root/radiance/ray/src/px/ra_skel.c
Revision: 2.12
Committed: Thu Jun 5 19:29:34 2003 UTC (21 years, 9 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1
Changes since 2.11: +5 -8 lines
2 static const char RCSid[] = "$Id: ra_skel.c,v 2.11 2003/02/22 02:07:28 greg Exp $";
5 * Skeletal 24-bit image conversion program. Replace "skel"
6 * in this file with a more appropriate image type identifier.
7 *
8 * The Rmakefile entry should look something like this:
9 * ra_skel: ra_skel.o
10 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrt -lm
11 * ra_skel.o: ../common/color.h ../common/resolu.h
12 *
13 * If you like to do things the hard way, you can link directly
14 * to the object files "color.o colrops.o resolu.o header.o" in
15 * the common subdirectory instead of using the -lrt library.
16 */
17
18 #include <stdio.h>
19 #include <math.h>
20 #include <time.h>
21
22 #include "platform.h"
23 #include "color.h"
24 #include "resolu.h"
25
26 double gamcor = 2.2; /* gamma correction */
27
28 int bradj = 0; /* brightness adjustment */
29
30 char *progname;
31
32 int xmax, ymax;
33
34
35 main(argc, argv)
36 int argc;
37 char *argv[];
38 {
39 int reverse = 0;
40 int i;
41
42 progname = argv[0];
43
44 for (i = 1; i < argc; i++)
45 if (argv[i][0] == '-')
46 switch (argv[i][1]) {
47 case 'g': /* gamma correction */
48 gamcor = atof(argv[++i]);
49 break;
50 case 'e': /* exposure adjustment */
51 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
52 goto userr;
53 bradj = atoi(argv[++i]);
54 break;
55 case 'r': /* reverse conversion */
56 reverse = 1;
57 break;
58 default:
59 goto userr;
60 }
61 else
62 break;
63
64 if (i < argc-2)
65 goto userr;
66 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
67 fprintf(stderr, "%s: can't open input \"%s\"\n",
68 progname, argv[i]);
69 exit(1);
70 }
71 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
72 fprintf(stderr, "%s: can't open output \"%s\"\n",
73 progname, argv[i+1]);
74 exit(1);
75 }
76 SET_FILE_BINARY(stdin);
77 SET_FILE_BINARY(stdout);
78 setcolrgam(gamcor); /* set up gamma correction */
79 if (reverse) {
80 /* get their image resolution */
81 read_skel_head(&xmax, &ymax);
82 /* put our header */
83 newheader("RADIANCE", stdout);
84 printargs(i, argv, stdout);
85 fputformat(COLRFMT, stdout);
86 putchar('\n');
87 fprtresolu(xmax, ymax, stdout);
88 /* convert file */
89 skel2ra();
90 } else {
91 /* get our header */
92 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
93 fgetresolu(&xmax, &ymax, stdin) < 0)
94 quiterr("bad picture format");
95 /* write their header */
96 write_skel_head(xmax, ymax);
97 /* convert file */
98 ra2skel();
99 }
100 exit(0);
101 userr:
102 fprintf(stderr,
103 "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
104 progname);
105 exit(1);
106 }
107
108
109 quiterr(err) /* print message and exit */
110 char *err;
111 {
112 if (err != NULL) {
113 fprintf(stderr, "%s: %s\n", progname, err);
114 exit(1);
115 }
116 exit(0);
117 }
118
119
120 skel2ra() /* convert 24-bit scanlines to Radiance picture */
121 {
122 COLR *scanout;
123 register int x;
124 int y;
125 /* allocate scanline */
126 scanout = (COLR *)malloc(xmax*sizeof(COLR));
127 if (scanout == NULL)
128 quiterr("out of memory in skel2ra");
129 /* convert image */
130 for (y = ymax-1; y >= 0; y--) {
131 for (x = 0; x < xmax; x++) {
132 scanout[x][RED] = getc(stdin);
133 scanout[x][GRN] = getc(stdin);
134 scanout[x][BLU] = getc(stdin);
135 }
136 if (feof(stdin) | ferror(stdin))
137 quiterr("error reading skel image");
138 /* undo gamma */
139 gambs_colrs(scanout, xmax);
140 if (bradj) /* adjust exposure */
141 shiftcolrs(scanout, xmax, bradj);
142 if (fwritecolrs(scanout, xmax, stdout) < 0)
143 quiterr("error writing Radiance picture");
144 }
145 /* free scanline */
146 free((void *)scanout);
147 }
148
149
150 ra2skel() /* convert Radiance scanlines to 24-bit */
151 {
152 COLR *scanin;
153 register int x;
154 int y;
155 /* allocate scanline */
156 scanin = (COLR *)malloc(xmax*sizeof(COLR));
157 if (scanin == NULL)
158 quiterr("out of memory in ra2skel");
159 /* convert image */
160 for (y = ymax-1; y >= 0; y--) {
161 if (freadcolrs(scanin, xmax, stdin) < 0)
162 quiterr("error reading Radiance picture");
163 if (bradj) /* adjust exposure */
164 shiftcolrs(scanin, xmax, bradj);
165 colrs_gambs(scanin, xmax); /* gamma correction */
166 for (x = 0; x < xmax; x++) {
167 putc(scanin[x][RED], stdout);
168 putc(scanin[x][GRN], stdout);
169 putc(scanin[x][BLU], stdout);
170 }
171 if (ferror(stdout))
172 quiterr("error writing skel file");
173 }
174 /* free scanline */
175 free((void *)scanin);
176 }
