root/radiance/ray/src/px/ra_t16.c
Revision: 1.3
Committed: Sun Jul 23 11:35:48 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.2: +16 -21 lines
Added dithering to 16-bit conversion
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ra_t16.c - program to convert between RADIANCE and
9 * Targa 16, 24 and 32-bit images.
10 *
11 * 11/2/88 Adapted from ra_t8.c
12 */
13
14 #include <stdio.h>
15
16 #include "color.h"
17
18 #include "targa.h"
19
20 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
21 && ((h)->dataBits==16 || (h)->dataBits==24))
22
23 #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
24
25 #define readtarga(h,d,f) ((h)->dataBits==16 ? readt16(h,d,f) : \
26 readt24(h,d,f))
27
28 #define writetarga(h,d,f) ((h)->dataBits==16 ? writet16(h,d,f) : \
29 writet24(h,d,f))
30
31 extern char *ecalloc(), *emalloc();
32
33 extern double atof(), pow();
34
35 double gamma = 2.0; /* gamma correction */
36
37 char *progname;
38
39 char msg[128];
40
41
42 main(argc, argv)
43 int argc;
44 char *argv[];
45 {
46 struct hdStruct head;
47 int reverse = 0;
48 int i;
49
50 progname = argv[0];
51
52 head.dataBits = 16;
53 for (i = 1; i < argc; i++)
54 if (argv[i][0] == '-')
55 switch (argv[i][1]) {
56 case 'g':
57 gamma = atof(argv[++i]);
58 break;
59 case 'r':
60 reverse = !reverse;
61 break;
62 case '2':
63 head.dataBits = 16;
64 break;
65 case '3':
66 head.dataBits = 24;
67 break;
68 default:
69 goto userr;
70 }
71 else
72 break;
73
74 if (i < argc-2)
75 goto userr;
76 /* open input file */
77 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
78 sprintf(msg, "can't open input \"%s\"", argv[i]);
79 quiterr(msg);
80 }
81 /* open output file */
82 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
83 sprintf(msg, "can't open output \"%s\"", argv[i+1]);
84 quiterr(msg);
85 }
86 /* convert */
87 if (reverse) {
88 /* get header */
89 if (getthead(&head, NULL, stdin) < 0)
90 quiterr("bad targa file");
91 if (!goodpic(&head))
92 quiterr("incompatible format");
93 /* put header */
94 printargs(argc, argv, stdout);
95 putchar('\n');
96 printf("-Y %d +X %d\n", head.y, head.x);
97 /* convert file */
98 tg2ra(&head);
99 } else {
100 getheader(stdin, NULL);
101 if (scanf("-Y %d +X %d\n", &head.y, &head.x) != 2)
102 quiterr("bad picture file");
103 /* assign header */
104 head.textSize = 0;
105 head.mapType = CM_NOMAP;
106 head.dataType = IM_RGB;
107 head.XOffset = 0;
108 head.YOffset = 0;
109 head.imType = 0;
110 /* write header */
111 putthead(&head, NULL, stdout);
112 /* convert file */
113 ra2tg(&head);
114 }
115 exit(0);
116 userr:
117 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma] [input [output]]\n",
118 progname);
119 exit(1);
120 }
121
122
123 int
124 getint2(fp) /* get a 2-byte positive integer */
125 register FILE *fp;
126 {
127 register int b1, b2;
128
129 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
130 quiterr("read error");
131
132 return(b1 | b2<<8);
133 }
134
135
136 putint2(i, fp) /* put a 2-byte positive integer */
137 register int i;
138 register FILE *fp;
139 {
140 putc(i&0xff, fp);
141 putc(i>>8&0xff, fp);
142 }
143
144
145 quiterr(err) /* print message and exit */
146 char *err;
147 {
148 fprintf(stderr, "%s: %s\n", progname, err);
149 exit(1);
150 }
151
152
153 eputs(s)
154 char *s;
155 {
156 fputs(s, stderr);
157 }
158
159
160 quit(code)
161 int code;
162 {
163 exit(code);
164 }
165
166
167 getthead(hp, ip, fp) /* read header from input */
168 struct hdStruct *hp;
169 char *ip;
170 register FILE *fp;
171 {
172 int nidbytes;
173
174 if ((nidbytes = getc(fp)) == EOF)
175 return(-1);
176 hp->mapType = getc(fp);
177 hp->dataType = getc(fp);
178 hp->mapOrig = getint2(fp);
179 hp->mapLength = getint2(fp);
180 hp->CMapBits = getc(fp);
181 hp->XOffset = getint2(fp);
182 hp->YOffset = getint2(fp);
183 hp->x = getint2(fp);
184 hp->y = getint2(fp);
185 hp->dataBits = getc(fp);
186 hp->imType = getc(fp);
187
188 if (ip != NULL)
189 if (nidbytes)
190 fread(ip, nidbytes, 1, fp);
191 else
192 *ip = '\0';
193 else if (nidbytes)
194 fseek(fp, (long)nidbytes, 1);
195
196 return(feof(fp) || ferror(fp) ? -1 : 0);
197 }
198
199
200 putthead(hp, ip, fp) /* write header to output */
201 struct hdStruct *hp;
202 char *ip;
203 register FILE *fp;
204 {
205 if (ip != NULL)
206 putc(strlen(ip), fp);
207 else
208 putc(0, fp);
209 putc(hp->mapType, fp);
210 putc(hp->dataType, fp);
211 putint2(hp->mapOrig, fp);
212 putint2(hp->mapLength, fp);
213 putc(hp->CMapBits, fp);
214 putint2(hp->XOffset, fp);
215 putint2(hp->YOffset, fp);
216 putint2(hp->x, fp);
217 putint2(hp->y, fp);
218 putc(hp->dataBits, fp);
219 putc(hp->imType, fp);
220
221 if (ip != NULL)
222 fputs(ip, fp);
223
224 return(ferror(fp) ? -1 : 0);
225 }
226
227
228 tg2ra(hp) /* targa file to RADIANCE file */
229 struct hdStruct *hp;
230 {
231 float gmap[256];
232 COLOR *scanline;
233 unsigned char *tarData;
234 register int i, j;
235 /* set up gamma correction */
236 for (i = 0; i < 256; i++)
237 gmap[i] = pow((i+.5)/256., gamma);
238 /* skip color table */
239 if (hp->mapType == CM_HASMAP)
240 fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
241 /* allocate targa data */
242 tarData = taralloc(hp);
243 /* get data */
244 readtarga(hp, tarData, stdin);
245 /* allocate input scanline */
246 scanline = (COLOR *)emalloc(hp->x*sizeof(COLOR));
247 /* convert file */
248 for (i = hp->y-1; i >= 0; i--) {
249 if (hp->dataBits == 16) {
250 register unsigned short *dp;
251 dp = (unsigned short *)tarData + i*hp->x;
252 for (j = 0; j < hp->x; j++) {
253 setcolor(scanline[j], gmap[*dp>>7 & 0xf8],
254 gmap[*dp>>2 & 0xf8],
255 gmap[*dp<<3 & 0xf8]);
256 dp++;
257 }
258 } else { /* hp->dataBits == 24 */
259 register unsigned char *dp;
260 dp = (unsigned char *)tarData + i*3*hp->x;
261 for (j = 0; j < hp->x; j++) {
262 setcolor(scanline[j], gmap[dp[2]],
263 gmap[dp[1]],
264 gmap[dp[0]]);
265 dp += 3;
266 }
267 }
268 if (fwritescan(scanline, hp->x, stdout) < 0)
269 quiterr("error writing RADIANCE file");
270 }
271 free((char *)scanline);
272 free((char *)tarData);
273 }
274
275
276 ra2tg(hp) /* convert radiance to targa file */
277 struct hdStruct *hp;
278 {
279 #define map(v) (v >= 1.0 ? 1023 : (int)(v*1023.+.5))
280 unsigned char gmap[1024];
281 register int i, j;
282 unsigned char *tarData;
283 COLOR *inline;
284 /* set up gamma correction */
285 for (i = 0; i < 1024; i++) {
286 j = 256.*pow((i+.5)/1024., 1./gamma);
287 gmap[i] = hp->dataBits == 16 && j > 248 ? 248 : j;
288 }
289 /* allocate space for data */
290 inline = (COLOR *)emalloc(hp->x*sizeof(COLOR));
291 tarData = taralloc(hp);
292 /* convert file */
293 for (j = hp->y-1; j >= 0; j--) {
294 if (freadscan(inline, hp->x, stdin) < 0)
295 quiterr("error reading RADIANCE file");
296 if (hp->dataBits == 16) {
297 register unsigned short *dp;
298 dp = (unsigned short *)tarData + j*hp->x;
299 for (i = 0; i < hp->x; i++) {
300 *dp = ((gmap[map(colval(inline[i],RED))]
301 +(random()&7)) & 0xf8)<<7;
302 *dp |= ((gmap[map(colval(inline[i],GRN))]
303 +(random()&7)) & 0xf8)<<2;
304 *dp++ |= (gmap[map(colval(inline[i],BLU))]
305 +(random()&7))>>3;
306 }
307 } else { /* hp->dataBits == 24 */
308 register unsigned char *dp;
309 dp = (unsigned char *)tarData + j*3*hp->x;
310 for (i = 0; i < hp->x; i++) {
311 *dp++ = gmap[map(colval(inline[i],BLU))];
312 *dp++ = gmap[map(colval(inline[i],GRN))];
313 *dp++ = gmap[map(colval(inline[i],RED))];
314 }
315 }
316 }
317 /* write out targa data */
318 writetarga(hp, tarData, stdout);
319
320 free((char *)inline);
321 free((char *)tarData);
322 #undef map
323 }
324
325
326 writet24(h, d, fp) /* write out 24-bit targa data */
327 struct hdStruct *h;
328 unsigned char *d;
329 FILE *fp;
330 {
331 if (h->dataType == IM_RGB) { /* uncompressed */
332 if (fwrite(d, 3*h->x, h->y, fp) != h->y)
333 quiterr("error writing targa file");
334 return;
335 }
336 quiterr("unsupported output type");
337 }
338
339
340 writet16(h, d, fp) /* write out 16-bit targa data */
341 struct hdStruct *h;
342 register unsigned short *d;
343 FILE *fp;
344 {
345 register int cnt;
346
347 if (h->dataType == IM_RGB) { /* uncompressed */
348 for (cnt = h->x*h->y; cnt-- > 0; )
349 putint2(*d++, fp);
350 if (ferror(fp))
351 quiterr("error writing targa file");
352 return;
353 }
354 quiterr("unsupported output type");
355 }
356
357
358 readt24(h, data, fp) /* read in 24-bit targa data */
359 register struct hdStruct *h;
360 unsigned char *data;
361 FILE *fp;
362 {
363 register int cnt, c;
364 register unsigned char *dp;
365 int r, g, b;
366
367 if (h->dataType == IM_RGB) { /* uncompressed */
368 if (fread(data, 3*h->x, h->y, fp) != h->y)
369 goto readerr;
370 return;
371 }
372 for (dp = data; dp < data+3*h->x*h->y; ) {
373 if ((c = getc(fp)) == EOF)
374 goto readerr;
375 cnt = (c & 0x7f) + 1;
376 if (c & 0x80) { /* repeated pixel */
377 b = getc(fp); g = getc(fp);
378 if ((r = getc(fp)) == EOF)
379 goto readerr;
380 while (cnt--) {
381 *dp++ = b;
382 *dp++ = g;
383 *dp++ = r;
384 }
385 } else /* non-repeating pixels */
386 while (cnt--) {
387 *dp++ = getc(fp); *dp++ = getc(fp);
388 if ((r = getc(fp)) == EOF)
389 goto readerr;
390 *dp++ = r;
391 }
392 }
393 return;
394 readerr:
395 quiterr("error reading targa file");
396 }
397
398
399 readt16(h, data, fp) /* read in 16-bit targa data */
400 register struct hdStruct *h;
401 unsigned short *data;
402 FILE *fp;
403 {
404 register int cnt, c;
405 register unsigned short *dp;
406
407 if (h->dataType == IM_RGB) { /* uncompressed */
408 dp = data;
409 for (cnt = h->x*h->y; cnt-- > 0; )
410 *dp++ = getint2(fp);
411 return;
412 }
413 for (dp = data; dp < data+h->x*h->y; ) {
414 if ((c = getc(fp)) == EOF)
415 goto readerr;
416 cnt = (c & 0x7f) + 1;
417 if (c & 0x80) { /* repeated pixel */
418 c = getint2(fp);
419 while (cnt--)
420 *dp++ = c;
421 } else /* non-repeating pixels */
422 while (cnt--)
423 *dp++ = getint2(fp);
424 }
425 return;
426 readerr:
427 quiterr("error reading targa file");
428 }
