root/radiance/ray/src/px/ra_skel.c
Revision: 2.15
Committed: Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.14: +1 -2 lines
2 static const char RCSid[] = "$Id: ra_skel.c,v 2.14 2025/06/06 19:11:21 greg Exp $";
5 * Skeletal 24-bit image conversion program. Replace "skel"
6 * in this file with a more appropriate image type identifier.
7 *
8 * The Rmakefile entry should look something like this:
9 * ra_skel: ra_skel.o
10 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrtrad -lm
11 * ra_skel.o: ../common/color.h ../common/resolu.h
12 *
13 * If you like to do things the hard way, you can link directly
14 * to the object files "color.o colrops.o resolu.o header.o" in
15 * the common subdirectory instead of using the -lrtrad library.
16 */
17
18 #include <stdio.h>
19 #include <math.h>
20 #include <time.h>
21 #include "platform.h"
22 #include "color.h"
23 #include "resolu.h"
24
25 double gamcor = 2.2; /* gamma correction */
26
27 int bradj = 0; /* brightness adjustment */
28
29 int xmax, ymax;
30
31
32 main(argc, argv)
33 int argc;
34 char *argv[];
35 {
36 int reverse = 0;
37 int i;
38
39 fixargv0(argv[0]);
40
41 for (i = 1; i < argc; i++)
42 if (argv[i][0] == '-')
43 switch (argv[i][1]) {
44 case 'g': /* gamma correction */
45 gamcor = atof(argv[++i]);
46 break;
47 case 'e': /* exposure adjustment */
48 if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
49 goto userr;
50 bradj = atoi(argv[++i]);
51 break;
52 case 'r': /* reverse conversion */
53 reverse = 1;
54 break;
55 default:
56 goto userr;
57 }
58 else
59 break;
60
61 if (i < argc-2)
62 goto userr;
63 if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
64 fprintf(stderr, "%s: can't open input \"%s\"\n",
65 progname, argv[i]);
66 exit(1);
67 }
68 if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
69 fprintf(stderr, "%s: can't open output \"%s\"\n",
70 progname, argv[i+1]);
71 exit(1);
72 }
73 SET_FILE_BINARY(stdin);
74 SET_FILE_BINARY(stdout);
75 setcolrgam(gamcor); /* set up gamma correction */
76 if (reverse) {
77 /* get their image resolution */
78 read_skel_head(&xmax, &ymax);
79 /* put our header */
80 newheader("RADIANCE", stdout);
81 printargs(i, argv, stdout);
82 fputformat(COLRFMT, stdout);
83 putchar('\n');
84 fprtresolu(xmax, ymax, stdout);
85 /* convert file */
86 skel2ra();
87 } else {
88 /* get our header */
89 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
90 fgetresolu(&xmax, &ymax, stdin) < 0)
91 quiterr("bad picture format");
92 /* write their header */
93 write_skel_head(xmax, ymax);
94 /* convert file */
95 ra2skel();
96 }
97 exit(0);
98 userr:
99 fprintf(stderr,
100 "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
101 progname);
102 exit(1);
103 }
104
105
106 quiterr(err) /* print message and exit */
107 char *err;
108 {
109 if (err != NULL) {
110 fprintf(stderr, "%s: %s\n", progname, err);
111 exit(1);
112 }
113 exit(0);
114 }
115
116
117 skel2ra() /* convert 24-bit scanlines to Radiance picture */
118 {
119 COLR *scanout;
120 register int x;
121 int y;
122 /* allocate scanline */
123 scanout = (COLR *)malloc(xmax*sizeof(COLR));
124 if (scanout == NULL)
125 quiterr("out of memory in skel2ra");
126 /* convert image */
127 for (y = ymax-1; y >= 0; y--) {
128 for (x = 0; x < xmax; x++) {
129 scanout[x][RED] = getc(stdin);
130 scanout[x][GRN] = getc(stdin);
131 scanout[x][BLU] = getc(stdin);
132 }
133 if (feof(stdin) | ferror(stdin))
134 quiterr("error reading skel image");
135 /* undo gamma */
136 gambs_colrs(scanout, xmax);
137 if (bradj) /* adjust exposure */
138 shiftcolrs(scanout, xmax, bradj);
139 if (fwritecolrs(scanout, xmax, stdout) < 0)
140 quiterr("error writing Radiance picture");
141 }
142 /* free scanline */
143 free((void *)scanout);
144 }
145
146
147 ra2skel() /* convert Radiance scanlines to 24-bit */
148 {
149 COLR *scanin;
150 register int x;
151 int y;
152 /* allocate scanline */
153 scanin = (COLR *)malloc(xmax*sizeof(COLR));
154 if (scanin == NULL)
155 quiterr("out of memory in ra2skel");
156 /* convert image */
157 for (y = ymax-1; y >= 0; y--) {
158 if (freadcolrs(scanin, xmax, stdin) < 0)
159 quiterr("error reading Radiance picture");
160 if (bradj) /* adjust exposure */
161 shiftcolrs(scanin, xmax, bradj);
162 colrs_gambs(scanin, xmax); /* gamma correction */
163 for (x = 0; x < xmax; x++) {
164 putc(scanin[x][RED], stdout);
165 putc(scanin[x][GRN], stdout);
166 putc(scanin[x][BLU], stdout);
167 }
168 if (ferror(stdout))
169 quiterr("error writing skel file");
170 }
171 /* free scanline */
172 free((void *)scanin);
173 }
