root/radiance/ray/src/px/ra_t16.c
Revision: 2.6
Committed: Sat Feb 22 02:07:28 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.5: +9 -8 lines
5 * ra_t16.c - program to convert between RADIANCE and
6 * Targa 16, 24 and 32-bit images.
7 *
8 * 11/2/88 Adapted from ra_t8.c
9 */
10
11 #include <stdio.h>
12
13 #ifdef MSDOS
14 #include <fcntl.h>
15 #endif
16
17 #include <time.h>
18
19 #include <math.h>
20
21 #include "color.h"
22
23 #include "resolu.h"
24
25 #include "random.h"
26
27 #include "targa.h"
28
29 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
30 && ((h)->dataBits==16 || (h)->dataBits==24))
31
32 #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
33
34 #define readtarga(h,d,f) ((h)->dataBits==16 ? readt16(h,d,f) : \
35 readt24(h,d,f))
36
37 #define writetarga(h,d,f) ((h)->dataBits==16 ? writet16(h,d,f) : \
38 writet24(h,d,f))
39
40 extern char *ecalloc(), *emalloc();
41
42 double gamcor = 2.2; /* gamma correction */
43
44 int bradj = 0; /* brightness adjustment */
45
46 char *progname;
47
48 char msg[128];
49
50
51 main(argc, argv)
52 int argc;
53 char *argv[];
54 {
55 struct hdStruct head;
56 int reverse = 0;
57 int i;
58 #ifdef MSDOS
59 extern int _fmode;
60 _fmode = O_BINARY;
61 setmode(fileno(stdin), O_BINARY);
62 setmode(fileno(stdout), O_BINARY);
63 #endif
64 progname = argv[0];
65
66 head.dataBits = 16;
67 for (i = 1; i < argc; i++)
68 if (argv[i][0] == '-')
69 switch (argv[i][1]) {
70 case 'g':
71 gamcor = atof(argv[++i]);
72 break;
73 case 'r':
74 reverse = !reverse;
75 break;
76 case '2':
77 head.dataBits = 16;
78 break;
79 case '3':
80 head.dataBits = 24;
81 break;
82 case 'e':
83 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
84 goto userr;
85 bradj = atoi(argv[++i]);
86 break;
87 default:
88 goto userr;
89 }
90 else
91 break;
92
93 if (i < argc-2)
94 goto userr;
95 /* open input file */
96 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
97 sprintf(msg, "can't open input \"%s\"", argv[i]);
98 quiterr(msg);
99 }
100 /* open output file */
101 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
102 sprintf(msg, "can't open output \"%s\"", argv[i+1]);
103 quiterr(msg);
104 }
105 /* set gamma */
106 setcolrgam(gamcor);
107 /* convert */
108 if (reverse) {
109 /* get header */
110 if (getthead(&head, NULL, stdin) < 0)
111 quiterr("bad targa file");
112 if (!goodpic(&head))
113 quiterr("incompatible format");
114 /* put header */
115 newheader("RADIANCE", stdout);
116 printargs(i, argv, stdout);
117 fputformat(COLRFMT, stdout);
118 putchar('\n');
119 fprtresolu(head.x, head.y, stdout);
120 /* convert file */
121 tg2ra(&head);
122 } else {
123 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
124 fgetresolu(&head.x, &head.y, stdin) < 0)
125 quiterr("bad picture file");
126 /* assign header */
127 head.textSize = 0;
128 head.mapType = CM_NOMAP;
129 head.dataType = IM_RGB;
130 head.XOffset = 0;
131 head.YOffset = 0;
132 head.imType = 0;
133 /* write header */
134 putthead(&head, NULL, stdout);
135 /* convert file */
136 ra2tg(&head);
137 }
138 exit(0);
139 userr:
140 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
141 progname);
142 exit(1);
143 }
144
145
146 int
147 getint2(fp) /* get a 2-byte positive integer */
148 register FILE *fp;
149 {
150 register int b1, b2;
151
152 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
153 quiterr("read error");
154
155 return(b1 | b2<<8);
156 }
157
158
159 putint2(i, fp) /* put a 2-byte positive integer */
160 register int i;
161 register FILE *fp;
162 {
163 putc(i&0xff, fp);
164 putc(i>>8&0xff, fp);
165 }
166
167
168 quiterr(err) /* print message and exit */
169 char *err;
170 {
171 fprintf(stderr, "%s: %s\n", progname, err);
172 exit(1);
173 }
174
175
176 void
177 eputs(s)
178 char *s;
179 {
180 fputs(s, stderr);
181 }
182
183
184 void
185 quit(code)
186 int code;
187 {
188 exit(code);
189 }
190
191
192 getthead(hp, ip, fp) /* read header from input */
193 struct hdStruct *hp;
194 char *ip;
195 register FILE *fp;
196 {
197 int nidbytes;
198
199 if ((nidbytes = getc(fp)) == EOF)
200 return(-1);
201 hp->mapType = getc(fp);
202 hp->dataType = getc(fp);
203 hp->mapOrig = getint2(fp);
204 hp->mapLength = getint2(fp);
205 hp->CMapBits = getc(fp);
206 hp->XOffset = getint2(fp);
207 hp->YOffset = getint2(fp);
208 hp->x = getint2(fp);
209 hp->y = getint2(fp);
210 hp->dataBits = getc(fp);
211 hp->imType = getc(fp);
212
213 if (ip != NULL)
214 if (nidbytes)
215 fread((char *)ip, nidbytes, 1, fp);
216 else
217 *ip = '\0';
218 else if (nidbytes)
219 fseek(fp, (long)nidbytes, 1);
220
221 return(feof(fp) || ferror(fp) ? -1 : 0);
222 }
223
224
225 putthead(hp, ip, fp) /* write header to output */
226 struct hdStruct *hp;
227 char *ip;
228 register FILE *fp;
229 {
230 if (ip != NULL)
231 putc(strlen(ip), fp);
232 else
233 putc(0, fp);
234 putc(hp->mapType, fp);
235 putc(hp->dataType, fp);
236 putint2(hp->mapOrig, fp);
237 putint2(hp->mapLength, fp);
238 putc(hp->CMapBits, fp);
239 putint2(hp->XOffset, fp);
240 putint2(hp->YOffset, fp);
241 putint2(hp->x, fp);
242 putint2(hp->y, fp);
243 putc(hp->dataBits, fp);
244 putc(hp->imType, fp);
245
246 if (ip != NULL)
247 fputs(ip, fp);
248
249 return(ferror(fp) ? -1 : 0);
250 }
251
252
253 tg2ra(hp) /* targa file to RADIANCE file */
254 struct hdStruct *hp;
255 {
256 COLR *scanline;
257 unsigned char *tarData;
258 register int i, j;
259 /* skip color table */
260 if (hp->mapType == CM_HASMAP)
261 fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
262 /* allocate targa data */
263 tarData = taralloc(hp);
264 /* get data */
265 readtarga(hp, tarData, stdin);
266 /* allocate input scanline */
267 scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
268 /* convert file */
269 for (i = hp->y-1; i >= 0; i--) {
270 if (hp->dataBits == 16) {
271 register unsigned short *dp;
272 dp = (unsigned short *)tarData + i*hp->x;
273 for (j = 0; j < hp->x; j++) {
274 scanline[j][RED] = *dp>>7 & 0xf8;
275 scanline[j][GRN] = *dp>>2 & 0xf8;
276 scanline[j][BLU] = *dp<<3 & 0xf8;
277 dp++;
278 }
279 } else { /* hp->dataBits == 24 */
280 register unsigned char *dp;
281 dp = (unsigned char *)tarData + i*3*hp->x;
282 for (j = 0; j < hp->x; j++) {
283 scanline[j][RED] = dp[2];
284 scanline[j][GRN] = dp[1];
285 scanline[j][BLU] = dp[0];
286 dp += 3;
287 }
288 }
289 gambs_colrs(scanline, hp->x);
290 if (bradj)
291 shiftcolrs(scanline, hp->x, bradj);
292 if (fwritecolrs(scanline, hp->x, stdout) < 0)
293 quiterr("error writing RADIANCE file");
294 }
295 free((void *)scanline);
296 free((void *)tarData);
297 }
298
299
300 ra2tg(hp) /* convert radiance to targa file */
301 struct hdStruct *hp;
302 {
303 register int i, j;
304 unsigned char *tarData;
305 COLR *inl;
306 /* allocate space for data */
307 inl = (COLR *)emalloc(hp->x*sizeof(COLR));
308 tarData = taralloc(hp);
309 /* convert file */
310 for (j = hp->y-1; j >= 0; j--) {
311 if (freadcolrs(inl, hp->x, stdin) < 0)
312 quiterr("error reading RADIANCE file");
313 if (bradj)
314 shiftcolrs(inl, hp->x, bradj);
315 colrs_gambs(inl, hp->x);
316 if (hp->dataBits == 16) {
317 register unsigned short *dp;
318 register int v;
319 dp = (unsigned short *)tarData + j*hp->x;
320 for (i = 0; i < hp->x; i++) {
321 v = inl[i][RED] + (random()&7);
322 if (v > 255) v = 255;
323 *dp = (v&0xf8)<<7;
324 v = inl[i][GRN] + (random()&7);
325 if (v > 255) v = 255;
326 *dp |= (v&0xf8)<<2;
327 v = inl[i][BLU] + (random()&7);
328 if (v > 255) v = 255;
329 *dp++ |= v>>3;
330 }
331 } else { /* hp->dataBits == 24 */
332 register unsigned char *dp;
333 dp = (unsigned char *)tarData + j*3*hp->x;
334 for (i = 0; i < hp->x; i++) {
335 *dp++ = inl[i][BLU];
336 *dp++ = inl[i][GRN];
337 *dp++ = inl[i][RED];
338 }
339 }
340 }
341 /* write out targa data */
342 writetarga(hp, tarData, stdout);
343
344 free((void *)inl);
345 free((void *)tarData);
346 }
347
348
349 writet24(h, d, fp) /* write out 24-bit targa data */
350 struct hdStruct *h;
351 unsigned char *d;
352 FILE *fp;
353 {
354 if (h->dataType == IM_RGB) { /* uncompressed */
355 if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
356 quiterr("error writing targa file");
357 return;
358 }
359 quiterr("unsupported output type");
360 }
361
362
363 writet16(h, d, fp) /* write out 16-bit targa data */
364 struct hdStruct *h;
365 register unsigned short *d;
366 FILE *fp;
367 {
368 register int cnt;
369
370 if (h->dataType == IM_RGB) { /* uncompressed */
371 for (cnt = h->x*h->y; cnt-- > 0; )
372 putint2(*d++, fp);
373 if (ferror(fp))
374 quiterr("error writing targa file");
375 return;
376 }
377 quiterr("unsupported output type");
378 }
379
380
381 readt24(h, data, fp) /* read in 24-bit targa data */
382 register struct hdStruct *h;
383 unsigned char *data;
384 FILE *fp;
385 {
386 register int cnt, c;
387 register unsigned char *dp;
388 int r, g, b;
389
390 if (h->dataType == IM_RGB) { /* uncompressed */
391 if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
392 goto readerr;
393 return;
394 }
395 for (dp = data; dp < data+3*h->x*h->y; ) {
396 if ((c = getc(fp)) == EOF)
397 goto readerr;
398 cnt = (c & 0x7f) + 1;
399 if (c & 0x80) { /* repeated pixel */
400 b = getc(fp); g = getc(fp);
401 if ((r = getc(fp)) == EOF)
402 goto readerr;
403 while (cnt--) {
404 *dp++ = b;
405 *dp++ = g;
406 *dp++ = r;
407 }
408 } else /* non-repeating pixels */
409 while (cnt--) {
410 *dp++ = getc(fp); *dp++ = getc(fp);
411 if ((r = getc(fp)) == EOF)
412 goto readerr;
413 *dp++ = r;
414 }
415 }
416 return;
417 readerr:
418 quiterr("error reading targa file");
419 }
420
421
422 readt16(h, data, fp) /* read in 16-bit targa data */
423 register struct hdStruct *h;
424 unsigned short *data;
425 FILE *fp;
426 {
427 register int cnt, c;
428 register unsigned short *dp;
429
430 if (h->dataType == IM_RGB) { /* uncompressed */
431 dp = data;
432 for (cnt = h->x*h->y; cnt-- > 0; )
433 *dp++ = getint2(fp);
434 return;
435 }
436 for (dp = data; dp < data+h->x*h->y; ) {
437 if ((c = getc(fp)) == EOF)
438 goto readerr;
439 cnt = (c & 0x7f) + 1;
440 if (c & 0x80) { /* repeated pixel */
441 c = getint2(fp);
442 while (cnt--)
443 *dp++ = c;
444 } else /* non-repeating pixels */
445 while (cnt--)
446 *dp++ = getint2(fp);
447 }
448 return;
449 readerr:
450 quiterr("error reading targa file");
451 }
