root/radiance/ray/src/px/ra_skel.c
Revision: 2.15
Committed: Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.14: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.15 static const char RCSid[] = "$Id: ra_skel.c,v 2.14 2025/06/06 19:11:21 greg Exp $";
3 greg 2.1 #endif
4 greg 2.4 /*
5     * Skeletal 24-bit image conversion program. Replace "skel"
6 greg 2.1 * in this file with a more appropriate image type identifier.
7     *
8 greg 2.10 * The Rmakefile entry should look something like this:
9 greg 2.1 * ra_skel: ra_skel.o
10 schorsch 2.13 * cc $(CFLAGS) -o ra_skel ra_skel.o -lrtrad -lm
11 greg 2.1 * ra_skel.o: ../common/color.h ../common/resolu.h
12     *
13     * If you like to do things the hard way, you can link directly
14     * to the object files "color.o colrops.o resolu.o header.o" in
15 schorsch 2.13 * the common subdirectory instead of using the -lrtrad library.
16 greg 2.1 */
17
18     #include <stdio.h>
19 greg 2.5 #include <math.h>
20 greg 2.11 #include <time.h>
21 schorsch 2.12 #include "platform.h"
22 greg 2.1 #include "color.h"
23     #include "resolu.h"
24
25 greg 2.6 double gamcor = 2.2; /* gamma correction */
26 greg 2.1
27     int bradj = 0; /* brightness adjustment */
28
29     int xmax, ymax;
30
31
32     main(argc, argv)
33     int argc;
34     char *argv[];
35     {
36     int reverse = 0;
37     int i;
38
39 greg 2.14 fixargv0(argv[0]);
40 greg 2.1
41     for (i = 1; i < argc; i++)
42     if (argv[i][0] == '-')
43     switch (argv[i][1]) {
44     case 'g': /* gamma correction */
45 greg 2.6 gamcor = atof(argv[++i]);
46 greg 2.1 break;
47     case 'e': /* exposure adjustment */
48     if (argv[i+1][0] != '+' && argv[i+1][0] != '-')
49     goto userr;
50     bradj = atoi(argv[++i]);
51     break;
52     case 'r': /* reverse conversion */
53     reverse = 1;
54     break;
55     default:
56     goto userr;
57     }
58     else
59     break;
60
61     if (i < argc-2)
62     goto userr;
63     if (i <= argc-1 && freopen(argv[i], "r", stdin) == NULL) {
64     fprintf(stderr, "%s: can't open input \"%s\"\n",
65     progname, argv[i]);
66     exit(1);
67     }
68     if (i == argc-2 && freopen(argv[i+1], "w", stdout) == NULL) {
69 greg 2.8 fprintf(stderr, "%s: can't open output \"%s\"\n",
70 greg 2.1 progname, argv[i+1]);
71     exit(1);
72     }
73 schorsch 2.12 SET_FILE_BINARY(stdin);
74     SET_FILE_BINARY(stdout);
75 greg 2.6 setcolrgam(gamcor); /* set up gamma correction */
76 greg 2.1 if (reverse) {
77     /* get their image resolution */
78     read_skel_head(&xmax, &ymax);
79     /* put our header */
80 greg 2.9 newheader("RADIANCE", stdout);
81 greg 2.1 printargs(i, argv, stdout);
82     fputformat(COLRFMT, stdout);
83     putchar('\n');
84     fprtresolu(xmax, ymax, stdout);
85     /* convert file */
86     skel2ra();
87     } else {
88     /* get our header */
89     if (checkheader(stdin, COLRFMT, NULL) < 0 ||
90     fgetresolu(&xmax, &ymax, stdin) < 0)
91     quiterr("bad picture format");
92     /* write their header */
93     write_skel_head(xmax, ymax);
94     /* convert file */
95     ra2skel();
96     }
97     exit(0);
98     userr:
99     fprintf(stderr,
100     "Usage: %s [-r][-g gamma][-e +/-stops] [input [output]]\n",
101     progname);
102     exit(1);
103     }
104
105
106     quiterr(err) /* print message and exit */
107     char *err;
108     {
109     if (err != NULL) {
110     fprintf(stderr, "%s: %s\n", progname, err);
111     exit(1);
112     }
113     exit(0);
114     }
115
116
117     skel2ra() /* convert 24-bit scanlines to Radiance picture */
118     {
119     COLR *scanout;
120     register int x;
121     int y;
122     /* allocate scanline */
123     scanout = (COLR *)malloc(xmax*sizeof(COLR));
124     if (scanout == NULL)
125     quiterr("out of memory in skel2ra");
126     /* convert image */
127     for (y = ymax-1; y >= 0; y--) {
128 greg 2.7 for (x = 0; x < xmax; x++) {
129     scanout[x][RED] = getc(stdin);
130     scanout[x][GRN] = getc(stdin);
131     scanout[x][BLU] = getc(stdin);
132     }
133     if (feof(stdin) | ferror(stdin))
134 greg 2.1 quiterr("error reading skel image");
135     /* undo gamma */
136     gambs_colrs(scanout, xmax);
137     if (bradj) /* adjust exposure */
138     shiftcolrs(scanout, xmax, bradj);
139     if (fwritecolrs(scanout, xmax, stdout) < 0)
140     quiterr("error writing Radiance picture");
141     }
142     /* free scanline */
143 greg 2.11 free((void *)scanout);
144 greg 2.1 }
145
146
147     ra2skel() /* convert Radiance scanlines to 24-bit */
148     {
149     COLR *scanin;
150     register int x;
151     int y;
152     /* allocate scanline */
153     scanin = (COLR *)malloc(xmax*sizeof(COLR));
154     if (scanin == NULL)
155     quiterr("out of memory in ra2skel");
156     /* convert image */
157     for (y = ymax-1; y >= 0; y--) {
158     if (freadcolrs(scanin, xmax, stdin) < 0)
159     quiterr("error reading Radiance picture");
160     if (bradj) /* adjust exposure */
161     shiftcolrs(scanin, xmax, bradj);
162     colrs_gambs(scanin, xmax); /* gamma correction */
163     for (x = 0; x < xmax; x++) {
164     putc(scanin[x][RED], stdout);
165     putc(scanin[x][GRN], stdout);
166     putc(scanin[x][BLU], stdout);
167     }
168     if (ferror(stdout))
169     quiterr("error writing skel file");
170     }
171     /* free scanline */
172 greg 2.11 free((void *)scanin);
173 greg 2.1 }
