root/radiance/ray/src/px/ra_skel.c
Revision: 2.13
Committed: Fri Mar 10 19:40:13 2006 UTC (19 years, 1 month ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
# User Rev Content
1 greg 2.1 #ifndef lint
2 schorsch 2.13 static const char RCSid[] = "$Id: ra_skel.c,v 2.12 2003/06/05 19:29:34 schorsch Exp $";
3 greg 2.1 #endif
4 greg 2.4 /*
5     * Skeletal 24-bit image conversion program. Replace "skel"
6 greg 2.1 * in this file with a more appropriate image type identifier.
7     *
8 greg 2.10 * The Rmakefile entry should look something like this:
9 greg 2.1 * ra_skel: ra_skel.o
10 schorsch 2.13 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrtrad -lm
11 greg 2.1 * ra_skel.o: ../common/color.h ../common/resolu.h
12     *
13     * If you like to do things the hard way, you can link directly
14     * to the object files "color.o colrops.o resolu.o header.o" in
15 schorsch 2.13 * the common subdirectory instead of using the -lrtrad library.
16 greg 2.1 */
17
18     #include <stdio.h>
19 greg 2.5 #include <math.h>
20 greg 2.11 #include <time.h>
21 schorsch 2.12
22     #include "platform.h"
23 greg 2.1 #include "color.h"
24     #include "resolu.h"
25
26 greg 2.6 double gamcor = 2.2; /* gamma correction */
27 greg 2.1
28     int bradj = 0; /* brightness adjustment */
29
30     char *progname;
31
32     int xmax, ymax;
33
34
35     main(argc, argv)
36     int argc;
37     char *argv[];
38     {
39     int reverse = 0;
40     int i;
41
42     progname = argv[0];
43
44     for (i = 1; i < argc; i++)
45     if (argv[i][0] == '-')
46     switch (argv[i][1]) {
47     case 'g': /* gamma correction */
48 greg 2.6 gamcor = atof(argv[++i]);
49 greg 2.1 break;
50     case 'e': /* exposure adjustment */
51     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
52     goto userr;
53     bradj = atoi(argv[++i]);
54     break;
55     case 'r': /* reverse conversion */
56     reverse = 1;
57     break;
58     default:
59     goto userr;
60     }
61     else
62     break;
63
64     if (i < argc-2)
65     goto userr;
66     if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
67     fprintf(stderr, "%s: can't open input \"%s\"\n",
68     progname, argv[i]);
69     exit(1);
70     }
71     if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
72 greg 2.8 fprintf(stderr, "%s: can't open output \"%s\"\n",
73 greg 2.1 progname, argv[i+1]);
74     exit(1);
75     }
76 schorsch 2.12 SET_FILE_BINARY(stdin);
77     SET_FILE_BINARY(stdout);
78 greg 2.6 setcolrgam(gamcor); /* set up gamma correction */
79 greg 2.1 if (reverse) {
80     /* get their image resolution */
81     read_skel_head(&xmax, &ymax);
82     /* put our header */
83 greg 2.9 newheader("RADIANCE", stdout);
84 greg 2.1 printargs(i, argv, stdout);
85     fputformat(COLRFMT, stdout);
86     putchar('\n');
87     fprtresolu(xmax, ymax, stdout);
88     /* convert file */
89     skel2ra();
90     } else {
91     /* get our header */
92     if (checkheader(stdin, COLRFMT, NULL) < 0 ||
93     fgetresolu(&xmax, &ymax, stdin) < 0)
94     quiterr("bad picture format");
95     /* write their header */
96     write_skel_head(xmax, ymax);
97     /* convert file */
98     ra2skel();
99     }
100     exit(0);
101     userr:
102     fprintf(stderr,
103     "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
104     progname);
105     exit(1);
106     }
107
108
109     quiterr(err) /* print message and exit */
110     char *err;
111     {
112     if (err != NULL) {
113     fprintf(stderr, "%s: %s\n", progname, err);
114     exit(1);
115     }
116     exit(0);
117     }
118
119
120     skel2ra() /* convert 24-bit scanlines to Radiance picture */
121     {
122     COLR *scanout;
123     register int x;
124     int y;
125     /* allocate scanline */
126     scanout = (COLR *)malloc(xmax*sizeof(COLR));
127     if (scanout == NULL)
128     quiterr("out of memory in skel2ra");
129     /* convert image */
130     for (y = ymax-1; y >= 0; y--) {
131 greg 2.7 for (x = 0; x < xmax; x++) {
132     scanout[x][RED] = getc(stdin);
133     scanout[x][GRN] = getc(stdin);
134     scanout[x][BLU] = getc(stdin);
135     }
136     if (feof(stdin) | ferror(stdin))
137 greg 2.1 quiterr("error reading skel image");
138     /* undo gamma */
139     gambs_colrs(scanout, xmax);
140     if (bradj) /* adjust exposure */
141     shiftcolrs(scanout, xmax, bradj);
142     if (fwritecolrs(scanout, xmax, stdout) < 0)
143     quiterr("error writing Radiance picture");
144     }
145     /* free scanline */
146 greg 2.11 free((void *)scanout);
147 greg 2.1 }
148
149
150     ra2skel() /* convert Radiance scanlines to 24-bit */
151     {
152     COLR *scanin;
153     register int x;
154     int y;
155     /* allocate scanline */
156     scanin = (COLR *)malloc(xmax*sizeof(COLR));
157     if (scanin == NULL)
158     quiterr("out of memory in ra2skel");
159     /* convert image */
160     for (y = ymax-1; y >= 0; y--) {
161     if (freadcolrs(scanin, xmax, stdin) < 0)
162     quiterr("error reading Radiance picture");
163     if (bradj) /* adjust exposure */
164     shiftcolrs(scanin, xmax, bradj);
165     colrs_gambs(scanin, xmax); /* gamma correction */
166     for (x = 0; x < xmax; x++) {
167     putc(scanin[x][RED], stdout);
168     putc(scanin[x][GRN], stdout);
169     putc(scanin[x][BLU], stdout);
170     }
171     if (ferror(stdout))
172     quiterr("error writing skel file");
173     }
174     /* free scanline */
175 greg 2.11 free((void *)scanin);
176 greg 2.1 }
