root/radiance/ray/src/px/ra_t16.c
Revision: 2.8
Committed: Sun Mar 28 20:33:14 2004 UTC (20 years, 2 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 2.7: +84 -53 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.8 static const char RCSid[] = "$Id: ra_t16.c,v 2.7 2003/06/05 19:29:34 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * ra_t16.c - program to convert between RADIANCE and
6     * Targa 16, 24 and 32-bit images.
7     *
8     * 11/2/88 Adapted from ra_t8.c
9     */
10
11     #include <stdio.h>
12 schorsch 2.8 #include <string.h>
13 greg 2.6 #include <time.h>
14 greg 2.3 #include <math.h>
15
16 schorsch 2.7 #include "platform.h"
17 schorsch 2.8 #include "rtmisc.h"
18 greg 1.1 #include "color.h"
19 greg 1.15 #include "resolu.h"
20 greg 1.5 #include "random.h"
21 greg 1.1 #include "targa.h"
22
23     #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
24     && ((h)->dataBits==16 || (h)->dataBits==24))
25
26     #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
27
28 schorsch 2.8 #define readtarga(h,d,f) ((h)->dataBits==16 ? \
29     readt16(h,(unsigned short*)d,f) : readt24(h,d,f))
30 greg 1.1
31 schorsch 2.8 #define writetarga(h,d,f) ((h)->dataBits==16 ? \
32     writet16(h,(unsigned short*)d,f) : writet24(h,d,f))
33 greg 1.1
34 greg 2.4 double gamcor = 2.2; /* gamma correction */
35 greg 1.13 int bradj = 0; /* brightness adjustment */
36 greg 1.1 char *progname;
37 schorsch 2.8 char msg[128];
38 greg 1.1
39 schorsch 2.8 static int getint2(FILE *fp);
40     static void putint2(int i, FILE *fp);
41     static void quiterr(char *err);
42     static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
43     static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
44     static void tg2ra(struct hdStruct *hp);
45     static void ra2tg(struct hdStruct *hp);
46     static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp);
47     static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp);
48     static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp);
49     static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp);
50 greg 1.1
51
52 schorsch 2.8 int
53     main(int argc, char *argv[])
54 greg 1.1 {
55     struct hdStruct head;
56     int reverse = 0;
57     int i;
58 schorsch 2.7 SET_DEFAULT_BINARY();
59     SET_FILE_BINARY(stdin);
60     SET_FILE_BINARY(stdout);
61 greg 1.1 progname = argv[0];
62
63     head.dataBits = 16;
64     for (i = 1; i < argc; i++)
65     if (argv[i][0] == '-')
66     switch (argv[i][1]) {
67     case 'g':
68 greg 2.4 gamcor = atof(argv[++i]);
69 greg 1.1 break;
70     case 'r':
71     reverse = !reverse;
72     break;
73     case '2':
74     head.dataBits = 16;
75     break;
76     case '3':
77     head.dataBits = 24;
78     break;
79 greg 1.13 case 'e':
80     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
81     goto userr;
82     bradj = atoi(argv[++i]);
83     break;
84 greg 1.1 default:
85     goto userr;
86     }
87     else
88     break;
89
90     if (i < argc-2)
91     goto userr;
92     /* open input file */
93     if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
94     sprintf(msg, "can't open input \"%s\"", argv[i]);
95     quiterr(msg);
96     }
97     /* open output file */
98     if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
99     sprintf(msg, "can't open output \"%s\"", argv[i+1]);
100     quiterr(msg);
101     }
102 greg 1.9 /* set gamma */
103 greg 2.4 setcolrgam(gamcor);
104 greg 1.1 /* convert */
105     if (reverse) {
106     /* get header */
107     if (getthead(&head, NULL, stdin) < 0)
108     quiterr("bad targa file");
109     if (!goodpic(&head))
110     quiterr("incompatible format");
111     /* put header */
112 greg 2.5 newheader("RADIANCE", stdout);
113 greg 1.7 printargs(i, argv, stdout);
114 greg 1.11 fputformat(COLRFMT, stdout);
115 greg 1.1 putchar('\n');
116 greg 1.15 fprtresolu(head.x, head.y, stdout);
117 greg 1.1 /* convert file */
118     tg2ra(&head);
119     } else {
120 greg 1.11 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
121 greg 1.15 fgetresolu(&head.x, &head.y, stdin) < 0)
122 greg 1.1 quiterr("bad picture file");
123     /* assign header */
124     head.textSize = 0;
125     head.mapType = CM_NOMAP;
126     head.dataType = IM_RGB;
127     head.XOffset = 0;
128     head.YOffset = 0;
129     head.imType = 0;
130     /* write header */
131     putthead(&head, NULL, stdout);
132     /* convert file */
133     ra2tg(&head);
134     }
135     exit(0);
136     userr:
137 greg 1.13 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
138 greg 1.1 progname);
139     exit(1);
140     }
141
142
143 schorsch 2.8 static int
144     getint2( /* get a 2-byte positive integer */
145     register FILE *fp
146     )
147 greg 1.1 {
148     register int b1, b2;
149
150     if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
151     quiterr("read error");
152
153     return(b1 | b2<<8);
154     }
155
156
157 schorsch 2.8 static void
158     putint2( /* put a 2-byte positive integer */
159     register int i,
160     register FILE *fp
161     )
162 greg 1.1 {
163     putc(i&0xff, fp);
164     putc(i>>8&0xff, fp);
165     }
166
167
168 schorsch 2.8 static void
169     quiterr( /* print message and exit */
170     char *err
171     )
172 greg 1.1 {
173     fprintf(stderr, "%s: %s\n", progname, err);
174     exit(1);
175     }
176
177
178 greg 2.6 void
179 schorsch 2.8 eputs(
180     char *s
181     )
182 greg 1.1 {
183     fputs(s, stderr);
184     }
185
186
187 greg 2.6 void
188 schorsch 2.8 quit(
189     int code
190     )
191 greg 1.1 {
192     exit(code);
193     }
194
195
196 schorsch 2.8 static int
197     getthead( /* read header from input */
198     struct hdStruct *hp,
199     char *ip,
200     register FILE *fp
201     )
202 greg 1.1 {
203     int nidbytes;
204
205     if ((nidbytes = getc(fp)) == EOF)
206     return(-1);
207     hp->mapType = getc(fp);
208     hp->dataType = getc(fp);
209     hp->mapOrig = getint2(fp);
210     hp->mapLength = getint2(fp);
211     hp->CMapBits = getc(fp);
212     hp->XOffset = getint2(fp);
213     hp->YOffset = getint2(fp);
214     hp->x = getint2(fp);
215     hp->y = getint2(fp);
216     hp->dataBits = getc(fp);
217     hp->imType = getc(fp);
218
219     if (ip != NULL)
220     if (nidbytes)
221 greg 1.6 fread((char *)ip, nidbytes, 1, fp);
222 greg 1.1 else
223     *ip = '\0';
224     else if (nidbytes)
225     fseek(fp, (long)nidbytes, 1);
226
227     return(feof(fp) || ferror(fp) ? -1 : 0);
228     }
229
230
231 schorsch 2.8 static int
232     putthead( /* write header to output */
233     struct hdStruct *hp,
234     char *ip,
235     register FILE *fp
236     )
237 greg 1.1 {
238     if (ip != NULL)
239     putc(strlen(ip), fp);
240     else
241     putc(0, fp);
242     putc(hp->mapType, fp);
243     putc(hp->dataType, fp);
244     putint2(hp->mapOrig, fp);
245     putint2(hp->mapLength, fp);
246     putc(hp->CMapBits, fp);
247     putint2(hp->XOffset, fp);
248     putint2(hp->YOffset, fp);
249     putint2(hp->x, fp);
250     putint2(hp->y, fp);
251     putc(hp->dataBits, fp);
252     putc(hp->imType, fp);
253
254     if (ip != NULL)
255     fputs(ip, fp);
256
257     return(ferror(fp) ? -1 : 0);
258     }
259
260
261 schorsch 2.8 static void
262     tg2ra( /* targa file to RADIANCE file */
263     struct hdStruct *hp
264     )
265 greg 1.1 {
266 greg 1.9 COLR *scanline;
267 greg 1.1 unsigned char *tarData;
268     register int i, j;
269     /* skip color table */
270     if (hp->mapType == CM_HASMAP)
271     fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
272     /* allocate targa data */
273     tarData = taralloc(hp);
274     /* get data */
275     readtarga(hp, tarData, stdin);
276     /* allocate input scanline */
277 greg 1.9 scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
278 greg 1.1 /* convert file */
279     for (i = hp->y-1; i >= 0; i--) {
280     if (hp->dataBits == 16) {
281     register unsigned short *dp;
282     dp = (unsigned short *)tarData + i*hp->x;
283     for (j = 0; j < hp->x; j++) {
284 greg 1.9 scanline[j][RED] = *dp>>7 & 0xf8;
285     scanline[j][GRN] = *dp>>2 & 0xf8;
286     scanline[j][BLU] = *dp<<3 & 0xf8;
287 greg 1.1 dp++;
288     }
289     } else { /* hp->dataBits == 24 */
290     register unsigned char *dp;
291     dp = (unsigned char *)tarData + i*3*hp->x;
292     for (j = 0; j < hp->x; j++) {
293 greg 1.9 scanline[j][RED] = dp[2];
294     scanline[j][GRN] = dp[1];
295     scanline[j][BLU] = dp[0];
296 greg 1.1 dp += 3;
297     }
298     }
299 greg 1.9 gambs_colrs(scanline, hp->x);
300 greg 1.13 if (bradj)
301     shiftcolrs(scanline, hp->x, bradj);
302 greg 1.9 if (fwritecolrs(scanline, hp->x, stdout) < 0)
303 greg 1.1 quiterr("error writing RADIANCE file");
304     }
305 greg 2.6 free((void *)scanline);
306     free((void *)tarData);
307 greg 1.1 }
308
309
310 schorsch 2.8 static void
311     ra2tg( /* convert radiance to targa file */
312     struct hdStruct *hp
313     )
314 greg 1.1 {
315 greg 1.3 register int i, j;
316 greg 1.1 unsigned char *tarData;
317 greg 1.9 COLR *inl;
318 greg 1.1 /* allocate space for data */
319 greg 1.9 inl = (COLR *)emalloc(hp->x*sizeof(COLR));
320 greg 1.1 tarData = taralloc(hp);
321     /* convert file */
322     for (j = hp->y-1; j >= 0; j--) {
323 greg 1.9 if (freadcolrs(inl, hp->x, stdin) < 0)
324 greg 1.1 quiterr("error reading RADIANCE file");
325 greg 1.13 if (bradj)
326     shiftcolrs(inl, hp->x, bradj);
327 greg 1.9 colrs_gambs(inl, hp->x);
328 greg 1.1 if (hp->dataBits == 16) {
329     register unsigned short *dp;
330 greg 1.12 register int v;
331 greg 1.1 dp = (unsigned short *)tarData + j*hp->x;
332     for (i = 0; i < hp->x; i++) {
333 greg 1.12 v = inl[i][RED] + (random()&7);
334     if (v > 255) v = 255;
335     *dp = (v&0xf8)<<7;
336     v = inl[i][GRN] + (random()&7);
337     if (v > 255) v = 255;
338     *dp |= (v&0xf8)<<2;
339     v = inl[i][BLU] + (random()&7);
340     if (v > 255) v = 255;
341     *dp++ |= v>>3;
342 greg 1.1 }
343     } else { /* hp->dataBits == 24 */
344     register unsigned char *dp;
345     dp = (unsigned char *)tarData + j*3*hp->x;
346     for (i = 0; i < hp->x; i++) {
347 greg 1.10 *dp++ = inl[i][BLU];
348     *dp++ = inl[i][GRN];
349 greg 1.9 *dp++ = inl[i][RED];
350 greg 1.1 }
351     }
352     }
353     /* write out targa data */
354     writetarga(hp, tarData, stdout);
355
356 greg 2.6 free((void *)inl);
357     free((void *)tarData);
358 greg 1.1 }
359
360
361 schorsch 2.8 static void
362     writet24( /* write out 24-bit targa data */
363     struct hdStruct *h,
364     unsigned char *d,
365     FILE *fp
366     )
367 greg 1.1 {
368     if (h->dataType == IM_RGB) { /* uncompressed */
369 greg 1.6 if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
370 greg 1.1 quiterr("error writing targa file");
371     return;
372     }
373     quiterr("unsupported output type");
374     }
375
376
377 schorsch 2.8 static void
378     writet16( /* write out 16-bit targa data */
379     struct hdStruct *h,
380     register unsigned short *d,
381     FILE *fp
382     )
383 greg 1.1 {
384     register int cnt;
385
386     if (h->dataType == IM_RGB) { /* uncompressed */
387     for (cnt = h->x*h->y; cnt-- > 0; )
388     putint2(*d++, fp);
389     if (ferror(fp))
390     quiterr("error writing targa file");
391     return;
392     }
393     quiterr("unsupported output type");
394     }
395
396
397 schorsch 2.8 static void
398     readt24( /* read in 24-bit targa data */
399     register struct hdStruct *h,
400     unsigned char *data,
401     FILE *fp
402     )
403 greg 1.1 {
404     register int cnt, c;
405     register unsigned char *dp;
406     int r, g, b;
407
408     if (h->dataType == IM_RGB) { /* uncompressed */
409 greg 1.6 if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
410 greg 1.1 goto readerr;
411     return;
412     }
413     for (dp = data; dp < data+3*h->x*h->y; ) {
414     if ((c = getc(fp)) == EOF)
415     goto readerr;
416     cnt = (c & 0x7f) + 1;
417     if (c & 0x80) { /* repeated pixel */
418 greg 1.2 b = getc(fp); g = getc(fp);
419     if ((r = getc(fp)) == EOF)
420 greg 1.1 goto readerr;
421     while (cnt--) {
422 greg 1.2 *dp++ = b;
423     *dp++ = g;
424 greg 1.1 *dp++ = r;
425     }
426     } else /* non-repeating pixels */
427     while (cnt--) {
428     *dp++ = getc(fp); *dp++ = getc(fp);
429 greg 1.2 if ((r = getc(fp)) == EOF)
430 greg 1.1 goto readerr;
431 greg 1.2 *dp++ = r;
432 greg 1.1 }
433     }
434     return;
435     readerr:
436     quiterr("error reading targa file");
437     }
438
439
440 schorsch 2.8 static void
441     readt16( /* read in 16-bit targa data */
442     register struct hdStruct *h,
443     unsigned short *data,
444     FILE *fp
445     )
446 greg 1.1 {
447     register int cnt, c;
448     register unsigned short *dp;
449
450     if (h->dataType == IM_RGB) { /* uncompressed */
451     dp = data;
452     for (cnt = h->x*h->y; cnt-- > 0; )
453     *dp++ = getint2(fp);
454     return;
455     }
456     for (dp = data; dp < data+h->x*h->y; ) {
457     if ((c = getc(fp)) == EOF)
458     goto readerr;
459     cnt = (c & 0x7f) + 1;
460     if (c & 0x80) { /* repeated pixel */
461     c = getint2(fp);
462     while (cnt--)
463     *dp++ = c;
464     } else /* non-repeating pixels */
465     while (cnt--)
466     *dp++ = getint2(fp);
467     }
468     return;
469     readerr:
470     quiterr("error reading targa file");
471     }
