--- ray/src/px/ra_t8.c 2019/12/28 18:05:14 2.16 +++ ray/src/px/ra_t8.c 2023/02/09 21:54:11 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ra_t8.c,v 2.16 2019/12/28 18:05:14 greg Exp $"; +static const char RCSid[] = "$Id: ra_t8.c,v 2.17 2023/02/09 21:54:11 greg Exp $"; #endif /* * ra_t8.c - program to convert between RADIANCE and @@ -152,10 +152,10 @@ userr: static int getint2( /* get a 2-byte positive integer */ - register FILE *fp + FILE *fp ) { - register int b1, b2; + int b1, b2; if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF) quiterr("read error"); @@ -166,8 +166,8 @@ getint2( /* get a 2-byte positive integer */ static void putint2( /* put a 2-byte positive integer */ - register int i, - register FILE *fp + int i, + FILE *fp ) { putc(i&0xff, fp); @@ -189,16 +189,14 @@ quiterr( /* print message and exit */ void -eputs(s) -char *s; +eputs(const char *s) { fputs(s, stderr); } void -quit(code) -int code; +quit(int code) { exit(code); } @@ -208,7 +206,7 @@ static int getthead( /* read header from input */ struct hdStruct *hp, char *ip, - register FILE *fp + FILE *fp ) { int nidbytes; @@ -243,7 +241,7 @@ static int putthead( /* write header to output */ struct hdStruct *hp, char *ip, - register FILE *fp + FILE *fp ) { if (ip != NULL) @@ -271,7 +269,7 @@ putthead( /* write header to output */ static int getrhead( /* load RADIANCE input file header */ - register struct hdStruct *h, + struct hdStruct *h, FILE *fp ) { @@ -312,7 +310,7 @@ tg2ra( /* targa file to RADIANCE file */ } map; COLR ctab[256]; COLR *scanline; - register int i, j; + int i, j; /* get color table */ if ((hp->CMapBits==24 ? fread((char *)(map.c3+hp->mapOrig), @@ -359,7 +357,7 @@ getmapped( /* read in and quantize image */ ) { long fpos; - register int y; + int y; setcolrgam(gamv); fpos = ftell(stdin); @@ -408,8 +406,8 @@ getgrey( /* read in and convert to greyscale image * ) { int y; - register uby8 *dp; - register int x; + uby8 *dp; + int x; setcolrgam(gamv); dp = tarData+xmax*ymax;; @@ -443,7 +441,7 @@ writetarga( /* write out targa data */ FILE *fp ) { - register int i, j; + int i, j; for (i = 0; i < h->mapLength; i++) /* write color map */ for (j = 2; j >= 0; j--) @@ -464,8 +462,8 @@ readtarga( /* read in targa data */ FILE *fp ) { - register int cnt, c; - register uby8 *dp; + int cnt, c; + uby8 *dp; if (h->dataType == IM_CMAP) { /* uncompressed */ if (fread((char *)data,h->x*sizeof(uby8),h->y,fp) != h->y)
