root/radiance/ray/src/px/ra_skel.c
Revision: 2.11
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.10: +4 -8 lines
5 * Skeletal 24-bit image conversion program. Replace "skel"
6 * in this file with a more appropriate image type identifier.
7 *
8 * The Rmakefile entry should look something like this:
9 * ra_skel: ra_skel.o
10 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrt -lm
11 * ra_skel.o: ../common/color.h ../common/resolu.h
12 *
13 * If you like to do things the hard way, you can link directly
14 * to the object files "color.o colrops.o resolu.o header.o" in
15 * the common subdirectory instead of using the -lrt library.
16 */
17
18 #include <stdio.h>
19 #include <math.h>
20 #ifdef MSDOS
21 #include <fcntl.h>
22 #endif
23 #include <time.h>
24 #include "color.h"
25 #include "resolu.h"
26
27 double gamcor = 2.2; /* gamma correction */
28
29 int bradj = 0; /* brightness adjustment */
30
31 char *progname;
32
33 int xmax, ymax;
34
35
36 main(argc, argv)
37 int argc;
38 char *argv[];
39 {
40 int reverse = 0;
41 int i;
42
43 progname = argv[0];
44
45 for (i = 1; i < argc; i++)
46 if (argv[i][0] == '-')
47 switch (argv[i][1]) {
48 case 'g': /* gamma correction */
49 gamcor = atof(argv[++i]);
50 break;
51 case 'e': /* exposure adjustment */
52 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
53 goto userr;
54 bradj = atoi(argv[++i]);
55 break;
56 case 'r': /* reverse conversion */
57 reverse = 1;
58 break;
59 default:
60 goto userr;
61 }
62 else
63 break;
64
65 if (i < argc-2)
66 goto userr;
67 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
68 fprintf(stderr, "%s: can't open input \"%s\"\n",
69 progname, argv[i]);
70 exit(1);
71 }
72 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
73 fprintf(stderr, "%s: can't open output \"%s\"\n",
74 progname, argv[i+1]);
75 exit(1);
76 }
77 #ifdef MSDOS
78 setmode(fileno(stdin), O_BINARY);
79 setmode(fileno(stdout), O_BINARY);
80 #endif
81 setcolrgam(gamcor); /* set up gamma correction */
82 if (reverse) {
83 /* get their image resolution */
84 read_skel_head(&xmax, &ymax);
85 /* put our header */
86 newheader("RADIANCE", stdout);
87 printargs(i, argv, stdout);
88 fputformat(COLRFMT, stdout);
89 putchar('\n');
90 fprtresolu(xmax, ymax, stdout);
91 /* convert file */
92 skel2ra();
93 } else {
94 /* get our header */
95 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
96 fgetresolu(&xmax, &ymax, stdin) < 0)
97 quiterr("bad picture format");
98 /* write their header */
99 write_skel_head(xmax, ymax);
100 /* convert file */
101 ra2skel();
102 }
103 exit(0);
104 userr:
105 fprintf(stderr,
106 "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
107 progname);
108 exit(1);
109 }
110
111
112 quiterr(err) /* print message and exit */
113 char *err;
114 {
115 if (err != NULL) {
116 fprintf(stderr, "%s: %s\n", progname, err);
117 exit(1);
118 }
119 exit(0);
120 }
121
122
123 skel2ra() /* convert 24-bit scanlines to Radiance picture */
124 {
125 COLR *scanout;
126 register int x;
127 int y;
128 /* allocate scanline */
129 scanout = (COLR *)malloc(xmax*sizeof(COLR));
130 if (scanout == NULL)
131 quiterr("out of memory in skel2ra");
132 /* convert image */
133 for (y = ymax-1; y >= 0; y--) {
134 for (x = 0; x < xmax; x++) {
135 scanout[x][RED] = getc(stdin);
136 scanout[x][GRN] = getc(stdin);
137 scanout[x][BLU] = getc(stdin);
138 }
139 if (feof(stdin) | ferror(stdin))
140 quiterr("error reading skel image");
141 /* undo gamma */
142 gambs_colrs(scanout, xmax);
143 if (bradj) /* adjust exposure */
144 shiftcolrs(scanout, xmax, bradj);
145 if (fwritecolrs(scanout, xmax, stdout) < 0)
146 quiterr("error writing Radiance picture");
147 }
148 /* free scanline */
149 free((void *)scanout);
150 }
151
152
153 ra2skel() /* convert Radiance scanlines to 24-bit */
154 {
155 COLR *scanin;
156 register int x;
157 int y;
158 /* allocate scanline */
159 scanin = (COLR *)malloc(xmax*sizeof(COLR));
160 if (scanin == NULL)
161 quiterr("out of memory in ra2skel");
162 /* convert image */
163 for (y = ymax-1; y >= 0; y--) {
164 if (freadcolrs(scanin, xmax, stdin) < 0)
165 quiterr("error reading Radiance picture");
166 if (bradj) /* adjust exposure */
167 shiftcolrs(scanin, xmax, bradj);
168 colrs_gambs(scanin, xmax); /* gamma correction */
169 for (x = 0; x < xmax; x++) {
170 putc(scanin[x][RED], stdout);
171 putc(scanin[x][GRN], stdout);
172 putc(scanin[x][BLU], stdout);
173 }
174 if (ferror(stdout))
175 quiterr("error writing skel file");
176 }
177 /* free scanline */
178 free((void *)scanin);
179 }
