root/radiance/ray/src/px/ra_tiff.c
Revision: 2.20
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.19: +8 -11 lines
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <time.h>
13 #include "tiffio.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define GAMCOR 2.2 /* default gamma */
18
19 /* conversion flags */
20 #define C_CXFM 0x1 /* needs color transformation */
21 #define C_GAMUT 0x2 /* needs gamut mapping */
22 #define C_GAMMA 0x4 /* needs gamma correction */
23 #define C_GRY 0x8 /* TIFF is greyscale */
24 #define C_XYZE 0x10 /* Radiance is XYZE */
25 #define C_RFLT 0x20 /* Radiance data is float */
26 #define C_TFLT 0x40 /* TIFF data is float */
27 #define C_TWRD 0x80 /* TIFF data is 16-bit */
28 #define C_PRIM 0x100 /* has assigned primaries */
29
30 struct {
31 uint16 flags; /* conversion flags (defined above) */
32 uint16 comp; /* TIFF compression type */
33 uint16 phot; /* TIFF photometric type */
34 uint16 pconf; /* TIFF planar configuration */
35 float gamcor; /* gamma correction value */
36 short bradj; /* Radiance exposure adjustment (stops) */
37 uint16 orient; /* visual orientation (TIFF spec.) */
38 double stonits; /* input conversion to nits */
39 float pixrat; /* pixel aspect ratio */
40 FILE *rfp; /* Radiance stream pointer */
41 TIFF *tif; /* TIFF pointer */
42 uint32 xmax, ymax; /* image dimensions */
43 COLORMAT cmat; /* color transformation matrix */
44 RGBPRIMS prims; /* RGB primaries */
45 union {
46 COLR *colrs; /* 4-byte ???E pointer */
47 COLOR *colors; /* float array pointer */
48 char *p; /* generic pointer */
49 } r; /* Radiance scanline */
50 union {
51 uint8 *bp; /* byte pointer */
52 uint16 *wp; /* word pointer */
53 float *fp; /* float pointer */
54 char *p; /* generic pointer */
55 } t; /* TIFF scanline */
56 int (*tf)(); /* translation procedure */
57 } cvts = { /* conversion structure */
58 0, COMPRESSION_NONE, PHOTOMETRIC_RGB,
59 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
60 };
61
62 #define CHK(f) (cvts.flags & (f))
63 #define SET(f) (cvts.flags |= (f))
64 #define CLR(f) (cvts.flags &= ~(f))
65 #define TGL(f) (cvts.flags ^= (f))
66
67 int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
68 int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
69 int RRGGBB2Color(), GGry2Color();
70
71 short ortab[8] = { /* orientation conversion table */
72 YMAJOR|YDECR,
73 YMAJOR|YDECR|XDECR,
74 YMAJOR|XDECR,
75 YMAJOR,
76 YDECR,
77 XDECR|YDECR,
78 XDECR,
79 0
80 };
81
82 #define pixorder() ortab[cvts.orient-1]
83
84 char *progname;
85
86
87 main(argc, argv)
88 int argc;
89 char *argv[];
90 {
91 int reverse = 0;
92 int i;
93
94 progname = argv[0];
95
96 for (i = 1; i < argc; i++)
97 if (argv[i][0] == '-')
98 switch (argv[i][1]) {
99 case 'g': /* gamma correction */
100 cvts.gamcor = atof(argv[++i]);
101 break;
102 case 'x': /* XYZE Radiance output */
103 TGL(C_XYZE);
104 break;
105 case 'z': /* LZW compressed output */
106 cvts.comp = COMPRESSION_LZW;
107 break;
108 case 'L': /* LogLuv 32-bit output */
109 cvts.comp = COMPRESSION_SGILOG;
110 cvts.phot = PHOTOMETRIC_LOGLUV;
111 break;
112 case 'l': /* LogLuv 24-bit output */
113 cvts.comp = COMPRESSION_SGILOG24;
114 cvts.phot = PHOTOMETRIC_LOGLUV;
115 break;
116 case 'b': /* greyscale output? */
117 TGL(C_GRY);
118 break;
119 case 'e': /* exposure adjustment */
120 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
121 goto userr;
122 cvts.bradj = atoi(argv[++i]);
123 break;
124 case 'r': /* reverse conversion? */
125 reverse = !reverse;
126 break;
127 case '\0':
128 goto doneopts;
129 default:
130 goto userr;
131 }
132 else
133 break;
134 doneopts:
135 if (reverse) {
136
137 if (i != argc-2 && i != argc-1)
138 goto userr;
139
140 tiff2ra(i, argv);
141
142 } else {
143
144 if (i != argc-2)
145 goto userr;
146
147 if (CHK(C_GRY)) /* consistency corrections */
148 if (cvts.phot == PHOTOMETRIC_RGB)
149 cvts.phot = PHOTOMETRIC_MINISBLACK;
150 else {
151 cvts.phot = PHOTOMETRIC_LOGL;
152 cvts.comp = COMPRESSION_SGILOG;
153 }
154
155 ra2tiff(i, argv);
156 }
157
158 exit(0);
159 userr:
160 fprintf(stderr,
161 "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
162 progname);
163 fprintf(stderr,
164 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
165 progname);
166 exit(1);
167 }
168
169
170 quiterr(err) /* print message and exit */
171 char *err;
172 {
173 if (err != NULL) {
174 fprintf(stderr, "%s: %s\n", progname, err);
175 exit(1);
176 }
177 exit(0);
178 }
179
180
181 allocbufs() /* allocate scanline buffers */
182 {
183 int rsiz, tsiz;
184
185 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
186 tsiz = (CHK(C_TFLT) ? sizeof(float) :
187 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
188 (CHK(C_GRY) ? 1 : 3);
189 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
190 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
191 if (cvts.r.p == NULL | cvts.t.p == NULL)
192 quiterr("no memory to allocate scanline buffers");
193 }
194
195
196 initfromtif() /* initialize conversion from TIFF input */
197 {
198 uint16 hi;
199 float *fa, f1, f2;
200
201 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM);
202
203 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
204
205 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
206 cvts.prims[RED][CIEX] = fa[0];
207 cvts.prims[RED][CIEY] = fa[1];
208 cvts.prims[GRN][CIEX] = fa[2];
209 cvts.prims[GRN][CIEY] = fa[3];
210 cvts.prims[BLU][CIEX] = fa[4];
211 cvts.prims[BLU][CIEY] = fa[5];
212 cvts.prims[WHT][CIEX] = 1./3.;
213 cvts.prims[WHT][CIEY] = 1./3.;
214 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
215 cvts.prims[WHT][CIEX] = fa[0];
216 cvts.prims[WHT][CIEY] = fa[1];
217 }
218 SET(C_PRIM);
219 }
220
221 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
222 cvts.comp = COMPRESSION_NONE;
223
224 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
225 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
226 cvts.pixrat = f1/f2;
227
228 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
229
230 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
231 quiterr("TIFF has unspecified photometric type");
232
233 switch (cvts.phot) {
234 case PHOTOMETRIC_LOGLUV:
235 SET(C_RFLT|C_TFLT);
236 if (!CHK(C_XYZE)) {
237 cpcolormat(cvts.cmat, xyz2rgbmat);
238 SET(C_CXFM|C_GAMUT);
239 } else if (cvts.comp == COMPRESSION_SGILOG)
240 SET(C_GAMUT);
241 if (cvts.pconf != PLANARCONFIG_CONTIG)
242 quiterr("cannot handle separate Luv planes");
243 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
244 SGILOGDATAFMT_FLOAT);
245 cvts.tf = Luv2Color;
246 break;
247 case PHOTOMETRIC_LOGL:
248 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
249 cvts.pconf = PLANARCONFIG_CONTIG;
250 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
251 SGILOGDATAFMT_FLOAT);
252 cvts.tf = L2Color;
253 break;
254 case PHOTOMETRIC_YCBCR:
255 if (cvts.comp == COMPRESSION_JPEG &&
256 cvts.pconf == PLANARCONFIG_CONTIG) {
257 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
258 JPEGCOLORMODE_RGB);
259 cvts.phot = PHOTOMETRIC_RGB;
260 } else
261 quiterr("unsupported photometric type");
262 /* fall through */
263 case PHOTOMETRIC_RGB:
264 SET(C_GAMMA);
265 setcolrgam(cvts.gamcor);
266 if (CHK(C_XYZE)) {
267 comprgb2xyzWBmat(cvts.cmat,
268 CHK(C_PRIM) ? cvts.prims : stdprims);
269 SET(C_CXFM);
270 }
271 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
272 hi != 3)
273 quiterr("unsupported samples per pixel for RGB");
274 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
275 hi != 8 & hi != 16)
276 quiterr("unsupported bits per sample for RGB");
277 if (hi == 8)
278 cvts.tf = RGB2Colr;
279 else {
280 cvts.tf = RRGGBB2Color;
281 SET(C_RFLT|C_TWRD);
282 }
283 break;
284 case PHOTOMETRIC_MINISBLACK:
285 SET(C_GRY|C_GAMMA);
286 setcolrgam(cvts.gamcor);
287 cvts.pconf = PLANARCONFIG_CONTIG;
288 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
289 hi != 1)
290 quiterr("unsupported samples per pixel for greyscale");
291 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
292 hi != 8 & hi != 16)
293 quiterr("unsupported bits per sample for greyscale");
294 if (hi == 8)
295 cvts.tf = Gry2Colr;
296 else {
297 cvts.tf = GGry2Color;
298 SET(C_RFLT|C_TWRD);
299 }
300 break;
301 default:
302 quiterr("unsupported photometric type");
303 break;
304 }
305
306 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
307 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
308 quiterr("unknown input image resolution");
309
310 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
311 cvts.stonits = 1.;
312 /* add to Radiance header */
313 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
314 fputaspect(cvts.pixrat, cvts.rfp);
315 if (CHK(C_XYZE)) {
316 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
317 fputformat(CIEFMT, cvts.rfp);
318 } else {
319 if (CHK(C_PRIM))
320 fputprims(cvts.prims, cvts.rfp);
321 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
322 cvts.rfp);
323 fputformat(COLRFMT, cvts.rfp);
324 }
325
326 allocbufs(); /* allocate scanline buffers */
327 }
328
329
330 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
331 int ac;
332 char *av[];
333 {
334 int32 y;
335 /* open TIFF input */
336 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
337 quiterr("cannot open TIFF input");
338 /* open Radiance output */
339 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
340 cvts.rfp = stdout;
341 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
342 quiterr("cannot open Radiance output picture");
343 /* start output header */
344 newheader("RADIANCE", cvts.rfp);
345 printargs(ac, av, cvts.rfp);
346
347 initfromtif(); /* initialize conversion */
348
349 fputc('\n', cvts.rfp); /* finish Radiance header */
350 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
351
352 for (y = 0; y < cvts.ymax; y++) /* convert image */
353 (*cvts.tf)(y);
354 /* clean up */
355 fclose(cvts.rfp);
356 TIFFClose(cvts.tif);
357 }
358
359
360 int
361 headline(s) /* process Radiance input header line */
362 char *s;
363 {
364 char fmt[32];
365
366 if (formatval(fmt, s)) {
367 if (!strcmp(fmt, COLRFMT))
368 CLR(C_XYZE);
369 else if (!strcmp(fmt, CIEFMT))
370 SET(C_XYZE);
371 else
372 quiterr("unrecognized input picture format");
373 return(1);
374 }
375 if (isexpos(s)) {
376 cvts.stonits /= exposval(s);
377 return(1);
378 }
379 if (isaspect(s)) {
380 cvts.pixrat *= aspectval(s);
381 return(1);
382 }
383 if (isprims(s)) {
384 primsval(cvts.prims, s);
385 SET(C_PRIM);
386 return(1);
387 }
388 return(0);
389 }
390
391
392 initfromrad() /* initialize input from a Radiance picture */
393 {
394 int i1, i2, po;
395 /* read Radiance header */
396 CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
397 cvts.stonits = 1.;
398 cvts.pixrat = 1.;
399 cvts.pconf = PLANARCONFIG_CONTIG;
400 getheader(cvts.rfp, headline, NULL);
401 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
402 quiterr("bad Radiance picture");
403 cvts.xmax = i1; cvts.ymax = i2;
404 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
405 if (ortab[i1] == po) {
406 cvts.orient = i1 + 1;
407 break;
408 }
409 if (i1 >= 8)
410 quiterr("internal error 1 in initfromrad");
411 if (!(po & YMAJOR))
412 cvts.pixrat = 1./cvts.pixrat;
413 if (!CHK(C_XYZE))
414 cvts.stonits *= WHTEFFICACY;
415 /* set up conversion */
416 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
417 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
418
419 switch (cvts.phot) {
420 case PHOTOMETRIC_LOGLUV:
421 SET(C_RFLT|C_TFLT);
422 CLR(C_GRY);
423 if (!CHK(C_XYZE)) {
424 comprgb2xyzWBmat(cvts.cmat,
425 CHK(C_PRIM) ? cvts.prims : stdprims);
426 SET(C_CXFM);
427 }
428 if (cvts.comp != COMPRESSION_SGILOG &&
429 cvts.comp != COMPRESSION_SGILOG24)
430 quiterr("internal error 2 in initfromrad");
431 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
432 SGILOGDATAFMT_FLOAT);
433 cvts.tf = Color2Luv;
434 break;
435 case PHOTOMETRIC_LOGL:
436 SET(C_GRY|C_RFLT|C_TFLT);
437 if (cvts.comp != COMPRESSION_SGILOG)
438 quiterr("internal error 3 in initfromrad");
439 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
440 SGILOGDATAFMT_FLOAT);
441 cvts.tf = Color2L;
442 break;
443 case PHOTOMETRIC_RGB:
444 SET(C_GAMMA|C_GAMUT);
445 CLR(C_GRY);
446 setcolrgam(cvts.gamcor);
447 if (CHK(C_XYZE)) {
448 compxyz2rgbWBmat(cvts.cmat,
449 CHK(C_PRIM) ? cvts.prims : stdprims);
450 SET(C_CXFM);
451 }
452 if (CHK(C_PRIM)) {
453 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
454 (float *)cvts.prims);
455 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
456 (float *)cvts.prims[WHT]);
457 }
458 cvts.tf = Colr2RGB;
459 break;
460 case PHOTOMETRIC_MINISBLACK:
461 SET(C_GRY|C_GAMMA|C_GAMUT);
462 setcolrgam(cvts.gamcor);
463 cvts.tf = Colr2Gry;
464 break;
465 default:
466 quiterr("internal error 4 in initfromrad");
467 break;
468 }
469 /* set other TIFF fields */
470 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
471 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
472 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
473 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8);
474 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
475 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
476 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
477 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
478 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
479 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
480 cvts.stonits/pow(2.,(double)cvts.bradj));
481 if (cvts.comp == COMPRESSION_NONE)
482 i1 = TIFFScanlineSize(cvts.tif);
483 else
484 i1 = 3*cvts.xmax; /* conservative guess */
485 i2 = 8192/i1; /* compute good strip size */
486 if (i2 < 1) i2 = 1;
487 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
488
489 allocbufs(); /* allocate scanline buffers */
490 }
491
492
493 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
494 int ac;
495 char *av[];
496 {
497 uint32 y;
498 /* open Radiance file */
499 if (!strcmp(av[ac], "-"))
500 cvts.rfp = stdin;
501 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
502 quiterr("cannot open Radiance input picture");
503 /* open TIFF file */
504 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
505 quiterr("cannot open TIFF output");
506
507 initfromrad(); /* initialize conversion */
508
509 for (y = 0; y < cvts.ymax; y++) /* convert image */
510 (*cvts.tf)(y);
511 /* clean up */
512 TIFFClose(cvts.tif);
513 fclose(cvts.rfp);
514 }
515
516
517 int
518 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
519 uint32 y;
520 {
521 register int x;
522
523 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
524 quiterr("internal error 1 in Luv2Color");
525
526 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
527 quiterr("error reading TIFF input");
528
529 for (x = cvts.xmax; x--; ) {
530 colval(cvts.r.colors[x],CIEX) = cvts.t.fp[3*x];
531 colval(cvts.r.colors[x],CIEY) = cvts.t.fp[3*x + 1];
532 colval(cvts.r.colors[x],CIEZ) = cvts.t.fp[3*x + 2];
533 if (CHK(C_CXFM))
534 colortrans(cvts.r.colors[x], cvts.cmat,
535 cvts.r.colors[x]);
536 if (CHK(C_GAMUT))
537 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
538 CGAMUT_LOWER, cblack, cwhite);
539 }
540 if (cvts.bradj) {
541 double m = pow(2.,(double)cvts.bradj);
542 for (x = cvts.xmax; x--; )
543 scalecolor(cvts.r.colors[x], m);
544 }
545
546 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
547 quiterr("error writing Radiance picture");
548 }
549
550
551 int
552 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
553 uint32 y;
554 {
555 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
556 register double d;
557 register int x;
558
559 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
560 quiterr("internal error 1 in RRGGBB2Color");
561
562 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
563 quiterr("error reading TIFF input");
564
565 for (x = cvts.xmax; x--; ) {
566 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
567 if (dogamma) d = pow(d, cvts.gamcor);
568 colval(cvts.r.colors[x],RED) = d;
569 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
570 if (dogamma) d = pow(d, cvts.gamcor);
571 colval(cvts.r.colors[x],GRN) = d;
572 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
573 if (dogamma) d = pow(d, cvts.gamcor);
574 colval(cvts.r.colors[x],BLU) = d;
575 if (CHK(C_CXFM))
576 colortrans(cvts.r.colors[x], cvts.cmat,
577 cvts.r.colors[x]);
578 if (CHK(C_GAMUT))
579 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
580 CGAMUT_LOWER, cblack, cwhite);
581 }
582 if (cvts.bradj) {
583 d = pow(2.,(double)cvts.bradj);
584 for (x = cvts.xmax; x--; )
585 scalecolor(cvts.r.colors[x], d);
586 }
587
588 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
589 quiterr("error writing Radiance picture");
590 }
591
592
593 int
594 L2Color(y) /* read/convert/write L16->COLOR scanline */
595 uint32 y;
596 {
597 register int x;
598
599 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
600 quiterr("internal error 1 in L2Color");
601
602 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
603 quiterr("error reading TIFF input");
604
605 for (x = cvts.xmax; x--; )
606 colval(cvts.r.colors[x],RED) =
607 colval(cvts.r.colors[x],GRN) =
608 colval(cvts.r.colors[x],BLU) =
609 cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.;
610
611 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
612 quiterr("error writing Radiance picture");
613 }
614
615
616 int
617 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
618 uint32 y;
619 {
620 COLOR ctmp;
621 register int x;
622
623 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
624 quiterr("internal error 1 in RGB2Colr");
625
626 if (cvts.pconf == PLANARCONFIG_CONTIG) {
627 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
628 goto readerr;
629 for (x = cvts.xmax; x--; ) {
630 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
631 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
632 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
633 }
634 } else {
635 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
636 goto readerr;
637 if (TIFFReadScanline(cvts.tif,
638 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
639 goto readerr;
640 if (TIFFReadScanline(cvts.tif,
641 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
642 goto readerr;
643 for (x = cvts.xmax; x--; ) {
644 cvts.r.colrs[x][RED] = cvts.t.bp[x];
645 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
646 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
647 }
648 }
649
650 gambs_colrs(cvts.r.colrs, cvts.xmax);
651 if (CHK(C_CXFM))
652 for (x = cvts.xmax; x--; ) {
653 colr_color(ctmp, cvts.r.colrs[x]);
654 colortrans(ctmp, cvts.cmat, ctmp);
655 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
656 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
657 cblack, cwhite);
658 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
659 colval(ctmp,GRN), colval(ctmp,BLU));
660 }
661 if (cvts.bradj)
662 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
663
664 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
665 quiterr("error writing Radiance picture");
666 return;
667 readerr:
668 quiterr("error reading TIFF input");
669 }
670
671
672 int
673 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
674 uint32 y;
675 {
676 register int x;
677
678 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
679 quiterr("internal error 1 in Gry2Colr");
680
681 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
682 quiterr("error reading TIFF input");
683
684 for (x = cvts.xmax; x--; )
685 cvts.r.colrs[x][RED] =
686 cvts.r.colrs[x][GRN] =
687 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
688
689 gambs_colrs(cvts.r.colrs, cvts.xmax);
690 if (cvts.bradj)
691 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
692
693 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
694 quiterr("error writing Radiance picture");
695 }
696
697
698 int
699 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
700 uint32 y;
701 {
702 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
703 double m;
704 register double d;
705 register int x;
706
707 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
708 quiterr("internal error 1 in GGry2Color");
709
710 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
711 quiterr("error reading TIFF input");
712
713 if (cvts.bradj)
714 m = pow(2., (double)cvts.bradj);
715 for (x = cvts.xmax; x--; ) {
716 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
717 if (dogamma) d = pow(d, cvts.gamcor);
718 if (cvts.bradj) d *= m;
719 colval(cvts.r.colors[x],RED) =
720 colval(cvts.r.colors[x],GRN) =
721 colval(cvts.r.colors[x],BLU) = d;
722 }
723 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
724 quiterr("error writing Radiance picture");
725 }
726
727
728 int
729 Color2L(y) /* read/convert/write COLOR->L16 scanline */
730 uint32 y;
731 {
732 double m = pow(2.,(double)cvts.bradj);
733 register int x;
734
735 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
736 quiterr("internal error 1 in Color2L");
737
738 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
739 quiterr("error reading Radiance picture");
740
741 for (x = cvts.xmax; x--; )
742 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
743 : bright(cvts.r.colors[x]) );
744
745 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
746 quiterr("error writing TIFF output");
747 }
748
749
750 int
751 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
752 uint32 y;
753 {
754 register int x;
755
756 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
757 quiterr("internal error 1 in Color2Luv");
758
759 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
760 quiterr("error reading Radiance picture");
761
762 if (CHK(C_CXFM))
763 for (x = cvts.xmax; x--; )
764 colortrans(cvts.r.colors[x], cvts.cmat,
765 cvts.r.colors[x]);
766 if (cvts.bradj) {
767 double m = pow(2.,(double)cvts.bradj);
768 for (x = cvts.xmax; x--; )
769 scalecolor(cvts.r.colors[x], m);
770 }
771
772 for (x = cvts.xmax; x--; ) {
773 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
774 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
775 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
776 }
777
778 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
779 quiterr("error writing TIFF output");
780 }
781
782
783 int
784 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
785 uint32 y;
786 {
787 register int x;
788
789 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
790 quiterr("internal error 1 in Colr2Gry");
791
792 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
793 quiterr("error reading Radiance picture");
794
795 if (cvts.bradj)
796 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
797 for (x = cvts.xmax; x--; )
798 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
799 colrs_gambs(cvts.r.colrs, cvts.xmax);
800
801 for (x = cvts.xmax; x--; )
802 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
803
804 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
805 quiterr("error writing TIFF output");
806 }
807
808
809 int
810 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
811 uint32 y;
812 {
813 COLOR ctmp;
814 register int x;
815
816 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
817 quiterr("internal error 1 in Colr2RGB");
818
819 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
820 quiterr("error reading Radiance picture");
821
822 if (cvts.bradj)
823 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
824 if (CHK(C_CXFM))
825 for (x = cvts.xmax; x--; ) {
826 colr_color(ctmp, cvts.r.colrs[x]);
827 colortrans(ctmp, cvts.cmat, ctmp);
828 if (CHK(C_GAMUT))
829 clipgamut(ctmp, bright(ctmp), CGAMUT,
830 cblack, cwhite);
831 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
832 colval(ctmp,GRN), colval(ctmp,BLU));
833 }
834 colrs_gambs(cvts.r.colrs, cvts.xmax);
835
836 for (x = cvts.xmax; x--; ) {
837 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
838 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
839 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
840 }
841
842 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
843 quiterr("error writing TIFF output");
844 }
