root/radiance/ray/src/px/ra_t8.c
Fri May 20 02:06:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 2.13: +14 -14 lines
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.12: +76 -50 lines
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.11: +6 -19 lines
Tue May 13 17:58:33 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.10: +0 -0 lines
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.9: +7 -6 lines
Fri Nov 10 17:04:52 1995 UTC (29 years, 6 months ago) by greg
Changes since 2.8: +0 -1 lines
removed memcpy() declaration
Mon Nov 21 15:55:55 1994 UTC (30 years, 5 months ago) by greg
fixed Usage message to mention -n option
Fri Jun 10 12:51:18 1994 UTC (30 years, 11 months ago) by greg
Changes since 2.6: +26 -7 lines
Sun Feb 27 10:17:23 1994 UTC (31 years, 2 months ago) by greg
Wed Nov 11 17:34:12 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.4: +6 -3 lines
fixed bug in greyscale conversion
Tue Oct 13 11:36:13 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.3: +97 -130 lines
changed ra_t8 to use clrtab.c
Fri Oct 9 15:24:21 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.2: +25 -16 lines
Changes for 32-bit PC port
Thu Dec 19 14:52:23 1991 UTC (33 years, 4 months ago) by greg
Tue Nov 12 16:05:11 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 2.5
Mon Nov 11 14:01:53 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.11: +8 -4 lines
Diff to previous 1.11 , to selected 2.5
Fri Aug 23 13:40:01 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.10 , to selected 2.5
changed default gamma to 2.2, the NTSC standard value
Wed Aug 7 08:36:37 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.9: +14 -6 lines
Diff to previous 1.9 , to selected 2.5
added -e +/-stops option
Thu Apr 18 14:35:45 1991 UTC (34 years ago) by greg
Diff to previous 1.8 , to selected 2.5
Wed Nov 7 13:10:33 1990 UTC (34 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.5
minor improvement in gamma correction
Mon Mar 12 15:14:46 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.6: +8 -8 lines
Diff to previous 1.6 , to selected 2.5
changed "inline" to "inl" for compiler compatibility
Fri Feb 9 13:59:23 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.5 , to selected 2.5
changed arguments printed in header
Fri Jan 26 08:17:39 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.4 , to selected 2.5
Thu Jan 18 23:58:24 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.3: +10 -6 lines
Diff to previous 1.3 , to selected 2.5
Fri Oct 20 20:36:06 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.2: +7 -26 lines
change to color normalization calls
Tue Sep 12 13:04:38 1989 UTC (35 years, 8 months ago) by greg
Thu Feb 2 10:49:37 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.5
