--- ray/src/px/ra_t16.c 1991/12/19 14:52:20 2.2 +++ ray/src/px/ra_t16.c 2004/03/28 20:33:14 2.8 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ra_t16.c,v 2.8 2004/03/28 20:33:14 schorsch Exp $"; #endif - /* * ra_t16.c - program to convert between RADIANCE and * Targa 16, 24 and 32-bit images. @@ -12,13 +9,15 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include +#include +#include +#include +#include "platform.h" +#include "rtmisc.h" #include "color.h" - #include "resolu.h" - #include "random.h" - #include "targa.h" #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \ @@ -26,33 +25,39 @@ static char SCCSid[] = "$SunId$ LBL"; #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8) -#define readtarga(h,d,f) ((h)->dataBits==16 ? readt16(h,d,f) : \ - readt24(h,d,f)) +#define readtarga(h,d,f) ((h)->dataBits==16 ? \ + readt16(h,(unsigned short*)d,f) : readt24(h,d,f)) -#define writetarga(h,d,f) ((h)->dataBits==16 ? writet16(h,d,f) : \ - writet24(h,d,f)) +#define writetarga(h,d,f) ((h)->dataBits==16 ? \ + writet16(h,(unsigned short*)d,f) : writet24(h,d,f)) -extern char *ecalloc(), *emalloc(); - -extern double pow(); - -double gamma = 2.2; /* gamma correction */ - +double gamcor = 2.2; /* gamma correction */ int bradj = 0; /* brightness adjustment */ - char *progname; - char msg[128]; +static int getint2(FILE *fp); +static void putint2(int i, FILE *fp); +static void quiterr(char *err); +static int getthead(struct hdStruct *hp, char *ip, FILE *fp); +static int putthead(struct hdStruct *hp, char *ip, FILE *fp); +static void tg2ra(struct hdStruct *hp); +static void ra2tg(struct hdStruct *hp); +static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp); +static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp); +static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp); +static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp); -main(argc, argv) -int argc; -char *argv[]; + +int +main(int argc, char *argv[]) { struct hdStruct head; int reverse = 0; int i; - + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); progname = argv[0]; head.dataBits = 16; @@ -60,7 +65,7 @@ char *argv[]; if (argv[i][0] == '-') switch (argv[i][1]) { case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'r': reverse = !reverse; @@ -95,7 +100,7 @@ char *argv[]; quiterr(msg); } /* set gamma */ - setcolrgam(gamma); + setcolrgam(gamcor); /* convert */ if (reverse) { /* get header */ @@ -104,6 +109,7 @@ char *argv[]; if (!goodpic(&head)) quiterr("incompatible format"); /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); @@ -134,9 +140,10 @@ userr: } -int -getint2(fp) /* get a 2-byte positive integer */ -register FILE *fp; +static int +getint2( /* get a 2-byte positive integer */ + register FILE *fp +) { register int b1, b2; @@ -147,41 +154,51 @@ register FILE *fp; } -putint2(i, fp) /* put a 2-byte positive integer */ -register int i; -register FILE *fp; +static void +putint2( /* put a 2-byte positive integer */ + register int i, + register FILE *fp +) { putc(i&0xff, fp); putc(i>>8&0xff, fp); } -quiterr(err) /* print message and exit */ -char *err; +static void +quiterr( /* print message and exit */ + char *err +) { fprintf(stderr, "%s: %s\n", progname, err); exit(1); } -eputs(s) -char *s; +void +eputs( + char *s +) { fputs(s, stderr); } -quit(code) -int code; +void +quit( + int code +) { exit(code); } -getthead(hp, ip, fp) /* read header from input */ -struct hdStruct *hp; -char *ip; -register FILE *fp; +static int +getthead( /* read header from input */ + struct hdStruct *hp, + char *ip, + register FILE *fp +) { int nidbytes; @@ -211,10 +228,12 @@ register FILE *fp; } -putthead(hp, ip, fp) /* write header to output */ -struct hdStruct *hp; -char *ip; -register FILE *fp; +static int +putthead( /* write header to output */ + struct hdStruct *hp, + char *ip, + register FILE *fp +) { if (ip != NULL) putc(strlen(ip), fp); @@ -239,8 +258,10 @@ register FILE *fp; } -tg2ra(hp) /* targa file to RADIANCE file */ -struct hdStruct *hp; +static void +tg2ra( /* targa file to RADIANCE file */ + struct hdStruct *hp +) { COLR *scanline; unsigned char *tarData; @@ -281,13 +302,15 @@ struct hdStruct *hp; if (fwritecolrs(scanline, hp->x, stdout) < 0) quiterr("error writing RADIANCE file"); } - free((char *)scanline); - free((char *)tarData); + free((void *)scanline); + free((void *)tarData); } -ra2tg(hp) /* convert radiance to targa file */ -struct hdStruct *hp; +static void +ra2tg( /* convert radiance to targa file */ + struct hdStruct *hp +) { register int i, j; unsigned char *tarData; @@ -330,15 +353,17 @@ struct hdStruct *hp; /* write out targa data */ writetarga(hp, tarData, stdout); - free((char *)inl); - free((char *)tarData); + free((void *)inl); + free((void *)tarData); } -writet24(h, d, fp) /* write out 24-bit targa data */ -struct hdStruct *h; -unsigned char *d; -FILE *fp; +static void +writet24( /* write out 24-bit targa data */ + struct hdStruct *h, + unsigned char *d, + FILE *fp +) { if (h->dataType == IM_RGB) { /* uncompressed */ if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y) @@ -349,10 +374,12 @@ FILE *fp; } -writet16(h, d, fp) /* write out 16-bit targa data */ -struct hdStruct *h; -register unsigned short *d; -FILE *fp; +static void +writet16( /* write out 16-bit targa data */ + struct hdStruct *h, + register unsigned short *d, + FILE *fp +) { register int cnt; @@ -367,10 +394,12 @@ FILE *fp; } -readt24(h, data, fp) /* read in 24-bit targa data */ -register struct hdStruct *h; -unsigned char *data; -FILE *fp; +static void +readt24( /* read in 24-bit targa data */ + register struct hdStruct *h, + unsigned char *data, + FILE *fp +) { register int cnt, c; register unsigned char *dp; @@ -408,10 +437,12 @@ readerr: } -readt16(h, data, fp) /* read in 16-bit targa data */ -register struct hdStruct *h; -unsigned short *data; -FILE *fp; +static void +readt16( /* read in 16-bit targa data */ + register struct hdStruct *h, + unsigned short *data, + FILE *fp +) { register int cnt, c; register unsigned short *dp;
