root/radiance/ray/src/px/ra_tiff.c
Revision: 2.36
Committed: Fri Jul 19 17:37:56 2019 UTC (6 years ago) by greg
CVS Tags: rad5R4, rad5R3
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.35 2018/08/02 18:33:47 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <math.h>
11 #include <ctype.h>
12
13 #include "rtio.h"
14 #include "platform.h"
15 #include "tiffio.h"
16 #include "color.h"
17 #include "resolu.h"
18
19 #define GAMCOR 2.2 /* default gamma */
20
21 /* conversion flags */
22 #define C_CXFM 0x1 /* needs color transformation */
23 #define C_GAMUT 0x2 /* needs gamut mapping */
24 #define C_GAMMA 0x4 /* needs gamma correction */
25 #define C_GRY 0x8 /* TIFF is greyscale */
26 #define C_XYZE 0x10 /* Radiance is XYZE */
27 #define C_RFLT 0x20 /* Radiance data is float */
28 #define C_TFLT 0x40 /* TIFF data is float */
29 #define C_TWRD 0x80 /* TIFF data is 16-bit */
30 #define C_PRIM 0x100 /* has assigned primaries */
31
32 typedef void colcvf_t(uint32 y);
33
34 struct {
35 uint16 flags; /* conversion flags (defined above) */
36 char capdate[20]; /* capture date/time */
37 char owner[256]; /* content owner */
38 uint16 comp; /* TIFF compression type */
39 uint16 phot; /* TIFF photometric type */
40 uint16 pconf; /* TIFF planar configuration */
41 float gamcor; /* gamma correction value */
42 short bradj; /* Radiance exposure adjustment (stops) */
43 uint16 orient; /* visual orientation (TIFF spec.) */
44 double stonits; /* input conversion to nits */
45 float pixrat; /* pixel aspect ratio */
46 FILE *rfp; /* Radiance stream pointer */
47 TIFF *tif; /* TIFF pointer */
48 uint32 xmax, ymax; /* image dimensions */
49 COLORMAT cmat; /* color transformation matrix */
50 RGBPRIMS prims; /* RGB primaries */
51 union {
52 COLR *colrs; /* 4-byte ???E pointer */
53 COLOR *colors; /* float array pointer */
54 char *p; /* generic pointer */
55 } r; /* Radiance scanline */
56 union {
57 uint8 *bp; /* byte pointer */
58 uint16 *wp; /* word pointer */
59 float *fp; /* float pointer */
60 char *p; /* generic pointer */
61 } t; /* TIFF scanline */
62 colcvf_t *tf; /* translation procedure */
63 } cvts = { /* conversion structure */
64 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
65 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
66 };
67
68 #define CHK(f) (cvts.flags & (f))
69 #define SET(f) (cvts.flags |= (f))
70 #define CLR(f) (cvts.flags &= ~(f))
71 #define TGL(f) (cvts.flags ^= (f))
72
73 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
74 static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
75 static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
76
77 static gethfunc headline;
78 static void quiterr(char *err);
79 static void allocbufs(void);
80 static void initfromtif(void);
81 static void tiff2ra(int ac, char *av[]);
82 static void initfromrad(void);
83 static void ra2tiff(int ac, char *av[]);
84
85
86
87 #define RfGfBf2Color Luv2Color
88 #define Gryf2Color L2Color
89 #define Color2Gryf Color2L
90 #define Color2RfGfBf Color2Luv
91
92 short ortab[8] = { /* orientation conversion table */
93 YMAJOR|YDECR,
94 YMAJOR|YDECR|XDECR,
95 YMAJOR|XDECR,
96 YMAJOR,
97 YDECR,
98 XDECR|YDECR,
99 XDECR,
100 0
101 };
102
103 #define pixorder() ortab[cvts.orient-1]
104
105 extern char TMSTR[]; /* "CAPDATE=" from header.c */
106 char OWNSTR[] = "OWNER=";
107
108 char *progname;
109
110
111 int
112 main(int argc, char *argv[])
113 {
114 int reverse = 0;
115 int i;
116
117 progname = argv[0];
118
119 for (i = 1; i < argc; i++)
120 if (argv[i][0] == '-')
121 switch (argv[i][1]) {
122 case 'g': /* gamma correction */
123 cvts.gamcor = atof(argv[++i]);
124 break;
125 case 'x': /* XYZE Radiance output */
126 TGL(C_XYZE);
127 break;
128 case 'z': /* LZW compressed output */
129 cvts.comp = COMPRESSION_LZW;
130 break;
131 case 'L': /* LogLuv 32-bit output */
132 cvts.comp = COMPRESSION_SGILOG;
133 cvts.phot = PHOTOMETRIC_LOGLUV;
134 break;
135 case 'l': /* LogLuv 24-bit output */
136 cvts.comp = COMPRESSION_SGILOG24;
137 cvts.phot = PHOTOMETRIC_LOGLUV;
138 break;
139 case 'w': /* 16-bit/primary output? */
140 TGL(C_TWRD);
141 break;
142 case 'f': /* IEEE float output? */
143 TGL(C_TFLT);
144 break;
145 case 'b': /* greyscale output? */
146 TGL(C_GRY);
147 break;
148 case 'e': /* exposure adjustment */
149 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
150 goto userr;
151 cvts.bradj = atoi(argv[++i]);
152 break;
153 case 'r': /* reverse conversion? */
154 reverse = !reverse;
155 break;
156 case '\0':
157 goto doneopts;
158 default:
159 goto userr;
160 }
161 else
162 break;
163 doneopts:
164 if (reverse) {
165
166 if (i != argc-2 && i != argc-1)
167 goto userr;
168
169 tiff2ra(i, argv);
170
171 } else {
172
173 if (i != argc-2)
174 goto userr;
175 /* consistency checks */
176 if (CHK(C_GRY)) {
177 if (cvts.phot == PHOTOMETRIC_RGB)
178 cvts.phot = PHOTOMETRIC_MINISBLACK;
179 else {
180 cvts.phot = PHOTOMETRIC_LOGL;
181 cvts.comp = COMPRESSION_SGILOG;
182 }
183 }
184 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
185 goto userr;
186
187 ra2tiff(i, argv);
188 }
189
190 exit(0);
191 userr:
192 fprintf(stderr,
193 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n",
194 progname);
195 fprintf(stderr,
196 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n",
197 progname);
198 exit(1);
199 }
200
201
202 static void
203 quiterr( /* print message and exit */
204 char *err
205 )
206 {
207 if (err != NULL) {
208 fprintf(stderr, "%s: %s\n", progname, err);
209 exit(1);
210 }
211 exit(0);
212 }
213
214
215 static void
216 allocbufs(void) /* allocate scanline buffers */
217 {
218 int rsiz, tsiz;
219
220 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
221 tsiz = (CHK(C_TFLT) ? sizeof(float) :
222 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
223 (CHK(C_GRY) ? 1 : 3);
224 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
225 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
226 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
227 quiterr("no memory to allocate scanline buffers");
228 }
229
230
231 static void
232 initfromtif(void) /* initialize conversion from TIFF input */
233 {
234 uint16 hi;
235 char *cp;
236 float *fa, f1, f2;
237
238 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
239
240 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
241
242 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
243 cvts.prims[RED][CIEX] = fa[0];
244 cvts.prims[RED][CIEY] = fa[1];
245 cvts.prims[GRN][CIEX] = fa[2];
246 cvts.prims[GRN][CIEY] = fa[3];
247 cvts.prims[BLU][CIEX] = fa[4];
248 cvts.prims[BLU][CIEY] = fa[5];
249 cvts.prims[WHT][CIEX] = 1./3.;
250 cvts.prims[WHT][CIEY] = 1./3.;
251 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
252 cvts.prims[WHT][CIEX] = fa[0];
253 cvts.prims[WHT][CIEY] = fa[1];
254 }
255 SET(C_PRIM);
256 }
257
258 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
259 cvts.comp = COMPRESSION_NONE;
260
261 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
262 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
263 cvts.pixrat = f1/f2;
264
265 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
266
267 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
268 quiterr("TIFF has unspecified photometric type");
269
270 switch (cvts.phot) {
271 case PHOTOMETRIC_LOGLUV:
272 SET(C_RFLT|C_TFLT);
273 if (!CHK(C_XYZE)) {
274 cpcolormat(cvts.cmat, xyz2rgbmat);
275 SET(C_CXFM|C_GAMUT);
276 } else if (cvts.comp == COMPRESSION_SGILOG)
277 SET(C_GAMUT); /* may be outside XYZ gamut */
278 if (cvts.pconf != PLANARCONFIG_CONTIG)
279 quiterr("cannot handle separate Luv planes");
280 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
281 SGILOGDATAFMT_FLOAT);
282 cvts.tf = Luv2Color;
283 break;
284 case PHOTOMETRIC_LOGL:
285 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
286 cvts.pconf = PLANARCONFIG_CONTIG;
287 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
288 SGILOGDATAFMT_FLOAT);
289 cvts.tf = L2Color;
290 break;
291 case PHOTOMETRIC_YCBCR:
292 if (cvts.comp == COMPRESSION_JPEG &&
293 cvts.pconf == PLANARCONFIG_CONTIG) {
294 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
295 JPEGCOLORMODE_RGB);
296 cvts.phot = PHOTOMETRIC_RGB;
297 } else
298 quiterr("unsupported photometric type");
299 /* fall through */
300 case PHOTOMETRIC_RGB:
301 SET(C_GAMMA);
302 setcolrgam(cvts.gamcor);
303 if (CHK(C_XYZE)) {
304 comprgb2xyzWBmat(cvts.cmat,
305 CHK(C_PRIM) ? cvts.prims : stdprims);
306 SET(C_CXFM);
307 }
308 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
309 hi != 3)
310 quiterr("unsupported samples per pixel for RGB");
311 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
312 hi = -1;
313 switch (hi) {
314 case 8:
315 cvts.tf = RGB2Colr;
316 break;
317 case 16:
318 cvts.tf = RRGGBB2Color;
319 SET(C_RFLT|C_TWRD);
320 break;
321 case 32:
322 cvts.tf = RfGfBf2Color;
323 SET(C_RFLT|C_TFLT);
324 break;
325 default:
326 quiterr("unsupported bits per sample for RGB");
327 }
328 break;
329 case PHOTOMETRIC_MINISBLACK:
330 SET(C_GRY|C_GAMMA);
331 setcolrgam(cvts.gamcor);
332 cvts.pconf = PLANARCONFIG_CONTIG;
333 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
334 hi != 1)
335 quiterr("unsupported samples per pixel for greyscale");
336 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
337 hi = -1;
338 switch (hi) {
339 case 8:
340 cvts.tf = Gry2Colr;
341 break;
342 case 16:
343 cvts.tf = GGry2Color;
344 SET(C_RFLT|C_TWRD);
345 break;
346 case 32:
347 cvts.tf = Gryf2Color;
348 SET(C_RFLT|C_TFLT);
349 break;
350 default:
351 quiterr("unsupported bits per sample for Gray");
352 }
353 break;
354 default:
355 quiterr("unsupported photometric type");
356 break;
357 }
358
359 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
360 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
361 quiterr("unknown input image resolution");
362
363 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
364 cvts.stonits = -1.;
365
366 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
367 cvts.capdate[0] = '\0';
368 else {
369 strncpy(cvts.capdate, cp, 19);
370 cvts.capdate[19] = '\0';
371 }
372 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
373 cvts.owner[0] = '\0';
374 else {
375 strncpy(cvts.owner, cp, sizeof(cvts.owner));
376 cvts.owner[sizeof(cvts.owner)-1] = '\0';
377 }
378 /* add to Radiance header */
379 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
380 fputaspect(cvts.pixrat, cvts.rfp);
381 if (CHK(C_XYZE)) {
382 if (cvts.stonits > .0)
383 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
384 fputformat(CIEFMT, cvts.rfp);
385 } else {
386 if (CHK(C_PRIM))
387 fputprims(cvts.prims, cvts.rfp);
388 if (cvts.stonits > .0)
389 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
390 cvts.rfp);
391 fputformat(COLRFMT, cvts.rfp);
392 }
393 if (cvts.capdate[0])
394 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
395 if (cvts.owner[0])
396 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
397
398 allocbufs(); /* allocate scanline buffers */
399 }
400
401
402 static void
403 tiff2ra( /* convert TIFF image to Radiance picture */
404 int ac,
405 char *av[]
406 )
407 {
408 int32 y;
409 /* open TIFF input */
410 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
411 quiterr("cannot open TIFF input");
412 /* open Radiance output */
413 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
414 cvts.rfp = stdout;
415 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
416 quiterr("cannot open Radiance output picture");
417 SET_FILE_BINARY(cvts.rfp);
418 /* start output header */
419 newheader("RADIANCE", cvts.rfp);
420 printargs(ac, av, cvts.rfp);
421
422 initfromtif(); /* initialize conversion */
423
424 fputc('\n', cvts.rfp); /* finish Radiance header */
425 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
426
427 for (y = 0; y < cvts.ymax; y++) /* convert image */
428 (*cvts.tf)(y);
429 /* clean up */
430 fclose(cvts.rfp);
431 TIFFClose(cvts.tif);
432 }
433
434
435 static int
436 headline( /* process Radiance input header line */
437 char *s,
438 void *p
439 )
440 {
441 static int tmstrlen = 0;
442 static int ownstrlen = 0;
443 char fmt[MAXFMTLEN];
444
445 if (!tmstrlen)
446 tmstrlen = strlen(TMSTR);
447 if (!ownstrlen)
448 ownstrlen = strlen(OWNSTR);
449 if (formatval(fmt, s)) {
450 if (!strcmp(fmt, COLRFMT))
451 CLR(C_XYZE);
452 else if (!strcmp(fmt, CIEFMT))
453 SET(C_XYZE);
454 else
455 quiterr("unrecognized input picture format");
456 return(1);
457 }
458 if (isexpos(s)) {
459 cvts.stonits /= exposval(s);
460 return(1);
461 }
462 if (isaspect(s)) {
463 cvts.pixrat *= aspectval(s);
464 return(1);
465 }
466 if (isprims(s)) {
467 primsval(cvts.prims, s);
468 SET(C_PRIM);
469 return(1);
470 }
471 if (isdate(s)) {
472 if (s[tmstrlen] == ' ')
473 strncpy(cvts.capdate, s+tmstrlen+1, 19);
474 else
475 strncpy(cvts.capdate, s+tmstrlen, 19);
476 cvts.capdate[19] = '\0';
477 return(1);
478 }
479 if (!strncmp(s, OWNSTR, ownstrlen)) {
480 register char *cp = s + ownstrlen;
481
482 while (isspace(*cp))
483 ++cp;
484 strncpy(cvts.owner, cp, sizeof(cvts.owner));
485 cvts.owner[sizeof(cvts.owner)-1] = '\0';
486 for (cp = cvts.owner; *cp; cp++)
487 ;
488 while (cp > cvts.owner && isspace(cp[-1]))
489 *--cp = '\0';
490 return(1);
491 }
492 return(0);
493 }
494
495
496 static void
497 initfromrad(void) /* initialize input from a Radiance picture */
498 {
499 int i1, i2, po;
500 /* read Radiance header */
501 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
502 cvts.capdate[0] = '\0';
503 cvts.owner[0] = '\0';
504 cvts.stonits = 1.;
505 cvts.pixrat = 1.;
506 cvts.pconf = PLANARCONFIG_CONTIG;
507 getheader(cvts.rfp, headline, NULL);
508 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
509 quiterr("bad Radiance picture");
510 cvts.xmax = i1; cvts.ymax = i2;
511 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
512 if (ortab[i1] == po) {
513 cvts.orient = i1 + 1;
514 break;
515 }
516 if (i1 >= 8)
517 quiterr("internal error 1 in initfromrad");
518 if (!(po & YMAJOR))
519 cvts.pixrat = 1./cvts.pixrat;
520 if (!CHK(C_XYZE))
521 cvts.stonits *= WHTEFFICACY;
522 /* set up conversion */
523 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
524 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
525
526 switch (cvts.phot) {
527 case PHOTOMETRIC_LOGLUV:
528 SET(C_RFLT|C_TFLT);
529 CLR(C_GRY|C_TWRD);
530 if (!CHK(C_XYZE)) {
531 comprgb2xyzWBmat(cvts.cmat,
532 CHK(C_PRIM) ? cvts.prims : stdprims);
533 SET(C_CXFM);
534 }
535 if (cvts.comp != COMPRESSION_SGILOG &&
536 cvts.comp != COMPRESSION_SGILOG24)
537 quiterr("internal error 2 in initfromrad");
538 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
539 SGILOGDATAFMT_FLOAT);
540 cvts.tf = Color2Luv;
541 break;
542 case PHOTOMETRIC_LOGL:
543 SET(C_GRY|C_RFLT|C_TFLT);
544 CLR(C_TWRD);
545 if (cvts.comp != COMPRESSION_SGILOG)
546 quiterr("internal error 3 in initfromrad");
547 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
548 SGILOGDATAFMT_FLOAT);
549 cvts.tf = Color2L;
550 break;
551 case PHOTOMETRIC_RGB:
552 SET(C_GAMMA|C_GAMUT);
553 CLR(C_GRY);
554 setcolrgam(cvts.gamcor);
555 if (CHK(C_XYZE)) {
556 compxyz2rgbWBmat(cvts.cmat,
557 CHK(C_PRIM) ? cvts.prims : stdprims);
558 SET(C_CXFM);
559 }
560 if (CHK(C_PRIM)) {
561 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
562 (float *)cvts.prims);
563 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
564 (float *)cvts.prims[WHT]);
565 }
566 if (CHK(C_TWRD)) {
567 cvts.tf = Color2RRGGBB;
568 SET(C_RFLT);
569 } else if (CHK(C_TFLT)) {
570 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
571 SAMPLEFORMAT_IEEEFP);
572 cvts.tf = Color2RfGfBf;
573 SET(C_RFLT);
574 CLR(C_GAMUT);
575 } else
576 cvts.tf = Colr2RGB;
577 break;
578 case PHOTOMETRIC_MINISBLACK:
579 SET(C_GRY|C_GAMMA|C_GAMUT);
580 setcolrgam(cvts.gamcor);
581 if (CHK(C_TWRD)) {
582 cvts.tf = Color2GGry;
583 SET(C_RFLT);
584 } else if (CHK(C_TFLT)) {
585 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
586 SAMPLEFORMAT_IEEEFP);
587 cvts.tf = Color2Gryf;
588 SET(C_RFLT);
589 } else
590 cvts.tf = Colr2Gry;
591 break;
592 default:
593 quiterr("internal error 4 in initfromrad");
594 break;
595 }
596 /* set other TIFF fields */
597 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
598 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
599 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
600 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
601 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
602 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
603 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
604 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
605 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
606 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
607 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
608 cvts.stonits/pow(2.,(double)cvts.bradj));
609 if (cvts.capdate[0])
610 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
611 if (cvts.owner[0])
612 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
613 if (cvts.comp == COMPRESSION_NONE)
614 i1 = TIFFScanlineSize(cvts.tif);
615 else
616 i1 = 3*cvts.xmax; /* conservative guess */
617 i2 = 8192/i1; /* compute good strip size */
618 if (i2 < 1) i2 = 1;
619 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
620
621 allocbufs(); /* allocate scanline buffers */
622 }
623
624
625 static void
626 ra2tiff( /* convert Radiance picture to TIFF image */
627 int ac,
628 char *av[]
629 )
630 {
631 uint32 y;
632 /* open Radiance file */
633 if (!strcmp(av[ac], "-"))
634 cvts.rfp = stdin;
635 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
636 quiterr("cannot open Radiance input picture");
637 SET_FILE_BINARY(cvts.rfp);
638 /* open TIFF file */
639 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
640 quiterr("cannot open TIFF output");
641
642 initfromrad(); /* initialize conversion */
643
644 for (y = 0; y < cvts.ymax; y++) /* convert image */
645 (*cvts.tf)(y);
646 /* clean up */
647 TIFFClose(cvts.tif);
648 fclose(cvts.rfp);
649 }
650
651
652 static void
653 Luv2Color( /* read/convert/write Luv->COLOR scanline */
654 uint32 y
655 )
656 {
657 register int x;
658
659 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
660 quiterr("internal error 1 in Luv2Color");
661
662 if (cvts.pconf != PLANARCONFIG_CONTIG)
663 quiterr("cannot handle separate 32-bit color planes");
664
665 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
666 quiterr("error reading TIFF input");
667 /* also works for float RGB */
668 for (x = cvts.xmax; x--; ) {
669 setcolor(cvts.r.colors[x],
670 cvts.t.fp[3*x],
671 cvts.t.fp[3*x + 1],
672 cvts.t.fp[3*x + 2]);
673 if (CHK(C_CXFM))
674 colortrans(cvts.r.colors[x], cvts.cmat,
675 cvts.r.colors[x]);
676 if (CHK(C_GAMUT))
677 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
678 CGAMUT_LOWER, cblack, cwhite);
679 }
680 if (cvts.bradj) {
681 double m = pow(2.,(double)cvts.bradj);
682 for (x = cvts.xmax; x--; )
683 scalecolor(cvts.r.colors[x], m);
684 }
685
686 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
687 quiterr("error writing Radiance picture");
688 }
689
690
691 static void
692 RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
693 uint32 y
694 )
695 {
696 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
697 register double d;
698 register int x;
699
700 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
701 quiterr("internal error 1 in RRGGBB2Color");
702
703 if (cvts.pconf != PLANARCONFIG_CONTIG)
704 quiterr("cannot handle separate 16-bit color planes");
705
706 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
707 quiterr("error reading TIFF input");
708
709 for (x = cvts.xmax; x--; ) {
710 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
711 if (dogamma) d = pow(d, cvts.gamcor);
712 colval(cvts.r.colors[x],RED) = d;
713 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
714 if (dogamma) d = pow(d, cvts.gamcor);
715 colval(cvts.r.colors[x],GRN) = d;
716 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
717 if (dogamma) d = pow(d, cvts.gamcor);
718 colval(cvts.r.colors[x],BLU) = d;
719 if (CHK(C_CXFM))
720 colortrans(cvts.r.colors[x], cvts.cmat,
721 cvts.r.colors[x]);
722 }
723 if (cvts.bradj) {
724 d = pow(2.,(double)cvts.bradj);
725 for (x = cvts.xmax; x--; )
726 scalecolor(cvts.r.colors[x], d);
727 }
728
729 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
730 quiterr("error writing Radiance picture");
731 }
732
733
734 static void
735 L2Color( /* read/convert/write Lfloat->COLOR scanline */
736 uint32 y
737 )
738 {
739 float m = pow(2., (double)cvts.bradj);
740 register int x;
741
742 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
743 quiterr("internal error 1 in L2Color");
744
745 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
746 quiterr("error reading TIFF input");
747 /* also works for float greyscale */
748 for (x = cvts.xmax; x--; ) {
749 register float f = cvts.t.fp[x];
750 if (cvts.bradj) f *= m;
751 setcolor(cvts.r.colors[x], f, f, f);
752 }
753 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
754 quiterr("error writing Radiance picture");
755 }
756
757
758 static void
759 RGB2Colr( /* read/convert/write RGB->COLR scanline */
760 uint32 y
761 )
762 {
763 COLOR ctmp;
764 register int x;
765
766 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
767 quiterr("internal error 1 in RGB2Colr");
768
769 if (cvts.pconf == PLANARCONFIG_CONTIG) {
770 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
771 goto readerr;
772 for (x = cvts.xmax; x--; ) {
773 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
774 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
775 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
776 }
777 } else {
778 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
779 goto readerr;
780 if (TIFFReadScanline(cvts.tif,
781 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
782 goto readerr;
783 if (TIFFReadScanline(cvts.tif,
784 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
785 goto readerr;
786 for (x = cvts.xmax; x--; ) {
787 cvts.r.colrs[x][RED] = cvts.t.bp[x];
788 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
789 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
790 }
791 }
792
793 gambs_colrs(cvts.r.colrs, cvts.xmax);
794 if (CHK(C_CXFM))
795 for (x = cvts.xmax; x--; ) {
796 colr_color(ctmp, cvts.r.colrs[x]);
797 colortrans(ctmp, cvts.cmat, ctmp);
798 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
799 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
800 cblack, cwhite);
801 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
802 colval(ctmp,GRN), colval(ctmp,BLU));
803 }
804 if (cvts.bradj)
805 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
806
807 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
808 quiterr("error writing Radiance picture");
809 return;
810 readerr:
811 quiterr("error reading TIFF input");
812 }
813
814
815 static void
816 Gry2Colr( /* read/convert/write G8->COLR scanline */
817 uint32 y
818 )
819 {
820 register int x;
821
822 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
823 quiterr("internal error 1 in Gry2Colr");
824
825 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
826 quiterr("error reading TIFF input");
827
828 for (x = cvts.xmax; x--; )
829 cvts.r.colrs[x][RED] =
830 cvts.r.colrs[x][GRN] =
831 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
832
833 gambs_colrs(cvts.r.colrs, cvts.xmax);
834 if (cvts.bradj)
835 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
836
837 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
838 quiterr("error writing Radiance picture");
839 }
840
841
842 static void
843 GGry2Color( /* read/convert/write G16->COLOR scanline */
844 uint32 y
845 )
846 {
847 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
848 double m;
849 register double d;
850 register int x;
851
852 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
853 quiterr("internal error 1 in GGry2Color");
854
855 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
856 quiterr("error reading TIFF input");
857
858 if (cvts.bradj)
859 m = pow(2., (double)cvts.bradj);
860 for (x = cvts.xmax; x--; ) {
861 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
862 if (dogamma) d = pow(d, cvts.gamcor);
863 if (cvts.bradj) d *= m;
864 colval(cvts.r.colors[x],RED) =
865 colval(cvts.r.colors[x],GRN) =
866 colval(cvts.r.colors[x],BLU) = d;
867 }
868 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
869 quiterr("error writing Radiance picture");
870 }
871
872
873 static void
874 Color2GGry( /* read/convert/write COLOR->G16 scanline */
875 uint32 y
876 )
877 {
878 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
879 float m = pow(2.,(double)cvts.bradj);
880 register int x;
881
882 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
883 quiterr("internal error 1 in Color2GGry");
884
885 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
886 quiterr("error reading Radiance picture");
887
888 for (x = cvts.xmax; x--; ) {
889 register float f = m*( CHK(C_XYZE) ?
890 colval(cvts.r.colors[x],CIEY)
891 : bright(cvts.r.colors[x]) );
892 if (f <= 0)
893 cvts.t.wp[x] = 0;
894 else if (f >= 1)
895 cvts.t.wp[x] = 0xffff;
896 else if (dogamma)
897 cvts.t.wp[x] = (int)((float)(1L<<16) *
898 pow(f, 1./cvts.gamcor));
899 else
900 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
901 }
902
903 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
904 quiterr("error writing TIFF output");
905 }
906
907
908 static void
909 Color2L( /* read/convert/write COLOR->Lfloat scanline */
910 uint32 y
911 )
912 {
913 float m = pow(2.,(double)cvts.bradj);
914 register int x;
915
916 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
917 quiterr("internal error 1 in Color2L");
918
919 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
920 quiterr("error reading Radiance picture");
921
922 for (x = cvts.xmax; x--; )
923 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
924 : bright(cvts.r.colors[x]) );
925
926 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
927 quiterr("error writing TIFF output");
928 }
929
930
931 static void
932 Color2Luv( /* read/convert/write COLOR->Luv scanline */
933 uint32 y
934 )
935 {
936 register int x;
937
938 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
939 quiterr("internal error 1 in Color2Luv");
940
941 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
942 quiterr("error reading Radiance picture");
943
944 if (CHK(C_CXFM))
945 for (x = cvts.xmax; x--; )
946 colortrans(cvts.r.colors[x], cvts.cmat,
947 cvts.r.colors[x]);
948 if (cvts.bradj) {
949 double m = pow(2.,(double)cvts.bradj);
950 for (x = cvts.xmax; x--; )
951 scalecolor(cvts.r.colors[x], m);
952 }
953 /* also works for float RGB */
954 for (x = cvts.xmax; x--; ) {
955 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
956 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
957 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
958 }
959
960 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
961 quiterr("error writing TIFF output");
962 }
963
964
965 static void
966 Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
967 uint32 y
968 )
969 {
970 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
971 float m = pow(2.,(double)cvts.bradj);
972 register int x, i;
973
974 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
975 quiterr("internal error 1 in Color2RRGGBB");
976
977 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
978 quiterr("error reading Radiance picture");
979
980 for (x = cvts.xmax; x--; ) {
981 if (CHK(C_CXFM)) {
982 colortrans(cvts.r.colors[x], cvts.cmat,
983 cvts.r.colors[x]);
984 if (CHK(C_GAMUT))
985 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
986 CGAMUT_LOWER, cblack, cwhite);
987 }
988 for (i = 3; i--; ) {
989 register float f = m*colval(cvts.r.colors[x],i);
990 if (f <= 0)
991 cvts.t.wp[3*x + i] = 0;
992 else if (f >= 1)
993 cvts.t.wp[3*x + i] = 0xffff;
994 else if (dogamma)
995 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
996 pow(f, 1./cvts.gamcor));
997 else
998 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
999 }
1000 }
1001
1002 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1003 quiterr("error writing TIFF output");
1004 }
1005
1006
1007 static void
1008 Colr2Gry( /* read/convert/write COLR->RGB scanline */
1009 uint32 y
1010 )
1011 {
1012 register int x;
1013
1014 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1015 quiterr("internal error 1 in Colr2Gry");
1016
1017 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1018 quiterr("error reading Radiance picture");
1019
1020 if (cvts.bradj)
1021 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1022 for (x = cvts.xmax; x--; )
1023 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1024 colrs_gambs(cvts.r.colrs, cvts.xmax);
1025
1026 for (x = cvts.xmax; x--; )
1027 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1028
1029 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1030 quiterr("error writing TIFF output");
1031 }
1032
1033
1034 static void
1035 Colr2RGB( /* read/convert/write COLR->RGB scanline */
1036 uint32 y
1037 )
1038 {
1039 COLOR ctmp;
1040 register int x;
1041
1042 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1043 quiterr("internal error 1 in Colr2RGB");
1044
1045 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1046 quiterr("error reading Radiance picture");
1047
1048 if (cvts.bradj)
1049 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1050 if (CHK(C_CXFM))
1051 for (x = cvts.xmax; x--; ) {
1052 colr_color(ctmp, cvts.r.colrs[x]);
1053 colortrans(ctmp, cvts.cmat, ctmp);
1054 if (CHK(C_GAMUT))
1055 clipgamut(ctmp, bright(ctmp), CGAMUT,
1056 cblack, cwhite);
1057 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1058 colval(ctmp,GRN), colval(ctmp,BLU));
1059 }
1060 colrs_gambs(cvts.r.colrs, cvts.xmax);
1061
1062 for (x = cvts.xmax; x--; ) {
1063 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1064 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1065 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1066 }
1067
1068 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1069 quiterr("error writing TIFF output");
1070 }
