Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Minor compile fixes
Added handling of TIFFTAG_DATETIME and TIFFTAG_ARTIST
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug in allocated buffer size
added ability to read 16-bit/channel TIFFs
cosmetic changes to use correct macros for color assignments
added missing call to setgamcor()
minor fix
minor optimization
consolidated SGILOGDATAFMT values
changed StoNits to double and added JPEG reading capability
modified TIFF library with new photometric types
added a ton of new stuff for Luv format images and new tags
added -g option to header output
replaced some values with macros for improved readability
minor compiler warning fixes
renamed gamma to avoid math library conflict
added math.h for atof() usage
added -b option for greyscale images
added -z option for LZW compression
added back gamma control (though not properly registered)
took out use of image description (sniff!)
