root/radiance/ray/src/px/ra_tiff.c
Mon Nov 10 19:08:19 2008 UTC (16 years, 6 months ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32 , to selected 2.29
Fri Aug 19 02:31:32 2005 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R7P2, rad3R8, rad3R9
Changes since 2.31: +7 -5 lines
Diff to previous 2.31 , to selected 2.29
Tue Jun 7 16:54:23 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P1
Changes since 2.30: +7 -1 lines
Diff to previous 2.30 , to selected 2.29
Added missing error checks for 16-bit and 32-bit separate color planes
Tue Mar 22 15:26:05 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 2.29
Fixed remaining bug for conversion from XYZE -> 16-bit/channel TIFF
Revision 2.29 - (view) (download) (annotate) - [selected]
Tue Mar 22 04:51:56 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.28: +12 -6 lines
Diff to previous 2.28
Sun Mar 28 20:33:14 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.27: +87 -57 lines
Diff to previous 2.27 , to selected 2.29
Fri Jan 2 12:47:01 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.26: +10 -4 lines
Diff to previous 2.26 , to selected 2.29
Changes since 2.25: +6 -6 lines
Diff to previous 2.25 , to selected 2.29
Mon Jul 21 22:30:19 2003 UTC (21 years, 10 months ago) by schorsch
Diff to previous 2.24 , to selected 2.29
Wed Jul 16 01:32:53 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.23: +2 -1 lines
Diff to previous 2.23 , to selected 2.29
Minor compile fixes
Mon Jul 14 04:56:54 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.22: +5 -1 lines
Diff to previous 2.22 , to selected 2.29
Tue Jul 1 22:44:02 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.21: +59 -3 lines
Diff to previous 2.21 , to selected 2.29
Added handling of TIFFTAG_DATETIME and TIFFTAG_ARTIST
Tue Jul 1 19:04:08 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.20: +162 -49 lines
Diff to previous 2.20 , to selected 2.29
Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.19: +8 -11 lines
Diff to previous 2.19 , to selected 2.29
Wed Jun 2 10:57:53 1999 UTC (26 years ago) by gwlarson
Changes since 2.18: +16 -14 lines
Diff to previous 2.18 , to selected 2.29
fixed bug in allocated buffer size
Sun May 30 17:35:08 1999 UTC (26 years ago) by gwlarson
Changes since 2.17: +94 -10 lines
Diff to previous 2.17 , to selected 2.29
added ability to read 16-bit/channel TIFFs
Tue Oct 27 09:08:27 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 2.16: +5 -4 lines
Diff to previous 2.16 , to selected 2.29
Thu Oct 8 11:21:52 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 2.15: +10 -9 lines
Diff to previous 2.15 , to selected 2.29
cosmetic changes to use correct macros for color assignments
Wed Sep 24 14:54:03 1997 UTC (27 years, 8 months ago) by gregl
Changes since 2.14: +1 -0 lines
Diff to previous 2.14 , to selected 2.29
added missing call to setgamcor()
Fri Aug 29 15:35:28 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 2.13 , to selected 2.29
minor fix
Wed Aug 27 11:10:45 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 2.12 , to selected 2.29
minor optimization
Tue Aug 26 15:01:26 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 2.11 , to selected 2.29
consolidated SGILOGDATAFMT values
Fri Aug 15 18:30:14 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.10: +10 -1 lines
Diff to previous 2.10 , to selected 2.29
changed StoNits to double and added JPEG reading capability
Thu Jul 31 21:26:45 1997 UTC (27 years, 10 months ago) by gregl
Changes since 2.9: +80 -64 lines
Diff to previous 2.9 , to selected 2.29
modified TIFF library with new photometric types
Thu Jul 24 11:47:05 1997 UTC (27 years, 10 months ago) by gregl
Changes since 2.8: +640 -172 lines
Diff to previous 2.8 , to selected 2.29
added a ton of new stuff for Luv format images and new tags
Mon Oct 30 10:56:57 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.7: +5 -1 lines
Diff to previous 2.7 , to selected 2.29
added -g option to header output
Fri Nov 11 11:26:20 1994 UTC (30 years, 7 months ago) by greg
Changes since 2.6: +10 -5 lines
Diff to previous 2.6 , to selected 2.29
replaced some values with macros for improved readability
Sun Feb 27 10:17:27 1994 UTC (31 years, 3 months ago) by greg
Diff to previous 2.5 , to selected 2.29
Thu Nov 18 09:55:26 1993 UTC (31 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 2.29
minor compiler warning fixes
Mon Jul 12 12:41:18 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.3 , to selected 2.29
renamed gamma to avoid math library conflict
Fri Jun 4 14:48:05 1993 UTC (32 years ago) by greg
Diff to previous 2.2 , to selected 2.29
added math.h for atof() usage
Thu Dec 19 14:52:25 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.29
Tue Nov 12 16:05:41 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 2.29
Mon Nov 11 14:01:23 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.5: +4 -2 lines
Diff to previous 1.5 , to selected 2.29
Thu Aug 15 15:47:35 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.4: +39 -16 lines
Diff to previous 1.4 , to selected 2.29
added -b option for greyscale images
Thu Aug 15 14:48:55 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.3: +9 -1 lines
Diff to previous 1.3 , to selected 2.29
added -z option for LZW compression
Thu Aug 15 14:04:21 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.2: +0 -2 lines
Diff to previous 1.2 , to selected 2.29
added back gamma control (though not properly registered)
Thu Aug 15 13:54:08 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.1: +2 -55 lines
Diff to previous 1.1 , to selected 2.29
took out use of image description (sniff!)
Thu Aug 15 13:34:58 1991 UTC (33 years, 9 months ago) by greg
Diff to selected 2.29
