[RED][CIEX] = fa[0];
227 cvts.prims[RED][CIEY] = fa[1];
228 cvts.prims[GRN][CIEX] = fa[2];
229 cvts.prims[GRN][CIEY] = fa[3];
230 cvts.prims[BLU][CIEX] = fa[4];
231 cvts.prims[BLU][CIEY] = fa[5];
232 cvts.prims[WHT][CIEX] = 1./3.;
233 cvts.prims[WHT][CIEY] = 1./3.;
234 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
235 cvts.prims[WHT][CIEX] = fa[0];
236 cvts.prims[WHT][CIEY] = fa[1];
237 }
238 SET(C_PRIM);
239 }
240
241 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
242 cvts.comp = COMPRESSION_NONE;
243
244 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
245 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
246 cvts.pixrat = f1/f2;
247
248 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
249
250 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
251 quiterr("TIFF has unspecified photometric type");
252
253 switch (cvts.phot) {
254 case PHOTOMETRIC_LOGLUV:
255 SET(C_RFLT|C_TFLT);
256 if (!CHK(C_XYZE)) {
257 cpcolormat(cvts.cmat, xyz2rgbmat);
258 SET(C_CXFM|C_GAMUT);
259 } else if (cvts.comp == COMPRESSION_SGILOG)
260 SET(C_GAMUT);
261 if (cvts.pconf != PLANARCONFIG_CONTIG)
262 quiterr("cannot handle separate Luv planes");
263 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
264 SGILOGDATAFMT_FLOAT);
265 cvts.tf = Luv2Color;
266 break;
267 case PHOTOMETRIC_LOGL:
268 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
269 cvts.pconf = PLANARCONFIG_CONTIG;
270 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
271 SGILOGDATAFMT_FLOAT);
272 cvts.tf = L2Color;
273 break;
274 case PHOTOMETRIC_YCBCR:
275 if (cvts.comp == COMPRESSION_JPEG &&
276 cvts.pconf == PLANARCONFIG_CONTIG) {
277 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
278 JPEGCOLORMODE_RGB);
279 cvts.phot = PHOTOMETRIC_RGB;
280 } else
281 quiterr("unsupported photometric type");
282 /* fall through */
283 case PHOTOMETRIC_RGB:
284 SET(C_GAMMA);
285 setcolrgam(cvts.gamcor);
286 if (CHK(C_XYZE)) {
287 comprgb2xyzWBmat(cvts.cmat,
288 CHK(C_PRIM) ? cvts.prims : stdprims);
289 SET(C_CXFM);
290 }
291 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
292 hi != 3)
293 quiterr("unsupported samples per pixel for RGB");
294 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
295 hi = -1;
296 switch (hi) {
297 case 8:
298 cvts.tf = RGB2Colr;
299 break;
300 case 16:
301 cvts.tf = RRGGBB2Color;
302 SET(C_RFLT|C_TWRD);
303 break;
304 case 32:
305 cvts.tf = RfGfBf2Color;
306 SET(C_RFLT|C_TFLT);
307 break;
308 default:
309 quiterr("unsupported bits per sample for RGB");
310 }
311 break;
312 case PHOTOMETRIC_MINISBLACK:
313 SET(C_GRY|C_GAMMA);
314 setcolrgam(cvts.gamcor);
315 cvts.pconf = PLANARCONFIG_CONTIG;
316 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
317 hi != 1)
318 quiterr("unsupported samples per pixel for greyscale");
319 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
320 hi = -1;
321 switch (hi) {
322 case 8:
323 cvts.tf = Gry2Colr;
324 break;
325 case 16:
326 cvts.tf = GGry2Color;
327 SET(C_RFLT|C_TWRD);
328 break;
329 case 32:
330 cvts.tf = Gryf2Color;
331 SET(C_RFLT|C_TFLT);
332 break;
333 default:
334 quiterr("unsupported bits per sample for Gray");
335 }
336 break;
337 default:
338 quiterr("unsupported photometric type");
339 break;
340 }
341
342 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
343 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
344 quiterr("unknown input image resolution");
345
346 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
347 cvts.stonits = 1.;
348
349 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
350 cvts.capdate[0] = '\0';
351 else {
352 strncpy(cvts.capdate, cp, 19);
353 cvts.capdate[19] = '\0';
354 }
355 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
356 cvts.owner[0] = '\0';
357 else {
358 strncpy(cvts.owner, cp, sizeof(cvts.owner));
359 cvts.owner[sizeof(cvts.owner)-1] = '\0';
360 }
361 /* add to Radiance header */
362 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
363 fputaspect(cvts.pixrat, cvts.rfp);
364 if (CHK(C_XYZE)) {
365 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
366 fputformat(CIEFMT, cvts.rfp);
367 } else {
368 if (CHK(C_PRIM))
369 fputprims(cvts.prims, cvts.rfp);
370 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
371 cvts.rfp);
372 fputformat(COLRFMT, cvts.rfp);
373 }
374 if (cvts.capdate[0])
375 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
376 if (cvts.owner[0])
377 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
378
379 allocbufs(); /* allocate scanline buffers */
380 }
381
382
383 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
384 int ac;
385 char *av[];
386 {
387 int32 y;
388 /* open TIFF input */
389 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
390 quiterr("cannot open TIFF input");
391 /* open Radiance output */
392 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
393 cvts.rfp = stdout;
394 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
395 quiterr("cannot open Radiance output picture");
396 /* start output header */
397 newheader("RADIANCE", cvts.rfp);
398 printargs(ac, av, cvts.rfp);
399
400 initfromtif(); /* initialize conversion */
401
402 fputc('\n', cvts.rfp); /* finish Radiance header */
403 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
404
405 for (y = 0; y < cvts.ymax; y++) /* convert image */
406 (*cvts.tf)(y);
407 /* clean up */
408 fclose(cvts.rfp);
409 TIFFClose(cvts.tif);
410 }
411
412
413 int
414 headline(s) /* process Radiance input header line */
415 char *s;
416 {
417 static int tmstrlen = 0;
418 static int ownstrlen = 0;
419 char fmt[32];
420
421 if (!tmstrlen)
422 tmstrlen = strlen(TMSTR);
423 if (!ownstrlen)
424 ownstrlen = strlen(OWNSTR);
425 if (formatval(fmt, s)) {
426 if (!strcmp(fmt, COLRFMT))
427 CLR(C_XYZE);
428 else if (!strcmp(fmt, CIEFMT))
429 SET(C_XYZE);
430 else
431 quiterr("unrecognized input picture format");
432 return(1);
433 }
434 if (isexpos(s)) {
435 cvts.stonits /= exposval(s);
436 return(1);
437 }
438 if (isaspect(s)) {
439 cvts.pixrat *= aspectval(s);
440 return(1);
441 }
442 if (isprims(s)) {
443 primsval(cvts.prims, s);
444 SET(C_PRIM);
445 return(1);
446 }
447 if (isdate(s)) {
448 if (s[tmstrlen] == ' ')
449 strncpy(cvts.capdate, s+tmstrlen+1, 19);
450 else
451 strncpy(cvts.capdate, s+tmstrlen, 19);
452 cvts.capdate[19] = '\0';
453 return(1);
454 }
455 if (!strncmp(s, OWNSTR, ownstrlen)) {
456 register char *cp = s + ownstrlen;
457
458 while (isspace(*cp))
459 ++cp;
460 strncpy(cvts.owner, cp, sizeof(cvts.owner));
461 cvts.owner[sizeof(cvts.owner)-1] = '\0';
462 for (cp = cvts.owner; *cp; cp++)
463 ;
464 while (cp > cvts.owner && isspace(cp[-1]))
465 *--cp = '\0';
466 return(1);
467 }
468 return(0);
469 }
470
471
472 initfromrad() /* initialize input from a Radiance picture */
473 {
474 int i1, i2, po;
475 /* read Radiance header */
476 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
477 cvts.capdate[0] = '\0';
478 cvts.owner[0] = '\0';
479 cvts.stonits = 1.;
480 cvts.pixrat = 1.;
481 cvts.pconf = PLANARCONFIG_CONTIG;
482 getheader(cvts.rfp, headline, NULL);
483 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
484 quiterr("bad Radiance picture");
485 cvts.xmax = i1; cvts.ymax = i2;
486 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
487 if (ortab[i1] == po) {
488 cvts.orient = i1 + 1;
489 break;
490 }
491 if (i1 >= 8)
492 quiterr("internal error 1 in initfromrad");
493 if (!(po & YMAJOR))
494 cvts.pixrat = 1./cvts.pixrat;
495 if (!CHK(C_XYZE))
496 cvts.stonits *= WHTEFFICACY;
497 /* set up conversion */
498 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
499 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
500
501 switch (cvts.phot) {
502 case PHOTOMETRIC_LOGLUV:
503 SET(C_RFLT|C_TFLT);
504 CLR(C_GRY|C_TWRD);
505 if (!CHK(C_XYZE)) {
506 comprgb2xyzWBmat(cvts.cmat,
507 CHK(C_PRIM) ? cvts.prims : stdprims);
508 SET(C_CXFM);
509 }
510 if (cvts.comp != COMPRESSION_SGILOG &&
511 cvts.comp != COMPRESSION_SGILOG24)
512 quiterr("internal error 2 in initfromrad");
513 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
514 SGILOGDATAFMT_FLOAT);
515 cvts.tf = Color2Luv;
516 break;
517 case PHOTOMETRIC_LOGL:
518 SET(C_GRY|C_RFLT|C_TFLT);
519 CLR(C_TWRD);
520 if (cvts.comp != COMPRESSION_SGILOG)
521 quiterr("internal error 3 in initfromrad");
522 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
523 SGILOGDATAFMT_FLOAT);
524 cvts.tf = Color2L;
525 break;
526 case PHOTOMETRIC_RGB:
527 SET(C_GAMMA|C_GAMUT);
528 CLR(C_GRY);
529 setcolrgam(cvts.gamcor);
530 if (CHK(C_XYZE)) {
531 compxyz2rgbWBmat(cvts.cmat,
532 CHK(C_PRIM) ? cvts.prims : stdprims);
533 SET(C_CXFM);
534 }
535 if (CHK(C_PRIM)) {
536 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
537 (float *)cvts.prims);
538 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
539 (float *)cvts.prims[WHT]);
540 }
541 if (CHK(C_TWRD)) {
542 cvts.tf = Color2RRGGBB;
543 SET(C_RFLT);
544 } else if (CHK(C_TFLT)) {
545 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
546 SAMPLEFORMAT_IEEEFP);
547 cvts.tf = Color2RfGfBf;
548 SET(C_RFLT);
549 } else
550 cvts.tf = Colr2RGB;
551 break;
552 case PHOTOMETRIC_MINISBLACK:
553 SET(C_GRY|C_GAMMA|C_GAMUT);
554 setcolrgam(cvts.gamcor);
555 if (CHK(C_TWRD)) {
556 cvts.tf = Color2GGry;
557 SET(C_RFLT);
558 } else if (CHK(C_TFLT)) {
559 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
560 SAMPLEFORMAT_IEEEFP);
561 cvts.tf = Color2Gryf;
562 SET(C_RFLT);
563 } else
564 cvts.tf = Colr2Gry;
565 break;
566 default:
567 quiterr("internal error 4 in initfromrad");
568 break;
569 }
570 /* set other TIFF fields */
571 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
572 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
573 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
574 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
575 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
576 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
577 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
578 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
579 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
580 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
581 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
582 cvts.stonits/pow(2.,(double)cvts.bradj));
583 if (cvts.capdate[0])
584 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
585 if (cvts.owner[0])
586 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
587 if (cvts.comp == COMPRESSION_NONE)
588 i1 = TIFFScanlineSize(cvts.tif);
589 else
590 i1 = 3*cvts.xmax; /* conservative guess */
591 i2 = 8192/i1; /* compute good strip size */
592 if (i2 < 1) i2 = 1;
593 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
594
595 allocbufs(); /* allocate scanline buffers */
596 }
597
598
599 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
600 int ac;
601 char *av[];
602 {
603 uint32 y;
604 /* open Radiance file */
605 if (!strcmp(av[ac], "-"))
606 cvts.rfp = stdin;
607 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
608 quiterr("cannot open Radiance input picture");
609 /* open TIFF file */
610 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
611 quiterr("cannot open TIFF output");
612
613 initfromrad(); /* initialize conversion */
614
615 for (y = 0; y < cvts.ymax; y++) /* convert image */
616 (*cvts.tf)(y);
617 /* clean up */
618 TIFFClose(cvts.tif);
619 fclose(cvts.rfp);
620 }
621
622
623 void
624 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
625 uint32 y;
626 {
627 register int x;
628
629 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
630 quiterr("internal error 1 in Luv2Color");
631
632 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
633 quiterr("error reading TIFF input");
634 /* also works for float RGB */
635 for (x = cvts.xmax; x--; ) {
636 setcolor(cvts.r.colors[x],
637 cvts.t.fp[3*x],
638 cvts.t.fp[3*x + 1],
639 cvts.t.fp[3*x + 2]);
640 if (CHK(C_CXFM))
641 colortrans(cvts.r.colors[x], cvts.cmat,
642 cvts.r.colors[x]);
643 if (CHK(C_GAMUT))
644 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
645 CGAMUT_LOWER, cblack, cwhite);
646 }
647 if (cvts.bradj) {
648 double m = pow(2.,(double)cvts.bradj);
649 for (x = cvts.xmax; x--; )
650 scalecolor(cvts.r.colors[x], m);
651 }
652
653 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
654 quiterr("error writing Radiance picture");
655 }
656
657
658 void
659 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
660 uint32 y;
661 {
662 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
663 register double d;
664 register int x;
665
666 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
667 quiterr("internal error 1 in RRGGBB2Color");
668
669 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
670 quiterr("error reading TIFF input");
671
672 for (x = cvts.xmax; x--; ) {
673 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
674 if (dogamma) d = pow(d, cvts.gamcor);
675 colval(cvts.r.colors[x],RED) = d;
676 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
677 if (dogamma) d = pow(d, cvts.gamcor);
678 colval(cvts.r.colors[x],GRN) = d;
679 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
680 if (dogamma) d = pow(d, cvts.gamcor);
681 colval(cvts.r.colors[x],BLU) = d;
682 if (CHK(C_CXFM))
683 colortrans(cvts.r.colors[x], cvts.cmat,
684 cvts.r.colors[x]);
685 if (CHK(C_GAMUT))
686 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
687 CGAMUT_LOWER, cblack, cwhite);
688 }
689 if (cvts.bradj) {
690 d = pow(2.,(double)cvts.bradj);
691 for (x = cvts.xmax; x--; )
692 scalecolor(cvts.r.colors[x], d);
693 }
694
695 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
696 quiterr("error writing Radiance picture");
697 }
698
699
700 void
701 L2Color(y) /* read/convert/write Lfloat->COLOR scanline */
702 uint32 y;
703 {
704 float m = pow(2., (double)cvts.bradj);
705 register int x;
706
707 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
708 quiterr("internal error 1 in L2Color");
709
710 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
711 quiterr("error reading TIFF input");
712 /* also works for float greyscale */
713 for (x = cvts.xmax; x--; ) {
714 register float f = cvts.t.fp[x];
715 if (cvts.bradj) f *= m;
716 setcolor(cvts.r.colors[x], f, f, f);
717 }
718 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
719 quiterr("error writing Radiance picture");
720 }
721
722
723 void
724 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
725 uint32 y;
726 {
727 COLOR ctmp;
728 register int x;
729
730 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
731 quiterr("internal error 1 in RGB2Colr");
732
733 if (cvts.pconf == PLANARCONFIG_CONTIG) {
734 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
735 goto readerr;
736 for (x = cvts.xmax; x--; ) {
737 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
738 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
739 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
740 }
741 } else {
742 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
743 goto readerr;
744 if (TIFFReadScanline(cvts.tif,
745 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
746 goto readerr;
747 if (TIFFReadScanline(cvts.tif,
748 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
749 goto readerr;
750 for (x = cvts.xmax; x--; ) {
751 cvts.r.colrs[x][RED] = cvts.t.bp[x];
752 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
753 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
754 }
755 }
756
757 gambs_colrs(cvts.r.colrs, cvts.xmax);
758 if (CHK(C_CXFM))
759 for (x = cvts.xmax; x--; ) {
760 colr_color(ctmp, cvts.r.colrs[x]);
761 colortrans(ctmp, cvts.cmat, ctmp);
762 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
763 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
764 cblack, cwhite);
765 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
766 colval(ctmp,GRN), colval(ctmp,BLU));
767 }
768 if (cvts.bradj)
769 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
770
771 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
772 quiterr("error writing Radiance picture");
773 return;
774 readerr:
775 quiterr("error reading TIFF input");
776 }
777
778
779 void
780 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
781 uint32 y;
782 {
783 register int x;
784
785 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
786 quiterr("internal error 1 in Gry2Colr");
787
788 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
789 quiterr("error reading TIFF input");
790
791 for (x = cvts.xmax; x--; )
792 cvts.r.colrs[x][RED] =
793 cvts.r.colrs[x][GRN] =
794 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
795
796 gambs_colrs(cvts.r.colrs, cvts.xmax);
797 if (cvts.bradj)
798 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
799
800 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
801 quiterr("error writing Radiance picture");
802 }
803
804
805 void
806 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
807 uint32 y;
808 {
809 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
810 double m;
811 register double d;
812 register int x;
813
814 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
815 quiterr("internal error 1 in GGry2Color");
816
817 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
818 quiterr("error reading TIFF input");
819
820 if (cvts.bradj)
821 m = pow(2., (double)cvts.bradj);
822 for (x = cvts.xmax; x--; ) {
823 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
824 if (dogamma) d = pow(d, cvts.gamcor);
825 if (cvts.bradj) d *= m;
826 colval(cvts.r.colors[x],RED) =
827 colval(cvts.r.colors[x],GRN) =
828 colval(cvts.r.colors[x],BLU) = d;
829 }
830 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
831 quiterr("error writing Radiance picture");
832 }
833
834
835 void
836 Color2GGry(y) /* read/convert/write COLOR->G16 scanline */
837 uint32 y;
838 {
839 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
840 float m = pow(2.,(double)cvts.bradj);
841 register int x;
842
843 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
844 quiterr("internal error 1 in Color2GGry");
845
846 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
847 quiterr("error reading Radiance picture");
848
849 for (x = cvts.xmax; x--; ) {
850 register float f = m*( CHK(C_XYZE) ?
851 colval(cvts.r.colors[x],CIEY)
852 : bright(cvts.r.colors[x]) );
853 if (f <= 0)
854 cvts.t.wp[x] = 0;
855 else if (f >= 1)
856 cvts.t.wp[x] = 0xffff;
857 else if (dogamma)
858 cvts.t.wp[x] = (int)((float)(1L<<16) *
859 pow(f, 1./cvts.gamcor));
860 else
861 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
862 }
863
864 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
865 quiterr("error writing TIFF output");
866 }
867
868
869 void
870 Color2L(y) /* read/convert/write COLOR->Lfloat scanline */
871 uint32 y;
872 {
873 float m = pow(2.,(double)cvts.bradj);
874 register int x;
875
876 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
877 quiterr("internal error 1 in Color2L");
878
879 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
880 quiterr("error reading Radiance picture");
881
882 for (x = cvts.xmax; x--; )
883 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
884 : bright(cvts.r.colors[x]) );
885
886 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
887 quiterr("error writing TIFF output");
888 }
889
890
891 void
892 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
893 uint32 y;
894 {
895 register int x;
896
897 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
898 quiterr("internal error 1 in Color2Luv");
899
900 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
901 quiterr("error reading Radiance picture");
902
903 if (CHK(C_CXFM))
904 for (x = cvts.xmax; x--; )
905 colortrans(cvts.r.colors[x], cvts.cmat,
906 cvts.r.colors[x]);
907 if (cvts.bradj) {
908 double m = pow(2.,(double)cvts.bradj);
909 for (x = cvts.xmax; x--; )
910 scalecolor(cvts.r.colors[x], m);
911 }
912 /* also works for float RGB */
913 for (x = cvts.xmax; x--; ) {
914 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
915 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
916 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
917 }
918
919 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
920 quiterr("error writing TIFF output");
921 }
922
923
924 void
925 Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */
926 uint32 y;
927 {
928 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
929 float m = pow(2.,(double)cvts.bradj);
930 register int x, i;
931
932 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
933 quiterr("internal error 1 in Color2RRGGBB");
934
935 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
936 quiterr("error reading Radiance picture");
937
938 for (x = cvts.xmax; x--; )
939 for (i = 3; i--; ) {
940 register float f = m*colval(cvts.r.colors[x],i);
941 if (f <= 0)
942 cvts.t.wp[3*x + i] = 0;
943 else if (f >= 1)
944 cvts.t.wp[3*x + i] = 0xffff;
945 else if (dogamma)
946 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
947 pow(f, 1./cvts.gamcor));
948 else
949 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
950 }
951
952 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
953 quiterr("error writing TIFF output");
954 }
955
956
957 void
958 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
959 uint32 y;
960 {
961 register int x;
962
963 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
964 quiterr("internal error 1 in Colr2Gry");
965
966 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
967 quiterr("error reading Radiance picture");
968
969 if (cvts.bradj)
970 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
971 for (x = cvts.xmax; x--; )
972 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
973 colrs_gambs(cvts.r.colrs, cvts.xmax);
974
975 for (x = cvts.xmax; x--; )
976 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
977
978 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
979 quiterr("error writing TIFF output");
980 }
981
982
983 void
984 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
985 uint32 y;
986 {
987 COLOR ctmp;
988 register int x;
989
990 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
991 quiterr("internal error 1 in Colr2RGB");
992
993 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
994 quiterr("error reading Radiance picture");
995
996 if (cvts.bradj)
997 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
998 if (CHK(C_CXFM))
999 for (x = cvts.xmax; x--; ) {
1000 colr_color(ctmp, cvts.r.colrs[x]);
1001 colortrans(ctmp, cvts.cmat, ctmp);
1002 if (CHK(C_GAMUT))
1003 clipgamut(ctmp, bright(ctmp), CGAMUT,
1004 cblack, cwhite);
1005 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1006 colval(ctmp,GRN), colval(ctmp,BLU));
1007 }
1008 colrs_gambs(cvts.r.colrs, cvts.xmax);
1009
1010 for (x = cvts.xmax; x--; ) {
1011 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1012 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1013 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1014 }
1015
1016 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1017 quiterr("error writing TIFF output");
1018 }
