Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
renamed gamma to avoid conflict with some math libraries
changed default gamma to 2.2, the NTSC standard value
added -e +/-stops option
fixed bug in 16-bit ra2tg() code
fixed error introduced with byte ordering in ra2tg with 24-bit
changed gamma correction to colrops calls
changed "inline" to "inl" for compiler compatibility
changed arguments printed in header
added missing include file "random.h"
Added dithering to 16-bit conversion
Swapped byte order on 24-bit images
