root/radiance/ray/src/px/ra_tiff.c
Revision: 2.27
Committed: Fri Jan 2 12:47:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.26: +10 -4 lines
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.26 2003/07/27 22:12:03 schorsch Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include <time.h>
14 #include <string.h>
15
16 #include "tiffio.h"
17 #include "color.h"
18 #include "resolu.h"
19
20 #define GAMCOR 2.2 /* default gamma */
21
22 /* conversion flags */
23 #define C_CXFM 0x1 /* needs color transformation */
24 #define C_GAMUT 0x2 /* needs gamut mapping */
25 #define C_GAMMA 0x4 /* needs gamma correction */
26 #define C_GRY 0x8 /* TIFF is greyscale */
27 #define C_XYZE 0x10 /* Radiance is XYZE */
28 #define C_RFLT 0x20 /* Radiance data is float */
29 #define C_TFLT 0x40 /* TIFF data is float */
30 #define C_TWRD 0x80 /* TIFF data is 16-bit */
31 #define C_PRIM 0x100 /* has assigned primaries */
32
33 struct {
34 uint16 flags; /* conversion flags (defined above) */
35 char capdate[20]; /* capture date/time */
36 char owner[256]; /* content owner */
37 uint16 comp; /* TIFF compression type */
38 uint16 phot; /* TIFF photometric type */
39 uint16 pconf; /* TIFF planar configuration */
40 float gamcor; /* gamma correction value */
41 short bradj; /* Radiance exposure adjustment (stops) */
42 uint16 orient; /* visual orientation (TIFF spec.) */
43 double stonits; /* input conversion to nits */
44 float pixrat; /* pixel aspect ratio */
45 FILE *rfp; /* Radiance stream pointer */
46 TIFF *tif; /* TIFF pointer */
47 uint32 xmax, ymax; /* image dimensions */
48 COLORMAT cmat; /* color transformation matrix */
49 RGBPRIMS prims; /* RGB primaries */
50 union {
51 COLR *colrs; /* 4-byte ???E pointer */
52 COLOR *colors; /* float array pointer */
53 char *p; /* generic pointer */
54 } r; /* Radiance scanline */
55 union {
56 uint8 *bp; /* byte pointer */
57 uint16 *wp; /* word pointer */
58 float *fp; /* float pointer */
59 char *p; /* generic pointer */
60 } t; /* TIFF scanline */
61 void (*tf)(); /* translation procedure */
62 } cvts = { /* conversion structure */
63 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
64 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
65 };
66
67 #define CHK(f) (cvts.flags & (f))
68 #define SET(f) (cvts.flags |= (f))
69 #define CLR(f) (cvts.flags &= ~(f))
70 #define TGL(f) (cvts.flags ^= (f))
71
72 void Luv2Color(), L2Color(), RGB2Colr(), Gry2Colr();
73 void Color2Luv(), Color2L(), Colr2RGB(), Colr2Gry();
74 void RRGGBB2Color(), GGry2Color(), Color2RRGGBB(), Color2GGry();
75
76 #define RfGfBf2Color Luv2Color
77 #define Gryf2Color L2Color
78 #define Color2Gryf Color2L
79 #define Color2RfGfBf Color2Luv
80
81 short ortab[8] = { /* orientation conversion table */
82 YMAJOR|YDECR,
83 YMAJOR|YDECR|XDECR,
84 YMAJOR|XDECR,
85 YMAJOR,
86 YDECR,
87 XDECR|YDECR,
88 XDECR,
89 0
90 };
91
92 #define pixorder() ortab[cvts.orient-1]
93
94 extern char TMSTR[]; /* "CAPDATE=" from header.c */
95 char OWNSTR[] = "OWNER=";
96
97 char *progname;
98
99 static gethfunc headline;
100
101
102 main(argc, argv)
103 int argc;
104 char *argv[];
105 {
106 int reverse = 0;
107 int i;
108
109 progname = argv[0];
110
111 for (i = 1; i < argc; i++)
112 if (argv[i][0] == '-')
113 switch (argv[i][1]) {
114 case 'g': /* gamma correction */
115 cvts.gamcor = atof(argv[++i]);
116 break;
117 case 'x': /* XYZE Radiance output */
118 TGL(C_XYZE);
119 break;
120 case 'z': /* LZW compressed output */
121 cvts.comp = COMPRESSION_LZW;
122 break;
123 case 'L': /* LogLuv 32-bit output */
124 cvts.comp = COMPRESSION_SGILOG;
125 cvts.phot = PHOTOMETRIC_LOGLUV;
126 break;
127 case 'l': /* LogLuv 24-bit output */
128 cvts.comp = COMPRESSION_SGILOG24;
129 cvts.phot = PHOTOMETRIC_LOGLUV;
130 break;
131 case 'w': /* 16-bit/primary output? */
132 TGL(C_TWRD);
133 break;
134 case 'f': /* IEEE float output? */
135 TGL(C_TFLT);
136 break;
137 case 'b': /* greyscale output? */
138 TGL(C_GRY);
139 break;
140 case 'e': /* exposure adjustment */
141 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
142 goto userr;
143 cvts.bradj = atoi(argv[++i]);
144 break;
145 case 'r': /* reverse conversion? */
146 reverse = !reverse;
147 break;
148 case '\0':
149 goto doneopts;
150 default:
151 goto userr;
152 }
153 else
154 break;
155 doneopts:
156 if (reverse) {
157
158 if (i != argc-2 && i != argc-1)
159 goto userr;
160
161 tiff2ra(i, argv);
162
163 } else {
164
165 if (i != argc-2)
166 goto userr;
167 /* consistency checks */
168 if (CHK(C_GRY)) {
169 if (cvts.phot == PHOTOMETRIC_RGB)
170 cvts.phot = PHOTOMETRIC_MINISBLACK;
171 else {
172 cvts.phot = PHOTOMETRIC_LOGL;
173 cvts.comp = COMPRESSION_SGILOG;
174 }
175 }
176 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
177 goto userr;
178
179 ra2tiff(i, argv);
180 }
181
182 exit(0);
183 userr:
184 fprintf(stderr,
185 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
186 progname);
187 fprintf(stderr,
188 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
189 progname);
190 exit(1);
191 }
192
193
194 quiterr(err) /* print message and exit */
195 char *err;
196 {
197 if (err != NULL) {
198 fprintf(stderr, "%s: %s\n", progname, err);
199 exit(1);
200 }
201 exit(0);
202 }
203
204
205 allocbufs() /* allocate scanline buffers */
206 {
207 int rsiz, tsiz;
208
209 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
210 tsiz = (CHK(C_TFLT) ? sizeof(float) :
211 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
212 (CHK(C_GRY) ? 1 : 3);
213 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
214 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
215 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
216 quiterr("no memory to allocate scanline buffers");
217 }
218
219
220 initfromtif() /* initialize conversion from TIFF input */
221 {
222 uint16 hi;
223 char *cp;
224 float *fa, f1, f2;
225
226 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
227
228 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
229
230 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
231 cvts.prims[RED][CIEX] = fa[0];
232 cvts.prims[RED][CIEY] = fa[1];
233 cvts.prims[GRN][CIEX] = fa[2];
234 cvts.prims[GRN][CIEY] = fa[3];
235 cvts.prims[BLU][CIEX] = fa[4];
236 cvts.prims[BLU][CIEY] = fa[5];
237 cvts.prims[WHT][CIEX] = 1./3.;
238 cvts.prims[WHT][CIEY] = 1./3.;
239 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
240 cvts.prims[WHT][CIEX] = fa[0];
241 cvts.prims[WHT][CIEY] = fa[1];
242 }
243 SET(C_PRIM);
244 }
245
246 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
247 cvts.comp = COMPRESSION_NONE;
248
249 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
250 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
251 cvts.pixrat = f1/f2;
252
253 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
254
255 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
256 quiterr("TIFF has unspecified photometric type");
257
258 switch (cvts.phot) {
259 case PHOTOMETRIC_LOGLUV:
260 SET(C_RFLT|C_TFLT);
261 if (!CHK(C_XYZE)) {
262 cpcolormat(cvts.cmat, xyz2rgbmat);
263 SET(C_CXFM|C_GAMUT);
264 } else if (cvts.comp == COMPRESSION_SGILOG)
265 SET(C_GAMUT);
266 if (cvts.pconf != PLANARCONFIG_CONTIG)
267 quiterr("cannot handle separate Luv planes");
268 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
269 SGILOGDATAFMT_FLOAT);
270 cvts.tf = Luv2Color;
271 break;
272 case PHOTOMETRIC_LOGL:
273 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
274 cvts.pconf = PLANARCONFIG_CONTIG;
275 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
276 SGILOGDATAFMT_FLOAT);
277 cvts.tf = L2Color;
278 break;
279 case PHOTOMETRIC_YCBCR:
280 if (cvts.comp == COMPRESSION_JPEG &&
281 cvts.pconf == PLANARCONFIG_CONTIG) {
282 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
283 JPEGCOLORMODE_RGB);
284 cvts.phot = PHOTOMETRIC_RGB;
285 } else
286 quiterr("unsupported photometric type");
287 /* fall through */
288 case PHOTOMETRIC_RGB:
289 SET(C_GAMMA);
290 setcolrgam(cvts.gamcor);
291 if (CHK(C_XYZE)) {
292 comprgb2xyzWBmat(cvts.cmat,
293 CHK(C_PRIM) ? cvts.prims : stdprims);
294 SET(C_CXFM);
295 }
296 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
297 hi != 3)
298 quiterr("unsupported samples per pixel for RGB");
299 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
300 hi = -1;
301 switch (hi) {
302 case 8:
303 cvts.tf = RGB2Colr;
304 break;
305 case 16:
306 cvts.tf = RRGGBB2Color;
307 SET(C_RFLT|C_TWRD);
308 break;
309 case 32:
310 cvts.tf = RfGfBf2Color;
311 SET(C_RFLT|C_TFLT);
312 break;
313 default:
314 quiterr("unsupported bits per sample for RGB");
315 }
316 break;
317 case PHOTOMETRIC_MINISBLACK:
318 SET(C_GRY|C_GAMMA);
319 setcolrgam(cvts.gamcor);
320 cvts.pconf = PLANARCONFIG_CONTIG;
321 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
322 hi != 1)
323 quiterr("unsupported samples per pixel for greyscale");
324 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
325 hi = -1;
326 switch (hi) {
327 case 8:
328 cvts.tf = Gry2Colr;
329 break;
330 case 16:
331 cvts.tf = GGry2Color;
332 SET(C_RFLT|C_TWRD);
333 break;
334 case 32:
335 cvts.tf = Gryf2Color;
336 SET(C_RFLT|C_TFLT);
337 break;
338 default:
339 quiterr("unsupported bits per sample for Gray");
340 }
341 break;
342 default:
343 quiterr("unsupported photometric type");
344 break;
345 }
346
347 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
348 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
349 quiterr("unknown input image resolution");
350
351 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
352 cvts.stonits = 1.;
353
354 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
355 cvts.capdate[0] = '\0';
356 else {
357 strncpy(cvts.capdate, cp, 19);
358 cvts.capdate[19] = '\0';
359 }
360 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
361 cvts.owner[0] = '\0';
362 else {
363 strncpy(cvts.owner, cp, sizeof(cvts.owner));
364 cvts.owner[sizeof(cvts.owner)-1] = '\0';
365 }
366 /* add to Radiance header */
367 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
368 fputaspect(cvts.pixrat, cvts.rfp);
369 if (CHK(C_XYZE)) {
370 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
371 fputformat(CIEFMT, cvts.rfp);
372 } else {
373 if (CHK(C_PRIM))
374 fputprims(cvts.prims, cvts.rfp);
375 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
376 cvts.rfp);
377 fputformat(COLRFMT, cvts.rfp);
378 }
379 if (cvts.capdate[0])
380 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
381 if (cvts.owner[0])
382 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
383
384 allocbufs(); /* allocate scanline buffers */
385 }
386
387
388 tiff2ra(ac, av) /* convert TIFF image to Radiance picture */
389 int ac;
390 char *av[];
391 {
392 int32 y;
393 /* open TIFF input */
394 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
395 quiterr("cannot open TIFF input");
396 /* open Radiance output */
397 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
398 cvts.rfp = stdout;
399 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
400 quiterr("cannot open Radiance output picture");
401 /* start output header */
402 newheader("RADIANCE", cvts.rfp);
403 printargs(ac, av, cvts.rfp);
404
405 initfromtif(); /* initialize conversion */
406
407 fputc('\n', cvts.rfp); /* finish Radiance header */
408 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
409
410 for (y = 0; y < cvts.ymax; y++) /* convert image */
411 (*cvts.tf)(y);
412 /* clean up */
413 fclose(cvts.rfp);
414 TIFFClose(cvts.tif);
415 }
416
417
418 static int
419 headline( /* process Radiance input header line */
420 char *s,
421 void *p
422 )
423 {
424 static int tmstrlen = 0;
425 static int ownstrlen = 0;
426 char fmt[32];
427
428 if (!tmstrlen)
429 tmstrlen = strlen(TMSTR);
430 if (!ownstrlen)
431 ownstrlen = strlen(OWNSTR);
432 if (formatval(fmt, s)) {
433 if (!strcmp(fmt, COLRFMT))
434 CLR(C_XYZE);
435 else if (!strcmp(fmt, CIEFMT))
436 SET(C_XYZE);
437 else
438 quiterr("unrecognized input picture format");
439 return(1);
440 }
441 if (isexpos(s)) {
442 cvts.stonits /= exposval(s);
443 return(1);
444 }
445 if (isaspect(s)) {
446 cvts.pixrat *= aspectval(s);
447 return(1);
448 }
449 if (isprims(s)) {
450 primsval(cvts.prims, s);
451 SET(C_PRIM);
452 return(1);
453 }
454 if (isdate(s)) {
455 if (s[tmstrlen] == ' ')
456 strncpy(cvts.capdate, s+tmstrlen+1, 19);
457 else
458 strncpy(cvts.capdate, s+tmstrlen, 19);
459 cvts.capdate[19] = '\0';
460 return(1);
461 }
462 if (!strncmp(s, OWNSTR, ownstrlen)) {
463 register char *cp = s + ownstrlen;
464
465 while (isspace(*cp))
466 ++cp;
467 strncpy(cvts.owner, cp, sizeof(cvts.owner));
468 cvts.owner[sizeof(cvts.owner)-1] = '\0';
469 for (cp = cvts.owner; *cp; cp++)
470 ;
471 while (cp > cvts.owner && isspace(cp[-1]))
472 *--cp = '\0';
473 return(1);
474 }
475 return(0);
476 }
477
478
479 initfromrad() /* initialize input from a Radiance picture */
480 {
481 int i1, i2, po;
482 /* read Radiance header */
483 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
484 cvts.capdate[0] = '\0';
485 cvts.owner[0] = '\0';
486 cvts.stonits = 1.;
487 cvts.pixrat = 1.;
488 cvts.pconf = PLANARCONFIG_CONTIG;
489 getheader(cvts.rfp, headline, NULL);
490 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
491 quiterr("bad Radiance picture");
492 cvts.xmax = i1; cvts.ymax = i2;
493 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
494 if (ortab[i1] == po) {
495 cvts.orient = i1 + 1;
496 break;
497 }
498 if (i1 >= 8)
499 quiterr("internal error 1 in initfromrad");
500 if (!(po & YMAJOR))
501 cvts.pixrat = 1./cvts.pixrat;
502 if (!CHK(C_XYZE))
503 cvts.stonits *= WHTEFFICACY;
504 /* set up conversion */
505 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
506 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
507
508 switch (cvts.phot) {
509 case PHOTOMETRIC_LOGLUV:
510 SET(C_RFLT|C_TFLT);
511 CLR(C_GRY|C_TWRD);
512 if (!CHK(C_XYZE)) {
513 comprgb2xyzWBmat(cvts.cmat,
514 CHK(C_PRIM) ? cvts.prims : stdprims);
515 SET(C_CXFM);
516 }
517 if (cvts.comp != COMPRESSION_SGILOG &&
518 cvts.comp != COMPRESSION_SGILOG24)
519 quiterr("internal error 2 in initfromrad");
520 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
521 SGILOGDATAFMT_FLOAT);
522 cvts.tf = Color2Luv;
523 break;
524 case PHOTOMETRIC_LOGL:
525 SET(C_GRY|C_RFLT|C_TFLT);
526 CLR(C_TWRD);
527 if (cvts.comp != COMPRESSION_SGILOG)
528 quiterr("internal error 3 in initfromrad");
529 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
530 SGILOGDATAFMT_FLOAT);
531 cvts.tf = Color2L;
532 break;
533 case PHOTOMETRIC_RGB:
534 SET(C_GAMMA|C_GAMUT);
535 CLR(C_GRY);
536 setcolrgam(cvts.gamcor);
537 if (CHK(C_XYZE)) {
538 compxyz2rgbWBmat(cvts.cmat,
539 CHK(C_PRIM) ? cvts.prims : stdprims);
540 SET(C_CXFM);
541 }
542 if (CHK(C_PRIM)) {
543 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
544 (float *)cvts.prims);
545 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
546 (float *)cvts.prims[WHT]);
547 }
548 if (CHK(C_TWRD)) {
549 cvts.tf = Color2RRGGBB;
550 SET(C_RFLT);
551 } else if (CHK(C_TFLT)) {
552 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
553 SAMPLEFORMAT_IEEEFP);
554 cvts.tf = Color2RfGfBf;
555 SET(C_RFLT);
556 } else
557 cvts.tf = Colr2RGB;
558 break;
559 case PHOTOMETRIC_MINISBLACK:
560 SET(C_GRY|C_GAMMA|C_GAMUT);
561 setcolrgam(cvts.gamcor);
562 if (CHK(C_TWRD)) {
563 cvts.tf = Color2GGry;
564 SET(C_RFLT);
565 } else if (CHK(C_TFLT)) {
566 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
567 SAMPLEFORMAT_IEEEFP);
568 cvts.tf = Color2Gryf;
569 SET(C_RFLT);
570 } else
571 cvts.tf = Colr2Gry;
572 break;
573 default:
574 quiterr("internal error 4 in initfromrad");
575 break;
576 }
577 /* set other TIFF fields */
578 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
579 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
580 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
581 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
582 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
583 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
584 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
585 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
586 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
587 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
588 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
589 cvts.stonits/pow(2.,(double)cvts.bradj));
590 if (cvts.capdate[0])
591 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
592 if (cvts.owner[0])
593 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
594 if (cvts.comp == COMPRESSION_NONE)
595 i1 = TIFFScanlineSize(cvts.tif);
596 else
597 i1 = 3*cvts.xmax; /* conservative guess */
598 i2 = 8192/i1; /* compute good strip size */
599 if (i2 < 1) i2 = 1;
600 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
601
602 allocbufs(); /* allocate scanline buffers */
603 }
604
605
606 ra2tiff(ac, av) /* convert Radiance picture to TIFF image */
607 int ac;
608 char *av[];
609 {
610 uint32 y;
611 /* open Radiance file */
612 if (!strcmp(av[ac], "-"))
613 cvts.rfp = stdin;
614 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
615 quiterr("cannot open Radiance input picture");
616 /* open TIFF file */
617 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
618 quiterr("cannot open TIFF output");
619
620 initfromrad(); /* initialize conversion */
621
622 for (y = 0; y < cvts.ymax; y++) /* convert image */
623 (*cvts.tf)(y);
624 /* clean up */
625 TIFFClose(cvts.tif);
626 fclose(cvts.rfp);
627 }
628
629
630 void
631 Luv2Color(y) /* read/convert/write Luv->COLOR scanline */
632 uint32 y;
633 {
634 register int x;
635
636 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
637 quiterr("internal error 1 in Luv2Color");
638
639 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
640 quiterr("error reading TIFF input");
641 /* also works for float RGB */
642 for (x = cvts.xmax; x--; ) {
643 setcolor(cvts.r.colors[x],
644 cvts.t.fp[3*x],
645 cvts.t.fp[3*x + 1],
646 cvts.t.fp[3*x + 2]);
647 if (CHK(C_CXFM))
648 colortrans(cvts.r.colors[x], cvts.cmat,
649 cvts.r.colors[x]);
650 if (CHK(C_GAMUT))
651 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
652 CGAMUT_LOWER, cblack, cwhite);
653 }
654 if (cvts.bradj) {
655 double m = pow(2.,(double)cvts.bradj);
656 for (x = cvts.xmax; x--; )
657 scalecolor(cvts.r.colors[x], m);
658 }
659
660 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
661 quiterr("error writing Radiance picture");
662 }
663
664
665 void
666 RRGGBB2Color(y) /* read/convert/write RGB16->COLOR scanline */
667 uint32 y;
668 {
669 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
670 register double d;
671 register int x;
672
673 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
674 quiterr("internal error 1 in RRGGBB2Color");
675
676 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
677 quiterr("error reading TIFF input");
678
679 for (x = cvts.xmax; x--; ) {
680 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
681 if (dogamma) d = pow(d, cvts.gamcor);
682 colval(cvts.r.colors[x],RED) = d;
683 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
684 if (dogamma) d = pow(d, cvts.gamcor);
685 colval(cvts.r.colors[x],GRN) = d;
686 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
687 if (dogamma) d = pow(d, cvts.gamcor);
688 colval(cvts.r.colors[x],BLU) = d;
689 if (CHK(C_CXFM))
690 colortrans(cvts.r.colors[x], cvts.cmat,
691 cvts.r.colors[x]);
692 if (CHK(C_GAMUT))
693 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
694 CGAMUT_LOWER, cblack, cwhite);
695 }
696 if (cvts.bradj) {
697 d = pow(2.,(double)cvts.bradj);
698 for (x = cvts.xmax; x--; )
699 scalecolor(cvts.r.colors[x], d);
700 }
701
702 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
703 quiterr("error writing Radiance picture");
704 }
705
706
707 void
708 L2Color(y) /* read/convert/write Lfloat->COLOR scanline */
709 uint32 y;
710 {
711 float m = pow(2., (double)cvts.bradj);
712 register int x;
713
714 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
715 quiterr("internal error 1 in L2Color");
716
717 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
718 quiterr("error reading TIFF input");
719 /* also works for float greyscale */
720 for (x = cvts.xmax; x--; ) {
721 register float f = cvts.t.fp[x];
722 if (cvts.bradj) f *= m;
723 setcolor(cvts.r.colors[x], f, f, f);
724 }
725 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
726 quiterr("error writing Radiance picture");
727 }
728
729
730 void
731 RGB2Colr(y) /* read/convert/write RGB->COLR scanline */
732 uint32 y;
733 {
734 COLOR ctmp;
735 register int x;
736
737 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
738 quiterr("internal error 1 in RGB2Colr");
739
740 if (cvts.pconf == PLANARCONFIG_CONTIG) {
741 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
742 goto readerr;
743 for (x = cvts.xmax; x--; ) {
744 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
745 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
746 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
747 }
748 } else {
749 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
750 goto readerr;
751 if (TIFFReadScanline(cvts.tif,
752 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
753 goto readerr;
754 if (TIFFReadScanline(cvts.tif,
755 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
756 goto readerr;
757 for (x = cvts.xmax; x--; ) {
758 cvts.r.colrs[x][RED] = cvts.t.bp[x];
759 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
760 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
761 }
762 }
763
764 gambs_colrs(cvts.r.colrs, cvts.xmax);
765 if (CHK(C_CXFM))
766 for (x = cvts.xmax; x--; ) {
767 colr_color(ctmp, cvts.r.colrs[x]);
768 colortrans(ctmp, cvts.cmat, ctmp);
769 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
770 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
771 cblack, cwhite);
772 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
773 colval(ctmp,GRN), colval(ctmp,BLU));
774 }
775 if (cvts.bradj)
776 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
777
778 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
779 quiterr("error writing Radiance picture");
780 return;
781 readerr:
782 quiterr("error reading TIFF input");
783 }
784
785
786 void
787 Gry2Colr(y) /* read/convert/write G8->COLR scanline */
788 uint32 y;
789 {
790 register int x;
791
792 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
793 quiterr("internal error 1 in Gry2Colr");
794
795 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
796 quiterr("error reading TIFF input");
797
798 for (x = cvts.xmax; x--; )
799 cvts.r.colrs[x][RED] =
800 cvts.r.colrs[x][GRN] =
801 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
802
803 gambs_colrs(cvts.r.colrs, cvts.xmax);
804 if (cvts.bradj)
805 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
806
807 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
808 quiterr("error writing Radiance picture");
809 }
810
811
812 void
813 GGry2Color(y) /* read/convert/write G16->COLOR scanline */
814 uint32 y;
815 {
816 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
817 double m;
818 register double d;
819 register int x;
820
821 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
822 quiterr("internal error 1 in GGry2Color");
823
824 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
825 quiterr("error reading TIFF input");
826
827 if (cvts.bradj)
828 m = pow(2., (double)cvts.bradj);
829 for (x = cvts.xmax; x--; ) {
830 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
831 if (dogamma) d = pow(d, cvts.gamcor);
832 if (cvts.bradj) d *= m;
833 colval(cvts.r.colors[x],RED) =
834 colval(cvts.r.colors[x],GRN) =
835 colval(cvts.r.colors[x],BLU) = d;
836 }
837 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
838 quiterr("error writing Radiance picture");
839 }
840
841
842 void
843 Color2GGry(y) /* read/convert/write COLOR->G16 scanline */
844 uint32 y;
845 {
846 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
847 float m = pow(2.,(double)cvts.bradj);
848 register int x;
849
850 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
851 quiterr("internal error 1 in Color2GGry");
852
853 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
854 quiterr("error reading Radiance picture");
855
856 for (x = cvts.xmax; x--; ) {
857 register float f = m*( CHK(C_XYZE) ?
858 colval(cvts.r.colors[x],CIEY)
859 : bright(cvts.r.colors[x]) );
860 if (f <= 0)
861 cvts.t.wp[x] = 0;
862 else if (f >= 1)
863 cvts.t.wp[x] = 0xffff;
864 else if (dogamma)
865 cvts.t.wp[x] = (int)((float)(1L<<16) *
866 pow(f, 1./cvts.gamcor));
867 else
868 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
869 }
870
871 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
872 quiterr("error writing TIFF output");
873 }
874
875
876 void
877 Color2L(y) /* read/convert/write COLOR->Lfloat scanline */
878 uint32 y;
879 {
880 float m = pow(2.,(double)cvts.bradj);
881 register int x;
882
883 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
884 quiterr("internal error 1 in Color2L");
885
886 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
887 quiterr("error reading Radiance picture");
888
889 for (x = cvts.xmax; x--; )
890 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
891 : bright(cvts.r.colors[x]) );
892
893 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
894 quiterr("error writing TIFF output");
895 }
896
897
898 void
899 Color2Luv(y) /* read/convert/write COLOR->Luv scanline */
900 uint32 y;
901 {
902 register int x;
903
904 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
905 quiterr("internal error 1 in Color2Luv");
906
907 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
908 quiterr("error reading Radiance picture");
909
910 if (CHK(C_CXFM))
911 for (x = cvts.xmax; x--; )
912 colortrans(cvts.r.colors[x], cvts.cmat,
913 cvts.r.colors[x]);
914 if (cvts.bradj) {
915 double m = pow(2.,(double)cvts.bradj);
916 for (x = cvts.xmax; x--; )
917 scalecolor(cvts.r.colors[x], m);
918 }
919 /* also works for float RGB */
920 for (x = cvts.xmax; x--; ) {
921 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
922 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
923 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
924 }
925
926 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
927 quiterr("error writing TIFF output");
928 }
929
930
931 void
932 Color2RRGGBB(y) /* read/convert/write COLOR->RGB16 scanline */
933 uint32 y;
934 {
935 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
936 float m = pow(2.,(double)cvts.bradj);
937 register int x, i;
938
939 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
940 quiterr("internal error 1 in Color2RRGGBB");
941
942 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
943 quiterr("error reading Radiance picture");
944
945 for (x = cvts.xmax; x--; )
946 for (i = 3; i--; ) {
947 register float f = m*colval(cvts.r.colors[x],i);
948 if (f <= 0)
949 cvts.t.wp[3*x + i] = 0;
950 else if (f >= 1)
951 cvts.t.wp[3*x + i] = 0xffff;
952 else if (dogamma)
953 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
954 pow(f, 1./cvts.gamcor));
955 else
956 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
957 }
958
959 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
960 quiterr("error writing TIFF output");
961 }
962
963
964 void
965 Colr2Gry(y) /* read/convert/write COLR->RGB scanline */
966 uint32 y;
967 {
968 register int x;
969
970 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
971 quiterr("internal error 1 in Colr2Gry");
972
973 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
974 quiterr("error reading Radiance picture");
975
976 if (cvts.bradj)
977 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
978 for (x = cvts.xmax; x--; )
979 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
980 colrs_gambs(cvts.r.colrs, cvts.xmax);
981
982 for (x = cvts.xmax; x--; )
983 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
984
985 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
986 quiterr("error writing TIFF output");
987 }
988
989
990 void
991 Colr2RGB(y) /* read/convert/write COLR->RGB scanline */
992 uint32 y;
993 {
994 COLOR ctmp;
995 register int x;
996
997 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
998 quiterr("internal error 1 in Colr2RGB");
999
1000 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1001 quiterr("error reading Radiance picture");
1002
1003 if (cvts.bradj)
1004 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1005 if (CHK(C_CXFM))
1006 for (x = cvts.xmax; x--; ) {
1007 colr_color(ctmp, cvts.r.colrs[x]);
1008 colortrans(ctmp, cvts.cmat, ctmp);
1009 if (CHK(C_GAMUT))
1010 clipgamut(ctmp, bright(ctmp), CGAMUT,
1011 cblack, cwhite);
1012 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1013 colval(ctmp,GRN), colval(ctmp,BLU));
1014 }
1015 colrs_gambs(cvts.r.colrs, cvts.xmax);
1016
1017 for (x = cvts.xmax; x--; ) {
1018 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1019 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1020 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1021 }
1022
1023 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1024 quiterr("error writing TIFF output");
1025 }
