root/radiance/ray/src/px/ra_t16.c
Revision: 2.9
Committed: Tue Mar 20 18:45:04 2018 UTC (7 years, 3 months ago) by greg
Added missing rtio.h include to redefine getc, putc, etc.
2 static const char RCSid[] = "$Id: ra_t16.c,v 2.8 2004/03/28 20:33:14 schorsch Exp $";
5 * ra_t16.c - program to convert between RADIANCE and
6 * Targa 16, 24 and 32-bit images.
7 *
8 * 11/2/88 Adapted from ra_t8.c
9 */
10
11 #include <stdio.h>
12 #include <string.h>
13 #include <time.h>
14 #include <math.h>
15
16 #include "platform.h"
17 #include "rtio.h"
18 #include "rtmisc.h"
19 #include "color.h"
20 #include "resolu.h"
21 #include "random.h"
22 #include "targa.h"
23
24 #define goodpic(h) (((h)->dataType==IM_RGB || (h)->dataType==IM_CRGB) \
25 && ((h)->dataBits==16 || (h)->dataBits==24))
26
27 #define taralloc(h) (unsigned char *)emalloc((h)->x*(h)->y*(h)->dataBits/8)
28
29 #define readtarga(h,d,f) ((h)->dataBits==16 ? \
30 readt16(h,(unsigned short*)d,f) : readt24(h,d,f))
31
32 #define writetarga(h,d,f) ((h)->dataBits==16 ? \
33 writet16(h,(unsigned short*)d,f) : writet24(h,d,f))
34
35 double gamcor = 2.2; /* gamma correction */
36 int bradj = 0; /* brightness adjustment */
37 char *progname;
38 char msg[128];
39
40 static int getint2(FILE *fp);
41 static void putint2(int i, FILE *fp);
42 static void quiterr(char *err);
43 static int getthead(struct hdStruct *hp, char *ip, FILE *fp);
44 static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
45 static void tg2ra(struct hdStruct *hp);
46 static void ra2tg(struct hdStruct *hp);
47 static void writet24(struct hdStruct *h, unsigned char *d, FILE *fp);
48 static void writet16(struct hdStruct *h, unsigned short *d, FILE *fp);
49 static void readt24(struct hdStruct *h, unsigned char *data, FILE *fp);
50 static void readt16(struct hdStruct *h, unsigned short *data, FILE *fp);
51
52
53 int
54 main(int argc, char *argv[])
55 {
56 struct hdStruct head;
57 int reverse = 0;
58 int i;
59 SET_DEFAULT_BINARY();
60 SET_FILE_BINARY(stdin);
61 SET_FILE_BINARY(stdout);
62 progname = argv[0];
63
64 head.dataBits = 16;
65 for (i = 1; i < argc; i++)
66 if (argv[i][0] == '-')
67 switch (argv[i][1]) {
68 case 'g':
69 gamcor = atof(argv[++i]);
70 break;
71 case 'r':
72 reverse = !reverse;
73 break;
74 case '2':
75 head.dataBits = 16;
76 break;
77 case '3':
78 head.dataBits = 24;
79 break;
80 case 'e':
81 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
82 goto userr;
83 bradj = atoi(argv[++i]);
84 break;
85 default:
86 goto userr;
87 }
88 else
89 break;
90
91 if (i < argc-2)
92 goto userr;
93 /* open input file */
94 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
95 sprintf(msg, "can't open input \"%s\"", argv[i]);
96 quiterr(msg);
97 }
98 /* open output file */
99 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
100 sprintf(msg, "can't open output \"%s\"", argv[i+1]);
101 quiterr(msg);
102 }
103 /* set gamma */
104 setcolrgam(gamcor);
105 /* convert */
106 if (reverse) {
107 /* get header */
108 if (getthead(&head, NULL, stdin) < 0)
109 quiterr("bad targa file");
110 if (!goodpic(&head))
111 quiterr("incompatible format");
112 /* put header */
113 newheader("RADIANCE", stdout);
114 printargs(i, argv, stdout);
115 fputformat(COLRFMT, stdout);
116 putchar('\n');
117 fprtresolu(head.x, head.y, stdout);
118 /* convert file */
119 tg2ra(&head);
120 } else {
121 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
122 fgetresolu(&head.x, &head.y, stdin) < 0)
123 quiterr("bad picture file");
124 /* assign header */
125 head.textSize = 0;
126 head.mapType = CM_NOMAP;
127 head.dataType = IM_RGB;
128 head.XOffset = 0;
129 head.YOffset = 0;
130 head.imType = 0;
131 /* write header */
132 putthead(&head, NULL, stdout);
133 /* convert file */
134 ra2tg(&head);
135 }
136 exit(0);
137 userr:
138 fprintf(stderr, "Usage: %s [-2|-3|-r][-g gamma][-e +/-stops] [input [output]]\n",
139 progname);
140 exit(1);
141 }
142
143
144 static int
145 getint2( /* get a 2-byte positive integer */
146 register FILE *fp
147 )
148 {
149 register int b1, b2;
150
151 if ((b1 = getc(fp)) == EOF || (b2 = getc(fp)) == EOF)
152 quiterr("read error");
153
154 return(b1 | b2<<8);
155 }
156
157
158 static void
159 putint2( /* put a 2-byte positive integer */
160 register int i,
161 register FILE *fp
162 )
163 {
164 putc(i&0xff, fp);
165 putc(i>>8&0xff, fp);
166 }
167
168
169 static void
170 quiterr( /* print message and exit */
171 char *err
172 )
173 {
174 fprintf(stderr, "%s: %s\n", progname, err);
175 exit(1);
176 }
177
178
179 void
180 eputs(
181 char *s
182 )
183 {
184 fputs(s, stderr);
185 }
186
187
188 void
189 quit(
190 int code
191 )
192 {
193 exit(code);
194 }
195
196
197 static int
198 getthead( /* read header from input */
199 struct hdStruct *hp,
200 char *ip,
201 register FILE *fp
202 )
203 {
204 int nidbytes;
205
206 if ((nidbytes = getc(fp)) == EOF)
207 return(-1);
208 hp->mapType = getc(fp);
209 hp->dataType = getc(fp);
210 hp->mapOrig = getint2(fp);
211 hp->mapLength = getint2(fp);
212 hp->CMapBits = getc(fp);
213 hp->XOffset = getint2(fp);
214 hp->YOffset = getint2(fp);
215 hp->x = getint2(fp);
216 hp->y = getint2(fp);
217 hp->dataBits = getc(fp);
218 hp->imType = getc(fp);
219
220 if (ip != NULL)
221 if (nidbytes)
222 fread((char *)ip, nidbytes, 1, fp);
223 else
224 *ip = '\0';
225 else if (nidbytes)
226 fseek(fp, (long)nidbytes, 1);
227
228 return(feof(fp) || ferror(fp) ? -1 : 0);
229 }
230
231
232 static int
233 putthead( /* write header to output */
234 struct hdStruct *hp,
235 char *ip,
236 register FILE *fp
237 )
238 {
239 if (ip != NULL)
240 putc(strlen(ip), fp);
241 else
242 putc(0, fp);
243 putc(hp->mapType, fp);
244 putc(hp->dataType, fp);
245 putint2(hp->mapOrig, fp);
246 putint2(hp->mapLength, fp);
247 putc(hp->CMapBits, fp);
248 putint2(hp->XOffset, fp);
249 putint2(hp->YOffset, fp);
250 putint2(hp->x, fp);
251 putint2(hp->y, fp);
252 putc(hp->dataBits, fp);
253 putc(hp->imType, fp);
254
255 if (ip != NULL)
256 fputs(ip, fp);
257
258 return(ferror(fp) ? -1 : 0);
259 }
260
261
262 static void
263 tg2ra( /* targa file to RADIANCE file */
264 struct hdStruct *hp
265 )
266 {
267 COLR *scanline;
268 unsigned char *tarData;
269 register int i, j;
270 /* skip color table */
271 if (hp->mapType == CM_HASMAP)
272 fseek(stdin, (long)hp->mapLength*hp->CMapBits/8, 1);
273 /* allocate targa data */
274 tarData = taralloc(hp);
275 /* get data */
276 readtarga(hp, tarData, stdin);
277 /* allocate input scanline */
278 scanline = (COLR *)emalloc(hp->x*sizeof(COLR));
279 /* convert file */
280 for (i = hp->y-1; i >= 0; i--) {
281 if (hp->dataBits == 16) {
282 register unsigned short *dp;
283 dp = (unsigned short *)tarData + i*hp->x;
284 for (j = 0; j < hp->x; j++) {
285 scanline[j][RED] = *dp>>7 & 0xf8;
286 scanline[j][GRN] = *dp>>2 & 0xf8;
287 scanline[j][BLU] = *dp<<3 & 0xf8;
288 dp++;
289 }
290 } else { /* hp->dataBits == 24 */
291 register unsigned char *dp;
292 dp = (unsigned char *)tarData + i*3*hp->x;
293 for (j = 0; j < hp->x; j++) {
294 scanline[j][RED] = dp[2];
295 scanline[j][GRN] = dp[1];
296 scanline[j][BLU] = dp[0];
297 dp += 3;
298 }
299 }
300 gambs_colrs(scanline, hp->x);
301 if (bradj)
302 shiftcolrs(scanline, hp->x, bradj);
303 if (fwritecolrs(scanline, hp->x, stdout) < 0)
304 quiterr("error writing RADIANCE file");
305 }
306 free((void *)scanline);
307 free((void *)tarData);
308 }
309
310
311 static void
312 ra2tg( /* convert radiance to targa file */
313 struct hdStruct *hp
314 )
315 {
316 register int i, j;
317 unsigned char *tarData;
318 COLR *inl;
319 /* allocate space for data */
320 inl = (COLR *)emalloc(hp->x*sizeof(COLR));
321 tarData = taralloc(hp);
322 /* convert file */
323 for (j = hp->y-1; j >= 0; j--) {
324 if (freadcolrs(inl, hp->x, stdin) < 0)
325 quiterr("error reading RADIANCE file");
326 if (bradj)
327 shiftcolrs(inl, hp->x, bradj);
328 colrs_gambs(inl, hp->x);
329 if (hp->dataBits == 16) {
330 register unsigned short *dp;
331 register int v;
332 dp = (unsigned short *)tarData + j*hp->x;
333 for (i = 0; i < hp->x; i++) {
334 v = inl[i][RED] + (random()&7);
335 if (v > 255) v = 255;
336 *dp = (v&0xf8)<<7;
337 v = inl[i][GRN] + (random()&7);
338 if (v > 255) v = 255;
339 *dp |= (v&0xf8)<<2;
340 v = inl[i][BLU] + (random()&7);
341 if (v > 255) v = 255;
342 *dp++ |= v>>3;
343 }
344 } else { /* hp->dataBits == 24 */
345 register unsigned char *dp;
346 dp = (unsigned char *)tarData + j*3*hp->x;
347 for (i = 0; i < hp->x; i++) {
348 *dp++ = inl[i][BLU];
349 *dp++ = inl[i][GRN];
350 *dp++ = inl[i][RED];
351 }
352 }
353 }
354 /* write out targa data */
355 writetarga(hp, tarData, stdout);
356
357 free((void *)inl);
358 free((void *)tarData);
359 }
360
361
362 static void
363 writet24( /* write out 24-bit targa data */
364 struct hdStruct *h,
365 unsigned char *d,
366 FILE *fp
367 )
368 {
369 if (h->dataType == IM_RGB) { /* uncompressed */
370 if (fwrite((char *)d, 3*h->x, h->y, fp) != h->y)
371 quiterr("error writing targa file");
372 return;
373 }
374 quiterr("unsupported output type");
375 }
376
377
378 static void
379 writet16( /* write out 16-bit targa data */
380 struct hdStruct *h,
381 register unsigned short *d,
382 FILE *fp
383 )
384 {
385 register int cnt;
386
387 if (h->dataType == IM_RGB) { /* uncompressed */
388 for (cnt = h->x*h->y; cnt-- > 0; )
389 putint2(*d++, fp);
390 if (ferror(fp))
391 quiterr("error writing targa file");
392 return;
393 }
394 quiterr("unsupported output type");
395 }
396
397
398 static void
399 readt24( /* read in 24-bit targa data */
400 register struct hdStruct *h,
401 unsigned char *data,
402 FILE *fp
403 )
404 {
405 register int cnt, c;
406 register unsigned char *dp;
407 int r, g, b;
408
409 if (h->dataType == IM_RGB) { /* uncompressed */
410 if (fread((char *)data, 3*h->x, h->y, fp) != h->y)
411 goto readerr;
412 return;
413 }
414 for (dp = data; dp < data+3*h->x*h->y; ) {
415 if ((c = getc(fp)) == EOF)
416 goto readerr;
417 cnt = (c & 0x7f) + 1;
418 if (c & 0x80) { /* repeated pixel */
419 b = getc(fp); g = getc(fp);
420 if ((r = getc(fp)) == EOF)
421 goto readerr;
422 while (cnt--) {
423 *dp++ = b;
424 *dp++ = g;
425 *dp++ = r;
426 }
427 } else /* non-repeating pixels */
428 while (cnt--) {
429 *dp++ = getc(fp); *dp++ = getc(fp);
430 if ((r = getc(fp)) == EOF)
431 goto readerr;
432 *dp++ = r;
433 }
434 }
435 return;
436 readerr:
437 quiterr("error reading targa file");
438 }
439
440
441 static void
442 readt16( /* read in 16-bit targa data */
443 register struct hdStruct *h,
444 unsigned short *data,
445 FILE *fp
446 )
447 {
448 register int cnt, c;
449 register unsigned short *dp;
450
451 if (h->dataType == IM_RGB) { /* uncompressed */
452 dp = data;
453 for (cnt = h->x*h->y; cnt-- > 0; )
454 *dp++ = getint2(fp);
455 return;
456 }
457 for (dp = data; dp < data+h->x*h->y; ) {
458 if ((c = getc(fp)) == EOF)
459 goto readerr;
460 cnt = (c & 0x7f) + 1;
461 if (c & 0x80) { /* repeated pixel */
462 c = getint2(fp);
463 while (cnt--)
464 *dp++ = c;
465 } else /* non-repeating pixels */
466 while (cnt--)
467 *dp++ = getint2(fp);
468 }
469 return;
470 readerr:
471 quiterr("error reading targa file");
472 }
