root/radiance/ray/src/px/ra_tiff.c
Revision: 2.13
Committed: Wed Aug 27 11:10:45 1997 UTC (27 years, 9 months ago) by gregl
minor optimization
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to convert between RADIANCE and TIFF files.
9 * Added experimental LogLuv encodings 7/97 (GWL).
10 */
11
12 #include <stdio.h>
13 #include <math.h>
14 #include "tiffio.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define GAMCOR 2.2 /* default gamma */
19
20 #ifndef malloc
21 extern char *malloc();
22 #endif
23 /* conversion flags */
24 #define C_CXFM 0x1 /* needs color transformation */
25 #define C_GAMUT 0x2 /* needs gamut mapping */
26 #define C_GAMMA 0x4 /* needs gamma correction */
27 #define C_GRY 0x8 /* TIFF is greyscale */
28 #define C_XYZE 0x10 /* Radiance is XYZE */
29 #define C_RFLT 0x20 /* Radiance data is float */
30 #define C_TFLT 0x40 /* TIFF data is float */
31 #define C_PRIM 0x80 /* has assigned primaries */
32
33 struct {
34 uint16 flags; /* conversion flags (defined above) */
35 uint16 comp; /* TIFF compression type */
36 uint16 phot; /* TIFF photometric type */
37 uint16 pconf; /* TIFF planar configuration */
38 float gamcor; /* gamma correction value */
39 short bradj; /* Radiance exposure adjustment (stops) */
40 uint16 orient; /* visual orientation (TIFF spec.) */
41 double stonits; /* input conversion to nits */
42 float pixrat; /* pixel aspect ratio */
43 FILE *rfp; /* Radiance stream pointer */
44 TIFF *tif; /* TIFF pointer */
45 uint32 xmax, ymax; /* image dimensions */
46 COLORMAT cmat; /* color transformation matrix */
47 RGBPRIMS prims; /* RGB primaries */
48 union {
49 COLR *colrs; /* 4-byte ???E pointer */
50 COLOR *colors; /* float array pointer */
51 char *p; /* generic pointer */
52 } r; /* Radiance scanline */
53 union {
54 uint8 *bp; /* byte pointer */
55 float *fp; /* float pointer */
56 char *p; /* generic pointer */
57 } t; /* TIFF scanline */
58 int (*tf)(); /* translation procedure */
59 } cvts = { /* conversion structure */
60 0, COMPRESSION_NONE, PHOTOMETRIC_RGB,
61 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
62 };
63
64 #define CHK(f) (cvts.flags & (f))
65 #define SET(f) (cvts.flags |= (f))
66 #define CLR(f) (cvts.flags &= ~(f))
67 #define TGL(f) (cvts.flags ^= (f))
68
69 int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
70 int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
71
72 short ortab[8] = { /* orientation conversion table */
73 YMAJOR|YDECR,
74 YMAJOR|YDECR|XDECR,
75 YMAJOR|XDECR,
76 YMAJOR,
77 YDECR,
78 XDECR|YDECR,
79 XDECR,
80 0
81 };
82
83 #define pixorder() ortab[cvts.orient-1]
84
85 char *progname;
86
87
88 main(argc, argv)
89 int argc;
90 char *argv[];
91 {
92 int reverse = 0;
93 int i;
94
95 progname = argv[0];
96
97 for (i = 1; i < argc; i++)
98 if (argv[i][0] == '-')
99 switch (argv[i][1]) {
100 case 'g': /* gamma correction */
101 cvts.gamcor = atof(argv[++i]);
102 break;
103 case 'x': /* XYZE Radiance output */
104 TGL(C_XYZE);
105 break;
106 case 'z': /* LZW compressed output */
107 cvts.comp = COMPRESSION_LZW;
108 break;
109 case 'L': /* LogLuv 32-bit output */
110 cvts.comp = COMPRESSION_SGILOG;
111 cvts.phot = PHOTOMETRIC_LOGLUV;
112 break;
113 case 'l': /* LogLuv 24-bit output */
114 cvts.comp = COMPRESSION_SGILOG24;
115 cvts.phot = PHOTOMETRIC_LOGLUV;
116 break;
117 case 'b': /* greyscale output? */
118 TGL(C_GRY);
119 break;
120 case 'e': /* exposure adjustment */
121 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
122 goto userr;
123 cvts.bradj = atoi(argv[++i]);
124 break;
125 case 'r': /* reverse conversion? */
126 reverse = !reverse;
127 break;
128 case '\0':
129 goto doneopts;
130 default:
131 goto userr;
132 }
133 else
134 break;
135 doneopts:
136 if (reverse) {
137
138 if (i != argc-2 && i != argc-1)
139 goto userr;
140
141 tiff2ra(i, argv);
142
143 } else {
144
145 if (i != argc-2)
146 goto userr;
147
148 if (CHK(C_GRY)) /* consistency corrections */
149 if (cvts.phot == PHOTOMETRIC_RGB)
150 cvts.phot = PHOTOMETRIC_MINISBLACK;
151 else {
152 cvts.phot = PHOTOMETRIC_LOGL;
153 cvts.comp = COMPRESSION_SGILOG;
154 }
155
156 ra2tiff(i, argv);
157 }
158
159 exit(0);
160 userr:
161 fprintf(stderr,
162 "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
163 progname);
164 fprintf(stderr,
165 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
166 progname);
167 exit(1);
168 }
169
170
171 quiterr(err) /* print message and exit */
172 char *err;
173 {
174 if (err != NULL) {
175 fprintf(stderr, "%s: %s\n", progname, err);
176 exit(1);
177 }
178 exit(0);
179 }
180
181
182 allocbufs() /* allocate scanline buffers */
183 {
184 int rsiz, tsiz;
185
186 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
187 tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) *
188 (CHK(C_GRY) ? 1 : 3);
189 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
190 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
191 if (cvts.r.p == NULL | cvts.t.p == NULL)
192 quiterr("no memory to allocate scanline buffers");
193 }
194
195
196 initfromtif() /* initialize conversion from TIFF input */
197 {
198 uint16 hi;
199 float *fa, f1, f2;
200
201 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM);
202
203 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
204
205 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
206 cvts.prims[RED][CIEX] = fa[0];
207 cvts.prims[RED][CIEY] = fa[1];
208 cvts.prims[GRN][CIEX] = fa[2];
209 cvts.prims[GRN][CIEY] = fa[3];
210 cvts.prims[BLU][CIEX] = fa[4];
211 cvts.prims[BLU][CIEY] = fa[5];
212 cvts.prims[WHT][CIEX] = 1./3.;
213 cvts.prims[WHT][CIEY] = 1./3.;
214 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
215 cvts.prims[WHT][CIEX] = fa[0];
216 cvts.prims[WHT][CIEY] = fa[1];
217 }
218 SET(C_PRIM);
219 }
220
221 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
222 cvts.comp = COMPRESSION_NONE;
223
224 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
225 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
226 cvts.pixrat = f1/f2;
227
228 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
229
230 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
231 quiterr("TIFF has unspecified photometric type");
232
233 switch (cvts.phot) {
234 case PHOTOMETRIC_LOGLUV:
235 SET(C_RFLT|C_TFLT);
236 if (!CHK(C_XYZE)) {
237 cpcolormat(cvts.cmat, xyz2rgbmat);
238 SET(C_CXFM|C_GAMUT);
239 } else if (cvts.comp == COMPRESSION_SGILOG)
240 SET(C_GAMUT);
241 if (cvts.pconf != PLANARCONFIG_CONTIG)
242 quiterr("cannot handle separate Luv planes");
243 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
244 SGILOGDATAFMT_FLOAT);
245 cvts.tf = Luv2Color;
246 break;
247 case PHOTOMETRIC_LOGL:
248 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
249 cvts.pconf = PLANARCONFIG_CONTIG;
250 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
251 SGILOGDATAFMT_FLOAT);
252 cvts.tf = L2Color;
253 break;
254 case PHOTOMETRIC_YCBCR:
255 if (cvts.comp == COMPRESSION_JPEG &&
256 cvts.pconf == PLANARCONFIG_CONTIG) {
257 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
258 JPEGCOLORMODE_RGB);
259 cvts.phot = PHOTOMETRIC_RGB;
260 } else
261 quiterr("unsupported photometric type");
262 /* fall through */
263 case PHOTOMETRIC_RGB:
264 SET(C_GAMMA|C_GAMUT);
265 setcolrgam(cvts.gamcor);
266 if (CHK(C_XYZE)) {
267 comprgb2xyzmat(cvts.cmat,
268 CHK(C_PRIM) ? cvts.prims : stdprims);
269 SET(C_CXFM);
270 }
271 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
272 hi != 3)
273 quiterr("unsupported samples per pixel for RGB");
274 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
275 hi != 8)
276 quiterr("unsupported bits per sample for RGB");
277 cvts.tf = RGB2Colr;
278 break;
279 case PHOTOMETRIC_MINISBLACK:
280 SET(C_GRY|C_GAMMA|C_GAMUT);
281 cvts.pconf = PLANARCONFIG_CONTIG;
282 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
283 hi != 1)
284 quiterr("unsupported samples per pixel for greyscale");
285 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
286 hi != 8)
287 quiterr("unsupported bits per sample for greyscale");
288 cvts.tf = Gry2Colr;
289 break;
290 default:
291 quiterr("unsupported photometric type");
292 break;
293 }
294
295 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
296 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
297 quiterr("unknown input image resolution");
298
299 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
300 cvts.stonits = 1.;
301 /* add to Radiance header */
302 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
303 fputaspect(cvts.pixrat, cvts.rfp);
304 if (CHK(C_XYZE)) {
305 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
306 fputformat(CIEFMT, cvts.rfp);
307 } else {
308 if (CHK(C_PRIM))
309 fputprims(cvts.prims, cvts.rfp);
310 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
311 cvts.rfp);
312 fputformat(COLRFMT, cvts.rfp);
313 }
314
315 allocbufs(); /* allocate scanline buffers */
316 }
317
318
319 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
320 int ac;
321 char *av[];
322 {
323 int32 y;
324 /* open TIFF input */
325 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
326 quiterr("cannot open TIFF input");
327 /* open Radiance output */
328 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
329 cvts.rfp = stdout;
330 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
331 quiterr("cannot open Radiance output picture");
332 /* start output header */
333 newheader("RADIANCE", cvts.rfp);
334 printargs(ac, av, cvts.rfp);
335
336 initfromtif(); /* initialize conversion */
337
338 fputc('\n', cvts.rfp); /* finish Radiance header */
339 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
340
341 for (y = 0; y < cvts.ymax; y++) /* convert image */
342 (*cvts.tf)(y);
343 /* clean up */
344 fclose(cvts.rfp);
345 TIFFClose(cvts.tif);
346 }
347
348
349 int
350 headline(s) /* process Radiance input header line */
351 char *s;
352 {
353 char fmt[32];
354
355 if (formatval(fmt, s)) {
356 if (!strcmp(fmt, COLRFMT))
357 CLR(C_XYZE);
358 else if (!strcmp(fmt, CIEFMT))
359 SET(C_XYZE);
360 else
361 quiterr("unrecognized input picture format");
362 return;
363 }
364 if (isexpos(s)) {
365 cvts.stonits /= exposval(s);
366 return;
367 }
368 if (isaspect(s)) {
369 cvts.pixrat *= aspectval(s);
370 return;
371 }
372 if (isprims(s)) {
373 primsval(cvts.prims, s);
374 SET(C_PRIM);
375 return;
376 }
377 }
378
379
380 initfromrad() /* initialize input from a Radiance picture */
381 {
382 int i1, i2, po;
383 /* read Radiance header */
384 CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
385 cvts.stonits = 1.;
386 cvts.pixrat = 1.;
387 cvts.pconf = PLANARCONFIG_CONTIG;
388 getheader(cvts.rfp, headline, NULL);
389 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
390 quiterr("bad Radiance picture");
391 cvts.xmax = i1; cvts.ymax = i2;
392 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
393 if (ortab[i1] == po) {
394 cvts.orient = i1 + 1;
395 break;
396 }
397 if (i1 >= 8)
398 quiterr("internal error 1 in initfromrad");
399 if (!(po & YMAJOR))
400 cvts.pixrat = 1./cvts.pixrat;
401 if (!CHK(C_XYZE))
402 cvts.stonits *= WHTEFFICACY;
403 /* set up conversion */
404 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
405 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
406
407 switch (cvts.phot) {
408 case PHOTOMETRIC_LOGLUV:
409 SET(C_RFLT|C_TFLT);
410 CLR(C_GRY);
411 if (!CHK(C_XYZE)) {
412 cpcolormat(cvts.cmat, rgb2xyzmat);
413 SET(C_CXFM);
414 }
415 if (cvts.comp != COMPRESSION_SGILOG &&
416 cvts.comp != COMPRESSION_SGILOG24)
417 quiterr("internal error 2 in initfromrad");
418 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
419 SGILOGDATAFMT_FLOAT);
420 cvts.tf = Color2Luv;
421 break;
422 case PHOTOMETRIC_LOGL:
423 SET(C_GRY|C_RFLT|C_TFLT);
424 if (cvts.comp != COMPRESSION_SGILOG)
425 quiterr("internal error 3 in initfromrad");
426 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
427 SGILOGDATAFMT_FLOAT);
428 cvts.tf = Color2L;
429 break;
430 case PHOTOMETRIC_RGB:
431 SET(C_GAMMA|C_GAMUT);
432 CLR(C_GRY);
433 setcolrgam(cvts.gamcor);
434 if (CHK(C_XYZE)) {
435 compxyz2rgbmat(cvts.cmat,
436 CHK(C_PRIM) ? cvts.prims : stdprims);
437 SET(C_CXFM);
438 }
439 if (CHK(C_PRIM)) {
440 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
441 (float *)cvts.prims);
442 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
443 (float *)cvts.prims[WHT]);
444 }
445 cvts.tf = Colr2RGB;
446 break;
447 case PHOTOMETRIC_MINISBLACK:
448 SET(C_GRY|C_GAMMA|C_GAMUT);
449 setcolrgam(cvts.gamcor);
450 cvts.tf = Colr2Gry;
451 break;
452 default:
453 quiterr("internal error 4 in initfromrad");
454 break;
455 }
456 /* set other TIFF fields */
457 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
458 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
459 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
460 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8);
461 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
462 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
463 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
464 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
465 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
466 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
467 cvts.stonits/pow(2.,(double)cvts.bradj));
468 if (cvts.comp == COMPRESSION_NONE)
469 i1 = TIFFScanlineSize(cvts.tif);
470 else
471 i1 = 3*cvts.xmax; /* conservative guess */
472 i2 = 8192/i1; /* compute good strip size */
473 if (i2 < 1) i2 = 1;
474 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
475
476 allocbufs(); /* allocate scanline buffers */
477 }
478
479
480 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
481 int ac;
482 char *av[];
483 {
484 uint32 y;
485 /* open Radiance file */
486 if (!strcmp(av[ac], "-"))
487 cvts.rfp = stdin;
488 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
489 quiterr("cannot open Radiance input picture");
490 /* open TIFF file */
491 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
492 quiterr("cannot open TIFF output");
493
494 initfromrad(); /* initialize conversion */
495
496 for (y = 0; y < cvts.ymax; y++) /* convert image */
497 (*cvts.tf)(y);
498 /* clean up */
499 TIFFClose(cvts.tif);
500 fclose(cvts.rfp);
501 }
502
503
504 int
505 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
506 uint32 y;
507 {
508 register int x;
509
510 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
511 quiterr("internal error 1 in Luv2Color");
512
513 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
514 quiterr("error reading TIFF input");
515
516 for (x = cvts.xmax; x--; ) {
517 cvts.r.colors[x][RED] = cvts.t.fp[3*x];
518 cvts.r.colors[x][GRN] = cvts.t.fp[3*x + 1];
519 cvts.r.colors[x][BLU] = cvts.t.fp[3*x + 2];
520 if (CHK(C_CXFM))
521 colortrans(cvts.r.colors[x], cvts.cmat,
522 cvts.r.colors[x]);
523 if (CHK(C_GAMUT))
524 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
525 CGAMUT_LOWER, cblack, cwhite);
526 }
527 if (cvts.bradj) {
528 double m = pow(2.,(double)cvts.bradj);
529 for (x = cvts.xmax; x--; )
530 scalecolor(cvts.r.colors[x], m);
531 }
532
533 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
534 quiterr("error writing Radiance picture");
535 }
536
537
538 int
539 L2Color(y) /* read/convert/write L16->COLOR scanline */
540 uint32 y;
541 {
542 register int x;
543
544 if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
545 quiterr("internal error 1 in L2Color");
546
547 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
548 quiterr("error reading TIFF input");
549
550 for (x = cvts.xmax; x--; )
551 cvts.r.colors[x][RED] =
552 cvts.r.colors[x][GRN] =
553 cvts.r.colors[x][BLU] = cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.;
554
555 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
556 quiterr("error writing Radiance picture");
557 }
558
559
560 int
561 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
562 uint32 y;
563 {
564 COLOR ctmp;
565 register int x;
566
567 if (CHK(C_RFLT|C_TFLT|C_GRY))
568 quiterr("internal error 1 in RGB2Colr");
569
570 if (cvts.pconf == PLANARCONFIG_CONTIG) {
571 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
572 goto readerr;
573 for (x = cvts.xmax; x--; ) {
574 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
575 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
576 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
577 }
578 } else {
579 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
580 goto readerr;
581 if (TIFFReadScanline(cvts.tif,
582 (tidata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
583 goto readerr;
584 if (TIFFReadScanline(cvts.tif,
585 (tidata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
586 goto readerr;
587 for (x = cvts.xmax; x--; ) {
588 cvts.r.colrs[x][RED] = cvts.t.bp[x];
589 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
590 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
591 }
592 }
593
594 gambs_colrs(cvts.r.colrs, cvts.xmax);
595 if (CHK(C_CXFM))
596 for (x = cvts.xmax; x--; ) {
597 colr_color(ctmp, cvts.r.colrs[x]);
598 colortrans(ctmp, cvts.cmat, ctmp);
599 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
600 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
601 cblack, cwhite);
602 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
603 colval(ctmp,GRN), colval(ctmp,BLU));
604 }
605 if (cvts.bradj)
606 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
607
608 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
609 quiterr("error writing Radiance picture");
610 return;
611 readerr:
612 quiterr("error reading TIFF input");
613 }
614
615
616 int
617 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
618 uint32 y;
619 {
620 register int x;
621
622 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
623 quiterr("internal error 1 in Gry2Colr");
624
625 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
626 quiterr("error reading TIFF input");
627
628 for (x = cvts.xmax; x--; )
629 cvts.r.colrs[x][RED] =
630 cvts.r.colrs[x][GRN] =
631 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
632
633 gambs_colrs(cvts.r.colrs, cvts.xmax);
634 if (cvts.bradj)
635 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
636
637 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
638 quiterr("error writing Radiance picture");
639 }
640
641
642 int
643 Color2L(y) /* read/convert/write COLOR->L16 scanline */
644 uint32 y;
645 {
646 double m = pow(2.,(double)cvts.bradj);
647 register int x;
648
649 if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
650 quiterr("internal error 1 in Color2L");
651
652 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
653 quiterr("error reading Radiance picture");
654
655 for (x = cvts.xmax; x--; )
656 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
657 : bright(cvts.r.colors[x]) );
658
659 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
660 quiterr("error writing TIFF output");
661 }
662
663
664 int
665 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
666 uint32 y;
667 {
668 register int x;
669
670 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
671 quiterr("internal error 1 in Color2Luv");
672
673 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
674 quiterr("error reading Radiance picture");
675
676 if (CHK(C_CXFM))
677 for (x = cvts.xmax; x--; )
678 colortrans(cvts.r.colors[x], cvts.cmat,
679 cvts.r.colors[x]);
680 if (cvts.bradj) {
681 double m = pow(2.,(double)cvts.bradj);
682 for (x = cvts.xmax; x--; )
683 scalecolor(cvts.r.colors[x], m);
684 }
685
686 for (x = cvts.xmax; x--; ) {
687 cvts.t.fp[3*x] = colval(cvts.r.colors[x],RED);
688 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],GRN);
689 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],BLU);
690 }
691
692 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
693 quiterr("error writing TIFF output");
694 }
695
696
697 int
698 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
699 uint32 y;
700 {
701 register int x;
702
703 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
704 quiterr("internal error 1 in Colr2Gry");
705
706 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
707 quiterr("error reading Radiance picture");
708
709 if (cvts.bradj)
710 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
711 for (x = cvts.xmax; x--; )
712 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
713 colrs_gambs(cvts.r.colrs, cvts.xmax);
714
715 for (x = cvts.xmax; x--; )
716 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
717
718 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
719 quiterr("error writing TIFF output");
720 }
721
722
723 int
724 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
725 uint32 y;
726 {
727 COLOR ctmp;
728 register int x;
729
730 if (CHK(C_RFLT|C_TFLT|C_GRY))
731 quiterr("internal error 1 in Colr2RGB");
732
733 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
734 quiterr("error reading Radiance picture");
735
736 if (cvts.bradj)
737 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
738 if (CHK(C_CXFM))
739 for (x = cvts.xmax; x--; ) {
740 colr_color(ctmp, cvts.r.colrs[x]);
741 colortrans(ctmp, cvts.cmat, ctmp);
742 if (CHK(C_GAMUT))
743 clipgamut(ctmp, bright(ctmp), CGAMUT,
744 cblack, cwhite);
745 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
746 colval(ctmp,GRN), colval(ctmp,BLU));
747 }
748 colrs_gambs(cvts.r.colrs, cvts.xmax);
749
750 for (x = cvts.xmax; x--; ) {
751 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
752 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
753 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
754 }
755
756 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
757 quiterr("error writing TIFF output");
758 }
