--- ray/src/px/ra_tiff.c 1997/07/24 11:47:05 2.9 +++ ray/src/px/ra_tiff.c 2003/07/14 04:56:54 2.23 @@ -1,25 +1,21 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: ra_tiff.c,v 2.23 2003/07/14 04:56:54 greg Exp $"; #endif - /* * Program to convert between RADIANCE and TIFF files. - * Added experimental LogLuv encodings 7/97 (GWL). + * Added LogLuv encodings 7/97 (GWL). + * Added white-balance adjustment 10/01 (GW). */ #include #include +#include #include "tiffio.h" #include "color.h" #include "resolu.h" #define GAMCOR 2.2 /* default gamma */ -#ifndef malloc -extern char *malloc(); -#endif /* conversion flags */ #define C_CXFM 0x1 /* needs color transformation */ #define C_GAMUT 0x2 /* needs gamut mapping */ @@ -28,16 +24,20 @@ extern char *malloc(); #define C_XYZE 0x10 /* Radiance is XYZE */ #define C_RFLT 0x20 /* Radiance data is float */ #define C_TFLT 0x40 /* TIFF data is float */ -#define C_PRIM 0x80 /* has assigned primaries */ +#define C_TWRD 0x80 /* TIFF data is 16-bit */ +#define C_PRIM 0x100 /* has assigned primaries */ struct { uint16 flags; /* conversion flags (defined above) */ + char capdate[20]; /* capture date/time */ + char owner[256]; /* content owner */ uint16 comp; /* TIFF compression type */ + uint16 phot; /* TIFF photometric type */ uint16 pconf; /* TIFF planar configuration */ float gamcor; /* gamma correction value */ short bradj; /* Radiance exposure adjustment (stops) */ uint16 orient; /* visual orientation (TIFF spec.) */ - float stonits; /* input conversion to nits */ + double stonits; /* input conversion to nits */ float pixrat; /* pixel aspect ratio */ FILE *rfp; /* Radiance stream pointer */ TIFF *tif; /* TIFF pointer */ @@ -51,12 +51,14 @@ struct { } r; /* Radiance scanline */ union { uint8 *bp; /* byte pointer */ + uint16 *wp; /* word pointer */ float *fp; /* float pointer */ char *p; /* generic pointer */ } t; /* TIFF scanline */ - int (*tf)(); /* translation procedure */ + void (*tf)(); /* translation procedure */ } cvts = { /* conversion structure */ - 0, COMPRESSION_NONE, PLANARCONFIG_CONTIG, GAMCOR, 0, + 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB, + PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., }; #define CHK(f) (cvts.flags & (f)) @@ -64,9 +66,15 @@ struct { #define CLR(f) (cvts.flags &= ~(f)) #define TGL(f) (cvts.flags ^= (f)) -int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); -int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); +void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr(); +void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry(); +void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry(); +#define RfGfBf2Color Luv2Color +#define Gryf2Color L2Color +#define Color2Gryf Color2L +#define Color2RfGfBf Color2Luv + short ortab[8] = { /* orientation conversion table */ YMAJOR|YDECR, YMAJOR|YDECR|XDECR, @@ -80,6 +88,9 @@ short ortab[8] = { /* orientation conversion table */ #define pixorder() ortab[cvts.orient-1] +extern char TMSTR[]; /* "CAPDATE=" from header.c */ +char OWNSTR[] = "OWNER="; + char *progname; @@ -105,11 +116,19 @@ char *argv[]; cvts.comp = COMPRESSION_LZW; break; case 'L': /* LogLuv 32-bit output */ - cvts.comp = COMPRESSION_LOGLUV32; + cvts.comp = COMPRESSION_SGILOG; + cvts.phot = PHOTOMETRIC_LOGLUV; break; case 'l': /* LogLuv 24-bit output */ - cvts.comp = COMPRESSION_LOGLUV24; + cvts.comp = COMPRESSION_SGILOG24; + cvts.phot = PHOTOMETRIC_LOGLUV; break; + case 'w': /* 16-bit/primary output? */ + TGL(C_TWRD); + break; + case 'f': /* IEEE float output? */ + TGL(C_TFLT); + break; case 'b': /* greyscale output? */ TGL(C_GRY); break; @@ -140,18 +159,24 @@ doneopts: if (i != argc-2) goto userr; + /* consistency checks */ + if (CHK(C_GRY)) + if (cvts.phot == PHOTOMETRIC_RGB) + cvts.phot = PHOTOMETRIC_MINISBLACK; + else { + cvts.phot = PHOTOMETRIC_LOGL; + cvts.comp = COMPRESSION_SGILOG; + } + if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT)) + goto userr; - if (CHK(C_GRY) && (cvts.comp == COMPRESSION_LOGLUV24 || - cvts.comp == COMPRESSION_LOGLUV32)) - cvts.comp = COMPRESSION_LOGL16; - ra2tiff(i, argv); } exit(0); userr: fprintf(stderr, - "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", + "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n", progname); fprintf(stderr, " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n", @@ -176,7 +201,8 @@ allocbufs() /* allocate scanline buffers */ int rsiz, tsiz; rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); - tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) * + tsiz = (CHK(C_TFLT) ? sizeof(float) : + CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) * (CHK(C_GRY) ? 1 : 3); cvts.r.p = (char *)malloc(rsiz*cvts.xmax); cvts.t.p = (char *)malloc(tsiz*cvts.xmax); @@ -188,9 +214,10 @@ allocbufs() /* allocate scanline buffers */ initfromtif() /* initialize conversion from TIFF input */ { uint16 hi; + char *cp; float *fa, f1, f2; - CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM); + CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM); TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); @@ -216,71 +243,120 @@ initfromtif() /* initialize conversion from TIFF inpu if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) cvts.pixrat = f1/f2; - else - cvts.pixrat = 1.; - if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient)) - cvts.orient = 1; + TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient); - switch (cvts.comp) { - case COMPRESSION_LOGL16: - SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); - cvts.pconf = PLANARCONFIG_CONTIG; - TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT, - LOGLUVDATAFMT_FLTY); - TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, - SAMPLEFORMAT_IEEEFP); - cvts.tf = L2Color; - break; - case COMPRESSION_LOGLUV24: - case COMPRESSION_LOGLUV32: + if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot)) + quiterr("TIFF has unspecified photometric type"); + + switch (cvts.phot) { + case PHOTOMETRIC_LOGLUV: SET(C_RFLT|C_TFLT); if (!CHK(C_XYZE)) { cpcolormat(cvts.cmat, xyz2rgbmat); SET(C_CXFM|C_GAMUT); - } else if (cvts.comp == COMPRESSION_LOGLUV32) + } else if (cvts.comp == COMPRESSION_SGILOG) SET(C_GAMUT); if (cvts.pconf != PLANARCONFIG_CONTIG) quiterr("cannot handle separate Luv planes"); - TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT, - LOGLUVDATAFMT_FLTXYZ); - TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, - SAMPLEFORMAT_IEEEFP); + TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, + SGILOGDATAFMT_FLOAT); cvts.tf = Luv2Color; break; - default: - SET(C_GAMMA|C_GAMUT); + case PHOTOMETRIC_LOGL: + SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); + cvts.pconf = PLANARCONFIG_CONTIG; + TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, + SGILOGDATAFMT_FLOAT); + cvts.tf = L2Color; + break; + case PHOTOMETRIC_YCBCR: + if (cvts.comp == COMPRESSION_JPEG && + cvts.pconf == PLANARCONFIG_CONTIG) { + TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE, + JPEGCOLORMODE_RGB); + cvts.phot = PHOTOMETRIC_RGB; + } else + quiterr("unsupported photometric type"); + /* fall through */ + case PHOTOMETRIC_RGB: + SET(C_GAMMA); setcolrgam(cvts.gamcor); if (CHK(C_XYZE)) { - comprgb2xyzmat(cvts.cmat, + comprgb2xyzWBmat(cvts.cmat, CHK(C_PRIM) ? cvts.prims : stdprims); SET(C_CXFM); } if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || - (hi != 1 && hi != 3)) - quiterr("unsupported samples per pixel"); - if (hi == 1) { - SET(C_GRY); - cvts.pconf = PLANARCONFIG_CONTIG; - cvts.tf = Gry2Colr; - } else + hi != 3) + quiterr("unsupported samples per pixel for RGB"); + if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi)) + hi = -1; + switch (hi) { + case 8: cvts.tf = RGB2Colr; - if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) || - hi != 8) - quiterr("unsupported bits per sample"); + break; + case 16: + cvts.tf = RRGGBB2Color; + SET(C_RFLT|C_TWRD); + break; + case 32: + cvts.tf = RfGfBf2Color; + SET(C_RFLT|C_TFLT); + break; + default: + quiterr("unsupported bits per sample for RGB"); + } break; + case PHOTOMETRIC_MINISBLACK: + SET(C_GRY|C_GAMMA); + setcolrgam(cvts.gamcor); + cvts.pconf = PLANARCONFIG_CONTIG; + if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || + hi != 1) + quiterr("unsupported samples per pixel for greyscale"); + if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi)) + hi = -1; + switch (hi) { + case 8: + cvts.tf = Gry2Colr; + break; + case 16: + cvts.tf = GGry2Color; + SET(C_RFLT|C_TWRD); + break; + case 32: + cvts.tf = Gryf2Color; + SET(C_RFLT|C_TFLT); + break; + default: + quiterr("unsupported bits per sample for Gray"); + } + break; + default: + quiterr("unsupported photometric type"); + break; } - if (TIFFGetField(cvts.tif, TIFFTAG_PHOTOMETRIC, &hi) && - hi != (CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB)) - quiterr("unsupported photometric interpretation"); - if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) quiterr("unknown input image resolution"); if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) cvts.stonits = 1.; + + if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp)) + cvts.capdate[0] = '\0'; + else { + strncpy(cvts.capdate, cp, 19); + cvts.capdate[19] = '\0'; + } + if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp)) + cvts.owner[0] = '\0'; + else { + strncpy(cvts.owner, cp, sizeof(cvts.owner)); + cvts.owner[sizeof(cvts.owner)-1] = '\0'; + } /* add to Radiance header */ if (cvts.pixrat < .99 || cvts.pixrat > 1.01) fputaspect(cvts.pixrat, cvts.rfp); @@ -294,6 +370,10 @@ initfromtif() /* initialize conversion from TIFF inpu cvts.rfp); fputformat(COLRFMT, cvts.rfp); } + if (cvts.capdate[0]) + fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate); + if (cvts.owner[0]) + fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner); allocbufs(); /* allocate scanline buffers */ } @@ -333,8 +413,14 @@ int headline(s) /* process Radiance input header line */ char *s; { + static int tmstrlen = 0; + static int ownstrlen = 0; char fmt[32]; + if (!tmstrlen) + tmstrlen = strlen(TMSTR); + if (!ownstrlen) + ownstrlen = strlen(OWNSTR); if (formatval(fmt, s)) { if (!strcmp(fmt, COLRFMT)) CLR(C_XYZE); @@ -342,21 +428,43 @@ char *s; SET(C_XYZE); else quiterr("unrecognized input picture format"); - return; + return(1); } if (isexpos(s)) { cvts.stonits /= exposval(s); - return; + return(1); } if (isaspect(s)) { cvts.pixrat *= aspectval(s); - return; + return(1); } if (isprims(s)) { primsval(cvts.prims, s); SET(C_PRIM); - return; + return(1); } + if (isdate(s)) { + if (s[tmstrlen] == ' ') + strncpy(cvts.capdate, s+tmstrlen+1, 19); + else + strncpy(cvts.capdate, s+tmstrlen, 19); + cvts.capdate[19] = '\0'; + return(1); + } + if (!strncmp(s, OWNSTR, ownstrlen)) { + register char *cp = s + ownstrlen; + + while (isspace(*cp)) + ++cp; + strncpy(cvts.owner, cp, sizeof(cvts.owner)); + cvts.owner[sizeof(cvts.owner)-1] = '\0'; + for (cp = cvts.owner; *cp; cp++) + ; + while (cp > cvts.owner && isspace(cp[-1])) + *--cp = '\0'; + return(1); + } + return(0); } @@ -364,7 +472,9 @@ initfromrad() /* initialize input from a Radiance pi { int i1, i2, po; /* read Radiance header */ - CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); + CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM); + cvts.capdate[0] = '\0'; + cvts.owner[0] = '\0'; cvts.stonits = 1.; cvts.pixrat = 1.; cvts.pconf = PLANARCONFIG_CONTIG; @@ -385,57 +495,83 @@ initfromrad() /* initialize input from a Radiance pi cvts.stonits *= WHTEFFICACY; /* set up conversion */ TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); + TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot); - switch (cvts.comp) { - case COMPRESSION_LOGL16: - SET(C_GRY|C_RFLT|C_TFLT); - TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT, - LOGLUVDATAFMT_FLTY); - TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, - SAMPLEFORMAT_IEEEFP); - cvts.tf = Color2L; - break; - case COMPRESSION_LOGLUV24: - case COMPRESSION_LOGLUV32: + switch (cvts.phot) { + case PHOTOMETRIC_LOGLUV: SET(C_RFLT|C_TFLT); - CLR(C_GRY); + CLR(C_GRY|C_TWRD); if (!CHK(C_XYZE)) { - cpcolormat(cvts.cmat, rgb2xyzmat); + comprgb2xyzWBmat(cvts.cmat, + CHK(C_PRIM) ? cvts.prims : stdprims); SET(C_CXFM); } - TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT, - LOGLUVDATAFMT_FLTXYZ); - TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, - SAMPLEFORMAT_IEEEFP); + if (cvts.comp != COMPRESSION_SGILOG && + cvts.comp != COMPRESSION_SGILOG24) + quiterr("internal error 2 in initfromrad"); + TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, + SGILOGDATAFMT_FLOAT); cvts.tf = Color2Luv; break; - default: + case PHOTOMETRIC_LOGL: + SET(C_GRY|C_RFLT|C_TFLT); + CLR(C_TWRD); + if (cvts.comp != COMPRESSION_SGILOG) + quiterr("internal error 3 in initfromrad"); + TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, + SGILOGDATAFMT_FLOAT); + cvts.tf = Color2L; + break; + case PHOTOMETRIC_RGB: SET(C_GAMMA|C_GAMUT); + CLR(C_GRY); setcolrgam(cvts.gamcor); if (CHK(C_XYZE)) { - compxyz2rgbmat(cvts.cmat, + compxyz2rgbWBmat(cvts.cmat, CHK(C_PRIM) ? cvts.prims : stdprims); SET(C_CXFM); } - if (CHK(C_GRY)) - cvts.tf = Colr2Gry; - else - cvts.tf = Colr2RGB; if (CHK(C_PRIM)) { TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, (float *)cvts.prims); TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, (float *)cvts.prims[WHT]); } + if (CHK(C_TWRD)) { + cvts.tf = Color2RRGGBB; + SET(C_RFLT); + } else if (CHK(C_TFLT)) { + TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, + SAMPLEFORMAT_IEEEFP); + cvts.tf = Color2RfGfBf; + SET(C_RFLT); + } else + cvts.tf = Colr2RGB; break; + case PHOTOMETRIC_MINISBLACK: + SET(C_GRY|C_GAMMA|C_GAMUT); + setcolrgam(cvts.gamcor); + if (CHK(C_TWRD)) { + cvts.tf = Color2GGry; + SET(C_RFLT); + } else if (CHK(C_TFLT)) { + TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, + SAMPLEFORMAT_IEEEFP); + cvts.tf = Color2Gryf; + SET(C_RFLT); + } else + cvts.tf = Colr2Gry; + break; + default: + quiterr("internal error 4 in initfromrad"); + break; } /* set other TIFF fields */ TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); - TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8); - TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, - CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB); + TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, + CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8); TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); @@ -443,7 +579,14 @@ initfromrad() /* initialize input from a Radiance pi TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); TIFFSetField(cvts.tif, TIFFTAG_STONITS, cvts.stonits/pow(2.,(double)cvts.bradj)); - i1 = TIFFScanlineSize(cvts.tif); + if (cvts.capdate[0]) + TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate); + if (cvts.owner[0]) + TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner); + if (cvts.comp == COMPRESSION_NONE) + i1 = TIFFScanlineSize(cvts.tif); + else + i1 = 3*cvts.xmax; /* conservative guess */ i2 = 8192/i1; /* compute good strip size */ if (i2 < 1) i2 = 1; TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); @@ -476,22 +619,23 @@ char *av[]; } -int +void Luv2Color(y) /* read/convert/write Luv->COLOR scanline */ uint32 y; { register int x; - if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY)) + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) quiterr("internal error 1 in Luv2Color"); if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) quiterr("error reading TIFF input"); - + /* also works for float RGB */ for (x = cvts.xmax; x--; ) { - cvts.r.colors[x][RED] = cvts.t.fp[3*x]; - cvts.r.colors[x][GRN] = cvts.t.fp[3*x + 1]; - cvts.r.colors[x][BLU] = cvts.t.fp[3*x + 2]; + setcolor(cvts.r.colors[x], + cvts.t.fp[3*x], + cvts.t.fp[3*x + 1], + cvts.t.fp[3*x + 2]); if (CHK(C_CXFM)) colortrans(cvts.r.colors[x], cvts.cmat, cvts.r.colors[x]); @@ -510,36 +654,79 @@ uint32 y; } -int -L2Color(y) /* read/convert/write L16->COLOR scanline */ +void +RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */ uint32 y; { + int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; + register double d; register int x; - if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) - quiterr("internal error 1 in L2Color"); + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT)) + quiterr("internal error 1 in RRGGBB2Color"); if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) quiterr("error reading TIFF input"); - for (x = cvts.xmax; x--; ) - cvts.r.colors[x][RED] = - cvts.r.colors[x][GRN] = - cvts.r.colors[x][BLU] = cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.; + for (x = cvts.xmax; x--; ) { + d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16)); + if (dogamma) d = pow(d, cvts.gamcor); + colval(cvts.r.colors[x],RED) = d; + d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16)); + if (dogamma) d = pow(d, cvts.gamcor); + colval(cvts.r.colors[x],GRN) = d; + d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16)); + if (dogamma) d = pow(d, cvts.gamcor); + colval(cvts.r.colors[x],BLU) = d; + if (CHK(C_CXFM)) + colortrans(cvts.r.colors[x], cvts.cmat, + cvts.r.colors[x]); + if (CHK(C_GAMUT)) + clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], + CGAMUT_LOWER, cblack, cwhite); + } + if (cvts.bradj) { + d = pow(2.,(double)cvts.bradj); + for (x = cvts.xmax; x--; ) + scalecolor(cvts.r.colors[x], d); + } if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) quiterr("error writing Radiance picture"); } -int +void +L2Color(y) /* read/convert/write Lfloat->COLOR scanline */ +uint32 y; +{ + float m = pow(2., (double)cvts.bradj); + register int x; + + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) + quiterr("internal error 1 in L2Color"); + + if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) + quiterr("error reading TIFF input"); + /* also works for float greyscale */ + for (x = cvts.xmax; x--; ) { + register float f = cvts.t.fp[x]; + if (cvts.bradj) f *= m; + setcolor(cvts.r.colors[x], f, f, f); + } + if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) + quiterr("error writing Radiance picture"); +} + + +void RGB2Colr(y) /* read/convert/write RGB->COLR scanline */ uint32 y; { COLOR ctmp; register int x; - if (CHK(C_RFLT|C_TFLT|C_GRY)) + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY)) quiterr("internal error 1 in RGB2Colr"); if (cvts.pconf == PLANARCONFIG_CONTIG) { @@ -554,10 +741,10 @@ uint32 y; if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) goto readerr; if (TIFFReadScanline(cvts.tif, - (tidata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) + (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) goto readerr; if (TIFFReadScanline(cvts.tif, - (tidata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) + (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) goto readerr; for (x = cvts.xmax; x--; ) { cvts.r.colrs[x][RED] = cvts.t.bp[x]; @@ -588,13 +775,13 @@ readerr: } -int +void Gry2Colr(y) /* read/convert/write G8->COLR scanline */ uint32 y; { register int x; - if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY)) + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) quiterr("internal error 1 in Gry2Colr"); if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) @@ -614,14 +801,78 @@ uint32 y; } -int -Color2L(y) /* read/convert/write COLOR->L16 scanline */ +void +GGry2Color(y) /* read/convert/write G16->COLOR scanline */ uint32 y; { - double m = pow(2.,(double)cvts.bradj); + int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; + double m; + register double d; register int x; - if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | !CHK(C_GRY)) + if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD)) + quiterr("internal error 1 in GGry2Color"); + + if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) + quiterr("error reading TIFF input"); + + if (cvts.bradj) + m = pow(2., (double)cvts.bradj); + for (x = cvts.xmax; x--; ) { + d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16)); + if (dogamma) d = pow(d, cvts.gamcor); + if (cvts.bradj) d *= m; + colval(cvts.r.colors[x],RED) = + colval(cvts.r.colors[x],GRN) = + colval(cvts.r.colors[x],BLU) = d; + } + if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) + quiterr("error writing Radiance picture"); +} + + +void +Color2GGry(y) /* read/convert/write COLOR->G16 scanline */ +uint32 y; +{ + int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; + float m = pow(2.,(double)cvts.bradj); + register int x; + + if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY)) + quiterr("internal error 1 in Color2GGry"); + + if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) + quiterr("error reading Radiance picture"); + + for (x = cvts.xmax; x--; ) { + register float f = m*( CHK(C_XYZE) ? + colval(cvts.r.colors[x],CIEY) + : bright(cvts.r.colors[x]) ); + if (f <= 0) + cvts.t.wp[x] = 0; + else if (f >= 1) + cvts.t.wp[x] = 0xffff; + else if (dogamma) + cvts.t.wp[x] = (int)((float)(1L<<16) * + pow(f, 1./cvts.gamcor)); + else + cvts.t.wp[x] = (int)((float)(1L<<16) * f); + } + + if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) + quiterr("error writing TIFF output"); +} + + +void +Color2L(y) /* read/convert/write COLOR->Lfloat scanline */ +uint32 y; +{ + float m = pow(2.,(double)cvts.bradj); + register int x; + + if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) quiterr("internal error 1 in Color2L"); if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) @@ -636,13 +887,13 @@ uint32 y; } -int +void Color2Luv(y) /* read/convert/write COLOR->Luv scanline */ uint32 y; { register int x; - if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY)) + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) quiterr("internal error 1 in Color2Luv"); if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) @@ -657,11 +908,11 @@ uint32 y; for (x = cvts.xmax; x--; ) scalecolor(cvts.r.colors[x], m); } - + /* also works for float RGB */ for (x = cvts.xmax; x--; ) { - cvts.t.fp[3*x] = colval(cvts.r.colors[x],RED); - cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],GRN); - cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],BLU); + cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX); + cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY); + cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ); } if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) @@ -669,13 +920,46 @@ uint32 y; } -int +void +Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */ +uint32 y; +{ + int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01; + float m = pow(2.,(double)cvts.bradj); + register int x, i; + + if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD)) + quiterr("internal error 1 in Color2RRGGBB"); + + if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) + quiterr("error reading Radiance picture"); + + for (x = cvts.xmax; x--; ) + for (i = 3; i--; ) { + register float f = m*colval(cvts.r.colors[x],i); + if (f <= 0) + cvts.t.wp[3*x + i] = 0; + else if (f >= 1) + cvts.t.wp[3*x + i] = 0xffff; + else if (dogamma) + cvts.t.wp[3*x + i] = (int)((float)(1L<<16) * + pow(f, 1./cvts.gamcor)); + else + cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f); + } + + if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) + quiterr("error writing TIFF output"); +} + + +void Colr2Gry(y) /* read/convert/write COLR->RGB scanline */ uint32 y; { register int x; - if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY)) + if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) quiterr("internal error 1 in Colr2Gry"); if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) @@ -695,14 +979,14 @@ uint32 y; } -int +void Colr2RGB(y) /* read/convert/write COLR->RGB scanline */ uint32 y; { COLOR ctmp; register int x; - if (CHK(C_RFLT|C_TFLT|C_GRY)) + if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY)) quiterr("internal error 1 in Colr2RGB"); if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
