root/radiance/ray/src/px/ra_t16.c
Revision: 2.8
Committed: Sun Mar 28 20:33:14 2004 UTC (20 years, 2 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 2.7: +84 -53 lines
2 static const char RCSid[] = "$Id: ra_t16.c,v 2.7 2003/06/05 19:29:34 schorsch Exp $";
5 * ra_t16.c - program to convert between RADIANCE and
6 * Targa 16, 24 and 32-bit images.
7 *
8 * 11/2/88 Adapted from ra_t8.c
9 */
10
11 #include <stdio.h>
12 #include <string.h>
13 #include <time.h>
14 #include <math.h>
15
16 #include "platform.h"
17 #include "rtmisc.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "random.h"
21 #include "targa.h"
22
23 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
24 && ((h)->dataBits==16 || (h)->dataBits==24))
25
26 #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
27
28 #define readtarga(h,d,f) ((h)->dataBits==16 ? \
29 readt16(h,(unsigned short*)d,f) : readt24(h,d,f))
30
31 #define writetarga(h,d,f) ((h)->dataBits==16 ? \
32 writet16(h,(unsigned short*)d,f) : writet24(h,d,f))
33
34 double gamcor = 2.2; /* gamma correction */
35 int bradj = 0; /* brightness adjustment */
36 char *progname;
37 char msg[128];
38
39 static int getint2(FILE *fp);
40 static void putint2(int i, FILE *fp);
41 static void quiterr(char *err);
42 static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
43 static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
44 static void tg2ra(struct hdStruct *hp);
45 static void ra2tg(struct hdStruct *hp);
46 static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp);
47 static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp);
48 static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp);
49 static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp);
50
51
52 int
53 main(int argc, char *argv[])
54 {
55 struct hdStruct head;
56 int reverse = 0;
57 int i;
58 SET_DEFAULT_BINARY();
59 SET_FILE_BINARY(stdin);
60 SET_FILE_BINARY(stdout);
61 progname = argv[0];
62
63 head.dataBits = 16;
64 for (i = 1; i < argc; i++)
65 if (argv[i][0] == '-')
66 switch (argv[i][1]) {
67 case 'g':
68 gamcor = atof(argv[++i]);
69 break;
70 case 'r':
71 reverse = !reverse;
72 break;
73 case '2':
74 head.dataBits = 16;
75 break;
76 case '3':
77 head.dataBits = 24;
78 break;
79 case 'e':
80 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
81 goto userr;
82 bradj = atoi(argv[++i]);
83 break;
84 default:
85 goto userr;
86 }
87 else
88 break;
89
90 if (i < argc-2)
91 goto userr;
92 /* open input file */
93 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
94 sprintf(msg, "can't open input \"%s\"", argv[i]);
95 quiterr(msg);
96 }
97 /* open output file */
98 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
99 sprintf(msg, "can't open output \"%s\"", argv[i+1]);
100 quiterr(msg);
101 }
102 /* set gamma */
103 setcolrgam(gamcor);
104 /* convert */
105 if (reverse) {
106 /* get header */
107 if (getthead(&head, NULL, stdin) < 0)
108 quiterr("bad targa file");
109 if (!goodpic(&head))
110 quiterr("incompatible format");
111 /* put header */
112 newheader("RADIANCE", stdout);
113 printargs(i, argv, stdout);
114 fputformat(COLRFMT, stdout);
115 putchar('\n');
116 fprtresolu(head.x, head.y, stdout);
117 /* convert file */
118 tg2ra(&head);
119 } else {
120 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
121 fgetresolu(&head.x, &head.y, stdin) < 0)
122 quiterr("bad picture file");
123 /* assign header */
124 head.textSize = 0;
125 head.mapType = CM_NOMAP;
126 head.dataType = IM_RGB;
127 head.XOffset = 0;
128 head.YOffset = 0;
129 head.imType = 0;
130 /* write header */
131 putthead(&head, NULL, stdout);
132 /* convert file */
133 ra2tg(&head);
134 }
135 exit(0);
136 userr:
137 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
138 progname);
139 exit(1);
140 }
141
142
143 static int
144 getint2( /* get a 2-byte positive integer */
145 register FILE *fp
146 )
147 {
148 register int b1, b2;
149
150 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
151 quiterr("read error");
152
153 return(b1 | b2<<8);
154 }
155
156
157 static void
158 putint2( /* put a 2-byte positive integer */
159 register int i,
160 register FILE *fp
161 )
162 {
163 putc(i&0xff, fp);
164 putc(i>>8&0xff, fp);
165 }
166
167
168 static void
169 quiterr( /* print message and exit */
170 char *err
171 )
172 {
173 fprintf(stderr, "%s: %s\n", progname, err);
174 exit(1);
175 }
176
177
178 void
179 eputs(
180 char *s
181 )
182 {
183 fputs(s, stderr);
184 }
185
186
187 void
188 quit(
189 int code
190 )
191 {
192 exit(code);
193 }
194
195
196 static int
197 getthead( /* read header from input */
198 struct hdStruct *hp,
199 char *ip,
200 register FILE *fp
201 )
202 {
203 int nidbytes;
204
205 if ((nidbytes = getc(fp)) == EOF)
206 return(-1);
207 hp->mapType = getc(fp);
208 hp->dataType = getc(fp);
209 hp->mapOrig = getint2(fp);
210 hp->mapLength = getint2(fp);
211 hp->CMapBits = getc(fp);
212 hp->XOffset = getint2(fp);
213 hp->YOffset = getint2(fp);
214 hp->x = getint2(fp);
215 hp->y = getint2(fp);
216 hp->dataBits = getc(fp);
217 hp->imType = getc(fp);
218
219 if (ip != NULL)
220 if (nidbytes)
221 fread((char *)ip, nidbytes, 1, fp);
222 else
223 *ip = '\0';
224 else if (nidbytes)
225 fseek(fp, (long)nidbytes, 1);
226
227 return(feof(fp) || ferror(fp) ? -1 : 0);
228 }
229
230
231 static int
232 putthead( /* write header to output */
233 struct hdStruct *hp,
234 char *ip,
235 register FILE *fp
236 )
237 {
238 if (ip != NULL)
239 putc(strlen(ip), fp);
240 else
241 putc(0, fp);
242 putc(hp->mapType, fp);
243 putc(hp->dataType, fp);
244 putint2(hp->mapOrig, fp);
245 putint2(hp->mapLength, fp);
246 putc(hp->CMapBits, fp);
247 putint2(hp->XOffset, fp);
248 putint2(hp->YOffset, fp);
249 putint2(hp->x, fp);
250 putint2(hp->y, fp);
251 putc(hp->dataBits, fp);
252 putc(hp->imType, fp);
253
254 if (ip != NULL)
255 fputs(ip, fp);
256
257 return(ferror(fp) ? -1 : 0);
258 }
259
260
261 static void
262 tg2ra( /* targa file to RADIANCE file */
263 struct hdStruct *hp
264 )
265 {
266 COLR *scanline;
267 unsigned char *tarData;
268 register int i, j;
269 /* skip color table */
270 if (hp->mapType == CM_HASMAP)
271 fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
272 /* allocate targa data */
273 tarData = taralloc(hp);
274 /* get data */
275 readtarga(hp, tarData, stdin);
276 /* allocate input scanline */
277 scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
278 /* convert file */
279 for (i = hp->y-1; i >= 0; i--) {
280 if (hp->dataBits == 16) {
281 register unsigned short *dp;
282 dp = (unsigned short *)tarData + i*hp->x;
283 for (j = 0; j < hp->x; j++) {
284 scanline[j][RED] = *dp>>7 & 0xf8;
285 scanline[j][GRN] = *dp>>2 & 0xf8;
286 scanline[j][BLU] = *dp<<3 & 0xf8;
287 dp++;
288 }
289 } else { /* hp->dataBits == 24 */
290 register unsigned char *dp;
291 dp = (unsigned char *)tarData + i*3*hp->x;
292 for (j = 0; j < hp->x; j++) {
293 scanline[j][RED] = dp[2];
294 scanline[j][GRN] = dp[1];
295 scanline[j][BLU] = dp[0];
296 dp += 3;
297 }
298 }
299 gambs_colrs(scanline, hp->x);
300 if (bradj)
301 shiftcolrs(scanline, hp->x, bradj);
302 if (fwritecolrs(scanline, hp->x, stdout) < 0)
303 quiterr("error writing RADIANCE file");
304 }
305 free((void *)scanline);
306 free((void *)tarData);
307 }
308
309
310 static void
311 ra2tg( /* convert radiance to targa file */
312 struct hdStruct *hp
313 )
314 {
315 register int i, j;
316 unsigned char *tarData;
317 COLR *inl;
318 /* allocate space for data */
319 inl = (COLR *)emalloc(hp->x*sizeof(COLR));
320 tarData = taralloc(hp);
321 /* convert file */
322 for (j = hp->y-1; j >= 0; j--) {
323 if (freadcolrs(inl, hp->x, stdin) < 0)
324 quiterr("error reading RADIANCE file");
325 if (bradj)
326 shiftcolrs(inl, hp->x, bradj);
327 colrs_gambs(inl, hp->x);
328 if (hp->dataBits == 16) {
329 register unsigned short *dp;
330 register int v;
331 dp = (unsigned short *)tarData + j*hp->x;
332 for (i = 0; i < hp->x; i++) {
333 v = inl[i][RED] + (random()&7);
334 if (v > 255) v = 255;
335 *dp = (v&0xf8)<<7;
336 v = inl[i][GRN] + (random()&7);
337 if (v > 255) v = 255;
338 *dp |= (v&0xf8)<<2;
339 v = inl[i][BLU] + (random()&7);
340 if (v > 255) v = 255;
341 *dp++ |= v>>3;
342 }
343 } else { /* hp->dataBits == 24 */
344 register unsigned char *dp;
345 dp = (unsigned char *)tarData + j*3*hp->x;
346 for (i = 0; i < hp->x; i++) {
347 *dp++ = inl[i][BLU];
348 *dp++ = inl[i][GRN];
349 *dp++ = inl[i][RED];
350 }
351 }
352 }
353 /* write out targa data */
354 writetarga(hp, tarData, stdout);
355
356 free((void *)inl);
357 free((void *)tarData);
358 }
359
360
361 static void
362 writet24( /* write out 24-bit targa data */
363 struct hdStruct *h,
364 unsigned char *d,
365 FILE *fp
366 )
367 {
368 if (h->dataType == IM_RGB) { /* uncompressed */
369 if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
370 quiterr("error writing targa file");
371 return;
372 }
373 quiterr("unsupported output type");
374 }
375
376
377 static void
378 writet16( /* write out 16-bit targa data */
379 struct hdStruct *h,
380 register unsigned short *d,
381 FILE *fp
382 )
383 {
384 register int cnt;
385
386 if (h->dataType == IM_RGB) { /* uncompressed */
387 for (cnt = h->x*h->y; cnt-- > 0; )
388 putint2(*d++, fp);
389 if (ferror(fp))
390 quiterr("error writing targa file");
391 return;
392 }
393 quiterr("unsupported output type");
394 }
395
396
397 static void
398 readt24( /* read in 24-bit targa data */
399 register struct hdStruct *h,
400 unsigned char *data,
401 FILE *fp
402 )
403 {
404 register int cnt, c;
405 register unsigned char *dp;
406 int r, g, b;
407
408 if (h->dataType == IM_RGB) { /* uncompressed */
409 if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
410 goto readerr;
411 return;
412 }
413 for (dp = data; dp < data+3*h->x*h->y; ) {
414 if ((c = getc(fp)) == EOF)
415 goto readerr;
416 cnt = (c & 0x7f) + 1;
417 if (c & 0x80) { /* repeated pixel */
418 b = getc(fp); g = getc(fp);
419 if ((r = getc(fp)) == EOF)
420 goto readerr;
421 while (cnt--) {
422 *dp++ = b;
423 *dp++ = g;
424 *dp++ = r;
425 }
426 } else /* non-repeating pixels */
427 while (cnt--) {
428 *dp++ = getc(fp); *dp++ = getc(fp);
429 if ((r = getc(fp)) == EOF)
430 goto readerr;
431 *dp++ = r;
432 }
433 }
434 return;
435 readerr:
436 quiterr("error reading targa file");
437 }
438
439
440 static void
441 readt16( /* read in 16-bit targa data */
442 register struct hdStruct *h,
443 unsigned short *data,
444 FILE *fp
445 )
446 {
447 register int cnt, c;
448 register unsigned short *dp;
449
450 if (h->dataType == IM_RGB) { /* uncompressed */
451 dp = data;
452 for (cnt = h->x*h->y; cnt-- > 0; )
453 *dp++ = getint2(fp);
454 return;
455 }
456 for (dp = data; dp < data+h->x*h->y; ) {
457 if ((c = getc(fp)) == EOF)
458 goto readerr;
459 cnt = (c & 0x7f) + 1;
460 if (c & 0x80) { /* repeated pixel */
461 c = getint2(fp);
462 while (cnt--)
463 *dp++ = c;
464 } else /* non-repeating pixels */
465 while (cnt--)
466 *dp++ = getint2(fp);
467 }
468 return;
469 readerr:
470 quiterr("error reading targa file");
471 }
