root/radiance/ray/src/px/ra_tiff.c
Revision: 2.39
Committed: Fri Jun 6 19:11:21 2025 UTC (7 weeks, 5 days ago) by greg
Changes since 2.38: +4 -6 lines
refactor: Making use of printargs() more consistent with fixargv0()
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.38 2024/10/04 19:15:19 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <math.h>
11 #include <ctype.h>
12 #include "paths.h"
13 #include "rtio.h"
14 #include "platform.h"
15 #include "tiffio.h"
16 #include "color.h"
17 #include "resolu.h"
18
19 #define GAMCOR 2.2 /* default gamma */
20
21 /* conversion flags */
22 #define C_CXFM 0x1 /* needs color transformation */
23 #define C_GAMUT 0x2 /* needs gamut mapping */
24 #define C_GAMMA 0x4 /* needs gamma correction */
25 #define C_GRY 0x8 /* TIFF is greyscale */
26 #define C_XYZE 0x10 /* Radiance is XYZE */
27 #define C_SPEC 0x20 /* Radiance is spectral */
28 #define C_RFLT 0x40 /* Radiance data is float */
29 #define C_TFLT 0x80 /* TIFF data is float */
30 #define C_TWRD 0x100 /* TIFF data is 16-bit */
31 #define C_PRIM 0x200 /* has assigned primaries */
32
33 typedef void colcvf_t(uint32 y);
34
35 struct CONVST {
36 uint16 flags; /* conversion flags (defined above) */
37 char capdate[20]; /* capture date/time */
38 char owner[256]; /* content owner */
39 uint16 comp; /* TIFF compression type */
40 uint16 phot; /* TIFF photometric type */
41 uint16 pconf; /* TIFF planar configuration */
42 float gamcor; /* gamma correction value */
43 short bradj; /* Radiance exposure adjustment (stops) */
44 uint16 orient; /* visual orientation (TIFF spec.) */
45 double stonits; /* input conversion to nits */
46 float pixrat; /* pixel aspect ratio */
47 int ncc; /* # color components for spectral */
48 float wpt[4]; /* wavelength partitions */
49 FILE *rfp; /* Radiance stream pointer */
50 TIFF *tif; /* TIFF pointer */
51 uint32 xmax, ymax; /* image dimensions */
52 COLORMAT cmat; /* color transformation matrix */
53 RGBPRIMS prims; /* RGB primaries */
54 union {
55 COLR *colrs; /* 4-byte ???E pointer */
56 COLOR *colors; /* float array pointer */
57 void *p; /* generic pointer */
58 } r; /* Radiance scanline */
59 union {
60 uint8 *bp; /* byte pointer */
61 uint16 *wp; /* word pointer */
62 float *fp; /* float pointer */
63 void *p; /* generic pointer */
64 } t; /* TIFF scanline */
65 colcvf_t *tf; /* translation procedure */
66 } cvts = { /* conversion structure */
67 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
68 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., 3,
69 };
70
71 #define CHK(f) (cvts.flags & (f))
72 #define SET(f) (cvts.flags |= (f))
73 #define CLR(f) (cvts.flags &= ~(f))
74 #define TGL(f) (cvts.flags ^= (f))
75
76 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
77 static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
78 static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
79
80 static gethfunc headline;
81 static void quiterr(char *err);
82 static void allocbufs(void);
83 static void initfromtif(void);
84 static void tiff2ra(int ac, char *av[]);
85 static void initfromrad(void);
86 static void ra2tiff(int ac, char *av[]);
87 static void ReadRadScan(struct CONVST *cvp);
88
89
90 #define RfGfBf2Color Luv2Color
91 #define Gryf2Color L2Color
92 #define Color2Gryf Color2L
93 #define Color2RfGfBf Color2Luv
94
95 short ortab[8] = { /* orientation conversion table */
96 YMAJOR|YDECR,
97 YMAJOR|YDECR|XDECR,
98 YMAJOR|XDECR,
99 YMAJOR,
100 YDECR,
101 XDECR|YDECR,
102 XDECR,
103 0
104 };
105
106 #define pixorder() ortab[cvts.orient-1]
107
108 extern char TMSTR[]; /* "CAPDATE=" from header.c */
109 char OWNSTR[] = "OWNER=";
110
111
112 int
113 main(int argc, char *argv[])
114 {
115 int reverse = 0;
116 int i;
117 /* set global progname */
118 fixargv0(argv[0]);
119
120 for (i = 1; i < argc; i++)
121 if (argv[i][0] == '-')
122 switch (argv[i][1]) {
123 case 'g': /* gamma correction */
124 cvts.gamcor = atof(argv[++i]);
125 break;
126 case 'x': /* XYZE Radiance output */
127 TGL(C_XYZE);
128 break;
129 case 'z': /* LZW compressed output */
130 cvts.comp = COMPRESSION_LZW;
131 break;
132 case 'L': /* LogLuv 32-bit output */
133 cvts.comp = COMPRESSION_SGILOG;
134 cvts.phot = PHOTOMETRIC_LOGLUV;
135 break;
136 case 'l': /* LogLuv 24-bit output */
137 cvts.comp = COMPRESSION_SGILOG24;
138 cvts.phot = PHOTOMETRIC_LOGLUV;
139 break;
140 case 'w': /* 16-bit/primary output? */
141 TGL(C_TWRD);
142 break;
143 case 'f': /* IEEE float output? */
144 TGL(C_TFLT);
145 break;
146 case 'b': /* greyscale output? */
147 TGL(C_GRY);
148 break;
149 case 'e': /* exposure adjustment */
150 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
151 goto userr;
152 cvts.bradj = atoi(argv[++i]);
153 break;
154 case 'r': /* reverse conversion? */
155 reverse = !reverse;
156 break;
157 case '\0':
158 goto doneopts;
159 default:
160 goto userr;
161 }
162 else
163 break;
164 doneopts:
165 if (reverse) {
166
167 if (i != argc-2 && i != argc-1)
168 goto userr;
169
170 tiff2ra(i, argv);
171
172 } else {
173
174 if (i != argc-2)
175 goto userr;
176 /* consistency checks */
177 if (CHK(C_GRY)) {
178 if (cvts.phot == PHOTOMETRIC_RGB)
179 cvts.phot = PHOTOMETRIC_MINISBLACK;
180 else {
181 cvts.phot = PHOTOMETRIC_LOGL;
182 cvts.comp = COMPRESSION_SGILOG;
183 }
184 }
185 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
186 goto userr;
187
188 ra2tiff(i, argv);
189 }
190
191 exit(0);
192 userr:
193 fprintf(stderr,
194 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n",
195 progname);
196 fprintf(stderr,
197 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n",
198 progname);
199 exit(1);
200 }
201
202
203 static void
204 quiterr( /* print message and exit */
205 char *err
206 )
207 {
208 if (err != NULL) {
209 fprintf(stderr, "%s: %s\n", progname, err);
210 exit(1);
211 }
212 exit(0);
213 }
214
215
216 static void
217 allocbufs(void) /* allocate scanline buffers */
218 {
219 int rsiz, tsiz;
220
221 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
222 tsiz = (CHK(C_TFLT) ? sizeof(float) :
223 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
224 (CHK(C_GRY) ? 1 : 3);
225 cvts.r.p = malloc(rsiz*cvts.xmax);
226 cvts.t.p = malloc(tsiz*cvts.xmax);
227 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
228 quiterr("no memory to allocate scanline buffers");
229 }
230
231
232 static void
233 initfromtif(void) /* initialize conversion from TIFF input */
234 {
235 uint16 hi;
236 char *cp;
237 float *fa, f1, f2;
238
239 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
240
241 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
242 cvts.prims[RED][CIEX] = fa[0];
243 cvts.prims[RED][CIEY] = fa[1];
244 cvts.prims[GRN][CIEX] = fa[2];
245 cvts.prims[GRN][CIEY] = fa[3];
246 cvts.prims[BLU][CIEX] = fa[4];
247 cvts.prims[BLU][CIEY] = fa[5];
248 cvts.prims[WHT][CIEX] = 1./3.;
249 cvts.prims[WHT][CIEY] = 1./3.;
250 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
251 cvts.prims[WHT][CIEX] = fa[0];
252 cvts.prims[WHT][CIEY] = fa[1];
253 }
254 SET(C_PRIM);
255 }
256
257 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
258 cvts.comp = COMPRESSION_NONE;
259
260 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
261 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
262 cvts.pixrat = f1/f2;
263
264 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
265
266 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
267 quiterr("TIFF has unspecified photometric type");
268
269 switch (cvts.phot) {
270 case PHOTOMETRIC_LOGLUV:
271 SET(C_RFLT|C_TFLT);
272 if (!CHK(C_XYZE)) {
273 cpcolormat(cvts.cmat, xyz2rgbmat);
274 SET(C_CXFM|C_GAMUT);
275 } else if (cvts.comp == COMPRESSION_SGILOG)
276 SET(C_GAMUT); /* may be outside XYZ gamut */
277 if (cvts.pconf != PLANARCONFIG_CONTIG)
278 quiterr("cannot handle separate Luv planes");
279 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
280 SGILOGDATAFMT_FLOAT);
281 cvts.tf = Luv2Color;
282 break;
283 case PHOTOMETRIC_LOGL:
284 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
285 cvts.pconf = PLANARCONFIG_CONTIG;
286 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
287 SGILOGDATAFMT_FLOAT);
288 cvts.tf = L2Color;
289 break;
290 case PHOTOMETRIC_YCBCR:
291 if (cvts.comp == COMPRESSION_JPEG &&
292 cvts.pconf == PLANARCONFIG_CONTIG) {
293 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
294 JPEGCOLORMODE_RGB);
295 cvts.phot = PHOTOMETRIC_RGB;
296 } else
297 quiterr("unsupported photometric type");
298 /* fall through */
299 case PHOTOMETRIC_RGB:
300 SET(C_GAMMA);
301 setcolrgam(cvts.gamcor);
302 if (CHK(C_XYZE)) {
303 comprgb2xyzWBmat(cvts.cmat,
304 CHK(C_PRIM) ? cvts.prims : stdprims);
305 SET(C_CXFM);
306 }
307 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
308 hi != 3)
309 quiterr("unsupported samples per pixel for RGB");
310 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
311 hi = -1;
312 switch (hi) {
313 case 8:
314 cvts.tf = RGB2Colr;
315 break;
316 case 16:
317 cvts.tf = RRGGBB2Color;
318 SET(C_RFLT|C_TWRD);
319 break;
320 case 32:
321 cvts.tf = RfGfBf2Color;
322 SET(C_RFLT|C_TFLT);
323 break;
324 default:
325 quiterr("unsupported bits per sample for RGB");
326 }
327 break;
328 case PHOTOMETRIC_MINISBLACK:
329 SET(C_GRY|C_GAMMA);
330 setcolrgam(cvts.gamcor);
331 cvts.pconf = PLANARCONFIG_CONTIG;
332 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
333 hi != 1)
334 quiterr("unsupported samples per pixel for greyscale");
335 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
336 hi = -1;
337 switch (hi) {
338 case 8:
339 cvts.tf = Gry2Colr;
340 break;
341 case 16:
342 cvts.tf = GGry2Color;
343 SET(C_RFLT|C_TWRD);
344 break;
345 case 32:
346 cvts.tf = Gryf2Color;
347 SET(C_RFLT|C_TFLT);
348 break;
349 default:
350 quiterr("unsupported bits per sample for Gray");
351 }
352 break;
353 default:
354 quiterr("unsupported photometric type");
355 break;
356 }
357
358 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
359 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
360 quiterr("unknown input image resolution");
361
362 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
363 cvts.stonits = -1.;
364
365 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
366 cvts.capdate[0] = '\0';
367 else {
368 strncpy(cvts.capdate, cp, 19);
369 cvts.capdate[19] = '\0';
370 }
371 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
372 cvts.owner[0] = '\0';
373 else {
374 strncpy(cvts.owner, cp, sizeof(cvts.owner));
375 cvts.owner[sizeof(cvts.owner)-1] = '\0';
376 }
377 /* add to Radiance header */
378 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
379 fputaspect(cvts.pixrat, cvts.rfp);
380 if (CHK(C_XYZE)) {
381 if (cvts.stonits > .0)
382 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
383 fputformat(CIEFMT, cvts.rfp);
384 } else {
385 if (CHK(C_PRIM))
386 fputprims(cvts.prims, cvts.rfp);
387 if (cvts.stonits > .0)
388 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
389 cvts.rfp);
390 fputformat(COLRFMT, cvts.rfp);
391 }
392 if (cvts.capdate[0])
393 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
394 if (cvts.owner[0])
395 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
396
397 allocbufs(); /* allocate scanline buffers */
398 }
399
400
401 static void
402 tiff2ra( /* convert TIFF image to Radiance picture */
403 int ac,
404 char *av[]
405 )
406 {
407 int32 y;
408 /* open TIFF input */
409 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
410 quiterr("cannot open TIFF input");
411 /* open Radiance output */
412 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
413 cvts.rfp = stdout;
414 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
415 quiterr("cannot open Radiance output picture");
416 SET_FILE_BINARY(cvts.rfp);
417 /* start output header */
418 newheader("RADIANCE", cvts.rfp);
419 printargs(ac, av, cvts.rfp);
420
421 initfromtif(); /* initialize conversion */
422
423 fputc('\n', cvts.rfp); /* finish Radiance header */
424 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
425
426 for (y = 0; y < cvts.ymax; y++) /* convert image */
427 (*cvts.tf)(y);
428 /* clean up */
429 fclose(cvts.rfp);
430 TIFFClose(cvts.tif);
431 }
432
433
434 static int
435 headline( /* process Radiance input header line */
436 char *s,
437 void *p
438 )
439 {
440 static int tmstrlen = 0;
441 static int ownstrlen = 0;
442 struct CONVST *cvp = (struct CONVST *)p;
443 char fmt[MAXFMTLEN];
444
445 if (!tmstrlen) {
446 tmstrlen = strlen(TMSTR);
447 ownstrlen = strlen(OWNSTR);
448 }
449 if (formatval(fmt, s)) {
450 CLR(C_XYZE|C_SPEC);
451 if (!strcmp(fmt, CIEFMT))
452 SET(C_XYZE);
453 else if (!strcmp(fmt, SPECFMT))
454 SET(C_SPEC);
455 else if (strcmp(fmt, COLRFMT))
456 return(-1);
457 return(1);
458 }
459 if (isexpos(s)) {
460 cvp->stonits /= exposval(s);
461 return(1);
462 }
463 if (isaspect(s)) {
464 cvp->pixrat *= aspectval(s);
465 return(1);
466 }
467 if (isprims(s)) {
468 primsval(cvp->prims, s);
469 SET(C_PRIM);
470 return(1);
471 }
472 if (isdate(s)) {
473 if (s[tmstrlen] == ' ')
474 strncpy(cvp->capdate, s+tmstrlen+1, 19);
475 else
476 strncpy(cvp->capdate, s+tmstrlen, 19);
477 cvp->capdate[19] = '\0';
478 return(1);
479 }
480 if (!strncmp(s, OWNSTR, ownstrlen)) {
481 char *cp = s + ownstrlen;
482
483 while (isspace(*cp))
484 ++cp;
485 strncpy(cvp->owner, cp, sizeof(cvp->owner));
486 cvp->owner[sizeof(cvp->owner)-1] = '\0';
487 for (cp = cvp->owner; *cp; cp++)
488 ;
489 while (cp > cvp->owner && isspace(cp[-1]))
490 *--cp = '\0';
491 return(1);
492 }
493 if (isncomp(s)) {
494 cvp->ncc = ncompval(s);
495 return((3 <= cvp->ncc) & (cvp->ncc < MAXCSAMP) ? 1 : -1);
496 }
497 if (iswlsplit(s))
498 return(wlsplitval(cvp->wpt, s) ? 1 : -1);
499 return(0);
500 }
501
502
503 static void
504 initfromrad(void) /* initialize input from a Radiance picture */
505 {
506 int i1, i2, po;
507 /* read Radiance header */
508 memcpy(cvts.wpt, WLPART, sizeof(cvts.wpt));
509 if (getheader(cvts.rfp, headline, &cvts) < 0 ||
510 (po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
511 quiterr("bad Radiance picture");
512 cvts.xmax = i1; cvts.ymax = i2;
513 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
514 if (ortab[i1] == po) {
515 cvts.orient = i1 + 1;
516 break;
517 }
518 if (i1 >= 8)
519 quiterr("internal error 1 in initfromrad");
520 if (!(po & YMAJOR))
521 cvts.pixrat = 1./cvts.pixrat;
522 if (!CHK(C_XYZE))
523 cvts.stonits *= WHTEFFICACY;
524 /* set up conversion */
525 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
526 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
527
528 switch (cvts.phot) {
529 case PHOTOMETRIC_LOGLUV:
530 SET(C_RFLT|C_TFLT);
531 CLR(C_GRY|C_TWRD);
532 if (!CHK(C_XYZE|C_SPEC)) {
533 comprgb2xyzWBmat(cvts.cmat,
534 CHK(C_PRIM) ? cvts.prims : stdprims);
535 SET(C_CXFM);
536 }
537 if (cvts.comp != COMPRESSION_SGILOG &&
538 cvts.comp != COMPRESSION_SGILOG24)
539 quiterr("internal error 2 in initfromrad");
540 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
541 SGILOGDATAFMT_FLOAT);
542 cvts.tf = Color2Luv;
543 break;
544 case PHOTOMETRIC_LOGL:
545 SET(C_GRY|C_RFLT|C_TFLT);
546 CLR(C_TWRD);
547 if (cvts.comp != COMPRESSION_SGILOG)
548 quiterr("internal error 3 in initfromrad");
549 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
550 SGILOGDATAFMT_FLOAT);
551 cvts.tf = Color2L;
552 break;
553 case PHOTOMETRIC_RGB:
554 SET(C_GAMMA|C_GAMUT);
555 CLR(C_GRY);
556 setcolrgam(cvts.gamcor);
557 if (CHK(C_TWRD|C_TFLT) ? CHK(C_XYZE|C_SPEC) : CHK(C_XYZE)) {
558 compxyz2rgbWBmat(cvts.cmat,
559 CHK(C_PRIM) ? cvts.prims : stdprims);
560 SET(C_CXFM);
561 }
562 if (CHK(C_PRIM)) {
563 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
564 (float *)cvts.prims);
565 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
566 (float *)cvts.prims[WHT]);
567 }
568 if (CHK(C_TWRD)) {
569 cvts.tf = Color2RRGGBB;
570 SET(C_RFLT);
571 } else if (CHK(C_TFLT)) {
572 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
573 SAMPLEFORMAT_IEEEFP);
574 cvts.tf = Color2RfGfBf;
575 SET(C_RFLT);
576 CLR(C_GAMUT);
577 } else
578 cvts.tf = Colr2RGB;
579 break;
580 case PHOTOMETRIC_MINISBLACK:
581 SET(C_GRY|C_GAMMA|C_GAMUT);
582 setcolrgam(cvts.gamcor);
583 if (CHK(C_TWRD)) {
584 cvts.tf = Color2GGry;
585 SET(C_RFLT);
586 } else if (CHK(C_TFLT)) {
587 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
588 SAMPLEFORMAT_IEEEFP);
589 cvts.tf = Color2Gryf;
590 SET(C_RFLT);
591 } else
592 cvts.tf = Colr2Gry;
593 break;
594 default:
595 quiterr("internal error 4 in initfromrad");
596 break;
597 }
598 /* set other TIFF fields */
599 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
600 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
601 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
602 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
603 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
604 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
605 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
606 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
607 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
608 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
609 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
610 cvts.stonits/pow(2.,(double)cvts.bradj));
611 if (cvts.capdate[0])
612 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
613 if (cvts.owner[0])
614 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
615 if (cvts.comp == COMPRESSION_NONE)
616 i1 = TIFFScanlineSize(cvts.tif);
617 else
618 i1 = 3*cvts.xmax; /* conservative guess */
619 i2 = 8192/i1; /* compute good strip size */
620 if (i2 < 1) i2 = 1;
621 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
622
623 allocbufs(); /* allocate scanline buffers */
624 }
625
626
627 static void
628 ra2tiff( /* convert Radiance picture to TIFF image */
629 int ac,
630 char *av[]
631 )
632 {
633 uint32 y;
634 /* open Radiance file */
635 if (!strcmp(av[ac], "-"))
636 cvts.rfp = stdin;
637 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
638 quiterr("cannot open Radiance input picture");
639 SET_FILE_BINARY(cvts.rfp);
640 /* open TIFF file */
641 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
642 quiterr("cannot open TIFF output");
643
644 initfromrad(); /* initialize conversion */
645
646 for (y = 0; y < cvts.ymax; y++) /* convert image */
647 (*cvts.tf)(y);
648 /* clean up */
649 TIFFClose(cvts.tif);
650 fclose(cvts.rfp);
651 }
652
653
654 static void
655 ReadRadScan(struct CONVST *cvp)
656 {
657 static struct CONVST *lastcvp = NULL;
658 static COLOR scomp[MAXCSAMP];
659
660 if (cvp->ncc > 3) { /* convert spectral pixels */
661 SCOLR sclr;
662 SCOLOR scol;
663 COLOR xyz;
664 int x, n;
665 if (lastcvp != cvp) {
666 for (n = cvp->ncc; n--; )
667 spec_cie(scomp[n],
668 cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*(n+1)/cvp->ncc,
669 cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*n/cvp->ncc);
670 lastcvp = cvp;
671 }
672 for (x = 0; x < cvp->xmax; x++) {
673 if (getbinary(sclr, cvp->ncc+1, 1, cvp->rfp) != 1)
674 goto readerr;
675 scolr2scolor(scol, sclr, cvp->ncc);
676 setcolor(cvp->r.colors[x], 0, 0, 0);
677 for (n = cvp->ncc; n--; ) {
678 copycolor(xyz, scomp[n]);
679 scalecolor(xyz, scol[n]);
680 addcolor(cvp->r.colors[x], xyz);
681 }
682 }
683 return;
684 }
685 if (freadscan(cvp->r.colors, cvp->xmax, cvp->rfp) >= 0)
686 return;
687 readerr:
688 quiterr("error reading Radiance picture");
689 }
690
691
692 static void
693 Luv2Color( /* read/convert/write Luv->COLOR scanline */
694 uint32 y
695 )
696 {
697 int x;
698
699 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
700 quiterr("internal error 1 in Luv2Color");
701
702 if (cvts.pconf != PLANARCONFIG_CONTIG)
703 quiterr("cannot handle separate 32-bit color planes");
704
705 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
706 quiterr("error reading TIFF input");
707 /* also works for float RGB */
708 for (x = cvts.xmax; x--; ) {
709 setcolor(cvts.r.colors[x],
710 cvts.t.fp[3*x],
711 cvts.t.fp[3*x + 1],
712 cvts.t.fp[3*x + 2]);
713 if (CHK(C_CXFM))
714 colortrans(cvts.r.colors[x], cvts.cmat,
715 cvts.r.colors[x]);
716 if (CHK(C_GAMUT))
717 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
718 CGAMUT_LOWER, cblack, cwhite);
719 }
720 if (cvts.bradj) {
721 double m = pow(2.,(double)cvts.bradj);
722 for (x = cvts.xmax; x--; )
723 scalecolor(cvts.r.colors[x], m);
724 }
725
726 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
727 quiterr("error writing Radiance picture");
728 }
729
730
731 static void
732 RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
733 uint32 y
734 )
735 {
736 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
737 double d;
738 int x;
739
740 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
741 quiterr("internal error 1 in RRGGBB2Color");
742
743 if (cvts.pconf != PLANARCONFIG_CONTIG)
744 quiterr("cannot handle separate 16-bit color planes");
745
746 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
747 quiterr("error reading TIFF input");
748
749 for (x = cvts.xmax; x--; ) {
750 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
751 if (dogamma) d = pow(d, cvts.gamcor);
752 colval(cvts.r.colors[x],RED) = d;
753 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
754 if (dogamma) d = pow(d, cvts.gamcor);
755 colval(cvts.r.colors[x],GRN) = d;
756 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
757 if (dogamma) d = pow(d, cvts.gamcor);
758 colval(cvts.r.colors[x],BLU) = d;
759 if (CHK(C_CXFM))
760 colortrans(cvts.r.colors[x], cvts.cmat,
761 cvts.r.colors[x]);
762 }
763 if (cvts.bradj) {
764 d = pow(2.,(double)cvts.bradj);
765 for (x = cvts.xmax; x--; )
766 scalecolor(cvts.r.colors[x], d);
767 }
768
769 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
770 quiterr("error writing Radiance picture");
771 }
772
773
774 static void
775 L2Color( /* read/convert/write Lfloat->COLOR scanline */
776 uint32 y
777 )
778 {
779 float m = pow(2., (double)cvts.bradj);
780 int x;
781
782 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
783 quiterr("internal error 1 in L2Color");
784
785 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
786 quiterr("error reading TIFF input");
787 /* also works for float greyscale */
788 for (x = cvts.xmax; x--; ) {
789 float f = cvts.t.fp[x];
790 if (cvts.bradj) f *= m;
791 setcolor(cvts.r.colors[x], f, f, f);
792 }
793 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
794 quiterr("error writing Radiance picture");
795 }
796
797
798 static void
799 RGB2Colr( /* read/convert/write RGB->COLR scanline */
800 uint32 y
801 )
802 {
803 COLOR ctmp;
804 int x;
805
806 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
807 quiterr("internal error 1 in RGB2Colr");
808
809 if (cvts.pconf == PLANARCONFIG_CONTIG) {
810 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
811 goto readerr;
812 for (x = cvts.xmax; x--; ) {
813 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
814 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
815 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
816 }
817 } else {
818 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
819 goto readerr;
820 if (TIFFReadScanline(cvts.tif,
821 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
822 goto readerr;
823 if (TIFFReadScanline(cvts.tif,
824 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
825 goto readerr;
826 for (x = cvts.xmax; x--; ) {
827 cvts.r.colrs[x][RED] = cvts.t.bp[x];
828 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
829 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
830 }
831 }
832
833 gambs_colrs(cvts.r.colrs, cvts.xmax);
834 if (CHK(C_CXFM))
835 for (x = cvts.xmax; x--; ) {
836 colr_color(ctmp, cvts.r.colrs[x]);
837 colortrans(ctmp, cvts.cmat, ctmp);
838 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
839 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
840 cblack, cwhite);
841 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
842 colval(ctmp,GRN), colval(ctmp,BLU));
843 }
844 if (cvts.bradj)
845 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
846
847 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
848 quiterr("error writing Radiance picture");
849 return;
850 readerr:
851 quiterr("error reading TIFF input");
852 }
853
854
855 static void
856 Gry2Colr( /* read/convert/write G8->COLR scanline */
857 uint32 y
858 )
859 {
860 int x;
861
862 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
863 quiterr("internal error 1 in Gry2Colr");
864
865 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
866 quiterr("error reading TIFF input");
867
868 for (x = cvts.xmax; x--; )
869 cvts.r.colrs[x][RED] =
870 cvts.r.colrs[x][GRN] =
871 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
872
873 gambs_colrs(cvts.r.colrs, cvts.xmax);
874 if (cvts.bradj)
875 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
876
877 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
878 quiterr("error writing Radiance picture");
879 }
880
881
882 static void
883 GGry2Color( /* read/convert/write G16->COLOR scanline */
884 uint32 y
885 )
886 {
887 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
888 double m;
889 double d;
890 int x;
891
892 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
893 quiterr("internal error 1 in GGry2Color");
894
895 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
896 quiterr("error reading TIFF input");
897
898 if (cvts.bradj)
899 m = pow(2., (double)cvts.bradj);
900 for (x = cvts.xmax; x--; ) {
901 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
902 if (dogamma) d = pow(d, cvts.gamcor);
903 if (cvts.bradj) d *= m;
904 colval(cvts.r.colors[x],RED) =
905 colval(cvts.r.colors[x],GRN) =
906 colval(cvts.r.colors[x],BLU) = d;
907 }
908 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
909 quiterr("error writing Radiance picture");
910 }
911
912
913 static void
914 Color2GGry( /* read/convert/write COLOR->G16 scanline */
915 uint32 y
916 )
917 {
918 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
919 float m = pow(2.,(double)cvts.bradj);
920 int x;
921
922 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
923 quiterr("internal error 1 in Color2GGry");
924
925 ReadRadScan(&cvts);
926
927 for (x = cvts.xmax; x--; ) {
928 float f = m*( CHK(C_XYZE) ?
929 colval(cvts.r.colors[x],CIEY)
930 : bright(cvts.r.colors[x]) );
931 if (f <= 0)
932 cvts.t.wp[x] = 0;
933 else if (f >= 1)
934 cvts.t.wp[x] = 0xffff;
935 else if (dogamma)
936 cvts.t.wp[x] = (int)((float)(1L<<16) *
937 pow(f, 1./cvts.gamcor));
938 else
939 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
940 }
941
942 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
943 quiterr("error writing TIFF output");
944 }
945
946
947 static void
948 Color2L( /* read/convert/write COLOR->Lfloat scanline */
949 uint32 y
950 )
951 {
952 float m = pow(2.,(double)cvts.bradj);
953 int x;
954
955 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
956 quiterr("internal error 1 in Color2L");
957
958 ReadRadScan(&cvts);
959
960 for (x = cvts.xmax; x--; )
961 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
962 : bright(cvts.r.colors[x]) );
963
964 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
965 quiterr("error writing TIFF output");
966 }
967
968
969 static void
970 Color2Luv( /* read/convert/write COLOR->Luv scanline */
971 uint32 y
972 )
973 {
974 int x;
975
976 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
977 quiterr("internal error 1 in Color2Luv");
978
979 ReadRadScan(&cvts);
980
981 if (CHK(C_CXFM))
982 for (x = cvts.xmax; x--; )
983 colortrans(cvts.r.colors[x], cvts.cmat,
984 cvts.r.colors[x]);
985 if (cvts.bradj) {
986 double m = pow(2.,(double)cvts.bradj);
987 for (x = cvts.xmax; x--; )
988 scalecolor(cvts.r.colors[x], m);
989 }
990 /* also works for float RGB */
991 for (x = cvts.xmax; x--; ) {
992 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
993 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
994 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
995 }
996
997 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
998 quiterr("error writing TIFF output");
999 }
1000
1001
1002 static void
1003 Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
1004 uint32 y
1005 )
1006 {
1007 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
1008 float m = pow(2.,(double)cvts.bradj);
1009 int x, i;
1010
1011 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
1012 quiterr("internal error 1 in Color2RRGGBB");
1013
1014 ReadRadScan(&cvts);
1015
1016 for (x = cvts.xmax; x--; ) {
1017 if (CHK(C_CXFM)) {
1018 colortrans(cvts.r.colors[x], cvts.cmat,
1019 cvts.r.colors[x]);
1020 if (CHK(C_GAMUT))
1021 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
1022 CGAMUT_LOWER, cblack, cwhite);
1023 }
1024 for (i = 3; i--; ) {
1025 float f = m*colval(cvts.r.colors[x],i);
1026 if (f <= 0)
1027 cvts.t.wp[3*x + i] = 0;
1028 else if (f >= 1)
1029 cvts.t.wp[3*x + i] = 0xffff;
1030 else if (dogamma)
1031 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
1032 pow(f, 1./cvts.gamcor));
1033 else
1034 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
1035 }
1036 }
1037
1038 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1039 quiterr("error writing TIFF output");
1040 }
1041
1042
1043 static void
1044 Colr2Gry( /* read/convert/write COLR->RGB scanline */
1045 uint32 y
1046 )
1047 {
1048 int x;
1049
1050 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1051 quiterr("internal error 1 in Colr2Gry");
1052
1053 if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp,
1054 cvts.ncc, cvts.wpt) < 0)
1055 quiterr("error reading Radiance picture");
1056
1057 if (cvts.bradj)
1058 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1059 for (x = cvts.xmax; x--; )
1060 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1061 colrs_gambs(cvts.r.colrs, cvts.xmax);
1062
1063 for (x = cvts.xmax; x--; )
1064 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1065
1066 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1067 quiterr("error writing TIFF output");
1068 }
1069
1070
1071 static void
1072 Colr2RGB( /* read/convert/write COLR->RGB scanline */
1073 uint32 y
1074 )
1075 {
1076 COLOR ctmp;
1077 int x;
1078
1079 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1080 quiterr("internal error 1 in Colr2RGB");
1081
1082 if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp,
1083 cvts.ncc, cvts.wpt) < 0)
1084 quiterr("error reading Radiance picture");
1085
1086 if (cvts.bradj)
1087 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1088 if (CHK(C_CXFM))
1089 for (x = cvts.xmax; x--; ) {
1090 colr_color(ctmp, cvts.r.colrs[x]);
1091 colortrans(ctmp, cvts.cmat, ctmp);
1092 if (CHK(C_GAMUT))
1093 clipgamut(ctmp, bright(ctmp), CGAMUT,
1094 cblack, cwhite);
1095 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1096 colval(ctmp,GRN), colval(ctmp,BLU));
1097 }
1098 colrs_gambs(cvts.r.colrs, cvts.xmax);
1099
1100 for (x = cvts.xmax; x--; ) {
1101 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1102 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1103 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1104 }
1105
1106 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1107 quiterr("error writing TIFF output");
1108 }
