root/radiance/ray/src/px/ra_tiff.c
Revision: 2.15
Committed: Wed Sep 24 14:54:03 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.14: +1 -0 lines
added missing call to setgamcor()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to convert between RADIANCE and TIFF files.
9 * Added experimental LogLuv encodings 7/97 (GWL).
10 */
11
12 #include <stdio.h>
13 #include <math.h>
14 #include "tiffio.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define GAMCOR 2.2 /* default gamma */
19
20 #ifndef malloc
21 extern char *malloc();
22 #endif
23 /* conversion flags */
24 #define C_CXFM 0x1 /* needs color transformation */
25 #define C_GAMUT 0x2 /* needs gamut mapping */
26 #define C_GAMMA 0x4 /* needs gamma correction */
27 #define C_GRY 0x8 /* TIFF is greyscale */
28 #define C_XYZE 0x10 /* Radiance is XYZE */
29 #define C_RFLT 0x20 /* Radiance data is float */
30 #define C_TFLT 0x40 /* TIFF data is float */
31 #define C_PRIM 0x80 /* has assigned primaries */
32
33 struct {
34 uint16 flags; /* conversion flags (defined above) */
35 uint16 comp; /* TIFF compression type */
36 uint16 phot; /* TIFF photometric type */
37 uint16 pconf; /* TIFF planar configuration */
38 float gamcor; /* gamma correction value */
39 short bradj; /* Radiance exposure adjustment (stops) */
40 uint16 orient; /* visual orientation (TIFF spec.) */
41 double stonits; /* input conversion to nits */
42 float pixrat; /* pixel aspect ratio */
43 FILE *rfp; /* Radiance stream pointer */
44 TIFF *tif; /* TIFF pointer */
45 uint32 xmax, ymax; /* image dimensions */
46 COLORMAT cmat; /* color transformation matrix */
47 RGBPRIMS prims; /* RGB primaries */
48 union {
49 COLR *colrs; /* 4-byte ???E pointer */
50 COLOR *colors; /* float array pointer */
51 char *p; /* generic pointer */
52 } r; /* Radiance scanline */
53 union {
54 uint8 *bp; /* byte pointer */
55 float *fp; /* float pointer */
56 char *p; /* generic pointer */
57 } t; /* TIFF scanline */
58 int (*tf)(); /* translation procedure */
59 } cvts = { /* conversion structure */
60 0, COMPRESSION_NONE, PHOTOMETRIC_RGB,
61 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
62 };
63
64 #define CHK(f) (cvts.flags & (f))
65 #define SET(f) (cvts.flags |= (f))
66 #define CLR(f) (cvts.flags &= ~(f))
67 #define TGL(f) (cvts.flags ^= (f))
68
69 int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
70 int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
71
72 short ortab[8] = { /* orientation conversion table */
73 YMAJOR|YDECR,
74 YMAJOR|YDECR|XDECR,
75 YMAJOR|XDECR,
76 YMAJOR,
77 YDECR,
78 XDECR|YDECR,
79 XDECR,
80 0
81 };
82
83 #define pixorder() ortab[cvts.orient-1]
84
85 char *progname;
86
87
88 main(argc, argv)
89 int argc;
90 char *argv[];
91 {
92 int reverse = 0;
93 int i;
94
95 progname = argv[0];
96
97 for (i = 1; i < argc; i++)
98 if (argv[i][0] == '-')
99 switch (argv[i][1]) {
100 case 'g': /* gamma correction */
101 cvts.gamcor = atof(argv[++i]);
102 break;
103 case 'x': /* XYZE Radiance output */
104 TGL(C_XYZE);
105 break;
106 case 'z': /* LZW compressed output */
107 cvts.comp = COMPRESSION_LZW;
108 break;
109 case 'L': /* LogLuv 32-bit output */
110 cvts.comp = COMPRESSION_SGILOG;
111 cvts.phot = PHOTOMETRIC_LOGLUV;
112 break;
113 case 'l': /* LogLuv 24-bit output */
114 cvts.comp = COMPRESSION_SGILOG24;
115 cvts.phot = PHOTOMETRIC_LOGLUV;
116 break;
117 case 'b': /* greyscale output? */
118 TGL(C_GRY);
119 break;
120 case 'e': /* exposure adjustment */
121 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
122 goto userr;
123 cvts.bradj = atoi(argv[++i]);
124 break;
125 case 'r': /* reverse conversion? */
126 reverse = !reverse;
127 break;
128 case '\0':
129 goto doneopts;
130 default:
131 goto userr;
132 }
133 else
134 break;
135 doneopts:
136 if (reverse) {
137
138 if (i != argc-2 && i != argc-1)
139 goto userr;
140
141 tiff2ra(i, argv);
142
143 } else {
144
145 if (i != argc-2)
146 goto userr;
147
148 if (CHK(C_GRY)) /* consistency corrections */
149 if (cvts.phot == PHOTOMETRIC_RGB)
150 cvts.phot = PHOTOMETRIC_MINISBLACK;
151 else {
152 cvts.phot = PHOTOMETRIC_LOGL;
153 cvts.comp = COMPRESSION_SGILOG;
154 }
155
156 ra2tiff(i, argv);
157 }
158
159 exit(0);
160 userr:
161 fprintf(stderr,
162 "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
163 progname);
164 fprintf(stderr,
165 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
166 progname);
167 exit(1);
168 }
169
170
171 quiterr(err) /* print message and exit */
172 char *err;
173 {
174 if (err != NULL) {
175 fprintf(stderr, "%s: %s\n", progname, err);
176 exit(1);
177 }
178 exit(0);
179 }
180
181
182 allocbufs() /* allocate scanline buffers */
183 {
184 int rsiz, tsiz;
185
186 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
187 tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) *
188 (CHK(C_GRY) ? 1 : 3);
189 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
190 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
191 if (cvts.r.p == NULL | cvts.t.p == NULL)
192 quiterr("no memory to allocate scanline buffers");
193 }
194
195
196 initfromtif() /* initialize conversion from TIFF input */
197 {
198 uint16 hi;
199 float *fa, f1, f2;
200
201 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM);
202
203 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
204
205 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
206 cvts.prims[RED][CIEX] = fa[0];
207 cvts.prims[RED][CIEY] = fa[1];
208 cvts.prims[GRN][CIEX] = fa[2];
209 cvts.prims[GRN][CIEY] = fa[3];
210 cvts.prims[BLU][CIEX] = fa[4];
211 cvts.prims[BLU][CIEY] = fa[5];
212 cvts.prims[WHT][CIEX] = 1./3.;
213 cvts.prims[WHT][CIEY] = 1./3.;
214 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
215 cvts.prims[WHT][CIEX] = fa[0];
216 cvts.prims[WHT][CIEY] = fa[1];
217 }
218 SET(C_PRIM);
219 }
220
221 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
222 cvts.comp = COMPRESSION_NONE;
223
224 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
225 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
226 cvts.pixrat = f1/f2;
227
228 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
229
230 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
231 quiterr("TIFF has unspecified photometric type");
232
233 switch (cvts.phot) {
234 case PHOTOMETRIC_LOGLUV:
235 SET(C_RFLT|C_TFLT);
236 if (!CHK(C_XYZE)) {
237 cpcolormat(cvts.cmat, xyz2rgbmat);
238 SET(C_CXFM|C_GAMUT);
239 } else if (cvts.comp == COMPRESSION_SGILOG)
240 SET(C_GAMUT);
241 if (cvts.pconf != PLANARCONFIG_CONTIG)
242 quiterr("cannot handle separate Luv planes");
243 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
244 SGILOGDATAFMT_FLOAT);
245 cvts.tf = Luv2Color;
246 break;
247 case PHOTOMETRIC_LOGL:
248 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
249 cvts.pconf = PLANARCONFIG_CONTIG;
250 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
251 SGILOGDATAFMT_FLOAT);
252 cvts.tf = L2Color;
253 break;
254 case PHOTOMETRIC_YCBCR:
255 if (cvts.comp == COMPRESSION_JPEG &&
256 cvts.pconf == PLANARCONFIG_CONTIG) {
257 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
258 JPEGCOLORMODE_RGB);
259 cvts.phot = PHOTOMETRIC_RGB;
260 } else
261 quiterr("unsupported photometric type");
262 /* fall through */
263 case PHOTOMETRIC_RGB:
264 SET(C_GAMMA|C_GAMUT);
265 setcolrgam(cvts.gamcor);
266 if (CHK(C_XYZE)) {
267 comprgb2xyzmat(cvts.cmat,
268 CHK(C_PRIM) ? cvts.prims : stdprims);
269 SET(C_CXFM);
270 }
271 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
272 hi != 3)
273 quiterr("unsupported samples per pixel for RGB");
274 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
275 hi != 8)
276 quiterr("unsupported bits per sample for RGB");
277 cvts.tf = RGB2Colr;
278 break;
279 case PHOTOMETRIC_MINISBLACK:
280 SET(C_GRY|C_GAMMA|C_GAMUT);
281 setcolrgam(cvts.gamcor);
282 cvts.pconf = PLANARCONFIG_CONTIG;
283 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
284 hi != 1)
285 quiterr("unsupported samples per pixel for greyscale");
286 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
287 hi != 8)
288 quiterr("unsupported bits per sample for greyscale");
289 cvts.tf = Gry2Colr;
290 break;
291 default:
292 quiterr("unsupported photometric type");
293 break;
294 }
295
296 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
297 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
298 quiterr("unknown input image resolution");
299
300 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
301 cvts.stonits = 1.;
302 /* add to Radiance header */
303 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
304 fputaspect(cvts.pixrat, cvts.rfp);
305 if (CHK(C_XYZE)) {
306 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
307 fputformat(CIEFMT, cvts.rfp);
308 } else {
309 if (CHK(C_PRIM))
310 fputprims(cvts.prims, cvts.rfp);
311 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
312 cvts.rfp);
313 fputformat(COLRFMT, cvts.rfp);
314 }
315
316 allocbufs(); /* allocate scanline buffers */
317 }
318
319
320 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
321 int ac;
322 char *av[];
323 {
324 int32 y;
325 /* open TIFF input */
326 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
327 quiterr("cannot open TIFF input");
328 /* open Radiance output */
329 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
330 cvts.rfp = stdout;
331 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
332 quiterr("cannot open Radiance output picture");
333 /* start output header */
334 newheader("RADIANCE", cvts.rfp);
335 printargs(ac, av, cvts.rfp);
336
337 initfromtif(); /* initialize conversion */
338
339 fputc('\n', cvts.rfp); /* finish Radiance header */
340 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
341
342 for (y = 0; y < cvts.ymax; y++) /* convert image */
343 (*cvts.tf)(y);
344 /* clean up */
345 fclose(cvts.rfp);
346 TIFFClose(cvts.tif);
347 }
348
349
350 int
351 headline(s) /* process Radiance input header line */
352 char *s;
353 {
354 char fmt[32];
355
356 if (formatval(fmt, s)) {
357 if (!strcmp(fmt, COLRFMT))
358 CLR(C_XYZE);
359 else if (!strcmp(fmt, CIEFMT))
360 SET(C_XYZE);
361 else
362 quiterr("unrecognized input picture format");
363 return;
364 }
365 if (isexpos(s)) {
366 cvts.stonits /= exposval(s);
367 return;
368 }
369 if (isaspect(s)) {
370 cvts.pixrat *= aspectval(s);
371 return;
372 }
373 if (isprims(s)) {
374 primsval(cvts.prims, s);
375 SET(C_PRIM);
376 return;
377 }
378 }
379
380
381 initfromrad() /* initialize input from a Radiance picture */
382 {
383 int i1, i2, po;
384 /* read Radiance header */
385 CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
386 cvts.stonits = 1.;
387 cvts.pixrat = 1.;
388 cvts.pconf = PLANARCONFIG_CONTIG;
389 getheader(cvts.rfp, headline, NULL);
390 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
391 quiterr("bad Radiance picture");
392 cvts.xmax = i1; cvts.ymax = i2;
393 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
394 if (ortab[i1] == po) {
395 cvts.orient = i1 + 1;
396 break;
397 }
398 if (i1 >= 8)
399 quiterr("internal error 1 in initfromrad");
400 if (!(po & YMAJOR))
401 cvts.pixrat = 1./cvts.pixrat;
402 if (!CHK(C_XYZE))
403 cvts.stonits *= WHTEFFICACY;
404 /* set up conversion */
405 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
406 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
407
408 switch (cvts.phot) {
409 case PHOTOMETRIC_LOGLUV:
410 SET(C_RFLT|C_TFLT);
411 CLR(C_GRY);
412 if (!CHK(C_XYZE)) {
413 cpcolormat(cvts.cmat, rgb2xyzmat);
414 SET(C_CXFM);
415 }
416 if (cvts.comp != COMPRESSION_SGILOG &&
417 cvts.comp != COMPRESSION_SGILOG24)
418 quiterr("internal error 2 in initfromrad");
419 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
420 SGILOGDATAFMT_FLOAT);
421 cvts.tf = Color2Luv;
422 break;
423 case PHOTOMETRIC_LOGL:
424 SET(C_GRY|C_RFLT|C_TFLT);
425 if (cvts.comp != COMPRESSION_SGILOG)
426 quiterr("internal error 3 in initfromrad");
427 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
428 SGILOGDATAFMT_FLOAT);
429 cvts.tf = Color2L;
430 break;
431 case PHOTOMETRIC_RGB:
432 SET(C_GAMMA|C_GAMUT);
433 CLR(C_GRY);
434 setcolrgam(cvts.gamcor);
435 if (CHK(C_XYZE)) {
436 compxyz2rgbmat(cvts.cmat,
437 CHK(C_PRIM) ? cvts.prims : stdprims);
438 SET(C_CXFM);
439 }
440 if (CHK(C_PRIM)) {
441 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
442 (float *)cvts.prims);
443 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
444 (float *)cvts.prims[WHT]);
445 }
446 cvts.tf = Colr2RGB;
447 break;
448 case PHOTOMETRIC_MINISBLACK:
449 SET(C_GRY|C_GAMMA|C_GAMUT);
450 setcolrgam(cvts.gamcor);
451 cvts.tf = Colr2Gry;
452 break;
453 default:
454 quiterr("internal error 4 in initfromrad");
455 break;
456 }
457 /* set other TIFF fields */
458 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
459 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
460 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
461 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8);
462 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
463 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
464 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
465 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
466 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
467 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
468 cvts.stonits/pow(2.,(double)cvts.bradj));
469 if (cvts.comp == COMPRESSION_NONE)
470 i1 = TIFFScanlineSize(cvts.tif);
471 else
472 i1 = 3*cvts.xmax; /* conservative guess */
473 i2 = 8192/i1; /* compute good strip size */
474 if (i2 < 1) i2 = 1;
475 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
476
477 allocbufs(); /* allocate scanline buffers */
478 }
479
480
481 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
482 int ac;
483 char *av[];
484 {
485 uint32 y;
486 /* open Radiance file */
487 if (!strcmp(av[ac], "-"))
488 cvts.rfp = stdin;
489 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
490 quiterr("cannot open Radiance input picture");
491 /* open TIFF file */
492 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
493 quiterr("cannot open TIFF output");
494
495 initfromrad(); /* initialize conversion */
496
497 for (y = 0; y < cvts.ymax; y++) /* convert image */
498 (*cvts.tf)(y);
499 /* clean up */
500 TIFFClose(cvts.tif);
501 fclose(cvts.rfp);
502 }
503
504
505 int
506 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
507 uint32 y;
508 {
509 register int x;
510
511 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
512 quiterr("internal error 1 in Luv2Color");
513
514 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
515 quiterr("error reading TIFF input");
516
517 for (x = cvts.xmax; x--; ) {
518 cvts.r.colors[x][RED] = cvts.t.fp[3*x];
519 cvts.r.colors[x][GRN] = cvts.t.fp[3*x + 1];
520 cvts.r.colors[x][BLU] = cvts.t.fp[3*x + 2];
521 if (CHK(C_CXFM))
522 colortrans(cvts.r.colors[x], cvts.cmat,
523 cvts.r.colors[x]);
524 if (CHK(C_GAMUT))
525 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
526 CGAMUT_LOWER, cblack, cwhite);
527 }
528 if (cvts.bradj) {
529 double m = pow(2.,(double)cvts.bradj);
530 for (x = cvts.xmax; x--; )
531 scalecolor(cvts.r.colors[x], m);
532 }
533
534 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
535 quiterr("error writing Radiance picture");
536 }
537
538
539 int
540 L2Color(y) /* read/convert/write L16->COLOR scanline */
541 uint32 y;
542 {
543 register int x;
544
545 if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
546 quiterr("internal error 1 in L2Color");
547
548 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
549 quiterr("error reading TIFF input");
550
551 for (x = cvts.xmax; x--; )
552 cvts.r.colors[x][RED] =
553 cvts.r.colors[x][GRN] =
554 cvts.r.colors[x][BLU] = cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.;
555
556 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
557 quiterr("error writing Radiance picture");
558 }
559
560
561 int
562 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
563 uint32 y;
564 {
565 COLOR ctmp;
566 register int x;
567
568 if (CHK(C_RFLT|C_TFLT|C_GRY))
569 quiterr("internal error 1 in RGB2Colr");
570
571 if (cvts.pconf == PLANARCONFIG_CONTIG) {
572 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
573 goto readerr;
574 for (x = cvts.xmax; x--; ) {
575 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
576 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
577 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
578 }
579 } else {
580 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
581 goto readerr;
582 if (TIFFReadScanline(cvts.tif,
583 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
584 goto readerr;
585 if (TIFFReadScanline(cvts.tif,
586 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
587 goto readerr;
588 for (x = cvts.xmax; x--; ) {
589 cvts.r.colrs[x][RED] = cvts.t.bp[x];
590 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
591 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
592 }
593 }
594
595 gambs_colrs(cvts.r.colrs, cvts.xmax);
596 if (CHK(C_CXFM))
597 for (x = cvts.xmax; x--; ) {
598 colr_color(ctmp, cvts.r.colrs[x]);
599 colortrans(ctmp, cvts.cmat, ctmp);
600 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
601 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
602 cblack, cwhite);
603 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
604 colval(ctmp,GRN), colval(ctmp,BLU));
605 }
606 if (cvts.bradj)
607 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
608
609 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
610 quiterr("error writing Radiance picture");
611 return;
612 readerr:
613 quiterr("error reading TIFF input");
614 }
615
616
617 int
618 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
619 uint32 y;
620 {
621 register int x;
622
623 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
624 quiterr("internal error 1 in Gry2Colr");
625
626 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
627 quiterr("error reading TIFF input");
628
629 for (x = cvts.xmax; x--; )
630 cvts.r.colrs[x][RED] =
631 cvts.r.colrs[x][GRN] =
632 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
633
634 gambs_colrs(cvts.r.colrs, cvts.xmax);
635 if (cvts.bradj)
636 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
637
638 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
639 quiterr("error writing Radiance picture");
640 }
641
642
643 int
644 Color2L(y) /* read/convert/write COLOR->L16 scanline */
645 uint32 y;
646 {
647 double m = pow(2.,(double)cvts.bradj);
648 register int x;
649
650 if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
651 quiterr("internal error 1 in Color2L");
652
653 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
654 quiterr("error reading Radiance picture");
655
656 for (x = cvts.xmax; x--; )
657 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
658 : bright(cvts.r.colors[x]) );
659
660 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
661 quiterr("error writing TIFF output");
662 }
663
664
665 int
666 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
667 uint32 y;
668 {
669 register int x;
670
671 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
672 quiterr("internal error 1 in Color2Luv");
673
674 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
675 quiterr("error reading Radiance picture");
676
677 if (CHK(C_CXFM))
678 for (x = cvts.xmax; x--; )
679 colortrans(cvts.r.colors[x], cvts.cmat,
680 cvts.r.colors[x]);
681 if (cvts.bradj) {
682 double m = pow(2.,(double)cvts.bradj);
683 for (x = cvts.xmax; x--; )
684 scalecolor(cvts.r.colors[x], m);
685 }
686
687 for (x = cvts.xmax; x--; ) {
688 cvts.t.fp[3*x] = colval(cvts.r.colors[x],RED);
689 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],GRN);
690 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],BLU);
691 }
692
693 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
694 quiterr("error writing TIFF output");
695 }
696
697
698 int
699 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
700 uint32 y;
701 {
702 register int x;
703
704 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
705 quiterr("internal error 1 in Colr2Gry");
706
707 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
708 quiterr("error reading Radiance picture");
709
710 if (cvts.bradj)
711 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
712 for (x = cvts.xmax; x--; )
713 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
714 colrs_gambs(cvts.r.colrs, cvts.xmax);
715
716 for (x = cvts.xmax; x--; )
717 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
718
719 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
720 quiterr("error writing TIFF output");
721 }
722
723
724 int
725 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
726 uint32 y;
727 {
728 COLOR ctmp;
729 register int x;
730
731 if (CHK(C_RFLT|C_TFLT|C_GRY))
732 quiterr("internal error 1 in Colr2RGB");
733
734 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
735 quiterr("error reading Radiance picture");
736
737 if (cvts.bradj)
738 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
739 if (CHK(C_CXFM))
740 for (x = cvts.xmax; x--; ) {
741 colr_color(ctmp, cvts.r.colrs[x]);
742 colortrans(ctmp, cvts.cmat, ctmp);
743 if (CHK(C_GAMUT))
744 clipgamut(ctmp, bright(ctmp), CGAMUT,
745 cblack, cwhite);
746 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
747 colval(ctmp,GRN), colval(ctmp,BLU));
748 }
749 colrs_gambs(cvts.r.colrs, cvts.xmax);
750
751 for (x = cvts.xmax; x--; ) {
752 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
753 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
754 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
755 }
756
757 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
758 quiterr("error writing TIFF output");
759 }
