--- ray/src/px/ra_t8.c 1992/10/13 11:36:13 2.4 +++ ray/src/px/ra_t8.c 1994/11/21 15:55:55 2.8 @@ -38,8 +38,10 @@ extern char *memcpy(); #define taralloc(h) (BYTE *)emalloc((h)->x*(h)->y) -extern BYTE clrtab[][3]; +BYTE clrtab[256][3]; +extern int samplefac; + extern char *ecalloc(), *emalloc(); extern long ftell(); @@ -76,6 +78,7 @@ char *argv[]; setmode(fileno(stdout), O_BINARY); #endif progname = argv[0]; + samplefac = 0; for (i = 1; i < argc; i++) if (argv[i][0] == '-') @@ -100,6 +103,9 @@ char *argv[]; case 'c': ncolors = atoi(argv[++i]); break; + case 'n': + samplefac = atoi(argv[++i]); + break; default: goto userr; } @@ -125,6 +131,7 @@ char *argv[]; xmax = head.x; ymax = head.y; /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); @@ -147,7 +154,7 @@ char *argv[]; quiterr(NULL); userr: fprintf(stderr, - "Usage: %s [-d][-c ncolors][-b][-g gamv][-e +/-stops] input [output]\n", + "Usage: %s [-d][-n samp][-c ncolors][-b][-g gamv][-e +/-stops] input [output]\n", progname); fprintf(stderr, " Or: %s -r [-g gamv][-e +/-stops] [input [output]]\n", progname); @@ -351,28 +358,41 @@ int dith; /* use dithering? */ setcolrgam(gamv); fpos = ftell(stdin); - new_histo(); /* build histogram */ + if ((samplefac ? neu_init(xmax*ymax) : new_histo(xmax*ymax)) == -1) + quiterr("cannot initialized histogram"); for (y = ymax-1; y >= 0; y--) { if (freadcolrs(inl, xmax, stdin) < 0) quiterr("error reading Radiance input"); if (bradj) shiftcolrs(inl, xmax, bradj); colrs_gambs(inl, xmax); - cnt_colrs(inl, xmax); + if (samplefac) + neu_colrs(inl, xmax); + else + cnt_colrs(inl, xmax); } if (fseek(stdin, fpos, 0) == EOF) quiterr("Radiance input must be from a file"); - new_clrtab(nc); /* map colors */ + if (samplefac) /* map colors */ + neu_clrtab(nc); + else + new_clrtab(nc); for (y = ymax-1; y >= 0; y--) { if (freadcolrs(inl, xmax, stdin) < 0) quiterr("error reading Radiance input"); if (bradj) shiftcolrs(inl, xmax, bradj); colrs_gambs(inl, xmax); - if (dith) - dith_colrs(tarData+y*xmax, inl, xmax); + if (samplefac) + if (dith) + neu_dith_colrs(tarData+y*xmax, inl, xmax); + else + neu_map_colrs(tarData+y*xmax, inl, xmax); else - map_colrs(tarData+y*xmax, inl, xmax); + if (dith) + dith_colrs(tarData+y*xmax, inl, xmax); + else + map_colrs(tarData+y*xmax, inl, xmax); } } @@ -391,18 +411,21 @@ int nc; /* number of colors to use */ quiterr("error reading Radiance input"); if (bradj) shiftcolrs(inl, xmax, bradj); + x = xmax; + while (x--) + inl[x][GRN] = normbright(inl[x]); colrs_gambs(inl, xmax); x = xmax; if (nc < 256) while (x--) - *--dp = ((long)normbright(inl[x])*nc+128)>>8; + *--dp = ((long)inl[x][GRN]*nc+nc/2)>>8; else while (x--) - *--dp = normbright(inl[x]); + *--dp = inl[x][GRN]; } for (x = 0; x < nc; x++) clrtab[x][RED] = clrtab[x][GRN] = - clrtab[x][BLU] = ((long)x*256+nc/2)/nc; + clrtab[x][BLU] = ((long)x*256+128)/nc; }
