root/radiance/ray/src/px/ra_t16.c
Revision: 2.12
Committed: Sat Jun 7 05:09:46 2025 UTC (7 weeks, 6 days ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.11: +1 -2 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.12 static const char RCSid[] = "$Id: ra_t16.c,v 2.11 2025/06/06 19:11:21 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * ra_t16.c - program to convert between RADIANCE and
6     * Targa 16, 24 and 32-bit images.
7     *
8     * 11/2/88 Adapted from ra_t8.c
9     */
10
11 greg 2.3 #include <math.h>
12 schorsch 2.7 #include "platform.h"
13 greg 2.9 #include "rtio.h"
14 schorsch 2.8 #include "rtmisc.h"
15 greg 1.1 #include "color.h"
16 greg 1.15 #include "resolu.h"
17 greg 1.5 #include "random.h"
18 greg 1.1 #include "targa.h"
19
20     #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
21     && ((h)->dataBits==16 || (h)->dataBits==24))
22
23     #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
24
25 schorsch 2.8 #define readtarga(h,d,f) ((h)->dataBits==16 ? \
26     readt16(h,(unsigned short*)d,f) : readt24(h,d,f))
27 greg 1.1
28 schorsch 2.8 #define writetarga(h,d,f) ((h)->dataBits==16 ? \
29     writet16(h,(unsigned short*)d,f) : writet24(h,d,f))
30 greg 1.1
31 greg 2.4 double gamcor = 2.2; /* gamma correction */
32 greg 1.13 int bradj = 0; /* brightness adjustment */
33 schorsch 2.8 char msg[128];
34 greg 1.1
35 schorsch 2.8 static int getint2(FILE *fp);
36     static void putint2(int i, FILE *fp);
37     static void quiterr(char *err);
38     static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
39     static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
40     static void tg2ra(struct hdStruct *hp);
41     static void ra2tg(struct hdStruct *hp);
42     static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp);
43     static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp);
44     static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp);
45     static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp);
46 greg 1.1
47
48 schorsch 2.8 int
49     main(int argc, char *argv[])
50 greg 1.1 {
51     struct hdStruct head;
52     int reverse = 0;
53     int i;
54 greg 2.11
55 schorsch 2.7 SET_DEFAULT_BINARY();
56     SET_FILE_BINARY(stdin);
57     SET_FILE_BINARY(stdout);
58 greg 2.11 fixargv0(argv[0]);
59 greg 1.1
60     head.dataBits = 16;
61     for (i = 1; i < argc; i++)
62     if (argv[i][0] == '-')
63     switch (argv[i][1]) {
64     case 'g':
65 greg 2.4 gamcor = atof(argv[++i]);
66 greg 1.1 break;
67     case 'r':
68     reverse = !reverse;
69     break;
70     case '2':
71     head.dataBits = 16;
72     break;
73     case '3':
74     head.dataBits = 24;
75     break;
76 greg 1.13 case 'e':
77     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
78     goto userr;
79     bradj = atoi(argv[++i]);
80     break;
81 greg 1.1 default:
82     goto userr;
83     }
84     else
85     break;
86
87     if (i < argc-2)
88     goto userr;
89     /* open input file */
90     if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
91     sprintf(msg, "can't open input \"%s\"", argv[i]);
92     quiterr(msg);
93     }
94     /* open output file */
95     if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
96     sprintf(msg, "can't open output \"%s\"", argv[i+1]);
97     quiterr(msg);
98     }
99 greg 1.9 /* set gamma */
100 greg 2.4 setcolrgam(gamcor);
101 greg 1.1 /* convert */
102     if (reverse) {
103     /* get header */
104     if (getthead(&head, NULL, stdin) < 0)
105     quiterr("bad targa file");
106     if (!goodpic(&head))
107     quiterr("incompatible format");
108     /* put header */
109 greg 2.5 newheader("RADIANCE", stdout);
110 greg 1.7 printargs(i, argv, stdout);
111 greg 1.11 fputformat(COLRFMT, stdout);
112 greg 1.1 putchar('\n');
113 greg 1.15 fprtresolu(head.x, head.y, stdout);
114 greg 1.1 /* convert file */
115     tg2ra(&head);
116     } else {
117 greg 1.11 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
118 greg 1.15 fgetresolu(&head.x, &head.y, stdin) < 0)
119 greg 1.1 quiterr("bad picture file");
120     /* assign header */
121     head.textSize = 0;
122     head.mapType = CM_NOMAP;
123     head.dataType = IM_RGB;
124     head.XOffset = 0;
125     head.YOffset = 0;
126     head.imType = 0;
127     /* write header */
128     putthead(&head, NULL, stdout);
129     /* convert file */
130     ra2tg(&head);
131     }
132     exit(0);
133     userr:
134 greg 1.13 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
135 greg 1.1 progname);
136     exit(1);
137     }
138
139
140 schorsch 2.8 static int
141     getint2( /* get a 2-byte positive integer */
142     register FILE *fp
143     )
144 greg 1.1 {
145     register int b1, b2;
146
147     if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
148     quiterr("read error");
149
150     return(b1 | b2<<8);
151     }
152
153
154 schorsch 2.8 static void
155     putint2( /* put a 2-byte positive integer */
156     register int i,
157     register FILE *fp
158     )
159 greg 1.1 {
160     putc(i&0xff, fp);
161     putc(i>>8&0xff, fp);
162     }
163
164
165 schorsch 2.8 static void
166     quiterr( /* print message and exit */
167     char *err
168     )
169 greg 1.1 {
170     fprintf(stderr, "%s: %s\n", progname, err);
171     exit(1);
172     }
173
174
175 greg 2.6 void
176 schorsch 2.8 eputs(
177     char *s
178     )
179 greg 1.1 {
180     fputs(s, stderr);
181     }
182
183
184 greg 2.6 void
185 schorsch 2.8 quit(
186     int code
187     )
188 greg 1.1 {
189     exit(code);
190     }
191
192
193 schorsch 2.8 static int
194     getthead( /* read header from input */
195     struct hdStruct *hp,
196     char *ip,
197     register FILE *fp
198     )
199 greg 1.1 {
200     int nidbytes;
201
202     if ((nidbytes = getc(fp)) == EOF)
203     return(-1);
204     hp->mapType = getc(fp);
205     hp->dataType = getc(fp);
206     hp->mapOrig = getint2(fp);
207     hp->mapLength = getint2(fp);
208     hp->CMapBits = getc(fp);
209     hp->XOffset = getint2(fp);
210     hp->YOffset = getint2(fp);
211     hp->x = getint2(fp);
212     hp->y = getint2(fp);
213     hp->dataBits = getc(fp);
214     hp->imType = getc(fp);
215
216     if (ip != NULL)
217     if (nidbytes)
218 greg 1.6 fread((char *)ip, nidbytes, 1, fp);
219 greg 1.1 else
220     *ip = '\0';
221     else if (nidbytes)
222     fseek(fp, (long)nidbytes, 1);
223
224     return(feof(fp) || ferror(fp) ? -1 : 0);
225     }
226
227
228 schorsch 2.8 static int
229     putthead( /* write header to output */
230     struct hdStruct *hp,
231     char *ip,
232     register FILE *fp
233     )
234 greg 1.1 {
235     if (ip != NULL)
236     putc(strlen(ip), fp);
237     else
238     putc(0, fp);
239     putc(hp->mapType, fp);
240     putc(hp->dataType, fp);
241     putint2(hp->mapOrig, fp);
242     putint2(hp->mapLength, fp);
243     putc(hp->CMapBits, fp);
244     putint2(hp->XOffset, fp);
245     putint2(hp->YOffset, fp);
246     putint2(hp->x, fp);
247     putint2(hp->y, fp);
248     putc(hp->dataBits, fp);
249     putc(hp->imType, fp);
250
251     if (ip != NULL)
252     fputs(ip, fp);
253
254     return(ferror(fp) ? -1 : 0);
255     }
256
257
258 schorsch 2.8 static void
259     tg2ra( /* targa file to RADIANCE file */
260     struct hdStruct *hp
261     )
262 greg 1.1 {
263 greg 1.9 COLR *scanline;
264 greg 1.1 unsigned char *tarData;
265     register int i, j;
266     /* skip color table */
267     if (hp->mapType == CM_HASMAP)
268     fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
269     /* allocate targa data */
270     tarData = taralloc(hp);
271     /* get data */
272     readtarga(hp, tarData, stdin);
273     /* allocate input scanline */
274 greg 1.9 scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
275 greg 1.1 /* convert file */
276     for (i = hp->y-1; i >= 0; i--) {
277     if (hp->dataBits == 16) {
278     register unsigned short *dp;
279     dp = (unsigned short *)tarData + i*hp->x;
280     for (j = 0; j < hp->x; j++) {
281 greg 1.9 scanline[j][RED] = *dp>>7 & 0xf8;
282     scanline[j][GRN] = *dp>>2 & 0xf8;
283     scanline[j][BLU] = *dp<<3 & 0xf8;
284 greg 1.1 dp++;
285     }
286     } else { /* hp->dataBits == 24 */
287     register unsigned char *dp;
288     dp = (unsigned char *)tarData + i*3*hp->x;
289     for (j = 0; j < hp->x; j++) {
290 greg 1.9 scanline[j][RED] = dp[2];
291     scanline[j][GRN] = dp[1];
292     scanline[j][BLU] = dp[0];
293 greg 1.1 dp += 3;
294     }
295     }
296 greg 1.9 gambs_colrs(scanline, hp->x);
297 greg 1.13 if (bradj)
298     shiftcolrs(scanline, hp->x, bradj);
299 greg 1.9 if (fwritecolrs(scanline, hp->x, stdout) < 0)
300 greg 1.1 quiterr("error writing RADIANCE file");
301     }
302 greg 2.6 free((void *)scanline);
303     free((void *)tarData);
304 greg 1.1 }
305
306
307 schorsch 2.8 static void
308     ra2tg( /* convert radiance to targa file */
309     struct hdStruct *hp
310     )
311 greg 1.1 {
312 greg 1.3 register int i, j;
313 greg 1.1 unsigned char *tarData;
314 greg 1.9 COLR *inl;
315 greg 1.1 /* allocate space for data */
316 greg 1.9 inl = (COLR *)emalloc(hp->x*sizeof(COLR));
317 greg 1.1 tarData = taralloc(hp);
318     /* convert file */
319     for (j = hp->y-1; j >= 0; j--) {
320 greg 1.9 if (freadcolrs(inl, hp->x, stdin) < 0)
321 greg 1.1 quiterr("error reading RADIANCE file");
322 greg 1.13 if (bradj)
323     shiftcolrs(inl, hp->x, bradj);
324 greg 1.9 colrs_gambs(inl, hp->x);
325 greg 1.1 if (hp->dataBits == 16) {
326     register unsigned short *dp;
327 greg 1.12 register int v;
328 greg 1.1 dp = (unsigned short *)tarData + j*hp->x;
329     for (i = 0; i < hp->x; i++) {
330 greg 1.12 v = inl[i][RED] + (random()&7);
331     if (v > 255) v = 255;
332     *dp = (v&0xf8)<<7;
333     v = inl[i][GRN] + (random()&7);
334     if (v > 255) v = 255;
335     *dp |= (v&0xf8)<<2;
336     v = inl[i][BLU] + (random()&7);
337     if (v > 255) v = 255;
338     *dp++ |= v>>3;
339 greg 1.1 }
340     } else { /* hp->dataBits == 24 */
341     register unsigned char *dp;
342     dp = (unsigned char *)tarData + j*3*hp->x;
343     for (i = 0; i < hp->x; i++) {
344 greg 1.10 *dp++ = inl[i][BLU];
345     *dp++ = inl[i][GRN];
346 greg 1.9 *dp++ = inl[i][RED];
347 greg 1.1 }
348     }
349     }
350     /* write out targa data */
351     writetarga(hp, tarData, stdout);
352
353 greg 2.6 free((void *)inl);
354     free((void *)tarData);
355 greg 1.1 }
356
357
358 schorsch 2.8 static void
359     writet24( /* write out 24-bit targa data */
360     struct hdStruct *h,
361     unsigned char *d,
362     FILE *fp
363     )
364 greg 1.1 {
365     if (h->dataType == IM_RGB) { /* uncompressed */
366 greg 1.6 if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
367 greg 1.1 quiterr("error writing targa file");
368     return;
369     }
370     quiterr("unsupported output type");
371     }
372
373
374 schorsch 2.8 static void
375     writet16( /* write out 16-bit targa data */
376     struct hdStruct *h,
377     register unsigned short *d,
378     FILE *fp
379     )
380 greg 1.1 {
381     register int cnt;
382
383     if (h->dataType == IM_RGB) { /* uncompressed */
384     for (cnt = h->x*h->y; cnt-- > 0; )
385     putint2(*d++, fp);
386     if (ferror(fp))
387     quiterr("error writing targa file");
388     return;
389     }
390     quiterr("unsupported output type");
391     }
392
393
394 schorsch 2.8 static void
395     readt24( /* read in 24-bit targa data */
396     register struct hdStruct *h,
397     unsigned char *data,
398     FILE *fp
399     )
400 greg 1.1 {
401     register int cnt, c;
402     register unsigned char *dp;
403     int r, g, b;
404
405     if (h->dataType == IM_RGB) { /* uncompressed */
406 greg 1.6 if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
407 greg 1.1 goto readerr;
408     return;
409     }
410     for (dp = data; dp < data+3*h->x*h->y; ) {
411     if ((c = getc(fp)) == EOF)
412     goto readerr;
413     cnt = (c & 0x7f) + 1;
414     if (c & 0x80) { /* repeated pixel */
415 greg 1.2 b = getc(fp); g = getc(fp);
416     if ((r = getc(fp)) == EOF)
417 greg 1.1 goto readerr;
418     while (cnt--) {
419 greg 1.2 *dp++ = b;
420     *dp++ = g;
421 greg 1.1 *dp++ = r;
422     }
423     } else /* non-repeating pixels */
424     while (cnt--) {
425     *dp++ = getc(fp); *dp++ = getc(fp);
426 greg 1.2 if ((r = getc(fp)) == EOF)
427 greg 1.1 goto readerr;
428 greg 1.2 *dp++ = r;
429 greg 1.1 }
430     }
431     return;
432     readerr:
433     quiterr("error reading targa file");
434     }
435
436
437 schorsch 2.8 static void
438     readt16( /* read in 16-bit targa data */
439     register struct hdStruct *h,
440     unsigned short *data,
441     FILE *fp
442     )
443 greg 1.1 {
444     register int cnt, c;
445     register unsigned short *dp;
446
447     if (h->dataType == IM_RGB) { /* uncompressed */
448     dp = data;
449     for (cnt = h->x*h->y; cnt-- > 0; )
450     *dp++ = getint2(fp);
451     return;
452     }
453     for (dp = data; dp < data+h->x*h->y; ) {
454     if ((c = getc(fp)) == EOF)
455     goto readerr;
456     cnt = (c & 0x7f) + 1;
457     if (c & 0x80) { /* repeated pixel */
458     c = getint2(fp);
459     while (cnt--)
460     *dp++ = c;
461     } else /* non-repeating pixels */
462     while (cnt--)
463     *dp++ = getint2(fp);
464     }
465     return;
466     readerr:
467     quiterr("error reading targa file");
468     }
