root/radiance/ray/src/px/ra_tiff.c
Revision: 2.32
Committed: Fri Aug 19 02:31:32 2005 UTC (19 years, 9 months ago) by greg
CVS Tags: rad3R7P2, rad3R8, rad3R9
Changes since 2.31: +7 -5 lines
2 static const char RCSid[] = "$Id: ra_tiff.c,v 2.31 2005/06/07 16:54:23 greg Exp $";
5 * Program to convert between RADIANCE and TIFF files.
6 * Added LogLuv encodings 7/97 (GWL).
7 * Added white-balance adjustment 10/01 (GW).
8 */
9
10 #include <stdio.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include <time.h>
14 #include <string.h>
15
16 #include "tiffio.h"
17 #include "color.h"
18 #include "resolu.h"
19
20 #define GAMCOR 2.2 /* default gamma */
21
22 /* conversion flags */
23 #define C_CXFM 0x1 /* needs color transformation */
24 #define C_GAMUT 0x2 /* needs gamut mapping */
25 #define C_GAMMA 0x4 /* needs gamma correction */
26 #define C_GRY 0x8 /* TIFF is greyscale */
27 #define C_XYZE 0x10 /* Radiance is XYZE */
28 #define C_RFLT 0x20 /* Radiance data is float */
29 #define C_TFLT 0x40 /* TIFF data is float */
30 #define C_TWRD 0x80 /* TIFF data is 16-bit */
31 #define C_PRIM 0x100 /* has assigned primaries */
32
33 typedef void colcvf_t(uint32 y);
34
35 struct {
36 uint16 flags; /* conversion flags (defined above) */
37 char capdate[20]; /* capture date/time */
38 char owner[256]; /* content owner */
39 uint16 comp; /* TIFF compression type */
40 uint16 phot; /* TIFF photometric type */
41 uint16 pconf; /* TIFF planar configuration */
42 float gamcor; /* gamma correction value */
43 short bradj; /* Radiance exposure adjustment (stops) */
44 uint16 orient; /* visual orientation (TIFF spec.) */
45 double stonits; /* input conversion to nits */
46 float pixrat; /* pixel aspect ratio */
47 FILE *rfp; /* Radiance stream pointer */
48 TIFF *tif; /* TIFF pointer */
49 uint32 xmax, ymax; /* image dimensions */
50 COLORMAT cmat; /* color transformation matrix */
51 RGBPRIMS prims; /* RGB primaries */
52 union {
53 COLR *colrs; /* 4-byte ???E pointer */
54 COLOR *colors; /* float array pointer */
55 char *p; /* generic pointer */
56 } r; /* Radiance scanline */
57 union {
58 uint8 *bp; /* byte pointer */
59 uint16 *wp; /* word pointer */
60 float *fp; /* float pointer */
61 char *p; /* generic pointer */
62 } t; /* TIFF scanline */
63 colcvf_t *tf; /* translation procedure */
64 } cvts = { /* conversion structure */
65 0, "", "", COMPRESSION_NONE, PHOTOMETRIC_RGB,
66 PLANARCONFIG_CONTIG, GAMCOR, 0, 1, 1., 1.,
67 };
68
69 #define CHK(f) (cvts.flags & (f))
70 #define SET(f) (cvts.flags |= (f))
71 #define CLR(f) (cvts.flags &= ~(f))
72 #define TGL(f) (cvts.flags ^= (f))
73
74 static colcvf_t Luv2Color, L2Color, RGB2Colr, Gry2Colr;
75 static colcvf_t Color2Luv, Color2L, Colr2RGB, Colr2Gry;
76 static colcvf_t RRGGBB2Color, GGry2Color, Color2RRGGBB, Color2GGry;
77
78 static gethfunc headline;
79 static void quiterr(char *err);
80 static void allocbufs(void);
81 static void initfromtif(void);
82 static void tiff2ra(int ac, char *av[]);
83 static void initfromrad(void);
84 static void ra2tiff(int ac, char *av[]);
85
86
87
88 #define RfGfBf2Color Luv2Color
89 #define Gryf2Color L2Color
90 #define Color2Gryf Color2L
91 #define Color2RfGfBf Color2Luv
92
93 short ortab[8] = { /* orientation conversion table */
94 YMAJOR|YDECR,
95 YMAJOR|YDECR|XDECR,
96 YMAJOR|XDECR,
97 YMAJOR,
98 YDECR,
99 XDECR|YDECR,
100 XDECR,
101 0
102 };
103
104 #define pixorder() ortab[cvts.orient-1]
105
106 extern char TMSTR[]; /* "CAPDATE=" from header.c */
107 char OWNSTR[] = "OWNER=";
108
109 char *progname;
110
111
112 int
113 main(int argc, char *argv[])
114 {
115 int reverse = 0;
116 int i;
117
118 progname = argv[0];
119
120 for (i = 1; i < argc; i++)
121 if (argv[i][0] == '-')
122 switch (argv[i][1]) {
123 case 'g': /* gamma correction */
124 cvts.gamcor = atof(argv[++i]);
125 break;
126 case 'x': /* XYZE Radiance output */
127 TGL(C_XYZE);
128 break;
129 case 'z': /* LZW compressed output */
130 cvts.comp = COMPRESSION_LZW;
131 break;
132 case 'L': /* LogLuv 32-bit output */
133 cvts.comp = COMPRESSION_SGILOG;
134 cvts.phot = PHOTOMETRIC_LOGLUV;
135 break;
136 case 'l': /* LogLuv 24-bit output */
137 cvts.comp = COMPRESSION_SGILOG24;
138 cvts.phot = PHOTOMETRIC_LOGLUV;
139 break;
140 case 'w': /* 16-bit/primary output? */
141 TGL(C_TWRD);
142 break;
143 case 'f': /* IEEE float output? */
144 TGL(C_TFLT);
145 break;
146 case 'b': /* greyscale output? */
147 TGL(C_GRY);
148 break;
149 case 'e': /* exposure adjustment */
150 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
151 goto userr;
152 cvts.bradj = atoi(argv[++i]);
153 break;
154 case 'r': /* reverse conversion? */
155 reverse = !reverse;
156 break;
157 case '\0':
158 goto doneopts;
159 default:
160 goto userr;
161 }
162 else
163 break;
164 doneopts:
165 if (reverse) {
166
167 if (i != argc-2 && i != argc-1)
168 goto userr;
169
170 tiff2ra(i, argv);
171
172 } else {
173
174 if (i != argc-2)
175 goto userr;
176 /* consistency checks */
177 if (CHK(C_GRY)) {
178 if (cvts.phot == PHOTOMETRIC_RGB)
179 cvts.phot = PHOTOMETRIC_MINISBLACK;
180 else {
181 cvts.phot = PHOTOMETRIC_LOGL;
182 cvts.comp = COMPRESSION_SGILOG;
183 }
184 }
185 if (CHK(C_TWRD|C_TFLT) == (C_TWRD|C_TFLT))
186 goto userr;
187
188 ra2tiff(i, argv);
189 }
190
191 exit(0);
192 userr:
193 fprintf(stderr,
194 "Usage: %s [-z|-L|-l|-f|-w][-b][-e +/-stops][-g gamma] {in.pic|-} out.tif\n",
195 progname);
196 fprintf(stderr,
197 " Or: %s -r [-x][-e +/-stops][-g gamma] in.tif [out.pic|-]\n",
198 progname);
199 exit(1);
200 }
201
202
203 static void
204 quiterr( /* print message and exit */
205 char *err
206 )
207 {
208 if (err != NULL) {
209 fprintf(stderr, "%s: %s\n", progname, err);
210 exit(1);
211 }
212 exit(0);
213 }
214
215
216 static void
217 allocbufs(void) /* allocate scanline buffers */
218 {
219 int rsiz, tsiz;
220
221 rsiz = CHK(C_RFLT) ? sizeof(COLOR) : sizeof(COLR);
222 tsiz = (CHK(C_TFLT) ? sizeof(float) :
223 CHK(C_TWRD) ? sizeof(uint16) : sizeof(uint8)) *
224 (CHK(C_GRY) ? 1 : 3);
225 cvts.r.p = (char *)malloc(rsiz*cvts.xmax);
226 cvts.t.p = (char *)malloc(tsiz*cvts.xmax);
227 if ((cvts.r.p == NULL) | (cvts.t.p == NULL))
228 quiterr("no memory to allocate scanline buffers");
229 }
230
231
232 static void
233 initfromtif(void) /* initialize conversion from TIFF input */
234 {
235 uint16 hi;
236 char *cp;
237 float *fa, f1, f2;
238
239 CLR(C_GRY|C_GAMMA|C_PRIM|C_RFLT|C_TFLT|C_TWRD|C_CXFM);
240
241 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PLANARCONFIG, &cvts.pconf);
242
243 if (TIFFGetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) {
244 cvts.prims[RED][CIEX] = fa[0];
245 cvts.prims[RED][CIEY] = fa[1];
246 cvts.prims[GRN][CIEX] = fa[2];
247 cvts.prims[GRN][CIEY] = fa[3];
248 cvts.prims[BLU][CIEX] = fa[4];
249 cvts.prims[BLU][CIEY] = fa[5];
250 cvts.prims[WHT][CIEX] = 1./3.;
251 cvts.prims[WHT][CIEY] = 1./3.;
252 if (TIFFGetField(cvts.tif, TIFFTAG_WHITEPOINT, &fa)) {
253 cvts.prims[WHT][CIEX] = fa[0];
254 cvts.prims[WHT][CIEY] = fa[1];
255 }
256 SET(C_PRIM);
257 }
258
259 if (!TIFFGetField(cvts.tif, TIFFTAG_COMPRESSION, &cvts.comp))
260 cvts.comp = COMPRESSION_NONE;
261
262 if (TIFFGetField(cvts.tif, TIFFTAG_XRESOLUTION, &f1) &&
263 TIFFGetField(cvts.tif, TIFFTAG_YRESOLUTION, &f2))
264 cvts.pixrat = f1/f2;
265
266 TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_ORIENTATION, &cvts.orient);
267
268 if (!TIFFGetFieldDefaulted(cvts.tif, TIFFTAG_PHOTOMETRIC, &cvts.phot))
269 quiterr("TIFF has unspecified photometric type");
270
271 switch (cvts.phot) {
272 case PHOTOMETRIC_LOGLUV:
273 SET(C_RFLT|C_TFLT);
274 if (!CHK(C_XYZE)) {
275 cpcolormat(cvts.cmat, xyz2rgbmat);
276 SET(C_CXFM|C_GAMUT);
277 } else if (cvts.comp == COMPRESSION_SGILOG)
278 SET(C_GAMUT); /* may be outside XYZ gamut */
279 if (cvts.pconf != PLANARCONFIG_CONTIG)
280 quiterr("cannot handle separate Luv planes");
281 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
282 SGILOGDATAFMT_FLOAT);
283 cvts.tf = Luv2Color;
284 break;
285 case PHOTOMETRIC_LOGL:
286 SET(C_GRY|C_RFLT|C_TFLT|C_GAMUT);
287 cvts.pconf = PLANARCONFIG_CONTIG;
288 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
289 SGILOGDATAFMT_FLOAT);
290 cvts.tf = L2Color;
291 break;
292 case PHOTOMETRIC_YCBCR:
293 if (cvts.comp == COMPRESSION_JPEG &&
294 cvts.pconf == PLANARCONFIG_CONTIG) {
295 TIFFSetField(cvts.tif, TIFFTAG_JPEGCOLORMODE,
296 JPEGCOLORMODE_RGB);
297 cvts.phot = PHOTOMETRIC_RGB;
298 } else
299 quiterr("unsupported photometric type");
300 /* fall through */
301 case PHOTOMETRIC_RGB:
302 SET(C_GAMMA);
303 setcolrgam(cvts.gamcor);
304 if (CHK(C_XYZE)) {
305 comprgb2xyzWBmat(cvts.cmat,
306 CHK(C_PRIM) ? cvts.prims : stdprims);
307 SET(C_CXFM);
308 }
309 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
310 hi != 3)
311 quiterr("unsupported samples per pixel for RGB");
312 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
313 hi = -1;
314 switch (hi) {
315 case 8:
316 cvts.tf = RGB2Colr;
317 break;
318 case 16:
319 cvts.tf = RRGGBB2Color;
320 SET(C_RFLT|C_TWRD);
321 break;
322 case 32:
323 cvts.tf = RfGfBf2Color;
324 SET(C_RFLT|C_TFLT);
325 break;
326 default:
327 quiterr("unsupported bits per sample for RGB");
328 }
329 break;
330 case PHOTOMETRIC_MINISBLACK:
331 SET(C_GRY|C_GAMMA);
332 setcolrgam(cvts.gamcor);
333 cvts.pconf = PLANARCONFIG_CONTIG;
334 if (!TIFFGetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, &hi) ||
335 hi != 1)
336 quiterr("unsupported samples per pixel for greyscale");
337 if (!TIFFGetField(cvts.tif, TIFFTAG_BITSPERSAMPLE, &hi))
338 hi = -1;
339 switch (hi) {
340 case 8:
341 cvts.tf = Gry2Colr;
342 break;
343 case 16:
344 cvts.tf = GGry2Color;
345 SET(C_RFLT|C_TWRD);
346 break;
347 case 32:
348 cvts.tf = Gryf2Color;
349 SET(C_RFLT|C_TFLT);
350 break;
351 default:
352 quiterr("unsupported bits per sample for Gray");
353 }
354 break;
355 default:
356 quiterr("unsupported photometric type");
357 break;
358 }
359
360 if (!TIFFGetField(cvts.tif, TIFFTAG_IMAGEWIDTH, &cvts.xmax) ||
361 !TIFFGetField(cvts.tif, TIFFTAG_IMAGELENGTH, &cvts.ymax))
362 quiterr("unknown input image resolution");
363
364 if (!TIFFGetField(cvts.tif, TIFFTAG_STONITS, &cvts.stonits))
365 cvts.stonits = -1.;
366
367 if (!TIFFGetField(cvts.tif, TIFFTAG_DATETIME, &cp))
368 cvts.capdate[0] = '\0';
369 else {
370 strncpy(cvts.capdate, cp, 19);
371 cvts.capdate[19] = '\0';
372 }
373 if (!TIFFGetField(cvts.tif, TIFFTAG_ARTIST, &cp))
374 cvts.owner[0] = '\0';
375 else {
376 strncpy(cvts.owner, cp, sizeof(cvts.owner));
377 cvts.owner[sizeof(cvts.owner)-1] = '\0';
378 }
379 /* add to Radiance header */
380 if (cvts.pixrat < .99 || cvts.pixrat > 1.01)
381 fputaspect(cvts.pixrat, cvts.rfp);
382 if (CHK(C_XYZE)) {
383 if (cvts.stonits > .0)
384 fputexpos(pow(2.,(double)cvts.bradj)/cvts.stonits, cvts.rfp);
385 fputformat(CIEFMT, cvts.rfp);
386 } else {
387 if (CHK(C_PRIM))
388 fputprims(cvts.prims, cvts.rfp);
389 if (cvts.stonits > .0)
390 fputexpos(WHTEFFICACY*pow(2.,(double)cvts.bradj)/cvts.stonits,
391 cvts.rfp);
392 fputformat(COLRFMT, cvts.rfp);
393 }
394 if (cvts.capdate[0])
395 fprintf(cvts.rfp, "%s %s\n", TMSTR, cvts.capdate);
396 if (cvts.owner[0])
397 fprintf(cvts.rfp, "%s %s\n", OWNSTR, cvts.owner);
398
399 allocbufs(); /* allocate scanline buffers */
400 }
401
402
403 static void
404 tiff2ra( /* convert TIFF image to Radiance picture */
405 int ac,
406 char *av[]
407 )
408 {
409 int32 y;
410 /* open TIFF input */
411 if ((cvts.tif = TIFFOpen(av[ac], "r")) == NULL)
412 quiterr("cannot open TIFF input");
413 /* open Radiance output */
414 if (av[ac+1] == NULL || !strcmp(av[ac+1], "-"))
415 cvts.rfp = stdout;
416 else if ((cvts.rfp = fopen(av[ac+1], "w")) == NULL)
417 quiterr("cannot open Radiance output picture");
418 /* start output header */
419 newheader("RADIANCE", cvts.rfp);
420 printargs(ac, av, cvts.rfp);
421
422 initfromtif(); /* initialize conversion */
423
424 fputc('\n', cvts.rfp); /* finish Radiance header */
425 fputresolu(pixorder(), (int)cvts.xmax, (int)cvts.ymax, cvts.rfp);
426
427 for (y = 0; y < cvts.ymax; y++) /* convert image */
428 (*cvts.tf)(y);
429 /* clean up */
430 fclose(cvts.rfp);
431 TIFFClose(cvts.tif);
432 }
433
434
435 static int
436 headline( /* process Radiance input header line */
437 char *s,
438 void *p
439 )
440 {
441 static int tmstrlen = 0;
442 static int ownstrlen = 0;
443 char fmt[32];
444
445 if (!tmstrlen)
446 tmstrlen = strlen(TMSTR);
447 if (!ownstrlen)
448 ownstrlen = strlen(OWNSTR);
449 if (formatval(fmt, s)) {
450 if (!strcmp(fmt, COLRFMT))
451 CLR(C_XYZE);
452 else if (!strcmp(fmt, CIEFMT))
453 SET(C_XYZE);
454 else
455 quiterr("unrecognized input picture format");
456 return(1);
457 }
458 if (isexpos(s)) {
459 cvts.stonits /= exposval(s);
460 return(1);
461 }
462 if (isaspect(s)) {
463 cvts.pixrat *= aspectval(s);
464 return(1);
465 }
466 if (isprims(s)) {
467 primsval(cvts.prims, s);
468 SET(C_PRIM);
469 return(1);
470 }
471 if (isdate(s)) {
472 if (s[tmstrlen] == ' ')
473 strncpy(cvts.capdate, s+tmstrlen+1, 19);
474 else
475 strncpy(cvts.capdate, s+tmstrlen, 19);
476 cvts.capdate[19] = '\0';
477 return(1);
478 }
479 if (!strncmp(s, OWNSTR, ownstrlen)) {
480 register char *cp = s + ownstrlen;
481
482 while (isspace(*cp))
483 ++cp;
484 strncpy(cvts.owner, cp, sizeof(cvts.owner));
485 cvts.owner[sizeof(cvts.owner)-1] = '\0';
486 for (cp = cvts.owner; *cp; cp++)
487 ;
488 while (cp > cvts.owner && isspace(cp[-1]))
489 *--cp = '\0';
490 return(1);
491 }
492 return(0);
493 }
494
495
496 static void
497 initfromrad(void) /* initialize input from a Radiance picture */
498 {
499 int i1, i2, po;
500 /* read Radiance header */
501 CLR(C_RFLT|C_XYZE|C_PRIM|C_GAMMA|C_CXFM);
502 cvts.capdate[0] = '\0';
503 cvts.owner[0] = '\0';
504 cvts.stonits = 1.;
505 cvts.pixrat = 1.;
506 cvts.pconf = PLANARCONFIG_CONTIG;
507 getheader(cvts.rfp, headline, NULL);
508 if ((po = fgetresolu(&i1, &i2, cvts.rfp)) < 0)
509 quiterr("bad Radiance picture");
510 cvts.xmax = i1; cvts.ymax = i2;
511 for (i1 = 0; i1 < 8; i1++) /* interpret orientation */
512 if (ortab[i1] == po) {
513 cvts.orient = i1 + 1;
514 break;
515 }
516 if (i1 >= 8)
517 quiterr("internal error 1 in initfromrad");
518 if (!(po & YMAJOR))
519 cvts.pixrat = 1./cvts.pixrat;
520 if (!CHK(C_XYZE))
521 cvts.stonits *= WHTEFFICACY;
522 /* set up conversion */
523 TIFFSetField(cvts.tif, TIFFTAG_COMPRESSION, cvts.comp);
524 TIFFSetField(cvts.tif, TIFFTAG_PHOTOMETRIC, cvts.phot);
525
526 switch (cvts.phot) {
527 case PHOTOMETRIC_LOGLUV:
528 SET(C_RFLT|C_TFLT);
529 CLR(C_GRY|C_TWRD);
530 if (!CHK(C_XYZE)) {
531 comprgb2xyzWBmat(cvts.cmat,
532 CHK(C_PRIM) ? cvts.prims : stdprims);
533 SET(C_CXFM);
534 }
535 if (cvts.comp != COMPRESSION_SGILOG &&
536 cvts.comp != COMPRESSION_SGILOG24)
537 quiterr("internal error 2 in initfromrad");
538 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
539 SGILOGDATAFMT_FLOAT);
540 cvts.tf = Color2Luv;
541 break;
542 case PHOTOMETRIC_LOGL:
543 SET(C_GRY|C_RFLT|C_TFLT);
544 CLR(C_TWRD);
545 if (cvts.comp != COMPRESSION_SGILOG)
546 quiterr("internal error 3 in initfromrad");
547 TIFFSetField(cvts.tif, TIFFTAG_SGILOGDATAFMT,
548 SGILOGDATAFMT_FLOAT);
549 cvts.tf = Color2L;
550 break;
551 case PHOTOMETRIC_RGB:
552 SET(C_GAMMA|C_GAMUT);
553 CLR(C_GRY);
554 setcolrgam(cvts.gamcor);
555 if (CHK(C_XYZE)) {
556 compxyz2rgbWBmat(cvts.cmat,
557 CHK(C_PRIM) ? cvts.prims : stdprims);
558 SET(C_CXFM);
559 }
560 if (CHK(C_PRIM)) {
561 TIFFSetField(cvts.tif, TIFFTAG_PRIMARYCHROMATICITIES,
562 (float *)cvts.prims);
563 TIFFSetField(cvts.tif, TIFFTAG_WHITEPOINT,
564 (float *)cvts.prims[WHT]);
565 }
566 if (CHK(C_TWRD)) {
567 cvts.tf = Color2RRGGBB;
568 SET(C_RFLT);
569 } else if (CHK(C_TFLT)) {
570 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
571 SAMPLEFORMAT_IEEEFP);
572 cvts.tf = Color2RfGfBf;
573 SET(C_RFLT);
574 CLR(C_GAMUT);
575 } else
576 cvts.tf = Colr2RGB;
577 break;
578 case PHOTOMETRIC_MINISBLACK:
579 SET(C_GRY|C_GAMMA|C_GAMUT);
580 setcolrgam(cvts.gamcor);
581 if (CHK(C_TWRD)) {
582 cvts.tf = Color2GGry;
583 SET(C_RFLT);
584 } else if (CHK(C_TFLT)) {
585 TIFFSetField(cvts.tif, TIFFTAG_SAMPLEFORMAT,
586 SAMPLEFORMAT_IEEEFP);
587 cvts.tf = Color2Gryf;
588 SET(C_RFLT);
589 } else
590 cvts.tf = Colr2Gry;
591 break;
592 default:
593 quiterr("internal error 4 in initfromrad");
594 break;
595 }
596 /* set other TIFF fields */
597 TIFFSetField(cvts.tif, TIFFTAG_IMAGEWIDTH, cvts.xmax);
598 TIFFSetField(cvts.tif, TIFFTAG_IMAGELENGTH, cvts.ymax);
599 TIFFSetField(cvts.tif, TIFFTAG_SAMPLESPERPIXEL, CHK(C_GRY) ? 1 : 3);
600 TIFFSetField(cvts.tif, TIFFTAG_BITSPERSAMPLE,
601 CHK(C_TFLT) ? 32 : CHK(C_TWRD) ? 16 : 8);
602 TIFFSetField(cvts.tif, TIFFTAG_XRESOLUTION, 72.);
603 TIFFSetField(cvts.tif, TIFFTAG_YRESOLUTION, 72./cvts.pixrat);
604 TIFFSetField(cvts.tif, TIFFTAG_ORIENTATION, cvts.orient);
605 TIFFSetField(cvts.tif, TIFFTAG_RESOLUTIONUNIT, 2);
606 TIFFSetField(cvts.tif, TIFFTAG_PLANARCONFIG, cvts.pconf);
607 TIFFSetField(cvts.tif, TIFFTAG_STONITS,
608 cvts.stonits/pow(2.,(double)cvts.bradj));
609 if (cvts.capdate[0])
610 TIFFSetField(cvts.tif, TIFFTAG_DATETIME, cvts.capdate);
611 if (cvts.owner[0])
612 TIFFSetField(cvts.tif, TIFFTAG_ARTIST, cvts.owner);
613 if (cvts.comp == COMPRESSION_NONE)
614 i1 = TIFFScanlineSize(cvts.tif);
615 else
616 i1 = 3*cvts.xmax; /* conservative guess */
617 i2 = 8192/i1; /* compute good strip size */
618 if (i2 < 1) i2 = 1;
619 TIFFSetField(cvts.tif, TIFFTAG_ROWSPERSTRIP, (uint32)i2);
620
621 allocbufs(); /* allocate scanline buffers */
622 }
623
624
625 static void
626 ra2tiff( /* convert Radiance picture to TIFF image */
627 int ac,
628 char *av[]
629 )
630 {
631 uint32 y;
632 /* open Radiance file */
633 if (!strcmp(av[ac], "-"))
634 cvts.rfp = stdin;
635 else if ((cvts.rfp = fopen(av[ac], "r")) == NULL)
636 quiterr("cannot open Radiance input picture");
637 /* open TIFF file */
638 if ((cvts.tif = TIFFOpen(av[ac+1], "w")) == NULL)
639 quiterr("cannot open TIFF output");
640
641 initfromrad(); /* initialize conversion */
642
643 for (y = 0; y < cvts.ymax; y++) /* convert image */
644 (*cvts.tf)(y);
645 /* clean up */
646 TIFFClose(cvts.tif);
647 fclose(cvts.rfp);
648 }
649
650
651 static void
652 Luv2Color( /* read/convert/write Luv->COLOR scanline */
653 uint32 y
654 )
655 {
656 register int x;
657
658 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
659 quiterr("internal error 1 in Luv2Color");
660
661 if (cvts.pconf != PLANARCONFIG_CONTIG)
662 quiterr("cannot handle separate 32-bit color planes");
663
664 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
665 quiterr("error reading TIFF input");
666 /* also works for float RGB */
667 for (x = cvts.xmax; x--; ) {
668 setcolor(cvts.r.colors[x],
669 cvts.t.fp[3*x],
670 cvts.t.fp[3*x + 1],
671 cvts.t.fp[3*x + 2]);
672 if (CHK(C_CXFM))
673 colortrans(cvts.r.colors[x], cvts.cmat,
674 cvts.r.colors[x]);
675 if (CHK(C_GAMUT))
676 clipgamut(cvts.r.colors[x], cvts.t.fp[3*x + 1],
677 CGAMUT_LOWER, cblack, cwhite);
678 }
679 if (cvts.bradj) {
680 double m = pow(2.,(double)cvts.bradj);
681 for (x = cvts.xmax; x--; )
682 scalecolor(cvts.r.colors[x], m);
683 }
684
685 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
686 quiterr("error writing Radiance picture");
687 }
688
689
690 static void
691 RRGGBB2Color( /* read/convert/write RGB16->COLOR scanline */
692 uint32 y
693 )
694 {
695 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
696 register double d;
697 register int x;
698
699 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_TWRD|C_RFLT))
700 quiterr("internal error 1 in RRGGBB2Color");
701
702 if (cvts.pconf != PLANARCONFIG_CONTIG)
703 quiterr("cannot handle separate 16-bit color planes");
704
705 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
706 quiterr("error reading TIFF input");
707
708 for (x = cvts.xmax; x--; ) {
709 d = (cvts.t.wp[3*x] + 0.5)*(1./(1L<<16));
710 if (dogamma) d = pow(d, cvts.gamcor);
711 colval(cvts.r.colors[x],RED) = d;
712 d = (cvts.t.wp[3*x + 1] + 0.5)*(1./(1L<<16));
713 if (dogamma) d = pow(d, cvts.gamcor);
714 colval(cvts.r.colors[x],GRN) = d;
715 d = (cvts.t.wp[3*x + 2] + 0.5)*(1./(1L<<16));
716 if (dogamma) d = pow(d, cvts.gamcor);
717 colval(cvts.r.colors[x],BLU) = d;
718 if (CHK(C_CXFM))
719 colortrans(cvts.r.colors[x], cvts.cmat,
720 cvts.r.colors[x]);
721 }
722 if (cvts.bradj) {
723 d = pow(2.,(double)cvts.bradj);
724 for (x = cvts.xmax; x--; )
725 scalecolor(cvts.r.colors[x], d);
726 }
727
728 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
729 quiterr("error writing Radiance picture");
730 }
731
732
733 static void
734 L2Color( /* read/convert/write Lfloat->COLOR scanline */
735 uint32 y
736 )
737 {
738 float m = pow(2., (double)cvts.bradj);
739 register int x;
740
741 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
742 quiterr("internal error 1 in L2Color");
743
744 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
745 quiterr("error reading TIFF input");
746 /* also works for float greyscale */
747 for (x = cvts.xmax; x--; ) {
748 register float f = cvts.t.fp[x];
749 if (cvts.bradj) f *= m;
750 setcolor(cvts.r.colors[x], f, f, f);
751 }
752 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
753 quiterr("error writing Radiance picture");
754 }
755
756
757 static void
758 RGB2Colr( /* read/convert/write RGB->COLR scanline */
759 uint32 y
760 )
761 {
762 COLOR ctmp;
763 register int x;
764
765 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY))
766 quiterr("internal error 1 in RGB2Colr");
767
768 if (cvts.pconf == PLANARCONFIG_CONTIG) {
769 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
770 goto readerr;
771 for (x = cvts.xmax; x--; ) {
772 cvts.r.colrs[x][RED] = cvts.t.bp[3*x];
773 cvts.r.colrs[x][GRN] = cvts.t.bp[3*x + 1];
774 cvts.r.colrs[x][BLU] = cvts.t.bp[3*x + 2];
775 }
776 } else {
777 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
778 goto readerr;
779 if (TIFFReadScanline(cvts.tif,
780 (tdata_t)(cvts.t.bp + cvts.xmax), y, 1) < 0)
781 goto readerr;
782 if (TIFFReadScanline(cvts.tif,
783 (tdata_t)(cvts.t.bp + 2*cvts.xmax), y, 2) < 0)
784 goto readerr;
785 for (x = cvts.xmax; x--; ) {
786 cvts.r.colrs[x][RED] = cvts.t.bp[x];
787 cvts.r.colrs[x][GRN] = cvts.t.bp[cvts.xmax + x];
788 cvts.r.colrs[x][BLU] = cvts.t.bp[2*cvts.xmax + x];
789 }
790 }
791
792 gambs_colrs(cvts.r.colrs, cvts.xmax);
793 if (CHK(C_CXFM))
794 for (x = cvts.xmax; x--; ) {
795 colr_color(ctmp, cvts.r.colrs[x]);
796 colortrans(ctmp, cvts.cmat, ctmp);
797 if (CHK(C_GAMUT)) /* !CHK(C_XYZE) */
798 clipgamut(ctmp, bright(ctmp), CGAMUT_LOWER,
799 cblack, cwhite);
800 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
801 colval(ctmp,GRN), colval(ctmp,BLU));
802 }
803 if (cvts.bradj)
804 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
805
806 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
807 quiterr("error writing Radiance picture");
808 return;
809 readerr:
810 quiterr("error reading TIFF input");
811 }
812
813
814 static void
815 Gry2Colr( /* read/convert/write G8->COLR scanline */
816 uint32 y
817 )
818 {
819 register int x;
820
821 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
822 quiterr("internal error 1 in Gry2Colr");
823
824 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
825 quiterr("error reading TIFF input");
826
827 for (x = cvts.xmax; x--; )
828 cvts.r.colrs[x][RED] =
829 cvts.r.colrs[x][GRN] =
830 cvts.r.colrs[x][BLU] = cvts.t.bp[x];
831
832 gambs_colrs(cvts.r.colrs, cvts.xmax);
833 if (cvts.bradj)
834 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
835
836 if (fwritecolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
837 quiterr("error writing Radiance picture");
838 }
839
840
841 static void
842 GGry2Color( /* read/convert/write G16->COLOR scanline */
843 uint32 y
844 )
845 {
846 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
847 double m;
848 register double d;
849 register int x;
850
851 if (CHK(C_TFLT|C_TWRD|C_GRY|C_RFLT) != (C_GRY|C_RFLT|C_TWRD))
852 quiterr("internal error 1 in GGry2Color");
853
854 if (TIFFReadScanline(cvts.tif, cvts.t.p, y, 0) < 0)
855 quiterr("error reading TIFF input");
856
857 if (cvts.bradj)
858 m = pow(2., (double)cvts.bradj);
859 for (x = cvts.xmax; x--; ) {
860 d = (cvts.t.wp[x] + 0.5)*(1./(1L<<16));
861 if (dogamma) d = pow(d, cvts.gamcor);
862 if (cvts.bradj) d *= m;
863 colval(cvts.r.colors[x],RED) =
864 colval(cvts.r.colors[x],GRN) =
865 colval(cvts.r.colors[x],BLU) = d;
866 }
867 if (fwritescan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
868 quiterr("error writing Radiance picture");
869 }
870
871
872 static void
873 Color2GGry( /* read/convert/write COLOR->G16 scanline */
874 uint32 y
875 )
876 {
877 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
878 float m = pow(2.,(double)cvts.bradj);
879 register int x;
880
881 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD|C_GRY))
882 quiterr("internal error 1 in Color2GGry");
883
884 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
885 quiterr("error reading Radiance picture");
886
887 for (x = cvts.xmax; x--; ) {
888 register float f = m*( CHK(C_XYZE) ?
889 colval(cvts.r.colors[x],CIEY)
890 : bright(cvts.r.colors[x]) );
891 if (f <= 0)
892 cvts.t.wp[x] = 0;
893 else if (f >= 1)
894 cvts.t.wp[x] = 0xffff;
895 else if (dogamma)
896 cvts.t.wp[x] = (int)((float)(1L<<16) *
897 pow(f, 1./cvts.gamcor));
898 else
899 cvts.t.wp[x] = (int)((float)(1L<<16) * f);
900 }
901
902 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
903 quiterr("error writing TIFF output");
904 }
905
906
907 static void
908 Color2L( /* read/convert/write COLOR->Lfloat scanline */
909 uint32 y
910 )
911 {
912 float m = pow(2.,(double)cvts.bradj);
913 register int x;
914
915 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TFLT|C_GRY))
916 quiterr("internal error 1 in Color2L");
917
918 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
919 quiterr("error reading Radiance picture");
920
921 for (x = cvts.xmax; x--; )
922 cvts.t.fp[x] = m*( CHK(C_XYZE) ? colval(cvts.r.colors[x],CIEY)
923 : bright(cvts.r.colors[x]) );
924
925 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
926 quiterr("error writing TIFF output");
927 }
928
929
930 static void
931 Color2Luv( /* read/convert/write COLOR->Luv scanline */
932 uint32 y
933 )
934 {
935 register int x;
936
937 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != (C_RFLT|C_TFLT))
938 quiterr("internal error 1 in Color2Luv");
939
940 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
941 quiterr("error reading Radiance picture");
942
943 if (CHK(C_CXFM))
944 for (x = cvts.xmax; x--; )
945 colortrans(cvts.r.colors[x], cvts.cmat,
946 cvts.r.colors[x]);
947 if (cvts.bradj) {
948 double m = pow(2.,(double)cvts.bradj);
949 for (x = cvts.xmax; x--; )
950 scalecolor(cvts.r.colors[x], m);
951 }
952 /* also works for float RGB */
953 for (x = cvts.xmax; x--; ) {
954 cvts.t.fp[3*x] = colval(cvts.r.colors[x],CIEX);
955 cvts.t.fp[3*x+1] = colval(cvts.r.colors[x],CIEY);
956 cvts.t.fp[3*x+2] = colval(cvts.r.colors[x],CIEZ);
957 }
958
959 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
960 quiterr("error writing TIFF output");
961 }
962
963
964 static void
965 Color2RRGGBB( /* read/convert/write COLOR->RGB16 scanline */
966 uint32 y
967 )
968 {
969 int dogamma = (cvts.gamcor < 0.99) | (cvts.gamcor > 1.01);
970 float m = pow(2.,(double)cvts.bradj);
971 register int x, i;
972
973 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY) != (C_RFLT|C_TWRD))
974 quiterr("internal error 1 in Color2RRGGBB");
975
976 if (freadscan(cvts.r.colors, cvts.xmax, cvts.rfp) < 0)
977 quiterr("error reading Radiance picture");
978
979 for (x = cvts.xmax; x--; ) {
980 if (CHK(C_CXFM)) {
981 colortrans(cvts.r.colors[x], cvts.cmat,
982 cvts.r.colors[x]);
983 if (CHK(C_GAMUT))
984 clipgamut(cvts.r.colors[x], bright(cvts.r.colors[x]),
985 CGAMUT_LOWER, cblack, cwhite);
986 }
987 for (i = 3; i--; ) {
988 register float f = m*colval(cvts.r.colors[x],i);
989 if (f <= 0)
990 cvts.t.wp[3*x + i] = 0;
991 else if (f >= 1)
992 cvts.t.wp[3*x + i] = 0xffff;
993 else if (dogamma)
994 cvts.t.wp[3*x + i] = (int)((float)(1L<<16) *
995 pow(f, 1./cvts.gamcor));
996 else
997 cvts.t.wp[3*x + i] = (int)((float)(1L<<16)*f);
998 }
999 }
1000
1001 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1002 quiterr("error writing TIFF output");
1003 }
1004
1005
1006 static void
1007 Colr2Gry( /* read/convert/write COLR->RGB scanline */
1008 uint32 y
1009 )
1010 {
1011 register int x;
1012
1013 if (CHK(C_RFLT|C_TWRD|C_TFLT|C_GRY) != C_GRY)
1014 quiterr("internal error 1 in Colr2Gry");
1015
1016 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1017 quiterr("error reading Radiance picture");
1018
1019 if (cvts.bradj)
1020 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1021 for (x = cvts.xmax; x--; )
1022 colval(cvts.r.colrs[x],CIEY) = normbright(cvts.r.colrs[x]);
1023 colrs_gambs(cvts.r.colrs, cvts.xmax);
1024
1025 for (x = cvts.xmax; x--; )
1026 cvts.t.bp[x] = colval(cvts.r.colrs[x],CIEY);
1027
1028 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1029 quiterr("error writing TIFF output");
1030 }
1031
1032
1033 static void
1034 Colr2RGB( /* read/convert/write COLR->RGB scanline */
1035 uint32 y
1036 )
1037 {
1038 COLOR ctmp;
1039 register int x;
1040
1041 if (CHK(C_RFLT|C_TFLT|C_TWRD|C_GRY))
1042 quiterr("internal error 1 in Colr2RGB");
1043
1044 if (freadcolrs(cvts.r.colrs, cvts.xmax, cvts.rfp) < 0)
1045 quiterr("error reading Radiance picture");
1046
1047 if (cvts.bradj)
1048 shiftcolrs(cvts.r.colrs, cvts.xmax, cvts.bradj);
1049 if (CHK(C_CXFM))
1050 for (x = cvts.xmax; x--; ) {
1051 colr_color(ctmp, cvts.r.colrs[x]);
1052 colortrans(ctmp, cvts.cmat, ctmp);
1053 if (CHK(C_GAMUT))
1054 clipgamut(ctmp, bright(ctmp), CGAMUT,
1055 cblack, cwhite);
1056 setcolr(cvts.r.colrs[x], colval(ctmp,RED),
1057 colval(ctmp,GRN), colval(ctmp,BLU));
1058 }
1059 colrs_gambs(cvts.r.colrs, cvts.xmax);
1060
1061 for (x = cvts.xmax; x--; ) {
1062 cvts.t.bp[3*x] = cvts.r.colrs[x][RED];
1063 cvts.t.bp[3*x+1] = cvts.r.colrs[x][GRN];
1064 cvts.t.bp[3*x+2] = cvts.r.colrs[x][BLU];
1065 }
1066
1067 if (TIFFWriteScanline(cvts.tif, cvts.t.p, y, 0) < 0)
1068 quiterr("error writing TIFF output");
1069 }
