root/radiance/ray/src/px/ra_tiff.c
Revision: 2.35
Committed: Thu Aug 2 18:33:47 2018 UTC (7 years ago) by greg
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.34 2010/12/04 00:24:43 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include <time.h>
14 #include <string.h>
15
16 #include "platform.h"
17 #include "tiffio.h"
18 #include "color.h"
19 #include "resolu.h"
20
21 #define GAMCOR 2.2 /* default gamma */
22
23 /* conversion flags */
24 #define C_CXFM 0x1 /* needs color transformation */
25 #define C_GAMUT 0x2 /* needs gamut mapping */
26 #define C_GAMMA 0x4 /* needs gamma correction */
27 #define C_GRY 0x8 /* TIFF is greyscale */
28 #define C_XYZE 0x10 /* Radiance is XYZE */
29 #define C_RFLT 0x20 /* Radiance data is float */
30 #define C_TFLT 0x40 /* TIFF data is float */
31 #define C_TWRD 0x80 /* TIFF data is 16-bit */
32 #define C_PRIM 0x100 /* has assigned primaries */
33
34 typedef void colcvf_t(uint32 y);
35
36 struct {
37 uint16 flags; /* conversion flags (defined above) */
38 char capdate[20]; /* capture date/time */
39 char owner[256]; /* content owner */
40 uint16 comp; /* TIFF compression type */
41 uint16 phot; /* TIFF photometric type */
42 uint16 pconf; /* TIFF planar configuration */
43 float gamcor; /* gamma correction value */
44 short bradj; /* Radiance exposure adjustment (stops) */
45 uint16 orient; /* visual orientation (TIFF spec.) */
46 double stonits; /* input conversion to nits */
47 float pixrat; /* pixel aspect ratio */
48 FILE *rfp; /* Radiance stream pointer */
49 TIFF *tif; /* TIFF pointer */
50 uint32 xmax, ymax; /* image dimensions */
51 COLORMAT cmat; /* color transformation matrix */
52 RGBPRIMS prims; /* RGB primaries */
53 union {
54 COLR *colrs; /* 4-byte ???E pointer */
55 COLOR *colors; /* float array pointer */
56 char *p; /* generic pointer */
57 } r; /* Radiance scanline */
58 union {
59 uint8 *bp; /* byte pointer */
60 uint16 *wp; /* word pointer */
61 float *fp; /* float pointer */
62 char *p; /* generic pointer */
63 } t; /* TIFF scanline */
64 colcvf_t *tf; /* translation procedure */
65 } cvts = { /* conversion structure */
66 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
67 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
68 };
69
70 #define CHK(f) (cvts.flags & (f))
71 #define SET(f) (cvts.flags |= (f))
72 #define CLR(f) (cvts.flags &= ~(f))
73 #define TGL(f) (cvts.flags ^= (f))
74
75 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
76 static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
77 static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
78
79 static gethfunc headline;
80 static void quiterr(char *err);
81 static void allocbufs(void);
82 static void initfromtif(void);
83 static void tiff2ra(int ac, char *av[]);
84 static void initfromrad(void);
85 static void ra2tiff(int ac, char *av[]);
86
87
88
89 #define RfGfBf2Color Luv2Color
90 #define Gryf2Color L2Color
91 #define Color2Gryf Color2L
92 #define Color2RfGfBf Color2Luv
93
94 short ortab[8] = { /* orientation conversion table */
95 YMAJOR|YDECR,
96 YMAJOR|YDECR|XDECR,
97 YMAJOR|XDECR,
98 YMAJOR,
99 YDECR,
100 XDECR|YDECR,
101 XDECR,
102 0
103 };
104
105 #define pixorder() ortab[cvts.orient-1]
106
107 extern char TMSTR[]; /* "CAPDATE=" from header.c */
108 char OWNSTR[] = "OWNER=";
109
110 char *progname;
111
112
113 int
114 main(int argc, char *argv[])
115 {
116 int reverse = 0;
117 int i;
118
119 progname = argv[0];
120
121 for (i = 1; i < argc; i++)
122 if (argv[i][0] == '-')
123 switch (argv[i][1]) {
124 case 'g': /* gamma correction */
125 cvts.gamcor = atof(argv[++i]);
126 break;
127 case 'x': /* XYZE Radiance output */
128 TGL(C_XYZE);
129 break;
130 case 'z': /* LZW compressed output */
131 cvts.comp = COMPRESSION_LZW;
132 break;
133 case 'L': /* LogLuv 32-bit output */
134 cvts.comp = COMPRESSION_SGILOG;
135 cvts.phot = PHOTOMETRIC_LOGLUV;
136 break;
137 case 'l': /* LogLuv 24-bit output */
138 cvts.comp = COMPRESSION_SGILOG24;
139 cvts.phot = PHOTOMETRIC_LOGLUV;
140 break;
141 case 'w': /* 16-bit/primary output? */
142 TGL(C_TWRD);
143 break;
144 case 'f': /* IEEE float output? */
145 TGL(C_TFLT);
146 break;
147 case 'b': /* greyscale output? */
148 TGL(C_GRY);
149 break;
150 case 'e': /* exposure adjustment */
151 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
152 goto userr;
153 cvts.bradj = atoi(argv[++i]);
154 break;
155 case 'r': /* reverse conversion? */
156 reverse = !reverse;
157 break;
158 case '\0':
159 goto doneopts;
160 default:
161 goto userr;
162 }
163 else
164 break;
165 doneopts:
166 if (reverse) {
167
168 if (i != argc-2 && i != argc-1)
169 goto userr;
170
171 tiff2ra(i, argv);
172
173 } else {
174
175 if (i != argc-2)
176 goto userr;
177 /* consistency checks */
178 if (CHK(C_GRY)) {
179 if (cvts.phot == PHOTOMETRIC_RGB)
180 cvts.phot = PHOTOMETRIC_MINISBLACK;
181 else {
182 cvts.phot = PHOTOMETRIC_LOGL;
183 cvts.comp = COMPRESSION_SGILOG;
184 }
185 }
186 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
187 goto userr;
188
189 ra2tiff(i, argv);
190 }
191
192 exit(0);
193 userr:
194 fprintf(stderr,
195 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.hdr|-} out.tif\n",
196 progname);
197 fprintf(stderr,
198 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.hdr|-]\n",
199 progname);
200 exit(1);
201 }
202
203
204 static void
205 quiterr( /* print message and exit */
206 char *err
207 )
208 {
209 if (err != NULL) {
210 fprintf(stderr, "%s: %s\n", progname, err);
211 exit(1);
212 }
213 exit(0);
214 }
215
216
217 static void
218 allocbufs(void) /* allocate scanline buffers */
219 {
220 int rsiz, tsiz;
221
222 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
223 tsiz = (CHK(C_TFLT) ? sizeof(float) :
224 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
225 (CHK(C_GRY) ? 1 : 3);
226 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
227 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
228 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
229 quiterr("no memory to allocate scanline buffers");
230 }
231
232
233 static void
234 initfromtif(void) /* initialize conversion from TIFF input */
235 {
236 uint16 hi;
237 char *cp;
238 float *fa, f1, f2;
239
240 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
241
242 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
243
244 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
245 cvts.prims[RED][CIEX] = fa[0];
246 cvts.prims[RED][CIEY] = fa[1];
247 cvts.prims[GRN][CIEX] = fa[2];
248 cvts.prims[GRN][CIEY] = fa[3];
249 cvts.prims[BLU][CIEX] = fa[4];
250 cvts.prims[BLU][CIEY] = fa[5];
251 cvts.prims[WHT][CIEX] = 1./3.;
252 cvts.prims[WHT][CIEY] = 1./3.;
253 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
254 cvts.prims[WHT][CIEX] = fa[0];
255 cvts.prims[WHT][CIEY] = fa[1];
256 }
257 SET(C_PRIM);
258 }
259
260 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
261 cvts.comp = COMPRESSION_NONE;
262
263 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
264 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
265 cvts.pixrat = f1/f2;
266
267 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
268
269 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
270 quiterr("TIFF has unspecified photometric type");
271
272 switch (cvts.phot) {
273 case PHOTOMETRIC_LOGLUV:
274 SET(C_RFLT|C_TFLT);
275 if (!CHK(C_XYZE)) {
276 cpcolormat(cvts.cmat, xyz2rgbmat);
277 SET(C_CXFM|C_GAMUT);
278 } else if (cvts.comp == COMPRESSION_SGILOG)
279 SET(C_GAMUT); /* may be outside XYZ gamut */
280 if (cvts.pconf != PLANARCONFIG_CONTIG)
281 quiterr("cannot handle separate Luv planes");
282 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
283 SGILOGDATAFMT_FLOAT);
284 cvts.tf = Luv2Color;
285 break;
286 case PHOTOMETRIC_LOGL:
287 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
288 cvts.pconf = PLANARCONFIG_CONTIG;
289 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
290 SGILOGDATAFMT_FLOAT);
291 cvts.tf = L2Color;
292 break;
293 case PHOTOMETRIC_YCBCR:
294 if (cvts.comp == COMPRESSION_JPEG &&
295 cvts.pconf == PLANARCONFIG_CONTIG) {
296 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
297 JPEGCOLORMODE_RGB);
298 cvts.phot = PHOTOMETRIC_RGB;
299 } else
300 quiterr("unsupported photometric type");
301 /* fall through */
302 case PHOTOMETRIC_RGB:
303 SET(C_GAMMA);
304 setcolrgam(cvts.gamcor);
305 if (CHK(C_XYZE)) {
306 comprgb2xyzWBmat(cvts.cmat,
307 CHK(C_PRIM) ? cvts.prims : stdprims);
308 SET(C_CXFM);
309 }
310 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
311 hi != 3)
312 quiterr("unsupported samples per pixel for RGB");
313 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
314 hi = -1;
315 switch (hi) {
316 case 8:
317 cvts.tf = RGB2Colr;
318 break;
319 case 16:
320 cvts.tf = RRGGBB2Color;
321 SET(C_RFLT|C_TWRD);
322 break;
323 case 32:
324 cvts.tf = RfGfBf2Color;
325 SET(C_RFLT|C_TFLT);
326 break;
327 default:
328 quiterr("unsupported bits per sample for RGB");
329 }
330 break;
331 case PHOTOMETRIC_MINISBLACK:
332 SET(C_GRY|C_GAMMA);
333 setcolrgam(cvts.gamcor);
334 cvts.pconf = PLANARCONFIG_CONTIG;
335 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
336 hi != 1)
337 quiterr("unsupported samples per pixel for greyscale");
338 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
339 hi = -1;
340 switch (hi) {
341 case 8:
342 cvts.tf = Gry2Colr;
343 break;
344 case 16:
345 cvts.tf = GGry2Color;
346 SET(C_RFLT|C_TWRD);
347 break;
348 case 32:
349 cvts.tf = Gryf2Color;
350 SET(C_RFLT|C_TFLT);
351 break;
352 default:
353 quiterr("unsupported bits per sample for Gray");
354 }
355 break;
356 default:
357 quiterr("unsupported photometric type");
358 break;
359 }
360
361 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
362 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
363 quiterr("unknown input image resolution");
364
365 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
366 cvts.stonits = -1.;
367
368 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
369 cvts.capdate[0] = '\0';
370 else {
371 strncpy(cvts.capdate, cp, 19);
372 cvts.capdate[19] = '\0';
373 }
374 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
375 cvts.owner[0] = '\0';
376 else {
377 strncpy(cvts.owner, cp, sizeof(cvts.owner));
378 cvts.owner[sizeof(cvts.owner)-1] = '\0';
379 }
380 /* add to Radiance header */
381 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
382 fputaspect(cvts.pixrat, cvts.rfp);
383 if (CHK(C_XYZE)) {
384 if (cvts.stonits > .0)
385 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
386 fputformat(CIEFMT, cvts.rfp);
387 } else {
388 if (CHK(C_PRIM))
389 fputprims(cvts.prims, cvts.rfp);
390 if (cvts.stonits > .0)
391 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
392 cvts.rfp);
393 fputformat(COLRFMT, cvts.rfp);
394 }
395 if (cvts.capdate[0])
396 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
397 if (cvts.owner[0])
398 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
399
400 allocbufs(); /* allocate scanline buffers */
401 }
402
403
404 static void
405 tiff2ra( /* convert TIFF image to Radiance picture */
406 int ac,
407 char *av[]
408 )
409 {
410 int32 y;
411 /* open TIFF input */
412 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
413 quiterr("cannot open TIFF input");
414 /* open Radiance output */
415 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
416 cvts.rfp = stdout;
417 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
418 quiterr("cannot open Radiance output picture");
419 SET_FILE_BINARY(cvts.rfp);
420 /* start output header */
421 newheader("RADIANCE", cvts.rfp);
422 printargs(ac, av, cvts.rfp);
423
424 initfromtif(); /* initialize conversion */
425
426 fputc('\n', cvts.rfp); /* finish Radiance header */
427 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
428
429 for (y = 0; y < cvts.ymax; y++) /* convert image */
430 (*cvts.tf)(y);
431 /* clean up */
432 fclose(cvts.rfp);
433 TIFFClose(cvts.tif);
434 }
435
436
437 static int
438 headline( /* process Radiance input header line */
439 char *s,
440 void *p
441 )
442 {
443 static int tmstrlen = 0;
444 static int ownstrlen = 0;
445 char fmt[MAXFMTLEN];
446
447 if (!tmstrlen)
448 tmstrlen = strlen(TMSTR);
449 if (!ownstrlen)
450 ownstrlen = strlen(OWNSTR);
451 if (formatval(fmt, s)) {
452 if (!strcmp(fmt, COLRFMT))
453 CLR(C_XYZE);
454 else if (!strcmp(fmt, CIEFMT))
455 SET(C_XYZE);
456 else
457 quiterr("unrecognized input picture format");
458 return(1);
459 }
460 if (isexpos(s)) {
461 cvts.stonits /= exposval(s);
462 return(1);
463 }
464 if (isaspect(s)) {
465 cvts.pixrat *= aspectval(s);
466 return(1);
467 }
468 if (isprims(s)) {
469 primsval(cvts.prims, s);
470 SET(C_PRIM);
471 return(1);
472 }
473 if (isdate(s)) {
474 if (s[tmstrlen] == ' ')
475 strncpy(cvts.capdate, s+tmstrlen+1, 19);
476 else
477 strncpy(cvts.capdate, s+tmstrlen, 19);
478 cvts.capdate[19] = '\0';
479 return(1);
480 }
481 if (!strncmp(s, OWNSTR, ownstrlen)) {
482 register char *cp = s + ownstrlen;
483
484 while (isspace(*cp))
485 ++cp;
486 strncpy(cvts.owner, cp, sizeof(cvts.owner));
487 cvts.owner[sizeof(cvts.owner)-1] = '\0';
488 for (cp = cvts.owner; *cp; cp++)
489 ;
490 while (cp > cvts.owner && isspace(cp[-1]))
491 *--cp = '\0';
492 return(1);
493 }
494 return(0);
495 }
496
497
498 static void
499 initfromrad(void) /* initialize input from a Radiance picture */
500 {
501 int i1, i2, po;
502 /* read Radiance header */
503 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
504 cvts.capdate[0] = '\0';
505 cvts.owner[0] = '\0';
506 cvts.stonits = 1.;
507 cvts.pixrat = 1.;
508 cvts.pconf = PLANARCONFIG_CONTIG;
509 getheader(cvts.rfp, headline, NULL);
510 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
511 quiterr("bad Radiance picture");
512 cvts.xmax = i1; cvts.ymax = i2;
513 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
514 if (ortab[i1] == po) {
515 cvts.orient = i1 + 1;
516 break;
517 }
518 if (i1 >= 8)
519 quiterr("internal error 1 in initfromrad");
520 if (!(po & YMAJOR))
521 cvts.pixrat = 1./cvts.pixrat;
522 if (!CHK(C_XYZE))
523 cvts.stonits *= WHTEFFICACY;
524 /* set up conversion */
525 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
526 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
527
528 switch (cvts.phot) {
529 case PHOTOMETRIC_LOGLUV:
530 SET(C_RFLT|C_TFLT);
531 CLR(C_GRY|C_TWRD);
532 if (!CHK(C_XYZE)) {
533 comprgb2xyzWBmat(cvts.cmat,
534 CHK(C_PRIM) ? cvts.prims : stdprims);
535 SET(C_CXFM);
536 }
537 if (cvts.comp != COMPRESSION_SGILOG &&
538 cvts.comp != COMPRESSION_SGILOG24)
539 quiterr("internal error 2 in initfromrad");
540 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
541 SGILOGDATAFMT_FLOAT);
542 cvts.tf = Color2Luv;
543 break;
544 case PHOTOMETRIC_LOGL:
545 SET(C_GRY|C_RFLT|C_TFLT);
546 CLR(C_TWRD);
547 if (cvts.comp != COMPRESSION_SGILOG)
548 quiterr("internal error 3 in initfromrad");
549 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
550 SGILOGDATAFMT_FLOAT);
551 cvts.tf = Color2L;
552 break;
553 case PHOTOMETRIC_RGB:
554 SET(C_GAMMA|C_GAMUT);
555 CLR(C_GRY);
556 setcolrgam(cvts.gamcor);
557 if (CHK(C_XYZE)) {
558 compxyz2rgbWBmat(cvts.cmat,
559 CHK(C_PRIM) ? cvts.prims : stdprims);
560 SET(C_CXFM);
561 }
562 if (CHK(C_PRIM)) {
563 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
564 (float *)cvts.prims);
565 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
566 (float *)cvts.prims[WHT]);
567 }
568 if (CHK(C_TWRD)) {
569 cvts.tf = Color2RRGGBB;
570 SET(C_RFLT);
571 } else if (CHK(C_TFLT)) {
572 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
573 SAMPLEFORMAT_IEEEFP);
574 cvts.tf = Color2RfGfBf;
575 SET(C_RFLT);
576 CLR(C_GAMUT);
577 } else
578 cvts.tf = Colr2RGB;
579 break;
580 case PHOTOMETRIC_MINISBLACK:
581 SET(C_GRY|C_GAMMA|C_GAMUT);
582 setcolrgam(cvts.gamcor);
583 if (CHK(C_TWRD)) {
584 cvts.tf = Color2GGry;
585 SET(C_RFLT);
586 } else if (CHK(C_TFLT)) {
587 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
588 SAMPLEFORMAT_IEEEFP);
589 cvts.tf = Color2Gryf;
590 SET(C_RFLT);
591 } else
592 cvts.tf = Colr2Gry;
593 break;
594 default:
595 quiterr("internal error 4 in initfromrad");
596 break;
597 }
598 /* set other TIFF fields */
599 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
600 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
601 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
602 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
603 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
604 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
605 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
606 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
607 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
608 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
609 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
610 cvts.stonits/pow(2.,(double)cvts.bradj));
611 if (cvts.capdate[0])
612 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
613 if (cvts.owner[0])
614 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
615 if (cvts.comp == COMPRESSION_NONE)
616 i1 = TIFFScanlineSize(cvts.tif);
617 else
618 i1 = 3*cvts.xmax; /* conservative guess */
619 i2 = 8192/i1; /* compute good strip size */
620 if (i2 < 1) i2 = 1;
621 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
622
623 allocbufs(); /* allocate scanline buffers */
624 }
625
626
627 static void
628 ra2tiff( /* convert Radiance picture to TIFF image */
629 int ac,
630 char *av[]
631 )
632 {
633 uint32 y;
634 /* open Radiance file */
635 if (!strcmp(av[ac], "-"))
636 cvts.rfp = stdin;
637 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
638 quiterr("cannot open Radiance input picture");
639 SET_FILE_BINARY(cvts.rfp);
640 /* open TIFF file */
641 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
642 quiterr("cannot open TIFF output");
643
644 initfromrad(); /* initialize conversion */
645
646 for (y = 0; y < cvts.ymax; y++) /* convert image */
647 (*cvts.tf)(y);
648 /* clean up */
649 TIFFClose(cvts.tif);
650 fclose(cvts.rfp);
651 }
652
653
654 static void
655 Luv2Color( /* read/convert/write Luv->COLOR scanline */
656 uint32 y
657 )
658 {
659 register int x;
660
661 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
662 quiterr("internal error 1 in Luv2Color");
663
664 if (cvts.pconf != PLANARCONFIG_CONTIG)
665 quiterr("cannot handle separate 32-bit color planes");
666
667 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
668 quiterr("error reading TIFF input");
669 /* also works for float RGB */
670 for (x = cvts.xmax; x--; ) {
671 setcolor(cvts.r.colors[x],
672 cvts.t.fp[3*x],
673 cvts.t.fp[3*x + 1],
674 cvts.t.fp[3*x + 2]);
675 if (CHK(C_CXFM))
676 colortrans(cvts.r.colors[x], cvts.cmat,
677 cvts.r.colors[x]);
678 if (CHK(C_GAMUT))
679 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
680 CGAMUT_LOWER, cblack, cwhite);
681 }
682 if (cvts.bradj) {
683 double m = pow(2.,(double)cvts.bradj);
684 for (x = cvts.xmax; x--; )
685 scalecolor(cvts.r.colors[x], m);
686 }
687
688 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
689 quiterr("error writing Radiance picture");
690 }
691
692
693 static void
694 RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
695 uint32 y
696 )
697 {
698 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
699 register double d;
700 register int x;
701
702 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
703 quiterr("internal error 1 in RRGGBB2Color");
704
705 if (cvts.pconf != PLANARCONFIG_CONTIG)
706 quiterr("cannot handle separate 16-bit color planes");
707
708 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
709 quiterr("error reading TIFF input");
710
711 for (x = cvts.xmax; x--; ) {
712 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
713 if (dogamma) d = pow(d, cvts.gamcor);
714 colval(cvts.r.colors[x],RED) = d;
715 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
716 if (dogamma) d = pow(d, cvts.gamcor);
717 colval(cvts.r.colors[x],GRN) = d;
718 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
719 if (dogamma) d = pow(d, cvts.gamcor);
720 colval(cvts.r.colors[x],BLU) = d;
721 if (CHK(C_CXFM))
722 colortrans(cvts.r.colors[x], cvts.cmat,
723 cvts.r.colors[x]);
724 }
725 if (cvts.bradj) {
726 d = pow(2.,(double)cvts.bradj);
727 for (x = cvts.xmax; x--; )
728 scalecolor(cvts.r.colors[x], d);
729 }
730
731 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
732 quiterr("error writing Radiance picture");
733 }
734
735
736 static void
737 L2Color( /* read/convert/write Lfloat->COLOR scanline */
738 uint32 y
739 )
740 {
741 float m = pow(2., (double)cvts.bradj);
742 register int x;
743
744 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
745 quiterr("internal error 1 in L2Color");
746
747 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
748 quiterr("error reading TIFF input");
749 /* also works for float greyscale */
750 for (x = cvts.xmax; x--; ) {
751 register float f = cvts.t.fp[x];
752 if (cvts.bradj) f *= m;
753 setcolor(cvts.r.colors[x], f, f, f);
754 }
755 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
756 quiterr("error writing Radiance picture");
757 }
758
759
760 static void
761 RGB2Colr( /* read/convert/write RGB->COLR scanline */
762 uint32 y
763 )
764 {
765 COLOR ctmp;
766 register int x;
767
768 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
769 quiterr("internal error 1 in RGB2Colr");
770
771 if (cvts.pconf == PLANARCONFIG_CONTIG) {
772 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
773 goto readerr;
774 for (x = cvts.xmax; x--; ) {
775 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
776 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
777 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
778 }
779 } else {
780 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
781 goto readerr;
782 if (TIFFReadScanline(cvts.tif,
783 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
784 goto readerr;
785 if (TIFFReadScanline(cvts.tif,
786 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
787 goto readerr;
788 for (x = cvts.xmax; x--; ) {
789 cvts.r.colrs[x][RED] = cvts.t.bp[x];
790 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
791 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
792 }
793 }
794
795 gambs_colrs(cvts.r.colrs, cvts.xmax);
796 if (CHK(C_CXFM))
797 for (x = cvts.xmax; x--; ) {
798 colr_color(ctmp, cvts.r.colrs[x]);
799 colortrans(ctmp, cvts.cmat, ctmp);
800 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
801 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
802 cblack, cwhite);
803 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
804 colval(ctmp,GRN), colval(ctmp,BLU));
805 }
806 if (cvts.bradj)
807 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
808
809 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
810 quiterr("error writing Radiance picture");
811 return;
812 readerr:
813 quiterr("error reading TIFF input");
814 }
815
816
817 static void
818 Gry2Colr( /* read/convert/write G8->COLR scanline */
819 uint32 y
820 )
821 {
822 register int x;
823
824 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
825 quiterr("internal error 1 in Gry2Colr");
826
827 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
828 quiterr("error reading TIFF input");
829
830 for (x = cvts.xmax; x--; )
831 cvts.r.colrs[x][RED] =
832 cvts.r.colrs[x][GRN] =
833 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
834
835 gambs_colrs(cvts.r.colrs, cvts.xmax);
836 if (cvts.bradj)
837 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
838
839 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
840 quiterr("error writing Radiance picture");
841 }
842
843
844 static void
845 GGry2Color( /* read/convert/write G16->COLOR scanline */
846 uint32 y
847 )
848 {
849 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
850 double m;
851 register double d;
852 register int x;
853
854 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
855 quiterr("internal error 1 in GGry2Color");
856
857 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
858 quiterr("error reading TIFF input");
859
860 if (cvts.bradj)
861 m = pow(2., (double)cvts.bradj);
862 for (x = cvts.xmax; x--; ) {
863 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
864 if (dogamma) d = pow(d, cvts.gamcor);
865 if (cvts.bradj) d *= m;
866 colval(cvts.r.colors[x],RED) =
867 colval(cvts.r.colors[x],GRN) =
868 colval(cvts.r.colors[x],BLU) = d;
869 }
870 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
871 quiterr("error writing Radiance picture");
872 }
873
874
875 static void
876 Color2GGry( /* read/convert/write COLOR->G16 scanline */
877 uint32 y
878 )
879 {
880 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
881 float m = pow(2.,(double)cvts.bradj);
882 register int x;
883
884 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
885 quiterr("internal error 1 in Color2GGry");
886
887 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
888 quiterr("error reading Radiance picture");
889
890 for (x = cvts.xmax; x--; ) {
891 register float f = m*( CHK(C_XYZE) ?
892 colval(cvts.r.colors[x],CIEY)
893 : bright(cvts.r.colors[x]) );
894 if (f <= 0)
895 cvts.t.wp[x] = 0;
896 else if (f >= 1)
897 cvts.t.wp[x] = 0xffff;
898 else if (dogamma)
899 cvts.t.wp[x] = (int)((float)(1L<<16) *
900 pow(f, 1./cvts.gamcor));
901 else
902 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
903 }
904
905 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
906 quiterr("error writing TIFF output");
907 }
908
909
910 static void
911 Color2L( /* read/convert/write COLOR->Lfloat scanline */
912 uint32 y
913 )
914 {
915 float m = pow(2.,(double)cvts.bradj);
916 register int x;
917
918 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
919 quiterr("internal error 1 in Color2L");
920
921 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
922 quiterr("error reading Radiance picture");
923
924 for (x = cvts.xmax; x--; )
925 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
926 : bright(cvts.r.colors[x]) );
927
928 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
929 quiterr("error writing TIFF output");
930 }
931
932
933 static void
934 Color2Luv( /* read/convert/write COLOR->Luv scanline */
935 uint32 y
936 )
937 {
938 register int x;
939
940 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
941 quiterr("internal error 1 in Color2Luv");
942
943 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
944 quiterr("error reading Radiance picture");
945
946 if (CHK(C_CXFM))
947 for (x = cvts.xmax; x--; )
948 colortrans(cvts.r.colors[x], cvts.cmat,
949 cvts.r.colors[x]);
950 if (cvts.bradj) {
951 double m = pow(2.,(double)cvts.bradj);
952 for (x = cvts.xmax; x--; )
953 scalecolor(cvts.r.colors[x], m);
954 }
955 /* also works for float RGB */
956 for (x = cvts.xmax; x--; ) {
957 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
958 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
959 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
960 }
961
962 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
963 quiterr("error writing TIFF output");
964 }
965
966
967 static void
968 Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
969 uint32 y
970 )
971 {
972 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
973 float m = pow(2.,(double)cvts.bradj);
974 register int x, i;
975
976 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
977 quiterr("internal error 1 in Color2RRGGBB");
978
979 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
980 quiterr("error reading Radiance picture");
981
982 for (x = cvts.xmax; x--; ) {
983 if (CHK(C_CXFM)) {
984 colortrans(cvts.r.colors[x], cvts.cmat,
985 cvts.r.colors[x]);
986 if (CHK(C_GAMUT))
987 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
988 CGAMUT_LOWER, cblack, cwhite);
989 }
990 for (i = 3; i--; ) {
991 register float f = m*colval(cvts.r.colors[x],i);
992 if (f <= 0)
993 cvts.t.wp[3*x + i] = 0;
994 else if (f >= 1)
995 cvts.t.wp[3*x + i] = 0xffff;
996 else if (dogamma)
997 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
998 pow(f, 1./cvts.gamcor));
999 else
1000 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
1001 }
1002 }
1003
1004 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1005 quiterr("error writing TIFF output");
1006 }
1007
1008
1009 static void
1010 Colr2Gry( /* read/convert/write COLR->RGB scanline */
1011 uint32 y
1012 )
1013 {
1014 register int x;
1015
1016 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1017 quiterr("internal error 1 in Colr2Gry");
1018
1019 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1020 quiterr("error reading Radiance picture");
1021
1022 if (cvts.bradj)
1023 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1024 for (x = cvts.xmax; x--; )
1025 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1026 colrs_gambs(cvts.r.colrs, cvts.xmax);
1027
1028 for (x = cvts.xmax; x--; )
1029 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1030
1031 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1032 quiterr("error writing TIFF output");
1033 }
1034
1035
1036 static void
1037 Colr2RGB( /* read/convert/write COLR->RGB scanline */
1038 uint32 y
1039 )
1040 {
1041 COLOR ctmp;
1042 register int x;
1043
1044 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1045 quiterr("internal error 1 in Colr2RGB");
1046
1047 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1048 quiterr("error reading Radiance picture");
1049
1050 if (cvts.bradj)
1051 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1052 if (CHK(C_CXFM))
1053 for (x = cvts.xmax; x--; ) {
1054 colr_color(ctmp, cvts.r.colrs[x]);
1055 colortrans(ctmp, cvts.cmat, ctmp);
1056 if (CHK(C_GAMUT))
1057 clipgamut(ctmp, bright(ctmp), CGAMUT,
1058 cblack, cwhite);
1059 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1060 colval(ctmp,GRN), colval(ctmp,BLU));
1061 }
1062 colrs_gambs(cvts.r.colrs, cvts.xmax);
1063
1064 for (x = cvts.xmax; x--; ) {
1065 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1066 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1067 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1068 }
1069
1070 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1071 quiterr("error writing TIFF output");
1072 }
