root/Development/ray/src/px/ra_t8.c
Revision: 2.14
Committed: Fri May 20 02:06:39 2011 UTC (14 years, 7 months ago) by greg
CVS Tags: rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1
Changes since 2.13: +14 -14 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.14 static const char RCSid[] = "$Id: ra_t8.c,v 2.13 2004/03/28 20:33:14 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * ra_t8.c - program to convert between RADIANCE and
6     * Targa 8-bit color-mapped images.
7     *
8     * 8/22/88 Adapted from ra_pr.c
9     */
10
11     #include <stdio.h>
12 schorsch 2.13 #include <string.h>
13 greg 2.10 #include <time.h>
14 schorsch 2.12 #include <math.h>
15 greg 2.10
16 schorsch 2.12 #include "platform.h"
17 schorsch 2.13 #include "rtmisc.h"
18 greg 1.1 #include "color.h"
19 greg 1.12 #include "resolu.h"
20 schorsch 2.13 #include "clrtab.h"
21 greg 1.1 #include "targa.h"
22
23
24 greg 2.3 #define goodpic(h) (my_imType(h) && my_mapType(h))
25     #define my_imType(h) (((h)->dataType==IM_CMAP || (h)->dataType==IM_CCMAP) \
26 greg 1.1 && (h)->dataBits==8 && (h)->imType==0)
27 greg 2.3 #define my_mapType(h) ((h)->mapType==CM_HASMAP && \
28 greg 1.1 ((h)->CMapBits==24 || (h)->CMapBits==32))
29
30 greg 2.14 #define taralloc(h) (uby8 *)emalloc((h)->x*(h)->y)
31 greg 1.1
32 greg 2.14 uby8 clrtab[256][3];
33 greg 2.7 extern int samplefac;
34 greg 2.4 double gamv = 2.2; /* gamv correction */
35 greg 1.10 int bradj = 0; /* brightness adjustment */
36 greg 1.1 char *progname;
37     char errmsg[128];
38 greg 1.7 COLR *inl;
39 greg 2.14 uby8 *tarData;
40 schorsch 2.13 int xmax, ymax;
41 greg 1.1
42 schorsch 2.13 static int getint2(FILE *fp);
43     static void putint2(int i, FILE *fp);
44     static void quiterr(char *err);
45     static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
46     static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
47     static int getrhead(struct hdStruct *h, FILE *fp);
48     static void tg2ra(struct hdStruct *hp);
49     static void getmapped(int nc, int dith);
50     static void getgrey(int nc);
51 greg 2.14 static void writetarga(struct hdStruct *h, uby8 *d, FILE *fp);
52     static void readtarga(struct hdStruct *h, uby8 *data, FILE *fp);
53 greg 1.1
54
55 schorsch 2.13 int
56     main(
57     int argc,
58     char *argv[]
59     )
60 greg 1.1 {
61 greg 2.3 struct hdStruct head;
62 greg 1.1 int dither = 1;
63     int reverse = 0;
64     int ncolors = 256;
65     int greyscale = 0;
66     int i;
67 schorsch 2.12 SET_DEFAULT_BINARY();
68     SET_FILE_BINARY(stdin);
69     SET_FILE_BINARY(stdout);
70 greg 1.1 progname = argv[0];
71 greg 2.7 samplefac = 0;
72 greg 1.1
73     for (i = 1; i < argc; i++)
74     if (argv[i][0] == '-')
75     switch (argv[i][1]) {
76     case 'd':
77     dither = !dither;
78     break;
79     case 'g':
80 greg 2.4 gamv = atof(argv[++i]);
81 greg 1.1 break;
82     case 'r':
83     reverse = !reverse;
84     break;
85     case 'b':
86     greyscale = 1;
87     break;
88 greg 1.10 case 'e':
89     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
90     goto userr;
91     bradj = atoi(argv[++i]);
92     break;
93 greg 1.1 case 'c':
94     ncolors = atoi(argv[++i]);
95     break;
96 greg 2.7 case 'n':
97     samplefac = atoi(argv[++i]);
98     break;
99 greg 1.1 default:
100     goto userr;
101     }
102     else
103     break;
104
105 greg 2.4 if (i < argc-2)
106     goto userr;
107     if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
108     sprintf(errmsg, "cannot open input \"%s\"", argv[i]);
109     quiterr(errmsg);
110     }
111     if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
112     sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]);
113     quiterr(errmsg);
114     }
115 greg 1.1 if (reverse) {
116     /* get header */
117     if (getthead(&head, NULL, stdin) < 0)
118     quiterr("bad targa file");
119     if (!goodpic(&head))
120     quiterr("incompatible format");
121     xmax = head.x;
122     ymax = head.y;
123     /* put header */
124 greg 2.6 newheader("RADIANCE", stdout);
125 greg 1.6 printargs(i, argv, stdout);
126 greg 1.9 fputformat(COLRFMT, stdout);
127 greg 1.1 putchar('\n');
128 greg 1.12 fprtresolu(xmax, ymax, stdout);
129 greg 1.1 /* convert file */
130     tg2ra(&head);
131     } else {
132 greg 2.4 if (getrhead(&head, stdin) < 0)
133     quiterr("bad Radiance input");
134 greg 1.1 /* write header */
135     putthead(&head, NULL, stdout);
136     /* convert file */
137     if (greyscale)
138 greg 2.4 getgrey(ncolors);
139 greg 1.1 else
140 greg 2.4 getmapped(ncolors, dither);
141 greg 1.1 /* write data */
142     writetarga(&head, tarData, stdout);
143     }
144     quiterr(NULL);
145     userr:
146     fprintf(stderr,
147 greg 2.8 "Usage: %s [-d][-n samp][-c ncolors][-b][-g gamv][-e +/-stops] input [output]\n",
148 greg 1.1 progname);
149 greg 2.4 fprintf(stderr, " Or: %s -r [-g gamv][-e +/-stops] [input [output]]\n",
150 greg 1.1 progname);
151     exit(1);
152     }
153
154
155 schorsch 2.13 static int
156     getint2( /* get a 2-byte positive integer */
157     register FILE *fp
158     )
159 greg 1.1 {
160     register int b1, b2;
161
162     if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
163     quiterr("read error");
164
165     return(b1 | b2<<8);
166     }
167
168
169 schorsch 2.13 static void
170     putint2( /* put a 2-byte positive integer */
171     register int i,
172     register FILE *fp
173     )
174 greg 1.1 {
175     putc(i&0xff, fp);
176     putc(i>>8&0xff, fp);
177     }
178
179
180 schorsch 2.13 static void
181     quiterr( /* print message and exit */
182     char *err
183     )
184 greg 1.1 {
185     if (err != NULL) {
186     fprintf(stderr, "%s: %s\n", progname, err);
187     exit(1);
188     }
189     exit(0);
190     }
191
192
193 greg 2.10 void
194 greg 1.1 eputs(s)
195     char *s;
196     {
197     fputs(s, stderr);
198     }
199
200
201 greg 2.10 void
202 greg 1.1 quit(code)
203     int code;
204     {
205     exit(code);
206     }
207
208
209 schorsch 2.13 static int
210     getthead( /* read header from input */
211     struct hdStruct *hp,
212     char *ip,
213     register FILE *fp
214     )
215 greg 1.1 {
216     int nidbytes;
217
218     if ((nidbytes = getc(fp)) == EOF)
219     return(-1);
220     hp->mapType = getc(fp);
221     hp->dataType = getc(fp);
222     hp->mapOrig = getint2(fp);
223     hp->mapLength = getint2(fp);
224     hp->CMapBits = getc(fp);
225     hp->XOffset = getint2(fp);
226     hp->YOffset = getint2(fp);
227     hp->x = getint2(fp);
228     hp->y = getint2(fp);
229     hp->dataBits = getc(fp);
230     hp->imType = getc(fp);
231
232     if (ip != NULL)
233     if (nidbytes)
234 greg 1.4 fread((char *)ip, nidbytes, 1, fp);
235 greg 1.1 else
236     *ip = '\0';
237     else if (nidbytes)
238     fseek(fp, (long)nidbytes, 1);
239
240     return(feof(fp) || ferror(fp) ? -1 : 0);
241     }
242
243
244 schorsch 2.13 static int
245     putthead( /* write header to output */
246     struct hdStruct *hp,
247     char *ip,
248     register FILE *fp
249     )
250 greg 1.1 {
251     if (ip != NULL)
252     putc(strlen(ip), fp);
253     else
254     putc(0, fp);
255     putc(hp->mapType, fp);
256     putc(hp->dataType, fp);
257     putint2(hp->mapOrig, fp);
258     putint2(hp->mapLength, fp);
259     putc(hp->CMapBits, fp);
260     putint2(hp->XOffset, fp);
261     putint2(hp->YOffset, fp);
262     putint2(hp->x, fp);
263     putint2(hp->y, fp);
264     putc(hp->dataBits, fp);
265     putc(hp->imType, fp);
266
267     if (ip != NULL)
268     fputs(ip, fp);
269
270     return(ferror(fp) ? -1 : 0);
271     }
272
273
274 schorsch 2.13 static int
275     getrhead( /* load RADIANCE input file header */
276     register struct hdStruct *h,
277     FILE *fp
278     )
279 greg 1.1 {
280 greg 1.9 /* get header info. */
281 greg 2.4 if (checkheader(fp, COLRFMT, NULL) < 0 ||
282     fgetresolu(&xmax, &ymax, fp) < 0)
283     return(-1);
284 greg 1.1 /* assign header */
285     h->textSize = 0;
286     h->mapType = CM_HASMAP;
287     h->dataType = IM_CMAP;
288     h->mapOrig = 0;
289     h->mapLength = 256;
290     h->CMapBits = 24;
291     h->XOffset = 0;
292     h->YOffset = 0;
293     h->x = xmax;
294     h->y = ymax;
295     h->dataBits = 8;
296     h->imType = 0;
297     /* allocate scanline */
298 greg 1.7 inl = (COLR *)emalloc(xmax*sizeof(COLR));
299 greg 1.1 /* allocate targa data */
300     tarData = taralloc(h);
301
302 greg 2.4 return(0);
303 greg 1.1 }
304
305
306 schorsch 2.13 static void
307     tg2ra( /* targa file to RADIANCE file */
308     struct hdStruct *hp
309     )
310 greg 1.1 {
311     union {
312 greg 2.14 uby8 c3[256][3];
313     uby8 c4[256][4];
314 greg 1.1 } map;
315     COLR ctab[256];
316     COLR *scanline;
317     register int i, j;
318
319     /* get color table */
320 greg 1.12 if ((hp->CMapBits==24 ? fread((char *)(map.c3+hp->mapOrig),
321     3*hp->mapLength,1,stdin) :
322     fread((char *)(map.c4+hp->mapOrig),
323     4*hp->mapLength,1,stdin)) != 1)
324 greg 1.1 quiterr("error reading color table");
325     /* convert table */
326     for (i = hp->mapOrig; i < hp->mapOrig+hp->mapLength; i++)
327     if (hp->CMapBits == 24)
328     setcolr(ctab[i],
329 greg 2.4 pow((map.c3[i][2]+.5)/256.,gamv),
330     pow((map.c3[i][1]+.5)/256.,gamv),
331     pow((map.c3[i][0]+.5)/256.,gamv));
332 greg 1.1 else
333     setcolr(ctab[i],
334 greg 2.4 pow((map.c4[i][3]+.5)/256.,gamv),
335     pow((map.c4[i][2]+.5)/256.,gamv),
336     pow((map.c4[i][1]+.5)/256.,gamv));
337 greg 1.10 if (bradj)
338     shiftcolrs(ctab, 256, bradj);
339 greg 1.1 /* allocate targa data */
340     tarData = taralloc(hp);
341     /* get data */
342     readtarga(hp, tarData, stdin);
343     /* allocate input scanline */
344     scanline = (COLR *)emalloc(xmax*sizeof(COLR));
345     /* convert file */
346     for (i = ymax-1; i >= 0; i--) {
347     for (j = 0; j < xmax; j++)
348     copycolr(scanline[j], ctab[tarData[i*xmax+j]]);
349     if (fwritecolrs(scanline, xmax, stdout) < 0)
350     quiterr("error writing RADIANCE file");
351     }
352 greg 2.10 free((void *)scanline);
353     free((void *)tarData);
354 greg 1.1 }
355
356
357 schorsch 2.13 static void
358     getmapped( /* read in and quantize image */
359     int nc, /* number of colors to use */
360     int dith /* use dithering? */
361     )
362 greg 1.1 {
363 greg 2.4 long fpos;
364     register int y;
365 greg 1.1
366 greg 2.4 setcolrgam(gamv);
367     fpos = ftell(stdin);
368 greg 2.7 if ((samplefac ? neu_init(xmax*ymax) : new_histo(xmax*ymax)) == -1)
369     quiterr("cannot initialized histogram");
370 greg 2.4 for (y = ymax-1; y >= 0; y--) {
371     if (freadcolrs(inl, xmax, stdin) < 0)
372     quiterr("error reading Radiance input");
373     if (bradj)
374     shiftcolrs(inl, xmax, bradj);
375     colrs_gambs(inl, xmax);
376 greg 2.7 if (samplefac)
377     neu_colrs(inl, xmax);
378     else
379     cnt_colrs(inl, xmax);
380 greg 1.1 }
381 greg 2.4 if (fseek(stdin, fpos, 0) == EOF)
382     quiterr("Radiance input must be from a file");
383 greg 2.7 if (samplefac) /* map colors */
384     neu_clrtab(nc);
385     else
386     new_clrtab(nc);
387 greg 2.4 for (y = ymax-1; y >= 0; y--) {
388     if (freadcolrs(inl, xmax, stdin) < 0)
389     quiterr("error reading Radiance input");
390     if (bradj)
391     shiftcolrs(inl, xmax, bradj);
392     colrs_gambs(inl, xmax);
393 greg 2.7 if (samplefac)
394     if (dith)
395     neu_dith_colrs(tarData+y*xmax, inl, xmax);
396     else
397     neu_map_colrs(tarData+y*xmax, inl, xmax);
398 greg 2.4 else
399 greg 2.7 if (dith)
400     dith_colrs(tarData+y*xmax, inl, xmax);
401     else
402     map_colrs(tarData+y*xmax, inl, xmax);
403 greg 2.4 }
404 greg 1.1 }
405
406
407 schorsch 2.13 static void
408     getgrey( /* read in and convert to greyscale image */
409     int nc /* number of colors to use */
410     )
411 greg 1.1 {
412 greg 2.4 int y;
413 greg 2.14 register uby8 *dp;
414 greg 2.4 register int x;
415
416     setcolrgam(gamv);
417     dp = tarData+xmax*ymax;;
418     for (y = ymax-1; y >= 0; y--) {
419     if (freadcolrs(inl, xmax, stdin) < 0)
420     quiterr("error reading Radiance input");
421     if (bradj)
422     shiftcolrs(inl, xmax, bradj);
423 greg 2.5 x = xmax;
424     while (x--)
425     inl[x][GRN] = normbright(inl[x]);
426 greg 2.4 colrs_gambs(inl, xmax);
427     x = xmax;
428     if (nc < 256)
429     while (x--)
430 greg 2.5 *--dp = ((long)inl[x][GRN]*nc+nc/2)>>8;
431 greg 2.4 else
432     while (x--)
433 greg 2.5 *--dp = inl[x][GRN];
434 greg 2.4 }
435     for (x = 0; x < nc; x++)
436     clrtab[x][RED] = clrtab[x][GRN] =
437 greg 2.5 clrtab[x][BLU] = ((long)x*256+128)/nc;
438 greg 1.1 }
439
440
441 schorsch 2.13 static void
442     writetarga( /* write out targa data */
443     struct hdStruct *h,
444 greg 2.14 uby8 *d,
445 schorsch 2.13 FILE *fp
446     )
447 greg 1.1 {
448 greg 2.4 register int i, j;
449
450     for (i = 0; i < h->mapLength; i++) /* write color map */
451     for (j = 2; j >= 0; j--)
452     putc(clrtab[i][j], fp);
453 greg 1.1 if (h->dataType == IM_CMAP) { /* uncompressed */
454 greg 2.14 if (fwrite((char *)d,h->x*sizeof(uby8),h->y,fp) != h->y)
455 greg 1.1 quiterr("error writing targa file");
456     return;
457     }
458     quiterr("unsupported output type");
459     }
460
461
462 schorsch 2.13 static void
463     readtarga( /* read in targa data */
464     struct hdStruct *h,
465 greg 2.14 uby8 *data,
466 schorsch 2.13 FILE *fp
467     )
468 greg 1.1 {
469     register int cnt, c;
470 greg 2.14 register uby8 *dp;
471 greg 1.1
472     if (h->dataType == IM_CMAP) { /* uncompressed */
473 greg 2.14 if (fread((char *)data,h->x*sizeof(uby8),h->y,fp) != h->y)
474 greg 1.1 goto readerr;
475     return;
476     }
477     for (dp = data; dp < data+h->x*h->y; ) {
478     if ((c = getc(fp)) == EOF)
479     goto readerr;
480     cnt = (c & 0x7f) + 1;
481     if (c & 0x80) { /* repeated pixel */
482     if ((c = getc(fp)) == EOF)
483     goto readerr;
484     while (cnt--)
485     *dp++ = c;
486     } else /* non-repeating pixels */
487     while (cnt--) {
488     if ((c = getc(fp)) == EOF)
489     goto readerr;
490     *dp++ = c;
491     }
492     }
493     return;
494     readerr:
495     quiterr("error reading targa file");
496     }
