root/radiance/ray/src/px/ra_tiff.c
Revision: 2.21
Committed: Tue Jul 1 19:04:08 2003 UTC (22 years ago) by greg
Changes since 2.20: +162 -49 lines
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.20 2003/02/22 02:07:28 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <time.h>
13 #include "tiffio.h"
14 #include "color.h"
15 #include "resolu.h"
16
17 #define GAMCOR 2.2 /* default gamma */
18
19 /* conversion flags */
20 #define C_CXFM 0x1 /* needs color transformation */
21 #define C_GAMUT 0x2 /* needs gamut mapping */
22 #define C_GAMMA 0x4 /* needs gamma correction */
23 #define C_GRY 0x8 /* TIFF is greyscale */
24 #define C_XYZE 0x10 /* Radiance is XYZE */
25 #define C_RFLT 0x20 /* Radiance data is float */
26 #define C_TFLT 0x40 /* TIFF data is float */
27 #define C_TWRD 0x80 /* TIFF data is 16-bit */
28 #define C_PRIM 0x100 /* has assigned primaries */
29
30 struct {
31 uint16 flags; /* conversion flags (defined above) */
32 uint16 comp; /* TIFF compression type */
33 uint16 phot; /* TIFF photometric type */
34 uint16 pconf; /* TIFF planar configuration */
35 float gamcor; /* gamma correction value */
36 short bradj; /* Radiance exposure adjustment (stops) */
37 uint16 orient; /* visual orientation (TIFF spec.) */
38 double stonits; /* input conversion to nits */
39 float pixrat; /* pixel aspect ratio */
40 FILE *rfp; /* Radiance stream pointer */
41 TIFF *tif; /* TIFF pointer */
42 uint32 xmax, ymax; /* image dimensions */
43 COLORMAT cmat; /* color transformation matrix */
44 RGBPRIMS prims; /* RGB primaries */
45 union {
46 COLR *colrs; /* 4-byte ???E pointer */
47 COLOR *colors; /* float array pointer */
48 char *p; /* generic pointer */
49 } r; /* Radiance scanline */
50 union {
51 uint8 *bp; /* byte pointer */
52 uint16 *wp; /* word pointer */
53 float *fp; /* float pointer */
54 char *p; /* generic pointer */
55 } t; /* TIFF scanline */
56 void (*tf)(); /* translation procedure */
57 } cvts = { /* conversion structure */
58 0, COMPRESSION_NONE, PHOTOMETRIC_RGB,
59 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
60 };
61
62 #define CHK(f) (cvts.flags & (f))
63 #define SET(f) (cvts.flags |= (f))
64 #define CLR(f) (cvts.flags &= ~(f))
65 #define TGL(f) (cvts.flags ^= (f))
66
67 void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
68 void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
69 void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry();
70
71 #define RfGfBf2Color Luv2Color
72 #define Gryf2Color L2Color
73 #define Color2Gryf Color2L
74 #define Color2RfGfBf Color2Luv
75
76 short ortab[8] = { /* orientation conversion table */
77 YMAJOR|YDECR,
78 YMAJOR|YDECR|XDECR,
79 YMAJOR|XDECR,
80 YMAJOR,
81 YDECR,
82 XDECR|YDECR,
83 XDECR,
84 0
85 };
86
87 #define pixorder() ortab[cvts.orient-1]
88
89 char *progname;
90
91
92 main(argc, argv)
93 int argc;
94 char *argv[];
95 {
96 int reverse = 0;
97 int i;
98
99 progname = argv[0];
100
101 for (i = 1; i < argc; i++)
102 if (argv[i][0] == '-')
103 switch (argv[i][1]) {
104 case 'g': /* gamma correction */
105 cvts.gamcor = atof(argv[++i]);
106 break;
107 case 'x': /* XYZE Radiance output */
108 TGL(C_XYZE);
109 break;
110 case 'z': /* LZW compressed output */
111 cvts.comp = COMPRESSION_LZW;
112 break;
113 case 'L': /* LogLuv 32-bit output */
114 cvts.comp = COMPRESSION_SGILOG;
115 cvts.phot = PHOTOMETRIC_LOGLUV;
116 break;
117 case 'l': /* LogLuv 24-bit output */
118 cvts.comp = COMPRESSION_SGILOG24;
119 cvts.phot = PHOTOMETRIC_LOGLUV;
120 break;
121 case 'w': /* 16-bit/primary output? */
122 TGL(C_TWRD);
123 break;
124 case 'f': /* IEEE float output? */
125 TGL(C_TFLT);
126 break;
127 case 'b': /* greyscale output? */
128 TGL(C_GRY);
129 break;
130 case 'e': /* exposure adjustment */
131 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
132 goto userr;
133 cvts.bradj = atoi(argv[++i]);
134 break;
135 case 'r': /* reverse conversion? */
136 reverse = !reverse;
137 break;
138 case '\0':
139 goto doneopts;
140 default:
141 goto userr;
142 }
143 else
144 break;
145 doneopts:
146 if (reverse) {
147
148 if (i != argc-2 && i != argc-1)
149 goto userr;
150
151 tiff2ra(i, argv);
152
153 } else {
154
155 if (i != argc-2)
156 goto userr;
157 /* consistency checks */
158 if (CHK(C_GRY))
159 if (cvts.phot == PHOTOMETRIC_RGB)
160 cvts.phot = PHOTOMETRIC_MINISBLACK;
161 else {
162 cvts.phot = PHOTOMETRIC_LOGL;
163 cvts.comp = COMPRESSION_SGILOG;
164 }
165 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
166 goto userr;
167
168 ra2tiff(i, argv);
169 }
170
171 exit(0);
172 userr:
173 fprintf(stderr,
174 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
175 progname);
176 fprintf(stderr,
177 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
178 progname);
179 exit(1);
180 }
181
182
183 quiterr(err) /* print message and exit */
184 char *err;
185 {
186 if (err != NULL) {
187 fprintf(stderr, "%s: %s\n", progname, err);
188 exit(1);
189 }
190 exit(0);
191 }
192
193
194 allocbufs() /* allocate scanline buffers */
195 {
196 int rsiz, tsiz;
197
198 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
199 tsiz = (CHK(C_TFLT) ? sizeof(float) :
200 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
201 (CHK(C_GRY) ? 1 : 3);
202 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
203 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
204 if (cvts.r.p == NULL | cvts.t.p == NULL)
205 quiterr("no memory to allocate scanline buffers");
206 }
207
208
209 initfromtif() /* initialize conversion from TIFF input */
210 {
211 uint16 hi;
212 float *fa, f1, f2;
213
214 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
215
216 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
217
218 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
219 cvts.prims[RED][CIEX] = fa[0];
220 cvts.prims[RED][CIEY] = fa[1];
221 cvts.prims[GRN][CIEX] = fa[2];
222 cvts.prims[GRN][CIEY] = fa[3];
223 cvts.prims[BLU][CIEX] = fa[4];
224 cvts.prims[BLU][CIEY] = fa[5];
225 cvts.prims[WHT][CIEX] = 1./3.;
226 cvts.prims[WHT][CIEY] = 1./3.;
227 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
228 cvts.prims[WHT][CIEX] = fa[0];
229 cvts.prims[WHT][CIEY] = fa[1];
230 }
231 SET(C_PRIM);
232 }
233
234 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
235 cvts.comp = COMPRESSION_NONE;
236
237 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
238 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
239 cvts.pixrat = f1/f2;
240
241 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
242
243 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
244 quiterr("TIFF has unspecified photometric type");
245
246 switch (cvts.phot) {
247 case PHOTOMETRIC_LOGLUV:
248 SET(C_RFLT|C_TFLT);
249 if (!CHK(C_XYZE)) {
250 cpcolormat(cvts.cmat, xyz2rgbmat);
251 SET(C_CXFM|C_GAMUT);
252 } else if (cvts.comp == COMPRESSION_SGILOG)
253 SET(C_GAMUT);
254 if (cvts.pconf != PLANARCONFIG_CONTIG)
255 quiterr("cannot handle separate Luv planes");
256 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
257 SGILOGDATAFMT_FLOAT);
258 cvts.tf = Luv2Color;
259 break;
260 case PHOTOMETRIC_LOGL:
261 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
262 cvts.pconf = PLANARCONFIG_CONTIG;
263 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
264 SGILOGDATAFMT_FLOAT);
265 cvts.tf = L2Color;
266 break;
267 case PHOTOMETRIC_YCBCR:
268 if (cvts.comp == COMPRESSION_JPEG &&
269 cvts.pconf == PLANARCONFIG_CONTIG) {
270 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
271 JPEGCOLORMODE_RGB);
272 cvts.phot = PHOTOMETRIC_RGB;
273 } else
274 quiterr("unsupported photometric type");
275 /* fall through */
276 case PHOTOMETRIC_RGB:
277 SET(C_GAMMA);
278 setcolrgam(cvts.gamcor);
279 if (CHK(C_XYZE)) {
280 comprgb2xyzWBmat(cvts.cmat,
281 CHK(C_PRIM) ? cvts.prims : stdprims);
282 SET(C_CXFM);
283 }
284 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
285 hi != 3)
286 quiterr("unsupported samples per pixel for RGB");
287 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
288 hi = -1;
289 switch (hi) {
290 case 8:
291 cvts.tf = RGB2Colr;
292 break;
293 case 16:
294 cvts.tf = RRGGBB2Color;
295 SET(C_RFLT|C_TWRD);
296 break;
297 case 32:
298 cvts.tf = RfGfBf2Color;
299 SET(C_RFLT|C_TFLT);
300 break;
301 default:
302 quiterr("unsupported bits per sample for RGB");
303 }
304 break;
305 case PHOTOMETRIC_MINISBLACK:
306 SET(C_GRY|C_GAMMA);
307 setcolrgam(cvts.gamcor);
308 cvts.pconf = PLANARCONFIG_CONTIG;
309 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
310 hi != 1)
311 quiterr("unsupported samples per pixel for greyscale");
312 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
313 hi = -1;
314 switch (hi) {
315 case 8:
316 cvts.tf = Gry2Colr;
317 break;
318 case 16:
319 cvts.tf = GGry2Color;
320 SET(C_RFLT|C_TWRD);
321 break;
322 case 32:
323 cvts.tf = Gryf2Color;
324 SET(C_RFLT|C_TFLT);
325 break;
326 default:
327 quiterr("unsupported bits per sample for Gray");
328 }
329 break;
330 default:
331 quiterr("unsupported photometric type");
332 break;
333 }
334
335 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
336 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
337 quiterr("unknown input image resolution");
338
339 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
340 cvts.stonits = 1.;
341 /* add to Radiance header */
342 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
343 fputaspect(cvts.pixrat, cvts.rfp);
344 if (CHK(C_XYZE)) {
345 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
346 fputformat(CIEFMT, cvts.rfp);
347 } else {
348 if (CHK(C_PRIM))
349 fputprims(cvts.prims, cvts.rfp);
350 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
351 cvts.rfp);
352 fputformat(COLRFMT, cvts.rfp);
353 }
354
355 allocbufs(); /* allocate scanline buffers */
356 }
357
358
359 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
360 int ac;
361 char *av[];
362 {
363 int32 y;
364 /* open TIFF input */
365 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
366 quiterr("cannot open TIFF input");
367 /* open Radiance output */
368 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
369 cvts.rfp = stdout;
370 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
371 quiterr("cannot open Radiance output picture");
372 /* start output header */
373 newheader("RADIANCE", cvts.rfp);
374 printargs(ac, av, cvts.rfp);
375
376 initfromtif(); /* initialize conversion */
377
378 fputc('\n', cvts.rfp); /* finish Radiance header */
379 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
380
381 for (y = 0; y < cvts.ymax; y++) /* convert image */
382 (*cvts.tf)(y);
383 /* clean up */
384 fclose(cvts.rfp);
385 TIFFClose(cvts.tif);
386 }
387
388
389 int
390 headline(s) /* process Radiance input header line */
391 char *s;
392 {
393 char fmt[32];
394
395 if (formatval(fmt, s)) {
396 if (!strcmp(fmt, COLRFMT))
397 CLR(C_XYZE);
398 else if (!strcmp(fmt, CIEFMT))
399 SET(C_XYZE);
400 else
401 quiterr("unrecognized input picture format");
402 return(1);
403 }
404 if (isexpos(s)) {
405 cvts.stonits /= exposval(s);
406 return(1);
407 }
408 if (isaspect(s)) {
409 cvts.pixrat *= aspectval(s);
410 return(1);
411 }
412 if (isprims(s)) {
413 primsval(cvts.prims, s);
414 SET(C_PRIM);
415 return(1);
416 }
417 return(0);
418 }
419
420
421 initfromrad() /* initialize input from a Radiance picture */
422 {
423 int i1, i2, po;
424 /* read Radiance header */
425 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
426 cvts.stonits = 1.;
427 cvts.pixrat = 1.;
428 cvts.pconf = PLANARCONFIG_CONTIG;
429 getheader(cvts.rfp, headline, NULL);
430 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
431 quiterr("bad Radiance picture");
432 cvts.xmax = i1; cvts.ymax = i2;
433 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
434 if (ortab[i1] == po) {
435 cvts.orient = i1 + 1;
436 break;
437 }
438 if (i1 >= 8)
439 quiterr("internal error 1 in initfromrad");
440 if (!(po & YMAJOR))
441 cvts.pixrat = 1./cvts.pixrat;
442 if (!CHK(C_XYZE))
443 cvts.stonits *= WHTEFFICACY;
444 /* set up conversion */
445 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
446 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
447
448 switch (cvts.phot) {
449 case PHOTOMETRIC_LOGLUV:
450 SET(C_RFLT|C_TFLT);
451 CLR(C_GRY|C_TWRD);
452 if (!CHK(C_XYZE)) {
453 comprgb2xyzWBmat(cvts.cmat,
454 CHK(C_PRIM) ? cvts.prims : stdprims);
455 SET(C_CXFM);
456 }
457 if (cvts.comp != COMPRESSION_SGILOG &&
458 cvts.comp != COMPRESSION_SGILOG24)
459 quiterr("internal error 2 in initfromrad");
460 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
461 SGILOGDATAFMT_FLOAT);
462 cvts.tf = Color2Luv;
463 break;
464 case PHOTOMETRIC_LOGL:
465 SET(C_GRY|C_RFLT|C_TFLT);
466 CLR(C_TWRD);
467 if (cvts.comp != COMPRESSION_SGILOG)
468 quiterr("internal error 3 in initfromrad");
469 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
470 SGILOGDATAFMT_FLOAT);
471 cvts.tf = Color2L;
472 break;
473 case PHOTOMETRIC_RGB:
474 SET(C_GAMMA|C_GAMUT);
475 CLR(C_GRY);
476 setcolrgam(cvts.gamcor);
477 if (CHK(C_XYZE)) {
478 compxyz2rgbWBmat(cvts.cmat,
479 CHK(C_PRIM) ? cvts.prims : stdprims);
480 SET(C_CXFM);
481 }
482 if (CHK(C_PRIM)) {
483 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
484 (float *)cvts.prims);
485 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
486 (float *)cvts.prims[WHT]);
487 }
488 if (CHK(C_TWRD)) {
489 cvts.tf = Color2RRGGBB;
490 SET(C_RFLT);
491 } else if (CHK(C_TFLT)) {
492 cvts.tf = Color2RfGfBf;
493 SET(C_RFLT);
494 } else
495 cvts.tf = Colr2RGB;
496 break;
497 case PHOTOMETRIC_MINISBLACK:
498 SET(C_GRY|C_GAMMA|C_GAMUT);
499 setcolrgam(cvts.gamcor);
500 if (CHK(C_TWRD)) {
501 cvts.tf = Color2GGry;
502 SET(C_RFLT);
503 } else if (CHK(C_TFLT)) {
504 cvts.tf = Color2Gryf;
505 SET(C_RFLT);
506 } else
507 cvts.tf = Colr2Gry;
508 break;
509 default:
510 quiterr("internal error 4 in initfromrad");
511 break;
512 }
513 /* set other TIFF fields */
514 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
515 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
516 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
517 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
518 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
519 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
520 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
521 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
522 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
523 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
524 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
525 cvts.stonits/pow(2.,(double)cvts.bradj));
526 if (cvts.comp == COMPRESSION_NONE)
527 i1 = TIFFScanlineSize(cvts.tif);
528 else
529 i1 = 3*cvts.xmax; /* conservative guess */
530 i2 = 8192/i1; /* compute good strip size */
531 if (i2 < 1) i2 = 1;
532 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
533
534 allocbufs(); /* allocate scanline buffers */
535 }
536
537
538 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
539 int ac;
540 char *av[];
541 {
542 uint32 y;
543 /* open Radiance file */
544 if (!strcmp(av[ac], "-"))
545 cvts.rfp = stdin;
546 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
547 quiterr("cannot open Radiance input picture");
548 /* open TIFF file */
549 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
550 quiterr("cannot open TIFF output");
551
552 initfromrad(); /* initialize conversion */
553
554 for (y = 0; y < cvts.ymax; y++) /* convert image */
555 (*cvts.tf)(y);
556 /* clean up */
557 TIFFClose(cvts.tif);
558 fclose(cvts.rfp);
559 }
560
561
562 void
563 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
564 uint32 y;
565 {
566 register int x;
567
568 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
569 quiterr("internal error 1 in Luv2Color");
570
571 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
572 quiterr("error reading TIFF input");
573 /* also works for float RGB */
574 for (x = cvts.xmax; x--; ) {
575 setcolor(cvts.r.colors[x],
576 cvts.t.fp[3*x],
577 cvts.t.fp[3*x + 1],
578 cvts.t.fp[3*x + 2]);
579 if (CHK(C_CXFM))
580 colortrans(cvts.r.colors[x], cvts.cmat,
581 cvts.r.colors[x]);
582 if (CHK(C_GAMUT))
583 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
584 CGAMUT_LOWER, cblack, cwhite);
585 }
586 if (cvts.bradj) {
587 double m = pow(2.,(double)cvts.bradj);
588 for (x = cvts.xmax; x--; )
589 scalecolor(cvts.r.colors[x], m);
590 }
591
592 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
593 quiterr("error writing Radiance picture");
594 }
595
596
597 void
598 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
599 uint32 y;
600 {
601 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
602 register double d;
603 register int x;
604
605 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
606 quiterr("internal error 1 in RRGGBB2Color");
607
608 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
609 quiterr("error reading TIFF input");
610
611 for (x = cvts.xmax; x--; ) {
612 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
613 if (dogamma) d = pow(d, cvts.gamcor);
614 colval(cvts.r.colors[x],RED) = d;
615 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
616 if (dogamma) d = pow(d, cvts.gamcor);
617 colval(cvts.r.colors[x],GRN) = d;
618 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
619 if (dogamma) d = pow(d, cvts.gamcor);
620 colval(cvts.r.colors[x],BLU) = d;
621 if (CHK(C_CXFM))
622 colortrans(cvts.r.colors[x], cvts.cmat,
623 cvts.r.colors[x]);
624 if (CHK(C_GAMUT))
625 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
626 CGAMUT_LOWER, cblack, cwhite);
627 }
628 if (cvts.bradj) {
629 d = pow(2.,(double)cvts.bradj);
630 for (x = cvts.xmax; x--; )
631 scalecolor(cvts.r.colors[x], d);
632 }
633
634 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
635 quiterr("error writing Radiance picture");
636 }
637
638
639 void
640 L2Color(y) /* read/convert/write Lfloat->COLOR scanline */
641 uint32 y;
642 {
643 float m = pow(2., (double)cvts.bradj);
644 register int x;
645
646 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
647 quiterr("internal error 1 in L2Color");
648
649 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
650 quiterr("error reading TIFF input");
651 /* also works for float greyscale */
652 for (x = cvts.xmax; x--; ) {
653 register float f = cvts.t.fp[x];
654 if (cvts.bradj) f *= m;
655 setcolor(cvts.r.colors[x], f, f, f);
656 }
657 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
658 quiterr("error writing Radiance picture");
659 }
660
661
662 void
663 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
664 uint32 y;
665 {
666 COLOR ctmp;
667 register int x;
668
669 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
670 quiterr("internal error 1 in RGB2Colr");
671
672 if (cvts.pconf == PLANARCONFIG_CONTIG) {
673 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
674 goto readerr;
675 for (x = cvts.xmax; x--; ) {
676 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
677 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
678 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
679 }
680 } else {
681 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
682 goto readerr;
683 if (TIFFReadScanline(cvts.tif,
684 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
685 goto readerr;
686 if (TIFFReadScanline(cvts.tif,
687 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
688 goto readerr;
689 for (x = cvts.xmax; x--; ) {
690 cvts.r.colrs[x][RED] = cvts.t.bp[x];
691 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
692 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
693 }
694 }
695
696 gambs_colrs(cvts.r.colrs, cvts.xmax);
697 if (CHK(C_CXFM))
698 for (x = cvts.xmax; x--; ) {
699 colr_color(ctmp, cvts.r.colrs[x]);
700 colortrans(ctmp, cvts.cmat, ctmp);
701 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
702 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
703 cblack, cwhite);
704 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
705 colval(ctmp,GRN), colval(ctmp,BLU));
706 }
707 if (cvts.bradj)
708 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
709
710 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
711 quiterr("error writing Radiance picture");
712 return;
713 readerr:
714 quiterr("error reading TIFF input");
715 }
716
717
718 void
719 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
720 uint32 y;
721 {
722 register int x;
723
724 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
725 quiterr("internal error 1 in Gry2Colr");
726
727 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
728 quiterr("error reading TIFF input");
729
730 for (x = cvts.xmax; x--; )
731 cvts.r.colrs[x][RED] =
732 cvts.r.colrs[x][GRN] =
733 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
734
735 gambs_colrs(cvts.r.colrs, cvts.xmax);
736 if (cvts.bradj)
737 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
738
739 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
740 quiterr("error writing Radiance picture");
741 }
742
743
744 void
745 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
746 uint32 y;
747 {
748 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
749 double m;
750 register double d;
751 register int x;
752
753 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
754 quiterr("internal error 1 in GGry2Color");
755
756 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
757 quiterr("error reading TIFF input");
758
759 if (cvts.bradj)
760 m = pow(2., (double)cvts.bradj);
761 for (x = cvts.xmax; x--; ) {
762 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
763 if (dogamma) d = pow(d, cvts.gamcor);
764 if (cvts.bradj) d *= m;
765 colval(cvts.r.colors[x],RED) =
766 colval(cvts.r.colors[x],GRN) =
767 colval(cvts.r.colors[x],BLU) = d;
768 }
769 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
770 quiterr("error writing Radiance picture");
771 }
772
773
774 void
775 Color2GGry(y) /* read/convert/write COLOR->G16 scanline */
776 uint32 y;
777 {
778 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
779 float m = pow(2.,(double)cvts.bradj);
780 register int x;
781
782 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
783 quiterr("internal error 1 in Color2GGry");
784
785 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
786 quiterr("error reading Radiance picture");
787
788 for (x = cvts.xmax; x--; ) {
789 register float f = m*( CHK(C_XYZE) ?
790 colval(cvts.r.colors[x],CIEY)
791 : bright(cvts.r.colors[x]) );
792 if (f <= 0)
793 cvts.t.wp[x] = 0;
794 else if (f >= 1)
795 cvts.t.wp[x] = 0xffff;
796 else if (dogamma)
797 cvts.t.wp[x] = (int)((float)(1L<<16) *
798 pow(f, 1./cvts.gamcor));
799 else
800 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
801 }
802
803 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
804 quiterr("error writing TIFF output");
805 }
806
807
808 void
809 Color2L(y) /* read/convert/write COLOR->Lfloat scanline */
810 uint32 y;
811 {
812 float m = pow(2.,(double)cvts.bradj);
813 register int x;
814
815 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
816 quiterr("internal error 1 in Color2L");
817
818 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
819 quiterr("error reading Radiance picture");
820
821 for (x = cvts.xmax; x--; )
822 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
823 : bright(cvts.r.colors[x]) );
824
825 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
826 quiterr("error writing TIFF output");
827 }
828
829
830 void
831 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
832 uint32 y;
833 {
834 register int x;
835
836 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
837 quiterr("internal error 1 in Color2Luv");
838
839 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
840 quiterr("error reading Radiance picture");
841
842 if (CHK(C_CXFM))
843 for (x = cvts.xmax; x--; )
844 colortrans(cvts.r.colors[x], cvts.cmat,
845 cvts.r.colors[x]);
846 if (cvts.bradj) {
847 double m = pow(2.,(double)cvts.bradj);
848 for (x = cvts.xmax; x--; )
849 scalecolor(cvts.r.colors[x], m);
850 }
851 /* also works for float RGB */
852 for (x = cvts.xmax; x--; ) {
853 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
854 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
855 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
856 }
857
858 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
859 quiterr("error writing TIFF output");
860 }
861
862
863 void
864 Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */
865 uint32 y;
866 {
867 int dogamma = cvts.gamcor < 0.99 | cvts.gamcor > 1.01;
868 float m = pow(2.,(double)cvts.bradj);
869 register int x, i;
870
871 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
872 quiterr("internal error 1 in Color2RRGGBB");
873
874 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
875 quiterr("error reading Radiance picture");
876
877 for (x = cvts.xmax; x--; )
878 for (i = 3; i--; ) {
879 register float f = m*colval(cvts.r.colors[x],i);
880 if (f <= 0)
881 cvts.t.wp[3*x + i] = 0;
882 else if (f >= 1)
883 cvts.t.wp[3*x + i] = 0xffff;
884 else if (dogamma)
885 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
886 pow(f, 1./cvts.gamcor));
887 else
888 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
889 }
890
891 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
892 quiterr("error writing TIFF output");
893 }
894
895
896 void
897 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
898 uint32 y;
899 {
900 register int x;
901
902 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
903 quiterr("internal error 1 in Colr2Gry");
904
905 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
906 quiterr("error reading Radiance picture");
907
908 if (cvts.bradj)
909 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
910 for (x = cvts.xmax; x--; )
911 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
912 colrs_gambs(cvts.r.colrs, cvts.xmax);
913
914 for (x = cvts.xmax; x--; )
915 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
916
917 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
918 quiterr("error writing TIFF output");
919 }
920
921
922 void
923 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
924 uint32 y;
925 {
926 COLOR ctmp;
927 register int x;
928
929 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
930 quiterr("internal error 1 in Colr2RGB");
931
932 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
933 quiterr("error reading Radiance picture");
934
935 if (cvts.bradj)
936 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
937 if (CHK(C_CXFM))
938 for (x = cvts.xmax; x--; ) {
939 colr_color(ctmp, cvts.r.colrs[x]);
940 colortrans(ctmp, cvts.cmat, ctmp);
941 if (CHK(C_GAMUT))
942 clipgamut(ctmp, bright(ctmp), CGAMUT,
943 cblack, cwhite);
944 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
945 colval(ctmp,GRN), colval(ctmp,BLU));
946 }
947 colrs_gambs(cvts.r.colrs, cvts.xmax);
948
949 for (x = cvts.xmax; x--; ) {
950 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
951 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
952 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
953 }
954
955 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
956 quiterr("error writing TIFF output");
957 }
