root/radiance/ray/src/px/ra_tiff.c
Revision: 2.23
Committed: Mon Jul 14 04:56:54 2003 UTC (22 years ago) by greg
Changes since 2.22: +5 -1 lines
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.22 2003/07/01 22:44:02 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include "tiffio.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define GAMCOR 2.2 /* default gamma */
18
19 /* conversion flags */
20 #define C_CXFM 0x1 /* needs color transformation */
21 #define C_GAMUT 0x2 /* needs gamut mapping */
22 #define C_GAMMA 0x4 /* needs gamma correction */
23 #define C_GRY 0x8 /* TIFF is greyscale */
24 #define C_XYZE 0x10 /* Radiance is XYZE */
25 #define C_RFLT 0x20 /* Radiance data is float */
26 #define C_TFLT 0x40 /* TIFF data is float */
27 #define C_TWRD 0x80 /* TIFF data is 16-bit */
28 #define C_PRIM 0x100 /* has assigned primaries */
29
30 struct {
31 uint16 flags; /* conversion flags (defined above) */
32 char capdate[20]; /* capture date/time */
33 char owner[256]; /* content owner */
34 uint16 comp; /* TIFF compression type */
35 uint16 phot; /* TIFF photometric type */
36 uint16 pconf; /* TIFF planar configuration */
37 float gamcor; /* gamma correction value */
38 short bradj; /* Radiance exposure adjustment (stops) */
39 uint16 orient; /* visual orientation (TIFF spec.) */
40 double stonits; /* input conversion to nits */
41 float pixrat; /* pixel aspect ratio */
42 FILE *rfp; /* Radiance stream pointer */
43 TIFF *tif; /* TIFF pointer */
44 uint32 xmax, ymax; /* image dimensions */
45 COLORMAT cmat; /* color transformation matrix */
46 RGBPRIMS prims; /* RGB primaries */
47 union {
48 COLR *colrs; /* 4-byte ???E pointer */
49 COLOR *colors; /* float array pointer */
50 char *p; /* generic pointer */
51 } r; /* Radiance scanline */
52 union {
53 uint8 *bp; /* byte pointer */
54 uint16 *wp; /* word pointer */
55 float *fp; /* float pointer */
56 char *p; /* generic pointer */
57 } t; /* TIFF scanline */
58 void (*tf)(); /* translation procedure */
59 } cvts = { /* conversion structure */
60 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
61 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
62 };
63
64 #define CHK(f) (cvts.flags & (f))
65 #define SET(f) (cvts.flags |= (f))
66 #define CLR(f) (cvts.flags &= ~(f))
67 #define TGL(f) (cvts.flags ^= (f))
68
69 void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
70 void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
71 void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry();
72
73 #define RfGfBf2Color Luv2Color
74 #define Gryf2Color L2Color
75 #define Color2Gryf Color2L
76 #define Color2RfGfBf Color2Luv
77
78 short ortab[8] = { /* orientation conversion table */
79 YMAJOR|YDECR,
80 YMAJOR|YDECR|XDECR,
81 YMAJOR|XDECR,
82 YMAJOR,
83 YDECR,
84 XDECR|YDECR,
85 XDECR,
86 0
87 };
88
89 #define pixorder() ortab[cvts.orient-1]
90
91 extern char TMSTR[]; /* "CAPDATE=" from header.c */
92 char OWNSTR[] = "OWNER=";
93
94 char *progname;
95
96
97 main(argc, argv)
98 int argc;
99 char *argv[];
100 {
101 int reverse = 0;
102 int i;
103
104 progname = argv[0];
105
106 for (i = 1; i < argc; i++)
107 if (argv[i][0] == '-')
108 switch (argv[i][1]) {
109 case 'g': /* gamma correction */
110 cvts.gamcor = atof(argv[++i]);
111 break;
112 case 'x': /* XYZE Radiance output */
113 TGL(C_XYZE);
114 break;
115 case 'z': /* LZW compressed output */
116 cvts.comp = COMPRESSION_LZW;
117 break;
118 case 'L': /* LogLuv 32-bit output */
119 cvts.comp = COMPRESSION_SGILOG;
120 cvts.phot = PHOTOMETRIC_LOGLUV;
121 break;
122 case 'l': /* LogLuv 24-bit output */
123 cvts.comp = COMPRESSION_SGILOG24;
124 cvts.phot = PHOTOMETRIC_LOGLUV;
125 break;
126 case 'w': /* 16-bit/primary output? */
127 TGL(C_TWRD);
128 break;
129 case 'f': /* IEEE float output? */
130 TGL(C_TFLT);
131 break;
132 case 'b': /* greyscale output? */
133 TGL(C_GRY);
134 break;
135 case 'e': /* exposure adjustment */
136 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
137 goto userr;
138 cvts.bradj = atoi(argv[++i]);
139 break;
140 case 'r': /* reverse conversion? */
141 reverse = !reverse;
142 break;
143 case '\0':
144 goto doneopts;
145 default:
146 goto userr;
147 }
148 else
149 break;
150 doneopts:
151 if (reverse) {
152
153 if (i != argc-2 && i != argc-1)
154 goto userr;
155
156 tiff2ra(i, argv);
157
158 } else {
159
160 if (i != argc-2)
161 goto userr;
162 /* consistency checks */
163 if (CHK(C_GRY))
164 if (cvts.phot == PHOTOMETRIC_RGB)
165 cvts.phot = PHOTOMETRIC_MINISBLACK;
166 else {
167 cvts.phot = PHOTOMETRIC_LOGL;
168 cvts.comp = COMPRESSION_SGILOG;
169 }
170 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
171 goto userr;
172
173 ra2tiff(i, argv);
174 }
175
176 exit(0);
177 userr:
178 fprintf(stderr,
179 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
180 progname);
181 fprintf(stderr,
182 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
183 progname);
184 exit(1);
185 }
186
187
188 quiterr(err) /* print message and exit */
189 char *err;
190 {
191 if (err != NULL) {
192 fprintf(stderr, "%s: %s\n", progname, err);
193 exit(1);
194 }
195 exit(0);
196 }
197
198
199 allocbufs() /* allocate scanline buffers */
200 {
201 int rsiz, tsiz;
202
203 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
204 tsiz = (CHK(C_TFLT) ? sizeof(float) :
205 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
206 (CHK(C_GRY) ? 1 : 3);
207 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
208 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
209 if (cvts.r.p == NULL | cvts.t.p == NULL)
210 quiterr("no memory to allocate scanline buffers");
211 }
212
213
214 initfromtif() /* initialize conversion from TIFF input */
215 {
216 uint16 hi;
217 char *cp;
218 float *fa, f1, f2;
219
220 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
221
222 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
223
224 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
225 cvts.prims[RED][CIEX] = fa[0];
226 cvts.prims[RED][CIEY] = fa[1];
227 cvts.prims[GRN][CIEX] = fa[2];
228 cvts.prims[GRN][CIEY] = fa[3];
229 cvts.prims[BLU][CIEX] = fa[4];
230 cvts.prims[BLU][CIEY] = fa[5];
231 cvts.prims[WHT][CIEX] = 1./3.;
232 cvts.prims[WHT][CIEY] = 1./3.;
233 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
234 cvts.prims[WHT][CIEX] = fa[0];
235 cvts.prims[WHT][CIEY] = fa[1];
236 }
237 SET(C_PRIM);
238 }
239
240 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
241 cvts.comp = COMPRESSION_NONE;
242
243 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
244 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
245 cvts.pixrat = f1/f2;
246
247 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
248
249 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
250 quiterr("TIFF has unspecified photometric type");
251
252 switch (cvts.phot) {
253 case PHOTOMETRIC_LOGLUV:
254 SET(C_RFLT|C_TFLT);
255 if (!CHK(C_XYZE)) {
256 cpcolormat(cvts.cmat, xyz2rgbmat);
257 SET(C_CXFM|C_GAMUT);
258 } else if (cvts.comp == COMPRESSION_SGILOG)
259 SET(C_GAMUT);
260 if (cvts.pconf != PLANARCONFIG_CONTIG)
261 quiterr("cannot handle separate Luv planes");
262 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
263 SGILOGDATAFMT_FLOAT);
264 cvts.tf = Luv2Color;
265 break;
266 case PHOTOMETRIC_LOGL:
267 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
268 cvts.pconf = PLANARCONFIG_CONTIG;
269 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
270 SGILOGDATAFMT_FLOAT);
271 cvts.tf = L2Color;
272 break;
273 case PHOTOMETRIC_YCBCR:
274 if (cvts.comp == COMPRESSION_JPEG &&
275 cvts.pconf == PLANARCONFIG_CONTIG) {
276 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
277 JPEGCOLORMODE_RGB);
278 cvts.phot = PHOTOMETRIC_RGB;
279 } else
280 quiterr("unsupported photometric type");
281 /* fall through */
282 case PHOTOMETRIC_RGB:
283 SET(C_GAMMA);
284 setcolrgam(cvts.gamcor);
285 if (CHK(C_XYZE)) {
286 comprgb2xyzWBmat(cvts.cmat,
287 CHK(C_PRIM) ? cvts.prims : stdprims);
288 SET(C_CXFM);
289 }
290 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
291 hi != 3)
292 quiterr("unsupported samples per pixel for RGB");
293 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
294 hi = -1;
295 switch (hi) {
296 case 8:
297 cvts.tf = RGB2Colr;
298 break;
299 case 16:
300 cvts.tf = RRGGBB2Color;
301 SET(C_RFLT|C_TWRD);
302 break;
303 case 32:
304 cvts.tf = RfGfBf2Color;
305 SET(C_RFLT|C_TFLT);
306 break;
307 default:
308 quiterr("unsupported bits per sample for RGB");
309 }
310 break;
311 case PHOTOMETRIC_MINISBLACK:
312 SET(C_GRY|C_GAMMA);
313 setcolrgam(cvts.gamcor);
314 cvts.pconf = PLANARCONFIG_CONTIG;
315 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
316 hi != 1)
317 quiterr("unsupported samples per pixel for greyscale");
318 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
319 hi = -1;
320 switch (hi) {
321 case 8:
322 cvts.tf = Gry2Colr;
323 break;
324 case 16:
325 cvts.tf = GGry2Color;
326 SET(C_RFLT|C_TWRD);
327 break;
328 case 32:
329 cvts.tf = Gryf2Color;
330 SET(C_RFLT|C_TFLT);
331 break;
332 default:
333 quiterr("unsupported bits per sample for Gray");
334 }
335 break;
336 default:
337 quiterr("unsupported photometric type");
338 break;
339 }
340
341 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
342 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
343 quiterr("unknown input image resolution");
344
345 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
346 cvts.stonits = 1.;
347
348 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
349 cvts.capdate[0] = '\0';
350 else {
351 strncpy(cvts.capdate, cp, 19);
352 cvts.capdate[19] = '\0';
353 }
354 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
355 cvts.owner[0] = '\0';
356 else {
357 strncpy(cvts.owner, cp, sizeof(cvts.owner));
358 cvts.owner[sizeof(cvts.owner)-1] = '\0';
359 }
360 /* add to Radiance header */
361 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
362 fputaspect(cvts.pixrat, cvts.rfp);
363 if (CHK(C_XYZE)) {
364 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
365 fputformat(CIEFMT, cvts.rfp);
366 } else {
367 if (CHK(C_PRIM))
368 fputprims(cvts.prims, cvts.rfp);
369 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
370 cvts.rfp);
371 fputformat(COLRFMT, cvts.rfp);
372 }
373 if (cvts.capdate[0])
374 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
375 if (cvts.owner[0])
376 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
377
378 allocbufs(); /* allocate scanline buffers */
379 }
380
381
382 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
383 int ac;
384 char *av[];
385 {
386 int32 y;
387 /* open TIFF input */
388 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
389 quiterr("cannot open TIFF input");
390 /* open Radiance output */
391 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
392 cvts.rfp = stdout;
393 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
394 quiterr("cannot open Radiance output picture");
395 /* start output header */
396 newheader("RADIANCE", cvts.rfp);
397 printargs(ac, av, cvts.rfp);
398
399 initfromtif(); /* initialize conversion */
400
401 fputc('\n', cvts.rfp); /* finish Radiance header */
402 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
403
404 for (y = 0; y < cvts.ymax; y++) /* convert image */
405 (*cvts.tf)(y);
406 /* clean up */
407 fclose(cvts.rfp);
408 TIFFClose(cvts.tif);
409 }
410
411
412 int
413 headline(s) /* process Radiance input header line */
414 char *s;
415 {
416 static int tmstrlen = 0;
417 static int ownstrlen = 0;
418 char fmt[32];
419
420 if (!tmstrlen)
421 tmstrlen = strlen(TMSTR);
422 if (!ownstrlen)
423 ownstrlen = strlen(OWNSTR);
424 if (formatval(fmt, s)) {
425 if (!strcmp(fmt, COLRFMT))
426 CLR(C_XYZE);
427 else if (!strcmp(fmt, CIEFMT))
428 SET(C_XYZE);
429 else
430 quiterr("unrecognized input picture format");
431 return(1);
432 }
433 if (isexpos(s)) {
434 cvts.stonits /= exposval(s);
435 return(1);
436 }
437 if (isaspect(s)) {
438 cvts.pixrat *= aspectval(s);
439 return(1);
440 }
441 if (isprims(s)) {
442 primsval(cvts.prims, s);
443 SET(C_PRIM);
444 return(1);
445 }
446 if (isdate(s)) {
447 if (s[tmstrlen] == ' ')
448 strncpy(cvts.capdate, s+tmstrlen+1, 19);
449 else
450 strncpy(cvts.capdate, s+tmstrlen, 19);
451 cvts.capdate[19] = '\0';
452 return(1);
453 }
454 if (!strncmp(s, OWNSTR, ownstrlen)) {
455 register char *cp = s + ownstrlen;
456
457 while (isspace(*cp))
458 ++cp;
459 strncpy(cvts.owner, cp, sizeof(cvts.owner));
460 cvts.owner[sizeof(cvts.owner)-1] = '\0';
461 for (cp = cvts.owner; *cp; cp++)
462 ;
463 while (cp > cvts.owner && isspace(cp[-1]))
464 *--cp = '\0';
465 return(1);
466 }
467 return(0);
468 }
469
470
471 initfromrad() /* initialize input from a Radiance picture */
472 {
473 int i1, i2, po;
474 /* read Radiance header */
475 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
476 cvts.capdate[0] = '\0';
477 cvts.owner[0] = '\0';
478 cvts.stonits = 1.;
479 cvts.pixrat = 1.;
480 cvts.pconf = PLANARCONFIG_CONTIG;
481 getheader(cvts.rfp, headline, NULL);
482 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
483 quiterr("bad Radiance picture");
484 cvts.xmax = i1; cvts.ymax = i2;
485 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
486 if (ortab[i1] == po) {
487 cvts.orient = i1 + 1;
488 break;
489 }
490 if (i1 >= 8)
491 quiterr("internal error 1 in initfromrad");
492 if (!(po & YMAJOR))
493 cvts.pixrat = 1./cvts.pixrat;
494 if (!CHK(C_XYZE))
495 cvts.stonits *= WHTEFFICACY;
496 /* set up conversion */
497 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
498 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
499
500 switch (cvts.phot) {
501 case PHOTOMETRIC_LOGLUV:
502 SET(C_RFLT|C_TFLT);
503 CLR(C_GRY|C_TWRD);
504 if (!CHK(C_XYZE)) {
505 comprgb2xyzWBmat(cvts.cmat,
506 CHK(C_PRIM) ? cvts.prims : stdprims);
507 SET(C_CXFM);
508 }
509 if (cvts.comp != COMPRESSION_SGILOG &&
510 cvts.comp != COMPRESSION_SGILOG24)
511 quiterr("internal error 2 in initfromrad");
512 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
513 SGILOGDATAFMT_FLOAT);
514 cvts.tf = Color2Luv;
515 break;
516 case PHOTOMETRIC_LOGL:
517 SET(C_GRY|C_RFLT|C_TFLT);
518 CLR(C_TWRD);
519 if (cvts.comp != COMPRESSION_SGILOG)
520 quiterr("internal error 3 in initfromrad");
521 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
522 SGILOGDATAFMT_FLOAT);
523 cvts.tf = Color2L;
524 break;
525 case PHOTOMETRIC_RGB:
526 SET(C_GAMMA|C_GAMUT);
527 CLR(C_GRY);
528 setcolrgam(cvts.gamcor);
529 if (CHK(C_XYZE)) {
530 compxyz2rgbWBmat(cvts.cmat,
531 CHK(C_PRIM) ? cvts.prims : stdprims);
532 SET(C_CXFM);
533 }
534 if (CHK(C_PRIM)) {
535 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
536 (float *)cvts.prims);
537 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
538 (float *)cvts.prims[WHT]);
539 }
540 if (CHK(C_TWRD)) {
541 cvts.tf = Color2RRGGBB;
542 SET(C_RFLT);
543 } else if (CHK(C_TFLT)) {
544 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
545 SAMPLEFORMAT_IEEEFP);
546 cvts.tf = Color2RfGfBf;
547 SET(C_RFLT);
548 } else
549 cvts.tf = Colr2RGB;
550 break;
551 case PHOTOMETRIC_MINISBLACK:
552 SET(C_GRY|C_GAMMA|C_GAMUT);
553 setcolrgam(cvts.gamcor);
554 if (CHK(C_TWRD)) {
555 cvts.tf = Color2GGry;
556 SET(C_RFLT);
557 } else if (CHK(C_TFLT)) {
558 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
559 SAMPLEFORMAT_IEEEFP);
560 cvts.tf = Color2Gryf;
561 SET(C_RFLT);
562 } else
563 cvts.tf = Colr2Gry;
564 break;
565 default:
566 quiterr("internal error 4 in initfromrad");
567 break;
568 }
569 /* set other TIFF fields */
570 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
571 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
572 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
573 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
574 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
575 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
576 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
577 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
578 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
579 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
580 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
581 cvts.stonits/pow(2.,(double)cvts.bradj));
582 if (cvts.capdate[0])
583 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
584 if (cvts.owner[0])
585 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
586 if (cvts.comp == COMPRESSION_NONE)
587 i1 = TIFFScanlineSize(cvts.tif);
588 else
589 i1 = 3*cvts.xmax; /* conservative guess */
590 i2 = 8192/i1; /* compute good strip size */
591 if (i2 < 1) i2 = 1;
592 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
593
594 allocbufs(); /* allocate scanline buffers */
595 }
596
597
598 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
599 int ac;
600 char *av[];
601 {
602 uint32 y;
603 /* open Radiance file */
604 if (!strcmp(av[ac], "-"))
605 cvts.rfp = stdin;
606 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
607 quiterr("cannot open Radiance input picture");
608 /* open TIFF file */
609 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
610 quiterr("cannot open TIFF output");
611
612 initfromrad(); /* initialize conversion */
613
614 for (y = 0; y < cvts.ymax; y++) /* convert image */
615 (*cvts.tf)(y);
616 /* clean up */
617 TIFFClose(cvts.tif);
618 fclose(cvts.rfp);
619 }
620
621
622 void
623 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
624 uint32 y;
625 {
626 register int x;
627
628 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
629 quiterr("internal error 1 in Luv2Color");
630
631 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
632 quiterr("error reading TIFF input");
633 /* also works for float RGB */
634 for (x = cvts.xmax; x--; ) {
635 setcolor(cvts.r.colors[x],
636 cvts.t.fp[3*x],
637 cvts.t.fp[3*x + 1],
638 cvts.t.fp[3*x + 2]);
639 if (CHK(C_CXFM))
640 colortrans(cvts.r.colors[x], cvts.cmat,
641 cvts.r.colors[x]);
642 if (CHK(C_GAMUT))
643 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
644 CGAMUT_LOWER, cblack, cwhite);
645 }
646 if (cvts.bradj) {
647 double m = pow(2.,(double)cvts.bradj);
648 for (x = cvts.xmax; x--; )
649 scalecolor(cvts.r.colors[x], m);
650 }
651
652 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
653 quiterr("error writing Radiance picture");
654 }
655
656
657 void
658 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
659 uint32 y;
660 {
661 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
662 register double d;
663 register int x;
664
665 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
666 quiterr("internal error 1 in RRGGBB2Color");
667
668 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
669 quiterr("error reading TIFF input");
670
671 for (x = cvts.xmax; x--; ) {
672 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
673 if (dogamma) d = pow(d, cvts.gamcor);
674 colval(cvts.r.colors[x],RED) = d;
675 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
676 if (dogamma) d = pow(d, cvts.gamcor);
677 colval(cvts.r.colors[x],GRN) = d;
678 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
679 if (dogamma) d = pow(d, cvts.gamcor);
680 colval(cvts.r.colors[x],BLU) = d;
681 if (CHK(C_CXFM))
682 colortrans(cvts.r.colors[x], cvts.cmat,
683 cvts.r.colors[x]);
684 if (CHK(C_GAMUT))
685 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
686 CGAMUT_LOWER, cblack, cwhite);
687 }
688 if (cvts.bradj) {
689 d = pow(2.,(double)cvts.bradj);
690 for (x = cvts.xmax; x--; )
691 scalecolor(cvts.r.colors[x], d);
692 }
693
694 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
695 quiterr("error writing Radiance picture");
696 }
697
698
699 void
700 L2Color(y) /* read/convert/write Lfloat->COLOR scanline */
701 uint32 y;
702 {
703 float m = pow(2., (double)cvts.bradj);
704 register int x;
705
706 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
707 quiterr("internal error 1 in L2Color");
708
709 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
710 quiterr("error reading TIFF input");
711 /* also works for float greyscale */
712 for (x = cvts.xmax; x--; ) {
713 register float f = cvts.t.fp[x];
714 if (cvts.bradj) f *= m;
715 setcolor(cvts.r.colors[x], f, f, f);
716 }
717 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
718 quiterr("error writing Radiance picture");
719 }
720
721
722 void
723 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
724 uint32 y;
725 {
726 COLOR ctmp;
727 register int x;
728
729 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
730 quiterr("internal error 1 in RGB2Colr");
731
732 if (cvts.pconf == PLANARCONFIG_CONTIG) {
733 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
734 goto readerr;
735 for (x = cvts.xmax; x--; ) {
736 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
737 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
738 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
739 }
740 } else {
741 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
742 goto readerr;
743 if (TIFFReadScanline(cvts.tif,
744 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
745 goto readerr;
746 if (TIFFReadScanline(cvts.tif,
747 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
748 goto readerr;
749 for (x = cvts.xmax; x--; ) {
750 cvts.r.colrs[x][RED] = cvts.t.bp[x];
751 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
752 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
753 }
754 }
755
756 gambs_colrs(cvts.r.colrs, cvts.xmax);
757 if (CHK(C_CXFM))
758 for (x = cvts.xmax; x--; ) {
759 colr_color(ctmp, cvts.r.colrs[x]);
760 colortrans(ctmp, cvts.cmat, ctmp);
761 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
762 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
763 cblack, cwhite);
764 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
765 colval(ctmp,GRN), colval(ctmp,BLU));
766 }
767 if (cvts.bradj)
768 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
769
770 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
771 quiterr("error writing Radiance picture");
772 return;
773 readerr:
774 quiterr("error reading TIFF input");
775 }
776
777
778 void
779 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
780 uint32 y;
781 {
782 register int x;
783
784 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
785 quiterr("internal error 1 in Gry2Colr");
786
787 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
788 quiterr("error reading TIFF input");
789
790 for (x = cvts.xmax; x--; )
791 cvts.r.colrs[x][RED] =
792 cvts.r.colrs[x][GRN] =
793 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
794
795 gambs_colrs(cvts.r.colrs, cvts.xmax);
796 if (cvts.bradj)
797 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
798
799 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
800 quiterr("error writing Radiance picture");
801 }
802
803
804 void
805 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
806 uint32 y;
807 {
808 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
809 double m;
810 register double d;
811 register int x;
812
813 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
814 quiterr("internal error 1 in GGry2Color");
815
816 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
817 quiterr("error reading TIFF input");
818
819 if (cvts.bradj)
820 m = pow(2., (double)cvts.bradj);
821 for (x = cvts.xmax; x--; ) {
822 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
823 if (dogamma) d = pow(d, cvts.gamcor);
824 if (cvts.bradj) d *= m;
825 colval(cvts.r.colors[x],RED) =
826 colval(cvts.r.colors[x],GRN) =
827 colval(cvts.r.colors[x],BLU) = d;
828 }
829 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
830 quiterr("error writing Radiance picture");
831 }
832
833
834 void
835 Color2GGry(y) /* read/convert/write COLOR->G16 scanline */
836 uint32 y;
837 {
838 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
839 float m = pow(2.,(double)cvts.bradj);
840 register int x;
841
842 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
843 quiterr("internal error 1 in Color2GGry");
844
845 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
846 quiterr("error reading Radiance picture");
847
848 for (x = cvts.xmax; x--; ) {
849 register float f = m*( CHK(C_XYZE) ?
850 colval(cvts.r.colors[x],CIEY)
851 : bright(cvts.r.colors[x]) );
852 if (f <= 0)
853 cvts.t.wp[x] = 0;
854 else if (f >= 1)
855 cvts.t.wp[x] = 0xffff;
856 else if (dogamma)
857 cvts.t.wp[x] = (int)((float)(1L<<16) *
858 pow(f, 1./cvts.gamcor));
859 else
860 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
861 }
862
863 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
864 quiterr("error writing TIFF output");
865 }
866
867
868 void
869 Color2L(y) /* read/convert/write COLOR->Lfloat scanline */
870 uint32 y;
871 {
872 float m = pow(2.,(double)cvts.bradj);
873 register int x;
874
875 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
876 quiterr("internal error 1 in Color2L");
877
878 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
879 quiterr("error reading Radiance picture");
880
881 for (x = cvts.xmax; x--; )
882 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
883 : bright(cvts.r.colors[x]) );
884
885 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
886 quiterr("error writing TIFF output");
887 }
888
889
890 void
891 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
892 uint32 y;
893 {
894 register int x;
895
896 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
897 quiterr("internal error 1 in Color2Luv");
898
899 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
900 quiterr("error reading Radiance picture");
901
902 if (CHK(C_CXFM))
903 for (x = cvts.xmax; x--; )
904 colortrans(cvts.r.colors[x], cvts.cmat,
905 cvts.r.colors[x]);
906 if (cvts.bradj) {
907 double m = pow(2.,(double)cvts.bradj);
908 for (x = cvts.xmax; x--; )
909 scalecolor(cvts.r.colors[x], m);
910 }
911 /* also works for float RGB */
912 for (x = cvts.xmax; x--; ) {
913 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
914 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
915 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
916 }
917
918 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
919 quiterr("error writing TIFF output");
920 }
921
922
923 void
924 Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */
925 uint32 y;
926 {
927 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
928 float m = pow(2.,(double)cvts.bradj);
929 register int x, i;
930
931 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
932 quiterr("internal error 1 in Color2RRGGBB");
933
934 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
935 quiterr("error reading Radiance picture");
936
937 for (x = cvts.xmax; x--; )
938 for (i = 3; i--; ) {
939 register float f = m*colval(cvts.r.colors[x],i);
940 if (f <= 0)
941 cvts.t.wp[3*x + i] = 0;
942 else if (f >= 1)
943 cvts.t.wp[3*x + i] = 0xffff;
944 else if (dogamma)
945 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
946 pow(f, 1./cvts.gamcor));
947 else
948 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
949 }
950
951 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
952 quiterr("error writing TIFF output");
953 }
954
955
956 void
957 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
958 uint32 y;
959 {
960 register int x;
961
962 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
963 quiterr("internal error 1 in Colr2Gry");
964
965 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
966 quiterr("error reading Radiance picture");
967
968 if (cvts.bradj)
969 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
970 for (x = cvts.xmax; x--; )
971 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
972 colrs_gambs(cvts.r.colrs, cvts.xmax);
973
974 for (x = cvts.xmax; x--; )
975 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
976
977 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
978 quiterr("error writing TIFF output");
979 }
980
981
982 void
983 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
984 uint32 y;
985 {
986 COLOR ctmp;
987 register int x;
988
989 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
990 quiterr("internal error 1 in Colr2RGB");
991
992 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
993 quiterr("error reading Radiance picture");
994
995 if (cvts.bradj)
996 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
997 if (CHK(C_CXFM))
998 for (x = cvts.xmax; x--; ) {
999 colr_color(ctmp, cvts.r.colrs[x]);
1000 colortrans(ctmp, cvts.cmat, ctmp);
1001 if (CHK(C_GAMUT))
1002 clipgamut(ctmp, bright(ctmp), CGAMUT,
1003 cblack, cwhite);
1004 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1005 colval(ctmp,GRN), colval(ctmp,BLU));
1006 }
1007 colrs_gambs(cvts.r.colrs, cvts.xmax);
1008
1009 for (x = cvts.xmax; x--; ) {
1010 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1011 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1012 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1013 }
1014
1015 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1016 quiterr("error writing TIFF output");
1017 }
