root/radiance/ray/src/px/ra_skel.c
Revision: 2.1
Committed: Tue Nov 12 15:16:41 1991 UTC (33 years, 8 months ago) by greg
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Skeletal 24-bit image conversion program. Replace "skel"
7 * in this file with a more appropriate image type identifier.
8 *
9 * The Makefile entry should look something like this:
10 * ra_skel: ra_skel.o
11 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrt -lm
12 * ra_skel.o: ../common/color.h ../common/resolu.h
13 *
14 * If you like to do things the hard way, you can link directly
15 * to the object files "color.o colrops.o resolu.o header.o" in
16 * the common subdirectory instead of using the -lrt library.
17 */
18
19 #include <stdio.h>
20 #include "color.h"
21 #include "resolu.h"
22
23 extern double atof();
24
25 double gamma = 2.2; /* gamma correction */
26
27 int bradj = 0; /* brightness adjustment */
28
29 char *progname;
30
31 int xmax, ymax;
32
33
34 main(argc, argv)
35 int argc;
36 char *argv[];
37 {
38 int reverse = 0;
39 int i;
40
41 progname = argv[0];
42
43 for (i = 1; i < argc; i++)
44 if (argv[i][0] == '-')
45 switch (argv[i][1]) {
46 case 'g': /* gamma correction */
47 gamma = atof(argv[++i]);
48 break;
49 case 'e': /* exposure adjustment */
50 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
51 goto userr;
52 bradj = atoi(argv[++i]);
53 break;
54 case 'r': /* reverse conversion */
55 reverse = 1;
56 break;
57 default:
58 goto userr;
59 }
60 else
61 break;
62
63 if (i < argc-2)
64 goto userr;
65 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
66 fprintf(stderr, "%s: can't open input \"%s\"\n",
67 progname, argv[i]);
68 exit(1);
69 }
70 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
71 fprintf(stderr, "can't open output \"%s\"\n",
72 progname, argv[i+1]);
73 exit(1);
74 }
75 setcolrgam(gamma); /* set up gamma correction */
76 if (reverse) {
77 /* get their image resolution */
78 read_skel_head(&xmax, &ymax);
79 /* put our header */
80 printargs(i, argv, stdout);
81 fputformat(COLRFMT, stdout);
82 putchar('\n');
83 fprtresolu(xmax, ymax, stdout);
84 /* convert file */
85 skel2ra();
86 } else {
87 /* get our header */
88 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
89 fgetresolu(&xmax, &ymax, stdin) < 0)
90 quiterr("bad picture format");
91 /* write their header */
92 write_skel_head(xmax, ymax);
93 /* convert file */
94 ra2skel();
95 }
96 exit(0);
97 userr:
98 fprintf(stderr,
99 "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
100 progname);
101 exit(1);
102 }
103
104
105 quiterr(err) /* print message and exit */
106 char *err;
107 {
108 if (err != NULL) {
109 fprintf(stderr, "%s: %s\n", progname, err);
110 exit(1);
111 }
112 exit(0);
113 }
114
115
116 skel2ra() /* convert 24-bit scanlines to Radiance picture */
117 {
118 COLR *scanout;
119 register int x;
120 int y;
121 /* allocate scanline */
122 scanout = (COLR *)malloc(xmax*sizeof(COLR));
123 if (scanout == NULL)
124 quiterr("out of memory in skel2ra");
125 /* convert image */
126 for (y = ymax-1; y >= 0; y--) {
127 scanout[x][RED] = getc(stdin);
128 scanout[x][GRN] = getc(stdin);
129 scanout[x][BLU] = getc(stdin);
130 if (feof(stdin) || ferror(stdin))
131 quiterr("error reading skel image");
132 /* undo gamma */
133 gambs_colrs(scanout, xmax);
134 if (bradj) /* adjust exposure */
135 shiftcolrs(scanout, xmax, bradj);
136 if (fwritecolrs(scanout, xmax, stdout) < 0)
137 quiterr("error writing Radiance picture");
138 }
139 /* free scanline */
140 free((char *)scanout);
141 }
142
143
144 ra2skel() /* convert Radiance scanlines to 24-bit */
145 {
146 COLR *scanin;
147 register int x;
148 int y;
149 /* allocate scanline */
150 scanin = (COLR *)malloc(xmax*sizeof(COLR));
151 if (scanin == NULL)
152 quiterr("out of memory in ra2skel");
153 /* convert image */
154 for (y = ymax-1; y >= 0; y--) {
155 if (freadcolrs(scanin, xmax, stdin) < 0)
156 quiterr("error reading Radiance picture");
157 if (bradj) /* adjust exposure */
158 shiftcolrs(scanin, xmax, bradj);
159 colrs_gambs(scanin, xmax); /* gamma correction */
160 for (x = 0; x < xmax; x++) {
161 putc(scanin[x][RED], stdout);
162 putc(scanin[x][GRN], stdout);
163 putc(scanin[x][BLU], stdout);
164 }
165 if (ferror(stdout))
166 quiterr("error writing skel file");
167 }
168 /* free scanline */
169 free((char *)scanin);
170 }
