1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ra_tiff.c,v 2.40 2025/06/07 05:09:46 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Program to convert between RADIANCE and TIFF files. |
6 |
* Added LogLuv encodings 7/97 (GWL). |
7 |
* Added white-balance adjustment 10/01 (GW). |
8 |
9 |
10 |
#include <math.h> |
11 |
#include <ctype.h> |
12 |
#include "rtio.h" |
13 |
#include "platform.h" |
14 |
#include "tiffio.h" |
15 |
#include "color.h" |
16 |
#include "resolu.h" |
17 |
18 |
#define GAMCOR 2.2 /* default gamma */ |
19 |
20 |
/* conversion flags */ |
21 |
#define C_CXFM 0x1 /* needs color transformation */ |
22 |
#define C_GAMUT 0x2 /* needs gamut mapping */ |
23 |
#define C_GAMMA 0x4 /* needs gamma correction */ |
24 |
#define C_GRY 0x8 /* TIFF is greyscale */ |
25 |
#define C_XYZE 0x10 /* Radiance is XYZE */ |
26 |
#define C_SPEC 0x20 /* Radiance is spectral */ |
27 |
#define C_RFLT 0x40 /* Radiance data is float */ |
28 |
#define C_TFLT 0x80 /* TIFF data is float */ |
29 |
#define C_TWRD 0x100 /* TIFF data is 16-bit */ |
30 |
#define C_PRIM 0x200 /* has assigned primaries */ |
31 |
32 |
typedef void colcvf_t(uint32 y); |
33 |
34 |
struct CONVST { |
35 |
uint16 flags; /* conversion flags (defined above) */ |
36 |
char capdate[20]; /* capture date/time */ |
37 |
char owner[256]; /* content owner */ |
38 |
uint16 comp; /* TIFF compression type */ |
39 |
uint16 phot; /* TIFF photometric type */ |
40 |
uint16 pconf; /* TIFF planar configuration */ |
41 |
float gamcor; /* gamma correction value */ |
42 |
short bradj; /* Radiance exposure adjustment (stops) */ |
43 |
uint16 orient; /* visual orientation (TIFF spec.) */ |
44 |
double stonits; /* input conversion to nits */ |
45 |
float pixrat; /* pixel aspect ratio */ |
46 |
int ncc; /* # color components for spectral */ |
47 |
float wpt[4]; /* wavelength partitions */ |
48 |
FILE *rfp; /* Radiance stream pointer */ |
49 |
TIFF *tif; /* TIFF pointer */ |
50 |
uint32 xmax, ymax; /* image dimensions */ |
51 |
COLORMAT cmat; /* color transformation matrix */ |
52 |
RGBPRIMS prims; /* RGB primaries */ |
53 |
union { |
54 |
COLR *colrs; /* 4-byte ???E pointer */ |
55 |
COLOR *colors; /* float array pointer */ |
56 |
void *p; /* generic pointer */ |
57 |
} r; /* Radiance scanline */ |
58 |
union { |
59 |
uint8 *bp; /* byte pointer */ |
60 |
uint16 *wp; /* word pointer */ |
61 |
float *fp; /* float pointer */ |
62 |
63 |
} t; /* TIFF scanline */ |
64 |
colcvf_t *tf; /* translation procedure */ |
65 |
} cvts = { /* conversion structure */ |
66 |
0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB, |
67 |
PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., 3, |
68 |
69 |
70 |
#define CHK(f) (cvts.flags & (f)) |
71 |
#define SET(f) (cvts.flags |= (f)) |
72 |
#define CLR(f) (cvts.flags &= ~(f)) |
73 |
#define TGL(f) (cvts.flags ^= (f)) |
74 |
75 |
static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr; |
76 |
static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry; |
77 |
static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry; |
78 |
79 |
static gethfunc headline; |
80 |
static void quiterr(char *err); |
81 |
static void allocbufs(void); |
82 |
static void initfromtif(void); |
83 |
static void tiff2ra(int ac, char *av[]); |
84 |
static void initfromrad(void); |
85 |
static void ra2tiff(int ac, char *av[]); |
86 |
static void ReadRadScan(struct CONVST *cvp); |
87 |
88 |
89 |
#define RfGfBf2Color Luv2Color |
90 |
#define Gryf2Color L2Color |
91 |
#define Color2Gryf Color2L |
92 |
#define Color2RfGfBf Color2Luv |
93 |
94 |
short ortab[8] = { /* orientation conversion table */ |
95 |
YMAJOR|YDECR, |
96 |
YMAJOR|YDECR|XDECR, |
97 |
YMAJOR|XDECR, |
98 |
YMAJOR, |
99 |
YDECR, |
100 |
XDECR|YDECR, |
101 |
XDECR, |
102 |
0 |
103 |
104 |
105 |
#define pixorder() ortab[cvts.orient-1] |
106 |
107 |
extern char TMSTR[]; /* "CAPDATE=" from header.c */ |
108 |
char OWNSTR[] = "OWNER="; |
109 |
110 |
111 |
int |
112 |
main(int argc, char *argv[]) |
113 |
114 |
int reverse = 0; |
115 |
int i; |
116 |
/* set global progname */ |
117 |
fixargv0(argv[0]); |
118 |
119 |
for (i = 1; i < argc; i++) |
120 |
if (argv[i][0] == '-') |
121 |
switch (argv[i][1]) { |
122 |
case 'g': /* gamma correction */ |
123 |
cvts.gamcor = atof(argv[++i]); |
124 |
break; |
125 |
case 'x': /* XYZE Radiance output */ |
126 |
TGL(C_XYZE); |
127 |
break; |
128 |
case 'z': /* LZW compressed output */ |
129 |
cvts.comp = COMPRESSION_LZW; |
130 |
break; |
131 |
case 'L': /* LogLuv 32-bit output */ |
132 |
cvts.comp = COMPRESSION_SGILOG; |
133 |
cvts.phot = PHOTOMETRIC_LOGLUV; |
134 |
break; |
135 |
case 'l': /* LogLuv 24-bit output */ |
136 |
cvts.comp = COMPRESSION_SGILOG24; |
137 |
138 |
break; |
139 |
case 'w': /* 16-bit/primary output? */ |
140 |
TGL(C_TWRD); |
141 |
break; |
142 |
case 'f': /* IEEE float output? */ |
143 |
TGL(C_TFLT); |
144 |
break; |
145 |
case 'b': /* greyscale output? */ |
146 |
TGL(C_GRY); |
147 |
break; |
148 |
case 'e': /* exposure adjustment */ |
149 |
if (argv[i+1][0] != '+' && argv[i+1][0] != '-') |
150 |
goto userr; |
151 |
cvts.bradj = atoi(argv[++i]); |
152 |
break; |
153 |
case 'r': /* reverse conversion? */ |
154 |
reverse = !reverse; |
155 |
break; |
156 |
case '\0': |
157 |
goto doneopts; |
158 |
default: |
159 |
goto userr; |
160 |
161 |
else |
162 |
break; |
163 |
doneopts: |
164 |
if (reverse) { |
165 |
166 |
if (i != argc-2 && i != argc-1) |
167 |
goto userr; |
168 |
169 |
tiff2ra(i, argv); |
170 |
171 |
} else { |
172 |
173 |
if (i != argc-2) |
174 |
goto userr; |
175 |
/* consistency checks */ |
176 |
if (CHK(C_GRY)) { |
177 |
if (cvts.phot == PHOTOMETRIC_RGB) |
178 |
cvts.phot = PHOTOMETRIC_MINISBLACK; |
179 |
else { |
180 |
cvts.phot = PHOTOMETRIC_LOGL; |
181 |
182 |
183 |
184 |
if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT)) |
185 |
goto userr; |
186 |
187 |
ra2tiff(i, argv); |
188 |
189 |
190 |
exit(0); |
191 |
userr: |
192 |
fprintf(stderr, |
193 |
"Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n", |
194 |
progname); |
195 |
fprintf(stderr, |
196 |
" Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n", |
197 |
progname); |
198 |
exit(1); |
199 |
200 |
201 |
202 |
static void |
203 |
quiterr( /* print message and exit */ |
204 |
char *err |
205 |
206 |
207 |
if (err != NULL) { |
208 |
fprintf(stderr, "%s: %s\n", progname, err); |
209 |
exit(1); |
210 |
211 |
exit(0); |
212 |
213 |
214 |
215 |
static void |
216 |
allocbufs(void) /* allocate scanline buffers */ |
217 |
218 |
int rsiz, tsiz; |
219 |
220 |
rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR); |
221 |
tsiz = (CHK(C_TFLT) ? sizeof(float) : |
222 |
CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) * |
223 |
(CHK(C_GRY) ? 1 : 3); |
224 |
cvts.r.p = malloc(rsiz*cvts.xmax); |
225 |
cvts.t.p = malloc(tsiz*cvts.xmax); |
226 |
if ((cvts.r.p == NULL) | (cvts.t.p == NULL)) |
227 |
quiterr("no memory to allocate scanline buffers"); |
228 |
229 |
230 |
231 |
static void |
232 |
initfromtif(void) /* initialize conversion from TIFF input */ |
233 |
234 |
uint16 hi; |
235 |
char *cp; |
236 |
float *fa, f1, f2; |
237 |
238 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf); |
239 |
240 |
if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
241 |
cvts.prims[RED][CIEX] = fa[0]; |
242 |
cvts.prims[RED][CIEY] = fa[1]; |
243 |
cvts.prims[GRN][CIEX] = fa[2]; |
244 |
cvts.prims[GRN][CIEY] = fa[3]; |
245 |
cvts.prims[BLU][CIEX] = fa[4]; |
246 |
cvts.prims[BLU][CIEY] = fa[5]; |
247 |
cvts.prims[WHT][CIEX] = 1./3.; |
248 |
cvts.prims[WHT][CIEY] = 1./3.; |
249 |
if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) { |
250 |
cvts.prims[WHT][CIEX] = fa[0]; |
251 |
cvts.prims[WHT][CIEY] = fa[1]; |
252 |
253 |
SET(C_PRIM); |
254 |
255 |
256 |
if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp)) |
257 |
cvts.comp = COMPRESSION_NONE; |
258 |
259 |
if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) && |
260 |
TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2)) |
261 |
cvts.pixrat = f1/f2; |
262 |
263 |
TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient); |
264 |
265 |
if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot)) |
266 |
quiterr("TIFF has unspecified photometric type"); |
267 |
268 |
switch (cvts.phot) { |
269 |
case PHOTOMETRIC_LOGLUV: |
270 |
SET(C_RFLT|C_TFLT); |
271 |
if (!CHK(C_XYZE)) { |
272 |
cpcolormat(cvts.cmat, xyz2rgbmat); |
273 |
SET(C_CXFM|C_GAMUT); |
274 |
} else if (cvts.comp == COMPRESSION_SGILOG) |
275 |
SET(C_GAMUT); /* may be outside XYZ gamut */ |
276 |
if (cvts.pconf != PLANARCONFIG_CONTIG) |
277 |
quiterr("cannot handle separate Luv planes"); |
278 |
TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT, |
279 |
SGILOGDATAFMT_FLOAT); |
280 |
cvts.tf = Luv2Color; |
281 |
break; |
282 |
case PHOTOMETRIC_LOGL: |
283 |
SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT); |
284 |
cvts.pconf = PLANARCONFIG_CONTIG; |
285 |
286 |
287 |
cvts.tf = L2Color; |
288 |
break; |
289 |
case PHOTOMETRIC_YCBCR: |
290 |
if (cvts.comp == COMPRESSION_JPEG && |
291 |
cvts.pconf == PLANARCONFIG_CONTIG) { |
292 |
TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE, |
293 |
JPEGCOLORMODE_RGB); |
294 |
cvts.phot = PHOTOMETRIC_RGB; |
295 |
} else |
296 |
quiterr("unsupported photometric type"); |
297 |
/* fall through */ |
298 |
case PHOTOMETRIC_RGB: |
299 |
SET(C_GAMMA); |
300 |
setcolrgam(cvts.gamcor); |
301 |
if (CHK(C_XYZE)) { |
302 |
comprgb2xyzWBmat(cvts.cmat, |
303 |
CHK(C_PRIM) ? cvts.prims : stdprims); |
304 |
SET(C_CXFM); |
305 |
306 |
if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) || |
307 |
hi != 3) |
308 |
quiterr("unsupported samples per pixel for RGB"); |
309 |
if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi)) |
310 |
hi = -1; |
311 |
switch (hi) { |
312 |
case 8: |
313 |
cvts.tf = RGB2Colr; |
314 |
break; |
315 |
case 16: |
316 |
cvts.tf = RRGGBB2Color; |
317 |
SET(C_RFLT|C_TWRD); |
318 |
break; |
319 |
case 32: |
320 |
cvts.tf = RfGfBf2Color; |
321 |
322 |
break; |
323 |
default: |
324 |
quiterr("unsupported bits per sample for RGB"); |
325 |
326 |
break; |
327 |
case PHOTOMETRIC_MINISBLACK: |
328 |
SET(C_GRY|C_GAMMA); |
329 |
330 |
331 |
332 |
hi != 1) |
333 |
quiterr("unsupported samples per pixel for greyscale"); |
334 |
335 |
hi = -1; |
336 |
switch (hi) { |
337 |
case 8: |
338 |
cvts.tf = Gry2Colr; |
339 |
break; |
340 |
case 16: |
341 |
cvts.tf = GGry2Color; |
342 |
343 |
break; |
344 |
case 32: |
345 |
cvts.tf = Gryf2Color; |
346 |
347 |
break; |
348 |
default: |
349 |
quiterr("unsupported bits per sample for Gray"); |
350 |
351 |
break; |
352 |
default: |
353 |
354 |
break; |
355 |
356 |
357 |
if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) || |
358 |
!TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax)) |
359 |
quiterr("unknown input image resolution"); |
360 |
361 |
if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits)) |
362 |
cvts.stonits = -1.; |
363 |
364 |
if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp)) |
365 |
cvts.capdate[0] = '\0'; |
366 |
else { |
367 |
strncpy(cvts.capdate, cp, 19); |
368 |
cvts.capdate[19] = '\0'; |
369 |
370 |
if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp)) |
371 |
cvts.owner[0] = '\0'; |
372 |
else { |
373 |
strncpy(cvts.owner, cp, sizeof(cvts.owner)); |
374 |
cvts.owner[sizeof(cvts.owner)-1] = '\0'; |
375 |
376 |
/* add to Radiance header */ |
377 |
if (cvts.pixrat < .999 || cvts.pixrat > 1.001) |
378 |
fputaspect(cvts.pixrat, cvts.rfp); |
379 |
380 |
if (cvts.stonits > .0) |
381 |
fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp); |
382 |
fputformat(CIEFMT, cvts.rfp); |
383 |
} else { |
384 |
if (CHK(C_PRIM)) |
385 |
fputprims(cvts.prims, cvts.rfp); |
386 |
387 |
fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits, |
388 |
cvts.rfp); |
389 |
fputformat(COLRFMT, cvts.rfp); |
390 |
391 |
if (cvts.capdate[0]) |
392 |
fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate); |
393 |
if (cvts.owner[0]) |
394 |
fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner); |
395 |
396 |
allocbufs(); /* allocate scanline buffers */ |
397 |
398 |
399 |
400 |
static void |
401 |
tiff2ra( /* convert TIFF image to Radiance picture */ |
402 |
int ac, |
403 |
char *av[] |
404 |
405 |
406 |
int32 y; |
407 |
/* open TIFF input */ |
408 |
if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL) |
409 |
quiterr("cannot open TIFF input"); |
410 |
/* open Radiance output */ |
411 |
if (av[ac+1] == NULL || !strcmp(av[ac+1], "-")) |
412 |
cvts.rfp = stdout; |
413 |
else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL) |
414 |
quiterr("cannot open Radiance output picture"); |
415 |
SET_FILE_BINARY(cvts.rfp); |
416 |
/* start output header */ |
417 |
newheader("RADIANCE", cvts.rfp); |
418 |
printargs(ac, av, cvts.rfp); |
419 |
420 |
initfromtif(); /* initialize conversion */ |
421 |
422 |
fputc('\n', cvts.rfp); /* finish Radiance header */ |
423 |
fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp); |
424 |
425 |
for (y = 0; y < cvts.ymax; y++) /* convert image */ |
426 |
(*cvts.tf)(y); |
427 |
/* clean up */ |
428 |
fclose(cvts.rfp); |
429 |
TIFFClose(cvts.tif); |
430 |
431 |
432 |
433 |
static int |
434 |
headline( /* process Radiance input header line */ |
435 |
char *s, |
436 |
void *p |
437 |
438 |
439 |
static int tmstrlen = 0; |
440 |
static int ownstrlen = 0; |
441 |
struct CONVST *cvp = (struct CONVST *)p; |
442 |
char fmt[MAXFMTLEN]; |
443 |
444 |
if (!tmstrlen) { |
445 |
tmstrlen = strlen(TMSTR); |
446 |
ownstrlen = strlen(OWNSTR); |
447 |
448 |
if (formatval(fmt, s)) { |
449 |
CLR(C_XYZE|C_SPEC); |
450 |
if (!strcmp(fmt, CIEFMT)) |
451 |
SET(C_XYZE); |
452 |
else if (!strcmp(fmt, SPECFMT)) |
453 |
SET(C_SPEC); |
454 |
else if (strcmp(fmt, COLRFMT)) |
455 |
return(-1); |
456 |
return(1); |
457 |
458 |
if (isexpos(s)) { |
459 |
cvp->stonits /= exposval(s); |
460 |
return(1); |
461 |
462 |
if (isaspect(s)) { |
463 |
cvp->pixrat *= aspectval(s); |
464 |
return(1); |
465 |
466 |
if (isprims(s)) { |
467 |
primsval(cvp->prims, s); |
468 |
SET(C_PRIM); |
469 |
return(1); |
470 |
471 |
if (isdate(s)) { |
472 |
if (s[tmstrlen] == ' ') |
473 |
strncpy(cvp->capdate, s+tmstrlen+1, 19); |
474 |
else |
475 |
strncpy(cvp->capdate, s+tmstrlen, 19); |
476 |
cvp->capdate[19] = '\0'; |
477 |
return(1); |
478 |
479 |
if (!strncmp(s, OWNSTR, ownstrlen)) { |
480 |
char *cp = s + ownstrlen; |
481 |
482 |
while (isspace(*cp)) |
483 |
++cp; |
484 |
strncpy(cvp->owner, cp, sizeof(cvp->owner)); |
485 |
cvp->owner[sizeof(cvp->owner)-1] = '\0'; |
486 |
for (cp = cvp->owner; *cp; cp++) |
487 |
488 |
while (cp > cvp->owner && isspace(cp[-1])) |
489 |
*--cp = '\0'; |
490 |
return(1); |
491 |
492 |
if (isncomp(s)) { |
493 |
cvp->ncc = ncompval(s); |
494 |
return((3 <= cvp->ncc) & (cvp->ncc < MAXCSAMP) ? 1 : -1); |
495 |
496 |
if (iswlsplit(s)) |
497 |
return(wlsplitval(cvp->wpt, s) ? 1 : -1); |
498 |
return(0); |
499 |
500 |
501 |
502 |
static void |
503 |
initfromrad(void) /* initialize input from a Radiance picture */ |
504 |
505 |
int i1, i2, po; |
506 |
/* read Radiance header */ |
507 |
memcpy(cvts.wpt, WLPART, sizeof(cvts.wpt)); |
508 |
if (getheader(cvts.rfp, headline, &cvts) < 0 || |
509 |
(po = fgetresolu(&i1, &i2, cvts.rfp)) < 0) |
510 |
quiterr("bad Radiance picture"); |
511 |
cvts.xmax = i1; cvts.ymax = i2; |
512 |
for (i1 = 0; i1 < 8; i1++) /* interpret orientation */ |
513 |
if (ortab[i1] == po) { |
514 |
cvts.orient = i1 + 1; |
515 |
break; |
516 |
517 |
if (i1 >= 8) |
518 |
quiterr("internal error 1 in initfromrad"); |
519 |
if (!(po & YMAJOR)) |
520 |
cvts.pixrat = 1./cvts.pixrat; |
521 |
if (!CHK(C_XYZE)) |
522 |
cvts.stonits *= WHTEFFICACY; |
523 |
/* set up conversion */ |
524 |
TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp); |
525 |
TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot); |
526 |
527 |
528 |
529 |
530 |
CLR(C_GRY|C_TWRD); |
531 |
if (!CHK(C_XYZE|C_SPEC)) { |
532 |
533 |
534 |
SET(C_CXFM); |
535 |
536 |
if (cvts.comp != COMPRESSION_SGILOG && |
537 |
cvts.comp != COMPRESSION_SGILOG24) |
538 |
quiterr("internal error 2 in initfromrad"); |
539 |
540 |
541 |
cvts.tf = Color2Luv; |
542 |
break; |
543 |
544 |
SET(C_GRY|C_RFLT|C_TFLT); |
545 |
CLR(C_TWRD); |
546 |
if (cvts.comp != COMPRESSION_SGILOG) |
547 |
quiterr("internal error 3 in initfromrad"); |
548 |
549 |
550 |
cvts.tf = Color2L; |
551 |
break; |
552 |
553 |
SET(C_GAMMA|C_GAMUT); |
554 |
CLR(C_GRY); |
555 |
556 |
if (CHK(C_TWRD|C_TFLT) ? CHK(C_XYZE|C_SPEC) : CHK(C_XYZE)) { |
557 |
compxyz2rgbWBmat(cvts.cmat, |
558 |
559 |
SET(C_CXFM); |
560 |
561 |
if (CHK(C_PRIM)) { |
562 |
TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, |
563 |
(float *)cvts.prims); |
564 |
TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT, |
565 |
(float *)cvts.prims[WHT]); |
566 |
567 |
if (CHK(C_TWRD)) { |
568 |
cvts.tf = Color2RRGGBB; |
569 |
SET(C_RFLT); |
570 |
} else if (CHK(C_TFLT)) { |
571 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT, |
572 |
SAMPLEFORMAT_IEEEFP); |
573 |
cvts.tf = Color2RfGfBf; |
574 |
SET(C_RFLT); |
575 |
CLR(C_GAMUT); |
576 |
} else |
577 |
cvts.tf = Colr2RGB; |
578 |
break; |
579 |
580 |
SET(C_GRY|C_GAMMA|C_GAMUT); |
581 |
582 |
583 |
cvts.tf = Color2GGry; |
584 |
SET(C_RFLT); |
585 |
586 |
587 |
588 |
cvts.tf = Color2Gryf; |
589 |
SET(C_RFLT); |
590 |
} else |
591 |
cvts.tf = Colr2Gry; |
592 |
break; |
593 |
default: |
594 |
quiterr("internal error 4 in initfromrad"); |
595 |
break; |
596 |
597 |
/* set other TIFF fields */ |
598 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax); |
599 |
TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax); |
600 |
TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3); |
601 |
TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, |
602 |
CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8); |
603 |
TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.); |
604 |
TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat); |
605 |
TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient); |
606 |
TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2); |
607 |
TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf); |
608 |
TIFFSetField(cvts.tif, TIFFTAG_STONITS, |
609 |
cvts.stonits/pow(2.,(double)cvts.bradj)); |
610 |
611 |
TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate); |
612 |
613 |
TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner); |
614 |
if (cvts.comp == COMPRESSION_NONE) |
615 |
i1 = TIFFScanlineSize(cvts.tif); |
616 |
else |
617 |
i1 = 3*cvts.xmax; /* conservative guess */ |
618 |
i2 = 8192/i1; /* compute good strip size */ |
619 |
if (i2 < 1) i2 = 1; |
620 |
TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2); |
621 |
622 |
623 |
624 |
625 |
626 |
static void |
627 |
ra2tiff( /* convert Radiance picture to TIFF image */ |
628 |
int ac, |
629 |
char *av[] |
630 |
631 |
632 |
uint32 y; |
633 |
/* open Radiance file */ |
634 |
if (!strcmp(av[ac], "-")) |
635 |
cvts.rfp = stdin; |
636 |
else if ((cvts.rfp = fopen(av[ac], "r")) == NULL) |
637 |
quiterr("cannot open Radiance input picture"); |
638 |
639 |
/* open TIFF file */ |
640 |
if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL) |
641 |
quiterr("cannot open TIFF output"); |
642 |
643 |
initfromrad(); /* initialize conversion */ |
644 |
645 |
646 |
(*cvts.tf)(y); |
647 |
/* clean up */ |
648 |
649 |
fclose(cvts.rfp); |
650 |
651 |
652 |
653 |
static void |
654 |
ReadRadScan(struct CONVST *cvp) |
655 |
656 |
static struct CONVST *lastcvp = NULL; |
657 |
static COLOR scomp[MAXCSAMP]; |
658 |
659 |
if (cvp->ncc > 3) { /* convert spectral pixels */ |
660 |
SCOLR sclr; |
661 |
SCOLOR scol; |
662 |
COLOR xyz; |
663 |
int x, n; |
664 |
if (lastcvp != cvp) { |
665 |
for (n = cvp->ncc; n--; ) |
666 |
spec_cie(scomp[n], |
667 |
cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*(n+1)/cvp->ncc, |
668 |
cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*n/cvp->ncc); |
669 |
lastcvp = cvp; |
670 |
671 |
for (x = 0; x < cvp->xmax; x++) { |
672 |
if (getbinary(sclr, cvp->ncc+1, 1, cvp->rfp) != 1) |
673 |
goto readerr; |
674 |
scolr2scolor(scol, sclr, cvp->ncc); |
675 |
setcolor(cvp->r.colors[x], 0, 0, 0); |
676 |
for (n = cvp->ncc; n--; ) { |
677 |
copycolor(xyz, scomp[n]); |
678 |
scalecolor(xyz, scol[n]); |
679 |
addcolor(cvp->r.colors[x], xyz); |
680 |
681 |
682 |
return; |
683 |
684 |
if (freadscan(cvp->r.colors, cvp->xmax, cvp->rfp) >= 0) |
685 |
return; |
686 |
readerr: |
687 |
quiterr("error reading Radiance picture"); |
688 |
689 |
690 |
691 |
static void |
692 |
Luv2Color( /* read/convert/write Luv->COLOR scanline */ |
693 |
uint32 y |
694 |
695 |
696 |
int x; |
697 |
698 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT)) |
699 |
quiterr("internal error 1 in Luv2Color"); |
700 |
701 |
702 |
quiterr("cannot handle separate 32-bit color planes"); |
703 |
704 |
if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
705 |
quiterr("error reading TIFF input"); |
706 |
/* also works for float RGB */ |
707 |
for (x = cvts.xmax; x--; ) { |
708 |
setcolor(cvts.r.colors[x], |
709 |
cvts.t.fp[3*x], |
710 |
cvts.t.fp[3*x + 1], |
711 |
cvts.t.fp[3*x + 2]); |
712 |
if (CHK(C_CXFM)) |
713 |
colortrans(cvts.r.colors[x], cvts.cmat, |
714 |
cvts.r.colors[x]); |
715 |
if (CHK(C_GAMUT)) |
716 |
clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1], |
717 |
CGAMUT_LOWER, cblack, cwhite); |
718 |
719 |
if (cvts.bradj) { |
720 |
double m = pow(2.,(double)cvts.bradj); |
721 |
for (x = cvts.xmax; x--; ) |
722 |
scalecolor(cvts.r.colors[x], m); |
723 |
724 |
725 |
if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0) |
726 |
quiterr("error writing Radiance picture"); |
727 |
728 |
729 |
730 |
static void |
731 |
RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */ |
732 |
uint32 y |
733 |
734 |
735 |
int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01); |
736 |
double d; |
737 |
int x; |
738 |
739 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT)) |
740 |
quiterr("internal error 1 in RRGGBB2Color"); |
741 |
742 |
743 |
quiterr("cannot handle separate 16-bit color planes"); |
744 |
745 |
746 |
747 |
748 |
749 |
d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16)); |
750 |
if (dogamma) d = pow(d, cvts.gamcor); |
751 |
colval(cvts.r.colors[x],RED) = d; |
752 |
d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16)); |
753 |
754 |
colval(cvts.r.colors[x],GRN) = d; |
755 |
d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16)); |
756 |
757 |
colval(cvts.r.colors[x],BLU) = d; |
758 |
if (CHK(C_CXFM)) |
759 |
760 |
761 |
762 |
if (cvts.bradj) { |
763 |
d = pow(2.,(double)cvts.bradj); |
764 |
765 |
scalecolor(cvts.r.colors[x], d); |
766 |
767 |
768 |
769 |
770 |
771 |
772 |
773 |
static void |
774 |
L2Color( /* read/convert/write Lfloat->COLOR scanline */ |
775 |
uint32 y |
776 |
777 |
778 |
float m = pow(2., (double)cvts.bradj); |
779 |
int x; |
780 |
781 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
782 |
quiterr("internal error 1 in L2Color"); |
783 |
784 |
785 |
786 |
/* also works for float greyscale */ |
787 |
788 |
float f = cvts.t.fp[x]; |
789 |
if (cvts.bradj) f *= m; |
790 |
setcolor(cvts.r.colors[x], f, f, f); |
791 |
792 |
793 |
794 |
795 |
796 |
797 |
static void |
798 |
RGB2Colr( /* read/convert/write RGB->COLR scanline */ |
799 |
uint32 y |
800 |
801 |
802 |
COLOR ctmp; |
803 |
int x; |
804 |
805 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY)) |
806 |
quiterr("internal error 1 in RGB2Colr"); |
807 |
808 |
if (cvts.pconf == PLANARCONFIG_CONTIG) { |
809 |
810 |
goto readerr; |
811 |
812 |
cvts.r.colrs[x][RED] = cvts.t.bp[3*x]; |
813 |
cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1]; |
814 |
cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2]; |
815 |
816 |
} else { |
817 |
818 |
goto readerr; |
819 |
if (TIFFReadScanline(cvts.tif, |
820 |
(tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0) |
821 |
goto readerr; |
822 |
823 |
(tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0) |
824 |
goto readerr; |
825 |
826 |
cvts.r.colrs[x][RED] = cvts.t.bp[x]; |
827 |
cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x]; |
828 |
cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x]; |
829 |
830 |
831 |
832 |
gambs_colrs(cvts.r.colrs, cvts.xmax); |
833 |
if (CHK(C_CXFM)) |
834 |
835 |
colr_color(ctmp, cvts.r.colrs[x]); |
836 |
colortrans(ctmp, cvts.cmat, ctmp); |
837 |
if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */ |
838 |
clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER, |
839 |
cblack, cwhite); |
840 |
setcolr(cvts.r.colrs[x], colval(ctmp,RED), |
841 |
colval(ctmp,GRN), colval(ctmp,BLU)); |
842 |
843 |
if (cvts.bradj) |
844 |
shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj); |
845 |
846 |
if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0) |
847 |
848 |
return; |
849 |
readerr: |
850 |
851 |
852 |
853 |
854 |
static void |
855 |
Gry2Colr( /* read/convert/write G8->COLR scanline */ |
856 |
uint32 y |
857 |
858 |
859 |
int x; |
860 |
861 |
if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY) |
862 |
quiterr("internal error 1 in Gry2Colr"); |
863 |
864 |
865 |
866 |
867 |
868 |
cvts.r.colrs[x][RED] = |
869 |
cvts.r.colrs[x][GRN] = |
870 |
cvts.r.colrs[x][BLU] = cvts.t.bp[x]; |
871 |
872 |
873 |
if (cvts.bradj) |
874 |
875 |
876 |
877 |
878 |
879 |
880 |
881 |
static void |
882 |
GGry2Color( /* read/convert/write G16->COLOR scanline */ |
883 |
uint32 y |
884 |
885 |
886 |
887 |
double m; |
888 |
double d; |
889 |
int x; |
890 |
891 |
if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD)) |
892 |
quiterr("internal error 1 in GGry2Color"); |
893 |
894 |
895 |
896 |
897 |
if (cvts.bradj) |
898 |
899 |
900 |
d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16)); |
901 |
902 |
if (cvts.bradj) d *= m; |
903 |
colval(cvts.r.colors[x],RED) = |
904 |
colval(cvts.r.colors[x],GRN) = |
905 |
906 |
907 |
908 |
909 |
910 |
911 |
912 |
static void |
913 |
Color2GGry( /* read/convert/write COLOR->G16 scanline */ |
914 |
uint32 y |
915 |
916 |
917 |
918 |
float m = pow(2.,(double)cvts.bradj); |
919 |
int x; |
920 |
921 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY)) |
922 |
quiterr("internal error 1 in Color2GGry"); |
923 |
924 |
ReadRadScan(&cvts); |
925 |
926 |
927 |
float f = m*( CHK(C_XYZE) ? |
928 |
colval(cvts.r.colors[x],CIEY) |
929 |
: bright(cvts.r.colors[x]) ); |
930 |
if (f <= 0) |
931 |
cvts.t.wp[x] = 0; |
932 |
else if (f >= 1) |
933 |
cvts.t.wp[x] = 0xffff; |
934 |
else if (dogamma) |
935 |
cvts.t.wp[x] = (int)((float)(1L<<16) * |
936 |
pow(f, 1./cvts.gamcor)); |
937 |
else |
938 |
cvts.t.wp[x] = (int)((float)(1L<<16) * f); |
939 |
940 |
941 |
if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0) |
942 |
quiterr("error writing TIFF output"); |
943 |
944 |
945 |
946 |
static void |
947 |
Color2L( /* read/convert/write COLOR->Lfloat scanline */ |
948 |
uint32 y |
949 |
950 |
951 |
952 |
int x; |
953 |
954 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY)) |
955 |
quiterr("internal error 1 in Color2L"); |
956 |
957 |
958 |
959 |
960 |
cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY) |
961 |
962 |
963 |
964 |
965 |
966 |
967 |
968 |
static void |
969 |
Color2Luv( /* read/convert/write COLOR->Luv scanline */ |
970 |
uint32 y |
971 |
972 |
973 |
int x; |
974 |
975 |
976 |
quiterr("internal error 1 in Color2Luv"); |
977 |
978 |
979 |
980 |
if (CHK(C_CXFM)) |
981 |
982 |
983 |
984 |
if (cvts.bradj) { |
985 |
986 |
987 |
988 |
989 |
990 |
991 |
cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX); |
992 |
cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY); |
993 |
cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ); |
994 |
995 |
996 |
997 |
998 |
999 |
1000 |
1001 |
static void |
1002 |
Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */ |
1003 |
uint32 y |
1004 |
1005 |
1006 |
1007 |
1008 |
int x, i; |
1009 |
1010 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD)) |
1011 |
quiterr("internal error 1 in Color2RRGGBB"); |
1012 |
1013 |
1014 |
1015 |
1016 |
if (CHK(C_CXFM)) { |
1017 |
1018 |
1019 |
if (CHK(C_GAMUT)) |
1020 |
clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]), |
1021 |
1022 |
1023 |
for (i = 3; i--; ) { |
1024 |
float f = m*colval(cvts.r.colors[x],i); |
1025 |
if (f <= 0) |
1026 |
cvts.t.wp[3*x + i] = 0; |
1027 |
else if (f >= 1) |
1028 |
cvts.t.wp[3*x + i] = 0xffff; |
1029 |
else if (dogamma) |
1030 |
cvts.t.wp[3*x + i] = (int)((float)(1L<<16) * |
1031 |
1032 |
else |
1033 |
cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f); |
1034 |
1035 |
1036 |
1037 |
1038 |
1039 |
1040 |
1041 |
1042 |
static void |
1043 |
Colr2Gry( /* read/convert/write COLR->RGB scanline */ |
1044 |
uint32 y |
1045 |
1046 |
1047 |
int x; |
1048 |
1049 |
1050 |
quiterr("internal error 1 in Colr2Gry"); |
1051 |
1052 |
if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp, |
1053 |
cvts.ncc, cvts.wpt) < 0) |
1054 |
1055 |
1056 |
if (cvts.bradj) |
1057 |
1058 |
1059 |
colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]); |
1060 |
colrs_gambs(cvts.r.colrs, cvts.xmax); |
1061 |
1062 |
1063 |
cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY); |
1064 |
1065 |
1066 |
1067 |
1068 |
1069 |
1070 |
static void |
1071 |
Colr2RGB( /* read/convert/write COLR->RGB scanline */ |
1072 |
uint32 y |
1073 |
1074 |
1075 |
COLOR ctmp; |
1076 |
int x; |
1077 |
1078 |
if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY)) |
1079 |
quiterr("internal error 1 in Colr2RGB"); |
1080 |
1081 |
1082 |
1083 |
1084 |
1085 |
if (cvts.bradj) |
1086 |
1087 |
if (CHK(C_CXFM)) |
1088 |
1089 |
1090 |
1091 |
if (CHK(C_GAMUT)) |
1092 |
clipgamut(ctmp, bright(ctmp), CGAMUT, |
1093 |
cblack, cwhite); |
1094 |
1095 |
1096 |
1097 |
1098 |
1099 |
1100 |
cvts.t.bp[3*x] = cvts.r.colrs[x][RED]; |
1101 |
cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN]; |
1102 |
cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU]; |
1103 |
1104 |
1105 |
1106 |
1107 |
