root/radiance/ray/src/px/ra_skel.c
Revision: 2.2
Committed: Thu Dec 19 14:52:19 1991 UTC (32 years, 6 months ago) by greg
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Skeletal 24-bit image conversion program. Replace "skel"
7 * in this file with a more appropriate image type identifier.
8 *
9 * The Makefile entry should look something like this:
10 * ra_skel: ra_skel.o
11 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrt -lm
12 * ra_skel.o: ../common/color.h ../common/resolu.h
13 *
14 * If you like to do things the hard way, you can link directly
15 * to the object files "color.o colrops.o resolu.o header.o" in
16 * the common subdirectory instead of using the -lrt library.
17 */
18
19 #include <stdio.h>
20 #include "color.h"
21 #include "resolu.h"
22
23
24 double gamma = 2.2; /* gamma correction */
25
26 int bradj = 0; /* brightness adjustment */
27
28 char *progname;
29
30 int xmax, ymax;
31
32
33 main(argc, argv)
34 int argc;
35 char *argv[];
36 {
37 int reverse = 0;
38 int i;
39
40 progname = argv[0];
41
42 for (i = 1; i < argc; i++)
43 if (argv[i][0] == '-')
44 switch (argv[i][1]) {
45 case 'g': /* gamma correction */
46 gamma = atof(argv[++i]);
47 break;
48 case 'e': /* exposure adjustment */
49 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
50 goto userr;
51 bradj = atoi(argv[++i]);
52 break;
53 case 'r': /* reverse conversion */
54 reverse = 1;
55 break;
56 default:
57 goto userr;
58 }
59 else
60 break;
61
62 if (i < argc-2)
63 goto userr;
64 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
65 fprintf(stderr, "%s: can't open input \"%s\"\n",
66 progname, argv[i]);
67 exit(1);
68 }
69 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
70 fprintf(stderr, "can't open output \"%s\"\n",
71 progname, argv[i+1]);
72 exit(1);
73 }
74 setcolrgam(gamma); /* set up gamma correction */
75 if (reverse) {
76 /* get their image resolution */
77 read_skel_head(&xmax, &ymax);
78 /* put our header */
79 printargs(i, argv, stdout);
80 fputformat(COLRFMT, stdout);
81 putchar('\n');
82 fprtresolu(xmax, ymax, stdout);
83 /* convert file */
84 skel2ra();
85 } else {
86 /* get our header */
87 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
88 fgetresolu(&xmax, &ymax, stdin) < 0)
89 quiterr("bad picture format");
90 /* write their header */
91 write_skel_head(xmax, ymax);
92 /* convert file */
93 ra2skel();
94 }
95 exit(0);
96 userr:
97 fprintf(stderr,
98 "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
99 progname);
100 exit(1);
101 }
102
103
104 quiterr(err) /* print message and exit */
105 char *err;
106 {
107 if (err != NULL) {
108 fprintf(stderr, "%s: %s\n", progname, err);
109 exit(1);
110 }
111 exit(0);
112 }
113
114
115 skel2ra() /* convert 24-bit scanlines to Radiance picture */
116 {
117 COLR *scanout;
118 register int x;
119 int y;
120 /* allocate scanline */
121 scanout = (COLR *)malloc(xmax*sizeof(COLR));
122 if (scanout == NULL)
123 quiterr("out of memory in skel2ra");
124 /* convert image */
125 for (y = ymax-1; y >= 0; y--) {
126 scanout[x][RED] = getc(stdin);
127 scanout[x][GRN] = getc(stdin);
128 scanout[x][BLU] = getc(stdin);
129 if (feof(stdin) || ferror(stdin))
130 quiterr("error reading skel image");
131 /* undo gamma */
132 gambs_colrs(scanout, xmax);
133 if (bradj) /* adjust exposure */
134 shiftcolrs(scanout, xmax, bradj);
135 if (fwritecolrs(scanout, xmax, stdout) < 0)
136 quiterr("error writing Radiance picture");
137 }
138 /* free scanline */
139 free((char *)scanout);
140 }
141
142
143 ra2skel() /* convert Radiance scanlines to 24-bit */
144 {
145 COLR *scanin;
146 register int x;
147 int y;
148 /* allocate scanline */
149 scanin = (COLR *)malloc(xmax*sizeof(COLR));
150 if (scanin == NULL)
151 quiterr("out of memory in ra2skel");
152 /* convert image */
153 for (y = ymax-1; y >= 0; y--) {
154 if (freadcolrs(scanin, xmax, stdin) < 0)
155 quiterr("error reading Radiance picture");
156 if (bradj) /* adjust exposure */
157 shiftcolrs(scanin, xmax, bradj);
158 colrs_gambs(scanin, xmax); /* gamma correction */
159 for (x = 0; x < xmax; x++) {
160 putc(scanin[x][RED], stdout);
161 putc(scanin[x][GRN], stdout);
162 putc(scanin[x][BLU], stdout);
163 }
164 if (ferror(stdout))
165 quiterr("error writing skel file");
166 }
167 /* free scanline */
168 free((char *)scanin);
169 }
