root/radiance/ray/src/px/ra_tiff.c
Revision: 2.38
Committed: Fri Oct 4 19:15:19 2024 UTC (8 months, 3 weeks ago) by greg
fix(ra_tiff): fixed logic for color matrix on spectral input
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.37 2024/10/04 18:49:06 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <math.h>
11 #include <ctype.h>
12
13 #include "rtio.h"
14 #include "platform.h"
15 #include "tiffio.h"
16 #include "color.h"
17 #include "resolu.h"
18
19 #define GAMCOR 2.2 /* default gamma */
20
21 /* conversion flags */
22 #define C_CXFM 0x1 /* needs color transformation */
23 #define C_GAMUT 0x2 /* needs gamut mapping */
24 #define C_GAMMA 0x4 /* needs gamma correction */
25 #define C_GRY 0x8 /* TIFF is greyscale */
26 #define C_XYZE 0x10 /* Radiance is XYZE */
27 #define C_SPEC 0x20 /* Radiance is spectral */
28 #define C_RFLT 0x40 /* Radiance data is float */
29 #define C_TFLT 0x80 /* TIFF data is float */
30 #define C_TWRD 0x100 /* TIFF data is 16-bit */
31 #define C_PRIM 0x200 /* has assigned primaries */
32
33 typedef void colcvf_t(uint32 y);
34
35 struct CONVST {
36 uint16 flags; /* conversion flags (defined above) */
37 char capdate[20]; /* capture date/time */
38 char owner[256]; /* content owner */
39 uint16 comp; /* TIFF compression type */
40 uint16 phot; /* TIFF photometric type */
41 uint16 pconf; /* TIFF planar configuration */
42 float gamcor; /* gamma correction value */
43 short bradj; /* Radiance exposure adjustment (stops) */
44 uint16 orient; /* visual orientation (TIFF spec.) */
45 double stonits; /* input conversion to nits */
46 float pixrat; /* pixel aspect ratio */
47 int ncc; /* # color components for spectral */
48 float wpt[4]; /* wavelength partitions */
49 FILE *rfp; /* Radiance stream pointer */
50 TIFF *tif; /* TIFF pointer */
51 uint32 xmax, ymax; /* image dimensions */
52 COLORMAT cmat; /* color transformation matrix */
53 RGBPRIMS prims; /* RGB primaries */
54 union {
55 COLR *colrs; /* 4-byte ???E pointer */
56 COLOR *colors; /* float array pointer */
57 void *p; /* generic pointer */
58 } r; /* Radiance scanline */
59 union {
60 uint8 *bp; /* byte pointer */
61 uint16 *wp; /* word pointer */
62 float *fp; /* float pointer */
63 void *p; /* generic pointer */
64 } t; /* TIFF scanline */
65 colcvf_t *tf; /* translation procedure */
66 } cvts = { /* conversion structure */
67 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
68 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1., 3,
69 };
70
71 #define CHK(f) (cvts.flags & (f))
72 #define SET(f) (cvts.flags |= (f))
73 #define CLR(f) (cvts.flags &= ~(f))
74 #define TGL(f) (cvts.flags ^= (f))
75
76 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
77 static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
78 static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
79
80 static gethfunc headline;
81 static void quiterr(char *err);
82 static void allocbufs(void);
83 static void initfromtif(void);
84 static void tiff2ra(int ac, char *av[]);
85 static void initfromrad(void);
86 static void ra2tiff(int ac, char *av[]);
87 static void ReadRadScan(struct CONVST *cvp);
88
89
90 #define RfGfBf2Color Luv2Color
91 #define Gryf2Color L2Color
92 #define Color2Gryf Color2L
93 #define Color2RfGfBf Color2Luv
94
95 short ortab[8] = { /* orientation conversion table */
96 YMAJOR|YDECR,
97 YMAJOR|YDECR|XDECR,
98 YMAJOR|XDECR,
99 YMAJOR,
100 YDECR,
101 XDECR|YDECR,
102 XDECR,
103 0
104 };
105
106 #define pixorder() ortab[cvts.orient-1]
107
108 extern char TMSTR[]; /* "CAPDATE=" from header.c */
109 char OWNSTR[] = "OWNER=";
110
111 char *progname;
112
113
114 int
115 main(int argc, char *argv[])
116 {
117 int reverse = 0;
118 int i;
119
120 progname = argv[0];
121
122 for (i = 1; i < argc; i++)
123 if (argv[i][0] == '-')
124 switch (argv[i][1]) {
125 case 'g': /* gamma correction */
126 cvts.gamcor = atof(argv[++i]);
127 break;
128 case 'x': /* XYZE Radiance output */
129 TGL(C_XYZE);
130 break;
131 case 'z': /* LZW compressed output */
132 cvts.comp = COMPRESSION_LZW;
133 break;
134 case 'L': /* LogLuv 32-bit output */
135 cvts.comp = COMPRESSION_SGILOG;
136 cvts.phot = PHOTOMETRIC_LOGLUV;
137 break;
138 case 'l': /* LogLuv 24-bit output */
139 cvts.comp = COMPRESSION_SGILOG24;
140 cvts.phot = PHOTOMETRIC_LOGLUV;
141 break;
142 case 'w': /* 16-bit/primary output? */
143 TGL(C_TWRD);
144 break;
145 case 'f': /* IEEE float output? */
146 TGL(C_TFLT);
147 break;
148 case 'b': /* greyscale output? */
149 TGL(C_GRY);
150 break;
151 case 'e': /* exposure adjustment */
152 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
153 goto userr;
154 cvts.bradj = atoi(argv[++i]);
155 break;
156 case 'r': /* reverse conversion? */
157 reverse = !reverse;
158 break;
159 case '\0':
160 goto doneopts;
161 default:
162 goto userr;
163 }
164 else
165 break;
166 doneopts:
167 if (reverse) {
168
169 if (i != argc-2 && i != argc-1)
170 goto userr;
171
172 tiff2ra(i, argv);
173
174 } else {
175
176 if (i != argc-2)
177 goto userr;
178 /* consistency checks */
179 if (CHK(C_GRY)) {
180 if (cvts.phot == PHOTOMETRIC_RGB)
181 cvts.phot = PHOTOMETRIC_MINISBLACK;
182 else {
183 cvts.phot = PHOTOMETRIC_LOGL;
184 cvts.comp = COMPRESSION_SGILOG;
185 }
186 }
187 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
188 goto userr;
189
190 ra2tiff(i, argv);
191 }
192
193 exit(0);
194 userr:
195 fprintf(stderr,
196 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n",
197 progname);
198 fprintf(stderr,
199 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n",
200 progname);
201 exit(1);
202 }
203
204
205 static void
206 quiterr( /* print message and exit */
207 char *err
208 )
209 {
210 if (err != NULL) {
211 fprintf(stderr, "%s: %s\n", progname, err);
212 exit(1);
213 }
214 exit(0);
215 }
216
217
218 static void
219 allocbufs(void) /* allocate scanline buffers */
220 {
221 int rsiz, tsiz;
222
223 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
224 tsiz = (CHK(C_TFLT) ? sizeof(float) :
225 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
226 (CHK(C_GRY) ? 1 : 3);
227 cvts.r.p = malloc(rsiz*cvts.xmax);
228 cvts.t.p = malloc(tsiz*cvts.xmax);
229 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
230 quiterr("no memory to allocate scanline buffers");
231 }
232
233
234 static void
235 initfromtif(void) /* initialize conversion from TIFF input */
236 {
237 uint16 hi;
238 char *cp;
239 float *fa, f1, f2;
240
241 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
242
243 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
244 cvts.prims[RED][CIEX] = fa[0];
245 cvts.prims[RED][CIEY] = fa[1];
246 cvts.prims[GRN][CIEX] = fa[2];
247 cvts.prims[GRN][CIEY] = fa[3];
248 cvts.prims[BLU][CIEX] = fa[4];
249 cvts.prims[BLU][CIEY] = fa[5];
250 cvts.prims[WHT][CIEX] = 1./3.;
251 cvts.prims[WHT][CIEY] = 1./3.;
252 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
253 cvts.prims[WHT][CIEX] = fa[0];
254 cvts.prims[WHT][CIEY] = fa[1];
255 }
256 SET(C_PRIM);
257 }
258
259 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
260 cvts.comp = COMPRESSION_NONE;
261
262 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
263 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
264 cvts.pixrat = f1/f2;
265
266 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
267
268 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
269 quiterr("TIFF has unspecified photometric type");
270
271 switch (cvts.phot) {
272 case PHOTOMETRIC_LOGLUV:
273 SET(C_RFLT|C_TFLT);
274 if (!CHK(C_XYZE)) {
275 cpcolormat(cvts.cmat, xyz2rgbmat);
276 SET(C_CXFM|C_GAMUT);
277 } else if (cvts.comp == COMPRESSION_SGILOG)
278 SET(C_GAMUT); /* may be outside XYZ gamut */
279 if (cvts.pconf != PLANARCONFIG_CONTIG)
280 quiterr("cannot handle separate Luv planes");
281 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
282 SGILOGDATAFMT_FLOAT);
283 cvts.tf = Luv2Color;
284 break;
285 case PHOTOMETRIC_LOGL:
286 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
287 cvts.pconf = PLANARCONFIG_CONTIG;
288 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
289 SGILOGDATAFMT_FLOAT);
290 cvts.tf = L2Color;
291 break;
292 case PHOTOMETRIC_YCBCR:
293 if (cvts.comp == COMPRESSION_JPEG &&
294 cvts.pconf == PLANARCONFIG_CONTIG) {
295 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
296 JPEGCOLORMODE_RGB);
297 cvts.phot = PHOTOMETRIC_RGB;
298 } else
299 quiterr("unsupported photometric type");
300 /* fall through */
301 case PHOTOMETRIC_RGB:
302 SET(C_GAMMA);
303 setcolrgam(cvts.gamcor);
304 if (CHK(C_XYZE)) {
305 comprgb2xyzWBmat(cvts.cmat,
306 CHK(C_PRIM) ? cvts.prims : stdprims);
307 SET(C_CXFM);
308 }
309 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
310 hi != 3)
311 quiterr("unsupported samples per pixel for RGB");
312 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
313 hi = -1;
314 switch (hi) {
315 case 8:
316 cvts.tf = RGB2Colr;
317 break;
318 case 16:
319 cvts.tf = RRGGBB2Color;
320 SET(C_RFLT|C_TWRD);
321 break;
322 case 32:
323 cvts.tf = RfGfBf2Color;
324 SET(C_RFLT|C_TFLT);
325 break;
326 default:
327 quiterr("unsupported bits per sample for RGB");
328 }
329 break;
330 case PHOTOMETRIC_MINISBLACK:
331 SET(C_GRY|C_GAMMA);
332 setcolrgam(cvts.gamcor);
333 cvts.pconf = PLANARCONFIG_CONTIG;
334 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
335 hi != 1)
336 quiterr("unsupported samples per pixel for greyscale");
337 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
338 hi = -1;
339 switch (hi) {
340 case 8:
341 cvts.tf = Gry2Colr;
342 break;
343 case 16:
344 cvts.tf = GGry2Color;
345 SET(C_RFLT|C_TWRD);
346 break;
347 case 32:
348 cvts.tf = Gryf2Color;
349 SET(C_RFLT|C_TFLT);
350 break;
351 default:
352 quiterr("unsupported bits per sample for Gray");
353 }
354 break;
355 default:
356 quiterr("unsupported photometric type");
357 break;
358 }
359
360 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
361 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
362 quiterr("unknown input image resolution");
363
364 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
365 cvts.stonits = -1.;
366
367 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
368 cvts.capdate[0] = '\0';
369 else {
370 strncpy(cvts.capdate, cp, 19);
371 cvts.capdate[19] = '\0';
372 }
373 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
374 cvts.owner[0] = '\0';
375 else {
376 strncpy(cvts.owner, cp, sizeof(cvts.owner));
377 cvts.owner[sizeof(cvts.owner)-1] = '\0';
378 }
379 /* add to Radiance header */
380 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
381 fputaspect(cvts.pixrat, cvts.rfp);
382 if (CHK(C_XYZE)) {
383 if (cvts.stonits > .0)
384 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
385 fputformat(CIEFMT, cvts.rfp);
386 } else {
387 if (CHK(C_PRIM))
388 fputprims(cvts.prims, cvts.rfp);
389 if (cvts.stonits > .0)
390 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
391 cvts.rfp);
392 fputformat(COLRFMT, cvts.rfp);
393 }
394 if (cvts.capdate[0])
395 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
396 if (cvts.owner[0])
397 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
398
399 allocbufs(); /* allocate scanline buffers */
400 }
401
402
403 static void
404 tiff2ra( /* convert TIFF image to Radiance picture */
405 int ac,
406 char *av[]
407 )
408 {
409 int32 y;
410 /* open TIFF input */
411 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
412 quiterr("cannot open TIFF input");
413 /* open Radiance output */
414 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
415 cvts.rfp = stdout;
416 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
417 quiterr("cannot open Radiance output picture");
418 SET_FILE_BINARY(cvts.rfp);
419 /* start output header */
420 newheader("RADIANCE", cvts.rfp);
421 printargs(ac, av, cvts.rfp);
422
423 initfromtif(); /* initialize conversion */
424
425 fputc('\n', cvts.rfp); /* finish Radiance header */
426 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
427
428 for (y = 0; y < cvts.ymax; y++) /* convert image */
429 (*cvts.tf)(y);
430 /* clean up */
431 fclose(cvts.rfp);
432 TIFFClose(cvts.tif);
433 }
434
435
436 static int
437 headline( /* process Radiance input header line */
438 char *s,
439 void *p
440 )
441 {
442 static int tmstrlen = 0;
443 static int ownstrlen = 0;
444 struct CONVST *cvp = (struct CONVST *)p;
445 char fmt[MAXFMTLEN];
446
447 if (!tmstrlen) {
448 tmstrlen = strlen(TMSTR);
449 ownstrlen = strlen(OWNSTR);
450 }
451 if (formatval(fmt, s)) {
452 CLR(C_XYZE|C_SPEC);
453 if (!strcmp(fmt, CIEFMT))
454 SET(C_XYZE);
455 else if (!strcmp(fmt, SPECFMT))
456 SET(C_SPEC);
457 else if (strcmp(fmt, COLRFMT))
458 return(-1);
459 return(1);
460 }
461 if (isexpos(s)) {
462 cvp->stonits /= exposval(s);
463 return(1);
464 }
465 if (isaspect(s)) {
466 cvp->pixrat *= aspectval(s);
467 return(1);
468 }
469 if (isprims(s)) {
470 primsval(cvp->prims, s);
471 SET(C_PRIM);
472 return(1);
473 }
474 if (isdate(s)) {
475 if (s[tmstrlen] == ' ')
476 strncpy(cvp->capdate, s+tmstrlen+1, 19);
477 else
478 strncpy(cvp->capdate, s+tmstrlen, 19);
479 cvp->capdate[19] = '\0';
480 return(1);
481 }
482 if (!strncmp(s, OWNSTR, ownstrlen)) {
483 char *cp = s + ownstrlen;
484
485 while (isspace(*cp))
486 ++cp;
487 strncpy(cvp->owner, cp, sizeof(cvp->owner));
488 cvp->owner[sizeof(cvp->owner)-1] = '\0';
489 for (cp = cvp->owner; *cp; cp++)
490 ;
491 while (cp > cvp->owner && isspace(cp[-1]))
492 *--cp = '\0';
493 return(1);
494 }
495 if (isncomp(s)) {
496 cvp->ncc = ncompval(s);
497 return((3 <= cvp->ncc) & (cvp->ncc < MAXCSAMP) ? 1 : -1);
498 }
499 if (iswlsplit(s))
500 return(wlsplitval(cvp->wpt, s) ? 1 : -1);
501 return(0);
502 }
503
504
505 static void
506 initfromrad(void) /* initialize input from a Radiance picture */
507 {
508 int i1, i2, po;
509 /* read Radiance header */
510 memcpy(cvts.wpt, WLPART, sizeof(cvts.wpt));
511 if (getheader(cvts.rfp, headline, &cvts) < 0 ||
512 (po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
513 quiterr("bad Radiance picture");
514 cvts.xmax = i1; cvts.ymax = i2;
515 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
516 if (ortab[i1] == po) {
517 cvts.orient = i1 + 1;
518 break;
519 }
520 if (i1 >= 8)
521 quiterr("internal error 1 in initfromrad");
522 if (!(po & YMAJOR))
523 cvts.pixrat = 1./cvts.pixrat;
524 if (!CHK(C_XYZE))
525 cvts.stonits *= WHTEFFICACY;
526 /* set up conversion */
527 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
528 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
529
530 switch (cvts.phot) {
531 case PHOTOMETRIC_LOGLUV:
532 SET(C_RFLT|C_TFLT);
533 CLR(C_GRY|C_TWRD);
534 if (!CHK(C_XYZE|C_SPEC)) {
535 comprgb2xyzWBmat(cvts.cmat,
536 CHK(C_PRIM) ? cvts.prims : stdprims);
537 SET(C_CXFM);
538 }
539 if (cvts.comp != COMPRESSION_SGILOG &&
540 cvts.comp != COMPRESSION_SGILOG24)
541 quiterr("internal error 2 in initfromrad");
542 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
543 SGILOGDATAFMT_FLOAT);
544 cvts.tf = Color2Luv;
545 break;
546 case PHOTOMETRIC_LOGL:
547 SET(C_GRY|C_RFLT|C_TFLT);
548 CLR(C_TWRD);
549 if (cvts.comp != COMPRESSION_SGILOG)
550 quiterr("internal error 3 in initfromrad");
551 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
552 SGILOGDATAFMT_FLOAT);
553 cvts.tf = Color2L;
554 break;
555 case PHOTOMETRIC_RGB:
556 SET(C_GAMMA|C_GAMUT);
557 CLR(C_GRY);
558 setcolrgam(cvts.gamcor);
559 if (CHK(C_TWRD|C_TFLT) ? CHK(C_XYZE|C_SPEC) : CHK(C_XYZE)) {
560 compxyz2rgbWBmat(cvts.cmat,
561 CHK(C_PRIM) ? cvts.prims : stdprims);
562 SET(C_CXFM);
563 }
564 if (CHK(C_PRIM)) {
565 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
566 (float *)cvts.prims);
567 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
568 (float *)cvts.prims[WHT]);
569 }
570 if (CHK(C_TWRD)) {
571 cvts.tf = Color2RRGGBB;
572 SET(C_RFLT);
573 } else if (CHK(C_TFLT)) {
574 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
575 SAMPLEFORMAT_IEEEFP);
576 cvts.tf = Color2RfGfBf;
577 SET(C_RFLT);
578 CLR(C_GAMUT);
579 } else
580 cvts.tf = Colr2RGB;
581 break;
582 case PHOTOMETRIC_MINISBLACK:
583 SET(C_GRY|C_GAMMA|C_GAMUT);
584 setcolrgam(cvts.gamcor);
585 if (CHK(C_TWRD)) {
586 cvts.tf = Color2GGry;
587 SET(C_RFLT);
588 } else if (CHK(C_TFLT)) {
589 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
590 SAMPLEFORMAT_IEEEFP);
591 cvts.tf = Color2Gryf;
592 SET(C_RFLT);
593 } else
594 cvts.tf = Colr2Gry;
595 break;
596 default:
597 quiterr("internal error 4 in initfromrad");
598 break;
599 }
600 /* set other TIFF fields */
601 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
602 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
603 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
604 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
605 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
606 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
607 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
608 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
609 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
610 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
611 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
612 cvts.stonits/pow(2.,(double)cvts.bradj));
613 if (cvts.capdate[0])
614 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
615 if (cvts.owner[0])
616 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
617 if (cvts.comp == COMPRESSION_NONE)
618 i1 = TIFFScanlineSize(cvts.tif);
619 else
620 i1 = 3*cvts.xmax; /* conservative guess */
621 i2 = 8192/i1; /* compute good strip size */
622 if (i2 < 1) i2 = 1;
623 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
624
625 allocbufs(); /* allocate scanline buffers */
626 }
627
628
629 static void
630 ra2tiff( /* convert Radiance picture to TIFF image */
631 int ac,
632 char *av[]
633 )
634 {
635 uint32 y;
636 /* open Radiance file */
637 if (!strcmp(av[ac], "-"))
638 cvts.rfp = stdin;
639 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
640 quiterr("cannot open Radiance input picture");
641 SET_FILE_BINARY(cvts.rfp);
642 /* open TIFF file */
643 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
644 quiterr("cannot open TIFF output");
645
646 initfromrad(); /* initialize conversion */
647
648 for (y = 0; y < cvts.ymax; y++) /* convert image */
649 (*cvts.tf)(y);
650 /* clean up */
651 TIFFClose(cvts.tif);
652 fclose(cvts.rfp);
653 }
654
655
656 static void
657 ReadRadScan(struct CONVST *cvp)
658 {
659 static struct CONVST *lastcvp = NULL;
660 static COLOR scomp[MAXCSAMP];
661
662 if (cvp->ncc > 3) { /* convert spectral pixels */
663 SCOLR sclr;
664 SCOLOR scol;
665 COLOR xyz;
666 int x, n;
667 if (lastcvp != cvp) {
668 for (n = cvp->ncc; n--; )
669 spec_cie(scomp[n],
670 cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*(n+1)/cvp->ncc,
671 cvp->wpt[0] + (cvp->wpt[3] - cvp->wpt[0])*n/cvp->ncc);
672 lastcvp = cvp;
673 }
674 for (x = 0; x < cvp->xmax; x++) {
675 if (getbinary(sclr, cvp->ncc+1, 1, cvp->rfp) != 1)
676 goto readerr;
677 scolr2scolor(scol, sclr, cvp->ncc);
678 setcolor(cvp->r.colors[x], 0, 0, 0);
679 for (n = cvp->ncc; n--; ) {
680 copycolor(xyz, scomp[n]);
681 scalecolor(xyz, scol[n]);
682 addcolor(cvp->r.colors[x], xyz);
683 }
684 }
685 return;
686 }
687 if (freadscan(cvp->r.colors, cvp->xmax, cvp->rfp) >= 0)
688 return;
689 readerr:
690 quiterr("error reading Radiance picture");
691 }
692
693
694 static void
695 Luv2Color( /* read/convert/write Luv->COLOR scanline */
696 uint32 y
697 )
698 {
699 int x;
700
701 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
702 quiterr("internal error 1 in Luv2Color");
703
704 if (cvts.pconf != PLANARCONFIG_CONTIG)
705 quiterr("cannot handle separate 32-bit color planes");
706
707 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
708 quiterr("error reading TIFF input");
709 /* also works for float RGB */
710 for (x = cvts.xmax; x--; ) {
711 setcolor(cvts.r.colors[x],
712 cvts.t.fp[3*x],
713 cvts.t.fp[3*x + 1],
714 cvts.t.fp[3*x + 2]);
715 if (CHK(C_CXFM))
716 colortrans(cvts.r.colors[x], cvts.cmat,
717 cvts.r.colors[x]);
718 if (CHK(C_GAMUT))
719 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
720 CGAMUT_LOWER, cblack, cwhite);
721 }
722 if (cvts.bradj) {
723 double m = pow(2.,(double)cvts.bradj);
724 for (x = cvts.xmax; x--; )
725 scalecolor(cvts.r.colors[x], m);
726 }
727
728 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
729 quiterr("error writing Radiance picture");
730 }
731
732
733 static void
734 RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
735 uint32 y
736 )
737 {
738 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
739 double d;
740 int x;
741
742 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
743 quiterr("internal error 1 in RRGGBB2Color");
744
745 if (cvts.pconf != PLANARCONFIG_CONTIG)
746 quiterr("cannot handle separate 16-bit color planes");
747
748 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
749 quiterr("error reading TIFF input");
750
751 for (x = cvts.xmax; x--; ) {
752 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
753 if (dogamma) d = pow(d, cvts.gamcor);
754 colval(cvts.r.colors[x],RED) = d;
755 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
756 if (dogamma) d = pow(d, cvts.gamcor);
757 colval(cvts.r.colors[x],GRN) = d;
758 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
759 if (dogamma) d = pow(d, cvts.gamcor);
760 colval(cvts.r.colors[x],BLU) = d;
761 if (CHK(C_CXFM))
762 colortrans(cvts.r.colors[x], cvts.cmat,
763 cvts.r.colors[x]);
764 }
765 if (cvts.bradj) {
766 d = pow(2.,(double)cvts.bradj);
767 for (x = cvts.xmax; x--; )
768 scalecolor(cvts.r.colors[x], d);
769 }
770
771 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
772 quiterr("error writing Radiance picture");
773 }
774
775
776 static void
777 L2Color( /* read/convert/write Lfloat->COLOR scanline */
778 uint32 y
779 )
780 {
781 float m = pow(2., (double)cvts.bradj);
782 int x;
783
784 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
785 quiterr("internal error 1 in L2Color");
786
787 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
788 quiterr("error reading TIFF input");
789 /* also works for float greyscale */
790 for (x = cvts.xmax; x--; ) {
791 float f = cvts.t.fp[x];
792 if (cvts.bradj) f *= m;
793 setcolor(cvts.r.colors[x], f, f, f);
794 }
795 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
796 quiterr("error writing Radiance picture");
797 }
798
799
800 static void
801 RGB2Colr( /* read/convert/write RGB->COLR scanline */
802 uint32 y
803 )
804 {
805 COLOR ctmp;
806 int x;
807
808 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
809 quiterr("internal error 1 in RGB2Colr");
810
811 if (cvts.pconf == PLANARCONFIG_CONTIG) {
812 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
813 goto readerr;
814 for (x = cvts.xmax; x--; ) {
815 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
816 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
817 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
818 }
819 } else {
820 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
821 goto readerr;
822 if (TIFFReadScanline(cvts.tif,
823 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
824 goto readerr;
825 if (TIFFReadScanline(cvts.tif,
826 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
827 goto readerr;
828 for (x = cvts.xmax; x--; ) {
829 cvts.r.colrs[x][RED] = cvts.t.bp[x];
830 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
831 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
832 }
833 }
834
835 gambs_colrs(cvts.r.colrs, cvts.xmax);
836 if (CHK(C_CXFM))
837 for (x = cvts.xmax; x--; ) {
838 colr_color(ctmp, cvts.r.colrs[x]);
839 colortrans(ctmp, cvts.cmat, ctmp);
840 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
841 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
842 cblack, cwhite);
843 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
844 colval(ctmp,GRN), colval(ctmp,BLU));
845 }
846 if (cvts.bradj)
847 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
848
849 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
850 quiterr("error writing Radiance picture");
851 return;
852 readerr:
853 quiterr("error reading TIFF input");
854 }
855
856
857 static void
858 Gry2Colr( /* read/convert/write G8->COLR scanline */
859 uint32 y
860 )
861 {
862 int x;
863
864 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
865 quiterr("internal error 1 in Gry2Colr");
866
867 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
868 quiterr("error reading TIFF input");
869
870 for (x = cvts.xmax; x--; )
871 cvts.r.colrs[x][RED] =
872 cvts.r.colrs[x][GRN] =
873 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
874
875 gambs_colrs(cvts.r.colrs, cvts.xmax);
876 if (cvts.bradj)
877 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
878
879 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
880 quiterr("error writing Radiance picture");
881 }
882
883
884 static void
885 GGry2Color( /* read/convert/write G16->COLOR scanline */
886 uint32 y
887 )
888 {
889 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
890 double m;
891 double d;
892 int x;
893
894 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
895 quiterr("internal error 1 in GGry2Color");
896
897 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
898 quiterr("error reading TIFF input");
899
900 if (cvts.bradj)
901 m = pow(2., (double)cvts.bradj);
902 for (x = cvts.xmax; x--; ) {
903 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
904 if (dogamma) d = pow(d, cvts.gamcor);
905 if (cvts.bradj) d *= m;
906 colval(cvts.r.colors[x],RED) =
907 colval(cvts.r.colors[x],GRN) =
908 colval(cvts.r.colors[x],BLU) = d;
909 }
910 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
911 quiterr("error writing Radiance picture");
912 }
913
914
915 static void
916 Color2GGry( /* read/convert/write COLOR->G16 scanline */
917 uint32 y
918 )
919 {
920 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
921 float m = pow(2.,(double)cvts.bradj);
922 int x;
923
924 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
925 quiterr("internal error 1 in Color2GGry");
926
927 ReadRadScan(&cvts);
928
929 for (x = cvts.xmax; x--; ) {
930 float f = m*( CHK(C_XYZE) ?
931 colval(cvts.r.colors[x],CIEY)
932 : bright(cvts.r.colors[x]) );
933 if (f <= 0)
934 cvts.t.wp[x] = 0;
935 else if (f >= 1)
936 cvts.t.wp[x] = 0xffff;
937 else if (dogamma)
938 cvts.t.wp[x] = (int)((float)(1L<<16) *
939 pow(f, 1./cvts.gamcor));
940 else
941 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
942 }
943
944 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
945 quiterr("error writing TIFF output");
946 }
947
948
949 static void
950 Color2L( /* read/convert/write COLOR->Lfloat scanline */
951 uint32 y
952 )
953 {
954 float m = pow(2.,(double)cvts.bradj);
955 int x;
956
957 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
958 quiterr("internal error 1 in Color2L");
959
960 ReadRadScan(&cvts);
961
962 for (x = cvts.xmax; x--; )
963 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
964 : bright(cvts.r.colors[x]) );
965
966 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
967 quiterr("error writing TIFF output");
968 }
969
970
971 static void
972 Color2Luv( /* read/convert/write COLOR->Luv scanline */
973 uint32 y
974 )
975 {
976 int x;
977
978 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
979 quiterr("internal error 1 in Color2Luv");
980
981 ReadRadScan(&cvts);
982
983 if (CHK(C_CXFM))
984 for (x = cvts.xmax; x--; )
985 colortrans(cvts.r.colors[x], cvts.cmat,
986 cvts.r.colors[x]);
987 if (cvts.bradj) {
988 double m = pow(2.,(double)cvts.bradj);
989 for (x = cvts.xmax; x--; )
990 scalecolor(cvts.r.colors[x], m);
991 }
992 /* also works for float RGB */
993 for (x = cvts.xmax; x--; ) {
994 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
995 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
996 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
997 }
998
999 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1000 quiterr("error writing TIFF output");
1001 }
1002
1003
1004 static void
1005 Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
1006 uint32 y
1007 )
1008 {
1009 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
1010 float m = pow(2.,(double)cvts.bradj);
1011 int x, i;
1012
1013 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
1014 quiterr("internal error 1 in Color2RRGGBB");
1015
1016 ReadRadScan(&cvts);
1017
1018 for (x = cvts.xmax; x--; ) {
1019 if (CHK(C_CXFM)) {
1020 colortrans(cvts.r.colors[x], cvts.cmat,
1021 cvts.r.colors[x]);
1022 if (CHK(C_GAMUT))
1023 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
1024 CGAMUT_LOWER, cblack, cwhite);
1025 }
1026 for (i = 3; i--; ) {
1027 float f = m*colval(cvts.r.colors[x],i);
1028 if (f <= 0)
1029 cvts.t.wp[3*x + i] = 0;
1030 else if (f >= 1)
1031 cvts.t.wp[3*x + i] = 0xffff;
1032 else if (dogamma)
1033 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
1034 pow(f, 1./cvts.gamcor));
1035 else
1036 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
1037 }
1038 }
1039
1040 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1041 quiterr("error writing TIFF output");
1042 }
1043
1044
1045 static void
1046 Colr2Gry( /* read/convert/write COLR->RGB scanline */
1047 uint32 y
1048 )
1049 {
1050 int x;
1051
1052 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1053 quiterr("internal error 1 in Colr2Gry");
1054
1055 if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp,
1056 cvts.ncc, cvts.wpt) < 0)
1057 quiterr("error reading Radiance picture");
1058
1059 if (cvts.bradj)
1060 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1061 for (x = cvts.xmax; x--; )
1062 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1063 colrs_gambs(cvts.r.colrs, cvts.xmax);
1064
1065 for (x = cvts.xmax; x--; )
1066 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1067
1068 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1069 quiterr("error writing TIFF output");
1070 }
1071
1072
1073 static void
1074 Colr2RGB( /* read/convert/write COLR->RGB scanline */
1075 uint32 y
1076 )
1077 {
1078 COLOR ctmp;
1079 int x;
1080
1081 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1082 quiterr("internal error 1 in Colr2RGB");
1083
1084 if (fread2colrs(cvts.r.colrs, cvts.xmax, cvts.rfp,
1085 cvts.ncc, cvts.wpt) < 0)
1086 quiterr("error reading Radiance picture");
1087
1088 if (cvts.bradj)
1089 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1090 if (CHK(C_CXFM))
1091 for (x = cvts.xmax; x--; ) {
1092 colr_color(ctmp, cvts.r.colrs[x]);
1093 colortrans(ctmp, cvts.cmat, ctmp);
1094 if (CHK(C_GAMUT))
1095 clipgamut(ctmp, bright(ctmp), CGAMUT,
1096 cblack, cwhite);
1097 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1098 colval(ctmp,GRN), colval(ctmp,BLU));
1099 }
1100 colrs_gambs(cvts.r.colrs, cvts.xmax);
1101
1102 for (x = cvts.xmax; x--; ) {
1103 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1104 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1105 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1106 }
1107
1108 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1109 quiterr("error writing TIFF output");
1110 }
