root/radiance/ray/src/px/ra_t8.c
Revision: 2.18
Committed: Fri Jun 6 19:11:21 2025 UTC (6 weeks, 4 days ago) by greg
refactor: Making use of printargs() more consistent with fixargv0()
2 static const char RCSid[] = "$Id: ra_t8.c,v 2.17 2023/02/09 21:54:11 greg Exp $";
5 * ra_t8.c - program to convert between RADIANCE and
6 * Targa 8-bit color-mapped images.
7 *
8 * 8/22/88 Adapted from ra_pr.c
9 */
10
11 #include <math.h>
12 #include "paths.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "rtmisc.h"
16 #include "color.h"
17 #include "resolu.h"
18 #include "clrtab.h"
19 #include "targa.h"
20
21
22 #define goodpic(h) (my_imType(h) && my_mapType(h))
23 #define my_imType(h) (((h)->dataType==IM_CMAP || (h)->dataType==IM_CCMAP) \
24 && (h)->dataBits==8 && (h)->imType==0)
25 #define my_mapType(h) ((h)->mapType==CM_HASMAP && \
26 ((h)->CMapBits==24 || (h)->CMapBits==32))
27
28 #define taralloc(h) (uby8 *)emalloc((h)->x*(h)->y)
29
30 uby8 clrtab[256][3];
31 extern int samplefac;
32 double gamv = 2.2; /* gamv correction */
33 int bradj = 0; /* brightness adjustment */
34 char errmsg[128];
35 COLR *inl;
36 uby8 *tarData;
37 int xmax, ymax;
38
39 static int getint2(FILE *fp);
40 static void putint2(int i, FILE *fp);
41 static void quiterr(char *err);
42 static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
43 static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
44 static int getrhead(struct hdStruct *h, FILE *fp);
45 static void tg2ra(struct hdStruct *hp);
46 static void getmapped(int nc, int dith);
47 static void getgrey(int nc);
48 static void writetarga(struct hdStruct *h, uby8 *d, FILE *fp);
49 static void readtarga(struct hdStruct *h, uby8 *data, FILE *fp);
50
51
52 int
53 main(
54 int argc,
55 char *argv[]
56 )
57 {
58 struct hdStruct head;
59 int dither = 1;
60 int reverse = 0;
61 int ncolors = 256;
62 int greyscale = 0;
63 int i;
64
65 SET_DEFAULT_BINARY();
66 SET_FILE_BINARY(stdin);
67 SET_FILE_BINARY(stdout);
68 fixargv0(argv[0]);
69 samplefac = 0;
70
71 for (i = 1; i < argc; i++)
72 if (argv[i][0] == '-')
73 switch (argv[i][1]) {
74 case 'd':
75 dither = !dither;
76 break;
77 case 'g':
78 gamv = atof(argv[++i]);
79 break;
80 case 'r':
81 reverse = !reverse;
82 break;
83 case 'b':
84 greyscale = 1;
85 break;
86 case 'e':
87 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
88 goto userr;
89 bradj = atoi(argv[++i]);
90 break;
91 case 'c':
92 ncolors = atoi(argv[++i]);
93 break;
94 case 'n':
95 samplefac = atoi(argv[++i]);
96 break;
97 default:
98 goto userr;
99 }
100 else
101 break;
102
103 if (i < argc-2)
104 goto userr;
105 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
106 sprintf(errmsg, "cannot open input \"%s\"", argv[i]);
107 quiterr(errmsg);
108 }
109 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
110 sprintf(errmsg, "cannot open output \"%s\"", argv[i+1]);
111 quiterr(errmsg);
112 }
113 if (reverse) {
114 /* get header */
115 if (getthead(&head, NULL, stdin) < 0)
116 quiterr("bad targa file");
117 if (!goodpic(&head))
118 quiterr("incompatible format");
119 xmax = head.x;
120 ymax = head.y;
121 /* put header */
122 newheader("RADIANCE", stdout);
123 printargs(i, argv, stdout);
124 fputformat(COLRFMT, stdout);
125 putchar('\n');
126 fprtresolu(xmax, ymax, stdout);
127 /* convert file */
128 tg2ra(&head);
129 } else {
130 if (getrhead(&head, stdin) < 0)
131 quiterr("bad Radiance input");
132 /* write header */
133 putthead(&head, NULL, stdout);
134 /* convert file */
135 if (greyscale)
136 getgrey(ncolors);
137 else
138 getmapped(ncolors, dither);
139 /* write data */
140 writetarga(&head, tarData, stdout);
141 }
142 quiterr(NULL);
143 userr:
144 fprintf(stderr,
145 "Usage: %s [-d][-n samp][-c ncolors][-b][-g gamv][-e +/-stops] input [output]\n",
146 progname);
147 fprintf(stderr, " Or: %s -r [-g gamv][-e +/-stops] [input [output]]\n",
148 progname);
149 exit(1);
150 }
151
152
153 static int
154 getint2( /* get a 2-byte positive integer */
155 FILE *fp
156 )
157 {
158 int b1, b2;
159
160 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
161 quiterr("read error");
162
163 return(b1 | b2<<8);
164 }
165
166
167 static void
168 putint2( /* put a 2-byte positive integer */
169 int i,
170 FILE *fp
171 )
172 {
173 putc(i&0xff, fp);
174 putc(i>>8&0xff, fp);
175 }
176
177
178 static void
179 quiterr( /* print message and exit */
180 char *err
181 )
182 {
183 if (err != NULL) {
184 fprintf(stderr, "%s: %s\n", progname, err);
185 exit(1);
186 }
187 exit(0);
188 }
189
190
191 void
192 eputs(const char *s)
193 {
194 fputs(s, stderr);
195 }
196
197
198 void
199 quit(int code)
200 {
201 exit(code);
202 }
203
204
205 static int
206 getthead( /* read header from input */
207 struct hdStruct *hp,
208 char *ip,
209 FILE *fp
210 )
211 {
212 int nidbytes;
213
214 if ((nidbytes = getc(fp)) == EOF)
215 return(-1);
216 hp->mapType = getc(fp);
217 hp->dataType = getc(fp);
218 hp->mapOrig = getint2(fp);
219 hp->mapLength = getint2(fp);
220 hp->CMapBits = getc(fp);
221 hp->XOffset = getint2(fp);
222 hp->YOffset = getint2(fp);
223 hp->x = getint2(fp);
224 hp->y = getint2(fp);
225 hp->dataBits = getc(fp);
226 hp->imType = getc(fp);
227
228 if (ip != NULL)
229 if (nidbytes)
230 fread((char *)ip, nidbytes, 1, fp);
231 else
232 *ip = '\0';
233 else if (nidbytes)
234 fseek(fp, (long)nidbytes, 1);
235
236 return(feof(fp) || ferror(fp) ? -1 : 0);
237 }
238
239
240 static int
241 putthead( /* write header to output */
242 struct hdStruct *hp,
243 char *ip,
244 FILE *fp
245 )
246 {
247 if (ip != NULL)
248 putc(strlen(ip), fp);
249 else
250 putc(0, fp);
251 putc(hp->mapType, fp);
252 putc(hp->dataType, fp);
253 putint2(hp->mapOrig, fp);
254 putint2(hp->mapLength, fp);
255 putc(hp->CMapBits, fp);
256 putint2(hp->XOffset, fp);
257 putint2(hp->YOffset, fp);
258 putint2(hp->x, fp);
259 putint2(hp->y, fp);
260 putc(hp->dataBits, fp);
261 putc(hp->imType, fp);
262
263 if (ip != NULL)
264 fputs(ip, fp);
265
266 return(ferror(fp) ? -1 : 0);
267 }
268
269
270 static int
271 getrhead( /* load RADIANCE input file header */
272 struct hdStruct *h,
273 FILE *fp
274 )
275 {
276 /* get header info. */
277 if (checkheader(fp, COLRFMT, NULL) < 0 ||
278 fgetresolu(&xmax, &ymax, fp) < 0)
279 return(-1);
280 /* assign header */
281 h->textSize = 0;
282 h->mapType = CM_HASMAP;
283 h->dataType = IM_CMAP;
284 h->mapOrig = 0;
285 h->mapLength = 256;
286 h->CMapBits = 24;
287 h->XOffset = 0;
288 h->YOffset = 0;
289 h->x = xmax;
290 h->y = ymax;
291 h->dataBits = 8;
292 h->imType = 0;
293 /* allocate scanline */
294 inl = (COLR *)emalloc(xmax*sizeof(COLR));
295 /* allocate targa data */
296 tarData = taralloc(h);
297
298 return(0);
299 }
300
301
302 static void
303 tg2ra( /* targa file to RADIANCE file */
304 struct hdStruct *hp
305 )
306 {
307 union {
308 uby8 c3[256][3];
309 uby8 c4[256][4];
310 } map;
311 COLR ctab[256];
312 COLR *scanline;
313 int i, j;
314
315 /* get color table */
316 if ((hp->CMapBits==24 ? fread((char *)(map.c3+hp->mapOrig),
317 3*hp->mapLength,1,stdin) :
318 fread((char *)(map.c4+hp->mapOrig),
319 4*hp->mapLength,1,stdin)) != 1)
320 quiterr("error reading color table");
321 /* convert table */
322 for (i = hp->mapOrig; i < hp->mapOrig+hp->mapLength; i++)
323 if (hp->CMapBits == 24)
324 setcolr(ctab[i],
325 pow((map.c3[i][2]+.5)/256.,gamv),
326 pow((map.c3[i][1]+.5)/256.,gamv),
327 pow((map.c3[i][0]+.5)/256.,gamv));
328 else
329 setcolr(ctab[i],
330 pow((map.c4[i][3]+.5)/256.,gamv),
331 pow((map.c4[i][2]+.5)/256.,gamv),
332 pow((map.c4[i][1]+.5)/256.,gamv));
333 if (bradj)
334 shiftcolrs(ctab, 256, bradj);
335 /* allocate targa data */
336 tarData = taralloc(hp);
337 /* get data */
338 readtarga(hp, tarData, stdin);
339 /* allocate input scanline */
340 scanline = (COLR *)emalloc(xmax*sizeof(COLR));
341 /* convert file */
342 for (i = ymax-1; i >= 0; i--) {
343 for (j = 0; j < xmax; j++)
344 copycolr(scanline[j], ctab[tarData[i*xmax+j]]);
345 if (fwritecolrs(scanline, xmax, stdout) < 0)
346 quiterr("error writing RADIANCE file");
347 }
348 free((void *)scanline);
349 free((void *)tarData);
350 }
351
352
353 static void
354 getmapped( /* read in and quantize image */
355 int nc, /* number of colors to use */
356 int dith /* use dithering? */
357 )
358 {
359 long fpos;
360 int y;
361
362 setcolrgam(gamv);
363 fpos = ftell(stdin);
364 if ((samplefac ? neu_init(xmax*ymax) : new_histo(xmax*ymax)) == -1)
365 quiterr("cannot initialized histogram");
366 for (y = ymax-1; y >= 0; y--) {
367 if (freadcolrs(inl, xmax, stdin) < 0)
368 quiterr("error reading Radiance input");
369 if (bradj)
370 shiftcolrs(inl, xmax, bradj);
371 colrs_gambs(inl, xmax);
372 if (samplefac)
373 neu_colrs(inl, xmax);
374 else
375 cnt_colrs(inl, xmax);
376 }
377 if (fseek(stdin, fpos, 0) == EOF)
378 quiterr("Radiance input must be from a file");
379 if (samplefac) /* map colors */
380 neu_clrtab(nc);
381 else
382 new_clrtab(nc);
383 for (y = ymax-1; y >= 0; y--) {
384 if (freadcolrs(inl, xmax, stdin) < 0)
385 quiterr("error reading Radiance input");
386 if (bradj)
387 shiftcolrs(inl, xmax, bradj);
388 colrs_gambs(inl, xmax);
389 if (samplefac)
390 if (dith)
391 neu_dith_colrs(tarData+y*xmax, inl, xmax);
392 else
393 neu_map_colrs(tarData+y*xmax, inl, xmax);
394 else
395 if (dith)
396 dith_colrs(tarData+y*xmax, inl, xmax);
397 else
398 map_colrs(tarData+y*xmax, inl, xmax);
399 }
400 }
401
402
403 static void
404 getgrey( /* read in and convert to greyscale image */
405 int nc /* number of colors to use */
406 )
407 {
408 int y;
409 uby8 *dp;
410 int x;
411
412 setcolrgam(gamv);
413 dp = tarData+xmax*ymax;;
414 for (y = ymax-1; y >= 0; y--) {
415 if (freadcolrs(inl, xmax, stdin) < 0)
416 quiterr("error reading Radiance input");
417 if (bradj)
418 shiftcolrs(inl, xmax, bradj);
419 x = xmax;
420 while (x--)
421 inl[x][GRN] = normbright(inl[x]);
422 colrs_gambs(inl, xmax);
423 x = xmax;
424 if (nc < 256)
425 while (x--)
426 *--dp = ((long)inl[x][GRN]*nc+nc/2)>>8;
427 else
428 while (x--)
429 *--dp = inl[x][GRN];
430 }
431 for (x = 0; x < nc; x++)
432 clrtab[x][RED] = clrtab[x][GRN] =
433 clrtab[x][BLU] = ((long)x*256+128)/nc;
434 }
435
436
437 static void
438 writetarga( /* write out targa data */
439 struct hdStruct *h,
440 uby8 *d,
441 FILE *fp
442 )
443 {
444 int i, j;
445
446 for (i = 0; i < h->mapLength; i++) /* write color map */
447 for (j = 2; j >= 0; j--)
448 putc(clrtab[i][j], fp);
449 if (h->dataType == IM_CMAP) { /* uncompressed */
450 if (fwrite((char *)d,h->x*sizeof(uby8),h->y,fp) != h->y)
451 quiterr("error writing targa file");
452 return;
453 }
454 quiterr("unsupported output type");
455 }
456
457
458 static void
459 readtarga( /* read in targa data */
460 struct hdStruct *h,
461 uby8 *data,
462 FILE *fp
463 )
464 {
465 int cnt, c;
466 uby8 *dp;
467
468 if (h->dataType == IM_CMAP) { /* uncompressed */
469 if (fread((char *)data,h->x*sizeof(uby8),h->y,fp) != h->y)
470 goto readerr;
471 return;
472 }
473 for (dp = data; dp < data+h->x*h->y; ) {
474 if ((c = getc(fp)) == EOF)
475 goto readerr;
476 cnt = (c & 0x7f) + 1;
477 if (c & 0x80) { /* repeated pixel */
478 if ((c = getc(fp)) == EOF)
479 goto readerr;
480 while (cnt--)
481 *dp++ = c;
482 } else /* non-repeating pixels */
483 while (cnt--) {
484 if ((c = getc(fp)) == EOF)
485 goto readerr;
486 *dp++ = c;
487 }
488 }
489 return;
490 readerr:
491 quiterr("error reading targa file");
492 }
