--- ray/src/px/ra_t16.c 1990/10/20 11:49:02 1.9 +++ ray/src/px/ra_t16.c 2003/02/22 02:07:28 2.6 @@ -1,9 +1,6 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: ra_t16.c,v 2.6 2003/02/22 02:07:28 greg Exp $"; #endif - /* * ra_t16.c - program to convert between RADIANCE and * Targa 16, 24 and 32-bit images. @@ -13,8 +10,18 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#ifdef MSDOS +#include +#endif + +#include + +#include + #include "color.h" +#include "resolu.h" + #include "random.h" #include "targa.h" @@ -32,9 +39,9 @@ static char SCCSid[] = "$SunId$ LBL"; extern char *ecalloc(), *emalloc(); -extern double atof(), pow(); +double gamcor = 2.2; /* gamma correction */ -double gamma = 2.0; /* gamma correction */ +int bradj = 0; /* brightness adjustment */ char *progname; @@ -48,7 +55,12 @@ char *argv[]; struct hdStruct head; int reverse = 0; int i; - +#ifdef MSDOS + extern int _fmode; + _fmode = O_BINARY; + setmode(fileno(stdin), O_BINARY); + setmode(fileno(stdout), O_BINARY); +#endif progname = argv[0]; head.dataBits = 16; @@ -56,7 +68,7 @@ char *argv[]; if (argv[i][0] == '-') switch (argv[i][1]) { case 'g': - gamma = atof(argv[++i]); + gamcor = atof(argv[++i]); break; case 'r': reverse = !reverse; @@ -67,6 +79,11 @@ char *argv[]; case '3': head.dataBits = 24; break; + case 'e': + if (argv[i+1][0] != '+' && argv[i+1][0] != '-') + goto userr; + bradj = atoi(argv[++i]); + break; default: goto userr; } @@ -86,7 +103,7 @@ char *argv[]; quiterr(msg); } /* set gamma */ - setcolrgam(gamma); + setcolrgam(gamcor); /* convert */ if (reverse) { /* get header */ @@ -95,14 +112,16 @@ char *argv[]; if (!goodpic(&head)) quiterr("incompatible format"); /* put header */ + newheader("RADIANCE", stdout); printargs(i, argv, stdout); + fputformat(COLRFMT, stdout); putchar('\n'); - fputresolu(YMAJOR|YDECR, head.x, head.y, stdout); + fprtresolu(head.x, head.y, stdout); /* convert file */ tg2ra(&head); } else { - getheader(stdin, NULL); - if (fgetresolu(&head.x, &head.y, stdin) != (YMAJOR|YDECR)) + if (checkheader(stdin, COLRFMT, NULL) < 0 || + fgetresolu(&head.x, &head.y, stdin) < 0) quiterr("bad picture file"); /* assign header */ head.textSize = 0; @@ -118,7 +137,7 @@ char *argv[]; } exit(0); userr: - fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma] [input [output]]\n", + fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n", progname); exit(1); } @@ -154,6 +173,7 @@ char *err; } +void eputs(s) char *s; { @@ -161,6 +181,7 @@ char *s; } +void quit(code) int code; { @@ -266,11 +287,13 @@ struct hdStruct *hp; } } gambs_colrs(scanline, hp->x); + if (bradj) + shiftcolrs(scanline, hp->x, bradj); if (fwritecolrs(scanline, hp->x, stdout) < 0) quiterr("error writing RADIANCE file"); } - free((char *)scanline); - free((char *)tarData); + free((void *)scanline); + free((void *)tarData); } @@ -287,30 +310,39 @@ struct hdStruct *hp; for (j = hp->y-1; j >= 0; j--) { if (freadcolrs(inl, hp->x, stdin) < 0) quiterr("error reading RADIANCE file"); + if (bradj) + shiftcolrs(inl, hp->x, bradj); colrs_gambs(inl, hp->x); if (hp->dataBits == 16) { register unsigned short *dp; + register int v; dp = (unsigned short *)tarData + j*hp->x; for (i = 0; i < hp->x; i++) { - *dp = ((inl[i][RED]+(random()&7)) & 0xf8)<<7; - *dp |= ((inl[i][GRN]+(random()&7)) & 0xf8)<<2; - *dp++ |= (inl[i][BLU]+(random()&7))>>3; + v = inl[i][RED] + (random()&7); + if (v > 255) v = 255; + *dp = (v&0xf8)<<7; + v = inl[i][GRN] + (random()&7); + if (v > 255) v = 255; + *dp |= (v&0xf8)<<2; + v = inl[i][BLU] + (random()&7); + if (v > 255) v = 255; + *dp++ |= v>>3; } } else { /* hp->dataBits == 24 */ register unsigned char *dp; dp = (unsigned char *)tarData + j*3*hp->x; for (i = 0; i < hp->x; i++) { - *dp++ = inl[i][RED]; - *dp++ = inl[i][GRN]; *dp++ = inl[i][BLU]; + *dp++ = inl[i][GRN]; + *dp++ = inl[i][RED]; } } } /* write out targa data */ writetarga(hp, tarData, stdout); - free((char *)inl); - free((char *)tarData); + free((void *)inl); + free((void *)tarData); }
