root/radiance/ray/src/px/ra_tiff.c
Revision: 2.9
Committed: Thu Jul 24 11:47:05 1997 UTC (27 years, 9 months ago) by gregl
Changes since 2.8: +640 -172 lines
added a ton of new stuff for Luv format images and new tags
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Program to convert between RADIANCE and TIFF files.
9 * Added experimental LogLuv encodings 7/97 (GWL).
10 */
11
12 #include <stdio.h>
13 #include <math.h>
14 #include "tiffio.h"
15 #include "color.h"
16 #include "resolu.h"
17
18 #define GAMCOR 2.2 /* default gamma */
19
20 #ifndef malloc
21 extern char *malloc();
22 #endif
23 /* conversion flags */
24 #define C_CXFM 0x1 /* needs color transformation */
25 #define C_GAMUT 0x2 /* needs gamut mapping */
26 #define C_GAMMA 0x4 /* needs gamma correction */
27 #define C_GRY 0x8 /* TIFF is greyscale */
28 #define C_XYZE 0x10 /* Radiance is XYZE */
29 #define C_RFLT 0x20 /* Radiance data is float */
30 #define C_TFLT 0x40 /* TIFF data is float */
31 #define C_PRIM 0x80 /* has assigned primaries */
32
33 struct {
34 uint16 flags; /* conversion flags (defined above) */
35 uint16 comp; /* TIFF compression type */
36 uint16 pconf; /* TIFF planar configuration */
37 float gamcor; /* gamma correction value */
38 short bradj; /* Radiance exposure adjustment (stops) */
39 uint16 orient; /* visual orientation (TIFF spec.) */
40 float stonits; /* input conversion to nits */
41 float pixrat; /* pixel aspect ratio */
42 FILE *rfp; /* Radiance stream pointer */
43 TIFF *tif; /* TIFF pointer */
44 uint32 xmax, ymax; /* image dimensions */
45 COLORMAT cmat; /* color transformation matrix */
46 RGBPRIMS prims; /* RGB primaries */
47 union {
48 COLR *colrs; /* 4-byte ???E pointer */
49 COLOR *colors; /* float array pointer */
50 char *p; /* generic pointer */
51 } r; /* Radiance scanline */
52 union {
53 uint8 *bp; /* byte pointer */
54 float *fp; /* float pointer */
55 char *p; /* generic pointer */
56 } t; /* TIFF scanline */
57 int (*tf)(); /* translation procedure */
58 } cvts = { /* conversion structure */
59 0, COMPRESSION_NONE, PLANARCONFIG_CONTIG, GAMCOR, 0,
60 };
61
62 #define CHK(f) (cvts.flags & (f))
63 #define SET(f) (cvts.flags |= (f))
64 #define CLR(f) (cvts.flags &= ~(f))
65 #define TGL(f) (cvts.flags ^= (f))
66
67 int Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
68 int Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
69
70 short ortab[8] = { /* orientation conversion table */
71 YMAJOR|YDECR,
72 YMAJOR|YDECR|XDECR,
73 YMAJOR|XDECR,
74 YMAJOR,
75 YDECR,
76 XDECR|YDECR,
77 XDECR,
78 0
79 };
80
81 #define pixorder() ortab[cvts.orient-1]
82
83 char *progname;
84
85
86 main(argc, argv)
87 int argc;
88 char *argv[];
89 {
90 int reverse = 0;
91 int i;
92
93 progname = argv[0];
94
95 for (i = 1; i < argc; i++)
96 if (argv[i][0] == '-')
97 switch (argv[i][1]) {
98 case 'g': /* gamma correction */
99 cvts.gamcor = atof(argv[++i]);
100 break;
101 case 'x': /* XYZE Radiance output */
102 TGL(C_XYZE);
103 break;
104 case 'z': /* LZW compressed output */
105 cvts.comp = COMPRESSION_LZW;
106 break;
107 case 'L': /* LogLuv 32-bit output */
108 cvts.comp = COMPRESSION_LOGLUV32;
109 break;
110 case 'l': /* LogLuv 24-bit output */
111 cvts.comp = COMPRESSION_LOGLUV24;
112 break;
113 case 'b': /* greyscale output? */
114 TGL(C_GRY);
115 break;
116 case 'e': /* exposure adjustment */
117 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
118 goto userr;
119 cvts.bradj = atoi(argv[++i]);
120 break;
121 case 'r': /* reverse conversion? */
122 reverse = !reverse;
123 break;
124 case '\0':
125 goto doneopts;
126 default:
127 goto userr;
128 }
129 else
130 break;
131 doneopts:
132 if (reverse) {
133
134 if (i != argc-2 && i != argc-1)
135 goto userr;
136
137 tiff2ra(i, argv);
138
139 } else {
140
141 if (i != argc-2)
142 goto userr;
143
144 if (CHK(C_GRY) && (cvts.comp == COMPRESSION_LOGLUV24 ||
145 cvts.comp == COMPRESSION_LOGLUV32))
146 cvts.comp = COMPRESSION_LOGL16;
147
148 ra2tiff(i, argv);
149 }
150
151 exit(0);
152 userr:
153 fprintf(stderr,
154 "Usage: %s [-z|-L|-l][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
155 progname);
156 fprintf(stderr,
157 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
158 progname);
159 exit(1);
160 }
161
162
163 quiterr(err) /* print message and exit */
164 char *err;
165 {
166 if (err != NULL) {
167 fprintf(stderr, "%s: %s\n", progname, err);
168 exit(1);
169 }
170 exit(0);
171 }
172
173
174 allocbufs() /* allocate scanline buffers */
175 {
176 int rsiz, tsiz;
177
178 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
179 tsiz = (CHK(C_TFLT) ? sizeof(float) : sizeof(uint8)) *
180 (CHK(C_GRY) ? 1 : 3);
181 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
182 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
183 if (cvts.r.p == NULL | cvts.t.p == NULL)
184 quiterr("no memory to allocate scanline buffers");
185 }
186
187
188 initfromtif() /* initialize conversion from TIFF input */
189 {
190 uint16 hi;
191 float *fa, f1, f2;
192
193 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_CXFM);
194
195 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
196
197 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
198 cvts.prims[RED][CIEX] = fa[0];
199 cvts.prims[RED][CIEY] = fa[1];
200 cvts.prims[GRN][CIEX] = fa[2];
201 cvts.prims[GRN][CIEY] = fa[3];
202 cvts.prims[BLU][CIEX] = fa[4];
203 cvts.prims[BLU][CIEY] = fa[5];
204 cvts.prims[WHT][CIEX] = 1./3.;
205 cvts.prims[WHT][CIEY] = 1./3.;
206 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
207 cvts.prims[WHT][CIEX] = fa[0];
208 cvts.prims[WHT][CIEY] = fa[1];
209 }
210 SET(C_PRIM);
211 }
212
213 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
214 cvts.comp = COMPRESSION_NONE;
215
216 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
217 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
218 cvts.pixrat = f1/f2;
219 else
220 cvts.pixrat = 1.;
221
222 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient))
223 cvts.orient = 1;
224
225 switch (cvts.comp) {
226 case COMPRESSION_LOGL16:
227 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
228 cvts.pconf = PLANARCONFIG_CONTIG;
229 TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT,
230 LOGLUVDATAFMT_FLTY);
231 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
232 SAMPLEFORMAT_IEEEFP);
233 cvts.tf = L2Color;
234 break;
235 case COMPRESSION_LOGLUV24:
236 case COMPRESSION_LOGLUV32:
237 SET(C_RFLT|C_TFLT);
238 if (!CHK(C_XYZE)) {
239 cpcolormat(cvts.cmat, xyz2rgbmat);
240 SET(C_CXFM|C_GAMUT);
241 } else if (cvts.comp == COMPRESSION_LOGLUV32)
242 SET(C_GAMUT);
243 if (cvts.pconf != PLANARCONFIG_CONTIG)
244 quiterr("cannot handle separate Luv planes");
245 TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT,
246 LOGLUVDATAFMT_FLTXYZ);
247 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
248 SAMPLEFORMAT_IEEEFP);
249 cvts.tf = Luv2Color;
250 break;
251 default:
252 SET(C_GAMMA|C_GAMUT);
253 setcolrgam(cvts.gamcor);
254 if (CHK(C_XYZE)) {
255 comprgb2xyzmat(cvts.cmat,
256 CHK(C_PRIM) ? cvts.prims : stdprims);
257 SET(C_CXFM);
258 }
259 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
260 (hi != 1 && hi != 3))
261 quiterr("unsupported samples per pixel");
262 if (hi == 1) {
263 SET(C_GRY);
264 cvts.pconf = PLANARCONFIG_CONTIG;
265 cvts.tf = Gry2Colr;
266 } else
267 cvts.tf = RGB2Colr;
268 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi) ||
269 hi != 8)
270 quiterr("unsupported bits per sample");
271 break;
272 }
273
274 if (TIFFGetField(cvts.tif, TIFFTAG_PHOTOMETRIC, &hi) &&
275 hi != (CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB))
276 quiterr("unsupported photometric interpretation");
277
278 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
279 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
280 quiterr("unknown input image resolution");
281
282 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
283 cvts.stonits = 1.;
284 /* add to Radiance header */
285 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
286 fputaspect(cvts.pixrat, cvts.rfp);
287 if (CHK(C_XYZE)) {
288 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
289 fputformat(CIEFMT, cvts.rfp);
290 } else {
291 if (CHK(C_PRIM))
292 fputprims(cvts.prims, cvts.rfp);
293 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
294 cvts.rfp);
295 fputformat(COLRFMT, cvts.rfp);
296 }
297
298 allocbufs(); /* allocate scanline buffers */
299 }
300
301
302 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
303 int ac;
304 char *av[];
305 {
306 int32 y;
307 /* open TIFF input */
308 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
309 quiterr("cannot open TIFF input");
310 /* open Radiance output */
311 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
312 cvts.rfp = stdout;
313 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
314 quiterr("cannot open Radiance output picture");
315 /* start output header */
316 newheader("RADIANCE", cvts.rfp);
317 printargs(ac, av, cvts.rfp);
318
319 initfromtif(); /* initialize conversion */
320
321 fputc('\n', cvts.rfp); /* finish Radiance header */
322 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
323
324 for (y = 0; y < cvts.ymax; y++) /* convert image */
325 (*cvts.tf)(y);
326 /* clean up */
327 fclose(cvts.rfp);
328 TIFFClose(cvts.tif);
329 }
330
331
332 int
333 headline(s) /* process Radiance input header line */
334 char *s;
335 {
336 char fmt[32];
337
338 if (formatval(fmt, s)) {
339 if (!strcmp(fmt, COLRFMT))
340 CLR(C_XYZE);
341 else if (!strcmp(fmt, CIEFMT))
342 SET(C_XYZE);
343 else
344 quiterr("unrecognized input picture format");
345 return;
346 }
347 if (isexpos(s)) {
348 cvts.stonits /= exposval(s);
349 return;
350 }
351 if (isaspect(s)) {
352 cvts.pixrat *= aspectval(s);
353 return;
354 }
355 if (isprims(s)) {
356 primsval(cvts.prims, s);
357 SET(C_PRIM);
358 return;
359 }
360 }
361
362
363 initfromrad() /* initialize input from a Radiance picture */
364 {
365 int i1, i2, po;
366 /* read Radiance header */
367 CLR(C_RFLT|C_TFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
368 cvts.stonits = 1.;
369 cvts.pixrat = 1.;
370 cvts.pconf = PLANARCONFIG_CONTIG;
371 getheader(cvts.rfp, headline, NULL);
372 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
373 quiterr("bad Radiance picture");
374 cvts.xmax = i1; cvts.ymax = i2;
375 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
376 if (ortab[i1] == po) {
377 cvts.orient = i1 + 1;
378 break;
379 }
380 if (i1 >= 8)
381 quiterr("internal error 1 in initfromrad");
382 if (!(po & YMAJOR))
383 cvts.pixrat = 1./cvts.pixrat;
384 if (!CHK(C_XYZE))
385 cvts.stonits *= WHTEFFICACY;
386 /* set up conversion */
387 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
388
389 switch (cvts.comp) {
390 case COMPRESSION_LOGL16:
391 SET(C_GRY|C_RFLT|C_TFLT);
392 TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT,
393 LOGLUVDATAFMT_FLTY);
394 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
395 SAMPLEFORMAT_IEEEFP);
396 cvts.tf = Color2L;
397 break;
398 case COMPRESSION_LOGLUV24:
399 case COMPRESSION_LOGLUV32:
400 SET(C_RFLT|C_TFLT);
401 CLR(C_GRY);
402 if (!CHK(C_XYZE)) {
403 cpcolormat(cvts.cmat, rgb2xyzmat);
404 SET(C_CXFM);
405 }
406 TIFFSetField(cvts.tif, TIFFTAG_LOGLUVDATAFMT,
407 LOGLUVDATAFMT_FLTXYZ);
408 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
409 SAMPLEFORMAT_IEEEFP);
410 cvts.tf = Color2Luv;
411 break;
412 default:
413 SET(C_GAMMA|C_GAMUT);
414 setcolrgam(cvts.gamcor);
415 if (CHK(C_XYZE)) {
416 compxyz2rgbmat(cvts.cmat,
417 CHK(C_PRIM) ? cvts.prims : stdprims);
418 SET(C_CXFM);
419 }
420 if (CHK(C_GRY))
421 cvts.tf = Colr2Gry;
422 else
423 cvts.tf = Colr2RGB;
424 if (CHK(C_PRIM)) {
425 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
426 (float *)cvts.prims);
427 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
428 (float *)cvts.prims[WHT]);
429 }
430 break;
431 }
432 /* set other TIFF fields */
433 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
434 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
435 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
436 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, CHK(C_TFLT) ? 32 : 8);
437 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC,
438 CHK(C_GRY) ? PHOTOMETRIC_MINISBLACK : PHOTOMETRIC_RGB);
439 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
440 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
441 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
442 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
443 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
444 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
445 cvts.stonits/pow(2.,(double)cvts.bradj));
446 i1 = TIFFScanlineSize(cvts.tif);
447 i2 = 8192/i1; /* compute good strip size */
448 if (i2 < 1) i2 = 1;
449 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
450
451 allocbufs(); /* allocate scanline buffers */
452 }
453
454
455 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
456 int ac;
457 char *av[];
458 {
459 uint32 y;
460 /* open Radiance file */
461 if (!strcmp(av[ac], "-"))
462 cvts.rfp = stdin;
463 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
464 quiterr("cannot open Radiance input picture");
465 /* open TIFF file */
466 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
467 quiterr("cannot open TIFF output");
468
469 initfromrad(); /* initialize conversion */
470
471 for (y = 0; y < cvts.ymax; y++) /* convert image */
472 (*cvts.tf)(y);
473 /* clean up */
474 TIFFClose(cvts.tif);
475 fclose(cvts.rfp);
476 }
477
478
479 int
480 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
481 uint32 y;
482 {
483 register int x;
484
485 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
486 quiterr("internal error 1 in Luv2Color");
487
488 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
489 quiterr("error reading TIFF input");
490
491 for (x = cvts.xmax; x--; ) {
492 cvts.r.colors[x][RED] = cvts.t.fp[3*x];
493 cvts.r.colors[x][GRN] = cvts.t.fp[3*x + 1];
494 cvts.r.colors[x][BLU] = cvts.t.fp[3*x + 2];
495 if (CHK(C_CXFM))
496 colortrans(cvts.r.colors[x], cvts.cmat,
497 cvts.r.colors[x]);
498 if (CHK(C_GAMUT))
499 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
500 CGAMUT_LOWER, cblack, cwhite);
501 }
502 if (cvts.bradj) {
503 double m = pow(2.,(double)cvts.bradj);
504 for (x = cvts.xmax; x--; )
505 scalecolor(cvts.r.colors[x], m);
506 }
507
508 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
509 quiterr("error writing Radiance picture");
510 }
511
512
513 int
514 L2Color(y) /* read/convert/write L16->COLOR scanline */
515 uint32 y;
516 {
517 register int x;
518
519 if (CHK(C_RFLT|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
520 quiterr("internal error 1 in L2Color");
521
522 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
523 quiterr("error reading TIFF input");
524
525 for (x = cvts.xmax; x--; )
526 cvts.r.colors[x][RED] =
527 cvts.r.colors[x][GRN] =
528 cvts.r.colors[x][BLU] = cvts.t.fp[x] > 0. ? cvts.t.fp[x] : 0.;
529
530 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
531 quiterr("error writing Radiance picture");
532 }
533
534
535 int
536 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
537 uint32 y;
538 {
539 COLOR ctmp;
540 register int x;
541
542 if (CHK(C_RFLT|C_TFLT|C_GRY))
543 quiterr("internal error 1 in RGB2Colr");
544
545 if (cvts.pconf == PLANARCONFIG_CONTIG) {
546 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
547 goto readerr;
548 for (x = cvts.xmax; x--; ) {
549 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
550 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
551 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
552 }
553 } else {
554 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
555 goto readerr;
556 if (TIFFReadScanline(cvts.tif,
557 (tidata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
558 goto readerr;
559 if (TIFFReadScanline(cvts.tif,
560 (tidata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
561 goto readerr;
562 for (x = cvts.xmax; x--; ) {
563 cvts.r.colrs[x][RED] = cvts.t.bp[x];
564 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
565 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
566 }
567 }
568
569 gambs_colrs(cvts.r.colrs, cvts.xmax);
570 if (CHK(C_CXFM))
571 for (x = cvts.xmax; x--; ) {
572 colr_color(ctmp, cvts.r.colrs[x]);
573 colortrans(ctmp, cvts.cmat, ctmp);
574 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
575 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
576 cblack, cwhite);
577 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
578 colval(ctmp,GRN), colval(ctmp,BLU));
579 }
580 if (cvts.bradj)
581 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
582
583 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
584 quiterr("error writing Radiance picture");
585 return;
586 readerr:
587 quiterr("error reading TIFF input");
588 }
589
590
591 int
592 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
593 uint32 y;
594 {
595 register int x;
596
597 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
598 quiterr("internal error 1 in Gry2Colr");
599
600 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
601 quiterr("error reading TIFF input");
602
603 for (x = cvts.xmax; x--; )
604 cvts.r.colrs[x][RED] =
605 cvts.r.colrs[x][GRN] =
606 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
607
608 gambs_colrs(cvts.r.colrs, cvts.xmax);
609 if (cvts.bradj)
610 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
611
612 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
613 quiterr("error writing Radiance picture");
614 }
615
616
617 int
618 Color2L(y) /* read/convert/write COLOR->L16 scanline */
619 uint32 y;
620 {
621 double m = pow(2.,(double)cvts.bradj);
622 register int x;
623
624 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | !CHK(C_GRY))
625 quiterr("internal error 1 in Color2L");
626
627 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
628 quiterr("error reading Radiance picture");
629
630 for (x = cvts.xmax; x--; )
631 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
632 : bright(cvts.r.colors[x]) );
633
634 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
635 quiterr("error writing TIFF output");
636 }
637
638
639 int
640 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
641 uint32 y;
642 {
643 register int x;
644
645 if (CHK(C_RFLT|C_TFLT) != (C_RFLT|C_TFLT) | CHK(C_GRY))
646 quiterr("internal error 1 in Color2Luv");
647
648 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
649 quiterr("error reading Radiance picture");
650
651 if (CHK(C_CXFM))
652 for (x = cvts.xmax; x--; )
653 colortrans(cvts.r.colors[x], cvts.cmat,
654 cvts.r.colors[x]);
655 if (cvts.bradj) {
656 double m = pow(2.,(double)cvts.bradj);
657 for (x = cvts.xmax; x--; )
658 scalecolor(cvts.r.colors[x], m);
659 }
660
661 for (x = cvts.xmax; x--; ) {
662 cvts.t.fp[3*x] = colval(cvts.r.colors[x],RED);
663 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],GRN);
664 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],BLU);
665 }
666
667 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
668 quiterr("error writing TIFF output");
669 }
670
671
672 int
673 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
674 uint32 y;
675 {
676 register int x;
677
678 if (CHK(C_RFLT|C_TFLT) | !CHK(C_GRY))
679 quiterr("internal error 1 in Colr2Gry");
680
681 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
682 quiterr("error reading Radiance picture");
683
684 if (cvts.bradj)
685 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
686 for (x = cvts.xmax; x--; )
687 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
688 colrs_gambs(cvts.r.colrs, cvts.xmax);
689
690 for (x = cvts.xmax; x--; )
691 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
692
693 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
694 quiterr("error writing TIFF output");
695 }
696
697
698 int
699 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
700 uint32 y;
701 {
702 COLOR ctmp;
703 register int x;
704
705 if (CHK(C_RFLT|C_TFLT|C_GRY))
706 quiterr("internal error 1 in Colr2RGB");
707
708 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
709 quiterr("error reading Radiance picture");
710
711 if (cvts.bradj)
712 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
713 if (CHK(C_CXFM))
714 for (x = cvts.xmax; x--; ) {
715 colr_color(ctmp, cvts.r.colrs[x]);
716 colortrans(ctmp, cvts.cmat, ctmp);
717 if (CHK(C_GAMUT))
718 clipgamut(ctmp, bright(ctmp), CGAMUT,
719 cblack, cwhite);
720 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
721 colval(ctmp,GRN), colval(ctmp,BLU));
722 }
723 colrs_gambs(cvts.r.colrs, cvts.xmax);
724
725 for (x = cvts.xmax; x--; ) {
726 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
727 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
728 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
729 }
730
731 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
732 quiterr("error writing TIFF output");
733 }
