root/radiance/ray/src/px/ra_t16.c
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.9: +1 -4 lines
Tue Mar 20 18:45:04 2018 UTC (6 years, 1 month ago) by greg
Added missing rtio.h include to redefine getc, putc, etc.
Changes since 2.7: +84 -53 lines
Changes since 2.6: +5 -16 lines
Changes since 2.5: +9 -8 lines
Sun Feb 27 10:17:20 1994 UTC (30 years, 2 months ago) by greg
Fri Oct 30 09:11:36 1992 UTC (31 years, 6 months ago) by greg
renamed gamma to avoid conflict with some math libraries
Fri Oct 2 16:29:07 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.2: +12 -3 lines
Thu Dec 19 14:52:20 1991 UTC (32 years, 5 months ago) by greg
Tue Nov 12 16:04:21 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.15 , to selected 2.10
Mon Nov 11 14:01:40 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.14: +4 -2 lines
Diff to previous 1.14 , to selected 2.10
Fri Aug 23 13:40:04 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.13 , to selected 2.10
changed default gamma to 2.2, the NTSC standard value
Wed Aug 7 08:36:35 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.12: +12 -1 lines
Diff to previous 1.12 , to selected 2.10
added -e +/-stops option
Fri May 17 08:41:52 1991 UTC (33 years ago) by greg
Changes since 1.11: +11 -4 lines
Diff to previous 1.11 , to selected 2.10
fixed bug in 16-bit ra2tg() code
Thu Apr 18 14:35:42 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.10 , to selected 2.10
Wed Dec 12 14:40:07 1990 UTC (33 years, 5 months ago) by greg
Diff to previous 1.9 , to selected 2.10
fixed error introduced with byte ordering in ra2tg with 24-bit
Sat Oct 20 11:49:02 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.8: +22 -33 lines
Diff to previous 1.8 , to selected 2.10
changed gamma correction to colrops calls
Mon Mar 12 15:14:42 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.7: +10 -10 lines
Diff to previous 1.7 , to selected 2.10
changed "inline" to "inl" for compiler compatibility
Fri Feb 9 13:59:21 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 2.10
changed arguments printed in header
Thu Jan 18 23:58:21 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5 , to selected 2.10
Fri Oct 20 16:42:28 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.4 , to selected 2.10
added missing include file "random.h"
Tue Sep 12 13:04:36 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 2.10
Sun Jul 23 11:35:48 1989 UTC (34 years, 10 months ago) by greg
Changes since 1.2: +16 -21 lines
Diff to previous 1.2 , to selected 2.10
Added dithering to 16-bit conversion
Wed May 31 17:27:18 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.1: +10 -10 lines
Diff to previous 1.1 , to selected 2.10
Swapped byte order on 24-bit images
Thu Feb 2 10:49:36 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.10
